"MS Removal Tool"
"MS Removal Tool"
Post by nightlily91 on Mon 11 Apr 2011, 5:13 pm
I have recently been attacked by something called "MS Removal Tool" it is destroying my patience and my computer's performance and I seek help. I found a guide to help with this problem (posted here [You must be registered and logged in to see this link.] however I followed all the guide's instructions up to #7 where after the scan was completed it had no results of their being any malware on my computer. So I tried a "full Scan" and still nothing. I would really appreciate any help anyone can offer, I am losing my marbles a bit here.:C Thanks
Operating System : Windows 7
Re: "MS Removal Tool"
Post by Crush on Tue 12 Apr 2011, 6:16 am
Please download ComboFix from BleepingComputer.com
Alternate link: GeeksToGo.com
Tech Officer
Tech Officer
