ms removal tool..serious problem
Post by cvs2004 on Mon 11 Apr 2011, 2:56 am
I have been stuck with this virus and I have access to the internet with IE. firefox is totally disabled. I have tried using malwarebytes and rkill that was on my computer, didnt work. I tried downloading anti-malware and rkill and that both failed. I went to a clean computer and downloaded both on a cd and also an external hard-drive and both failed. Evertime I tried to open in task mgr a file named jig.exe always opens instead. I have also tried opening these files in safe mode and that doesnt work either. I am running out of ideas here and could really use some help. when I took the cd and the hard drive to a clean computer it opened.
cvs2004
Unborn
Unborn
Operating System : windows xp
Re: ms removal tool..serious problem
Post by Belahzur on Mon 11 Apr 2011, 3:29 am
Download OTL by OldTimer to your Desktop.
Manager | Tech Officer
