Bumpng it Hotfix.exe still a problem
Hotfix.exe I feel lucky it let me post this. Surprised not seen here already
Post by Staples on 9th April 2011, 1:52 am
OK...I am off and running. After some helpful advice from 'houndmom' to a fellow 'lab-dad', I am re-posting this in the correct forum and got the OK to post my epic OTL logs...here we go.
A big thanks in advance for the treatment and helpful set up for the pre-geek here.
Hotfix.exe.
Which is supposedly part of a fake anti-spyware, malware or virus removal program called, 'Thinkpoint or Think Point'
They are both always seemingly associated from what I did find out.
It is screwing me big time
First off, I did all the recommended additions and OTL stuff for new members. It was pretty cool to be doing stuff with such complete directions that I wasn't staring at my screen hoping I clicked the right choice.
Anyway for the record I did all that required stuff!
Oh and I have the notepad saved results from the OTL I ran a day or so ago.
Warning one of them is 23 pages long. I went to print it and said whoa, I can't afford a new cartridge for this when I have to make a donation to GeekPolice.net ( a little butt kissing never hurts)
Please let me know how you want me to handle the notepad files the OTL program left me.
System - Windows XP
It actually sometimes says XP Professional which might be an issue but has been that way for awhile
This is an issue which is a possible reason for other problems such as a ridiculously high amount of hard disc usage. I keep trying to figure out if if I have duplicates of 'My Documents'. Hopefully it will show up in OTL reports ( which I have no idea what they are) or I may repost it elsewhere.
Again, not a new issue...if it is one
Browser I use Mozilla Firefox almost exclusively. Once in awhile Chrome, but thats mostly the wife's doing! God knows what she may have done.
Here are my symptoms.
1-Extremely sluggish...and has gotten worse each day
2-Recent search revealed 6-7 copies of hotfix.exe\prefetch and 1 copy of hotfix.exe without being in prefetch but a different location (can get it if necessary)
After working at my PC for a bit went back to my search program that was still open and 2 more instances of hotfix.exe where there, even though I had thought the search was finished. It had been checked at least an hour or so earlier
3- For a couple weeks or so, my monitor would go dark. I have no idea how long I have had this hotfix issue or it multiplied till it became such a big issue, but I thought my monitor was going bad. It is a airly new one, butit will go dark and I either shut it off and back on or wait and keep moving the mouse.
4- I had installed 'Zone Alarm' and has caused me a lot of headaches. It was so much bigger and more involved than I thought I removed it with control panel. It is still hanging around in places. It seemed suspect to me even though it is a well thought of program. I have had issues with infected downloads, especially at filehippo.net so anything is possible
There was a system restore done after the zone alarm issue which obviously did not fix the ZA situation
5- I had received a 'Windows Update' notice and clicked install and it wouldn't. Numerous times I tried and always didn't load, but came back with same error. I believe this is exactly what it said. "SQL server 2005 Express edition Pack 4 (KB2463332)"
6- I mentioned sluggish but in addition numerous clicks to open something. Other than waiting forever as my PC makes LOUD and LOUDER noises, some it never made before, it also takes extra clicks.
Seriously, the PC is making very strange grinds and is an issue by itself almost.
7- I just re-did the search of my PC for hotfix.exe and this is the result.
(very odd, back to only 5 issues from more the other night. I ran my anti-Virus (Avira free) so it might have done something, although I did not receive a notification
HOTFIX.EXE-0C3AED5A.pf C:\WINDOWS\prefetch
HOTFIX.EXE-2023806B.pf C:\WINDOWS\prefetch
HOTFIX.EXE-2F346FA7.pf C:\WINDOWS\prefetch
(cpu icon) hotfix.exe C:\WINDOWS\SQL9_KB970892_ENU
8- I had a program called Lazarus which was a Firefox add on or plug-in whatever, and it repeatedly gave me script errors with sqlite. It happened both times I tried it and some sqlite issues seemed to persist afterwards.
I think there are more, but I hope this is enough for now.
I may be guilty of Too much info already
but;
I just installed a new printer
I also just transferred files ('my document' stuff) to my memory stick to xfer to my new laptop. Which so far, this issue has not showed up on.
sincerely and look forward to a reply to this one
Staples
In case you won't notice, but I have never run one of these before and especially not on this machine. so, I am suspecting there might be a few years of problems and many wrong clicks.
OTL LOGS
Extras.Txt - notepad
OTL Extras logfile created on: 04/07/2011 12:57:05 AM - Run 1
OTL by OldTimer - Version 3.2.22.3 Folder = C:\Documents and Settings\Billy\My Documents\Downloads
Windows XP Professional Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
Locale: 00000409 | Country: United States | Language: ENU | Date Format: MM/dd/yyyy
511.00 Mb Total Physical Memory | 294.00 Mb Available Physical Memory | 58.00% Memory free
1.00 Gb Paging File | 1.00 Gb Available in Paging File | 67.00% Paging File free
Paging file location(s): c:\pagefile.sys 768 1536 [binary data]
Drive C: | 37.26 Gb Total Space | 5.06 Gb Free Space | 13.58% Space Free | Partition Type: NTFS
Computer Name: YOUR-55C7B0D99D | User Name: Billy | Logged in as Administrator.
.cpl [@ = cplfile] -- rundll32.exe shell32.dll,Control_RunDLL "%1",%*
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
comfile [open] -- "%1" %*
cplfile [cplopen] -- rundll32.exe shell32.dll,Control_RunDLL "%1",%*
exefile [open] -- "%1" %*
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
"FirstRunDisabled" = 1
"UpdatesDisableNotify" = 0
"AntiVirusOverride" = 0
"FirewallOverride" = 0
"AntiVirusDisableNotify" = 0
"FirewallDisableNotify" = 0
"DisableMonitoring" = 1
"DisableSR" = 0
"Start" = 0
"Start" = 2
"EnableFirewall" = 0
"DoNotAllowExceptions" = 0
"DisableNotifications" = 0
"1900:UDP" = 1900:UDP:LocalSubNet:Disabled:@xpsp2res.dll,-22007
"2869:TCP" = 2869:TCP:LocalSubNet:Disabled:@xpsp2res.dll,-22008
"9322:TCP" = 9322:TCP:*:Enabled:EKDiscovery
"5353:UDP" = 5353:UDP:*:Enabled:Bonjour Port 5353
"C:\WINDOWS\system32\usmt\migwiz.exe" = C:\WINDOWS\system32\usmt\migwiz.exe:*:Enabled:Files and Settings Transfer Wizard -- (Microsoft Corporation)
"C:\Program Files\MSN\MsnInstaller\msninst.exe" = C:\Program Files\MSN\MsnInstaller\msninst.exe:*:Enabled:msninst -- (Microsoft Corp.)
"C:\Program Files\Microsoft Small Business\Small Business Accounting 2007\SBAAccountantHost.exe" = C:\Program Files\Microsoft Small Business\Small Business Accounting 2007\SBAAccountantHost.exe:*:Enabled:Accountant View -- (Microsoft Corp.)
"C:\Program Files\Outlook Express\msimn.exe" = C:\Program Files\Outlook Express\msimn.exe:*:Enabled:Outlook Express -- (Microsoft Corporation)
"C:\Program Files\Common Files\AOL\Loader\aolload.exe" = C:\Program Files\Common Files\AOL\Loader\aolload.exe:*:Enabled:AOL Loader -- (AOL LLC)
"C:\Program Files\AIM6\aim6.exe" = C:\Program Files\AIM6\aim6.exe:*:Enabled:AIM
"C:\Program Files\Microsoft Small Business\Small Business Accounting 2007\AnalysisTools.exe" = C:\Program Files\Microsoft Small Business\Small Business Accounting 2007\AnalysisTools.exe:LocalSubNet:Disabled:Analysis Tools -- (Microsoft Corp.)
"C:\Program Files\AIM\aim.exe" = C:\Program Files\AIM\aim.exe:*:Enabled:AIM
"C:\WINDOWS\system32\dxdiag.exe" = C:\WINDOWS\system32\dxdiag.exe:*:Disabled:Microsoft DirectX Diagnostic Tool -- (Microsoft Corporation)
"C:\WINDOWS\system32\dpnsvr.exe" = C:\WINDOWS\system32\dpnsvr.exe:*:Disabled:Microsoft DirectPlay8 Server -- (Microsoft Corporation)
"C:\WINDOWS\system32\lxducoms.exe" = C:\WINDOWS\system32\lxducoms.exe:*:Enabled:5600-6600 Series Server -- ( )
"C:\Program Files\Kodak\AiO\Center\AiOHomeCenter.exe" = C:\Program Files\Kodak\AiO\Center\AiOHomeCenter.exe:*:Enabled:Kodak.AiO.HomeCenter -- (Eastman Kodak Company)
"C:\Program Files\Kodak\AiO\Center\Kodak.Statistics.exe" = C:\Program Files\Kodak\AiO\Center\Kodak.Statistics.exe:*:Enabled:Kodak.AiO.Statistics -- (Eastman Kodak Company)
"C:\Program Files\Kodak\AiO\Center\NetworkPrinterDiscovery.exe" = C:\Program Files\Kodak\AiO\Center\NetworkPrinterDiscovery.exe:*:Enabled:Kodak.AiO.SetupUtility -- (Eastman Kodak Company)
"C:\Program Files\Kodak\AiO\Firmware\KodakAiOUpdater.exe" = C:\Program Files\Kodak\AiO\Firmware\KodakAiOUpdater.exe:*:Enabled:Kodak.AiO.FwUpdater -- (Eastman Kodak Company)
"C:\Documents and Settings\All Users\Application Data\Kodak\Installer\Setup.exe" = C:\Documents and Settings\All Users\Application Data\Kodak\Installer\Setup.exe:*:Enabled:Kodak.AiO.Installer -- (Eastman Kodak Company)
"C:\WINDOWS\system32\ZoneLabs\vsmon.exe" = C:\WINDOWS\system32\ZoneLabs\vsmon.exe:*:Enabled:vsmon
"{0645A454-AD44-4F0D-99CF-6B762735AD1F}" = aioprnt
"{0840B4D6-7DD1-4187-8523-E6FC0007EFB7}" = Windows Live ID Sign-in Assistant
"{10812DE7-2E57-4740-B226-6B3BE34AF9D7}" = Lexmark Tools for Office
"{178832DE-9DE0-4C87-9F82-9315A9B03985}" = Windows Live Writer
"{1BD07DF4-FB06-41BA-B896-B2DA59000C96}" = Windows Live Toolbar
"{20ACB2F8-3BCA-45A8-80A2-9D3CB5C25F43}" = Safari
"{2656D0AB-9EA4-4C58-A117-635F3CED8B93}" = Microsoft UI Engine
"{26A24AE4-039D-4CA4-87B4-2F83216024FF}" = Java(TM) 6 Update 24
"{27EF8E7F-88D1-4ec5-ADE2-7E447FDF114E}" = Kodak AIO Printer
"{2AFFFDD7-ED85-4A90-8C52-5DA9EBDC9B8F}" = Microsoft SQL Server 2005 Express Edition (MSSMLBIZ)
"{2CE5A2E7-3437-4CE7-BCF4-85ED6EEFF9E4}" = iTunes
"{3101CB58-3482-4D21-AF1A-7057FC935355}" = KhalInstallWrapper
"{3175E049-F9A9-4A3D-8F19-AC9FB04514D1}" = Windows Live Communications Platform
"{353D20CC-719B-4A60-AD33-D03F88C10330}" = Microsoft Office Accounting PayPal Addin
"{3921A67A-5AB1-4E48-9444-C71814CF3027}" = VCRedistSetup
"{3EE9BCAE-E9A9-45E5-9B1C-83A4D357E05C}" = eReg
"{46614A49-222A-48EF-87A9-BFD603E608E1}" = Microsoft Office Accounting Fixed Asset Manager
"{474F25F5-BDC9-40E5-B1B6-F6BF23FC106F}" = Windows Live Essentials
"{48B41C3A-9A92-4B81-B653-C97FEB85C910}" = C4USelfUpdater
"{4B719A70-F14A-4f5c-90B5-346B24B7FFF1}" = Windows 7 Upgrade Advisor
"{50120000-1105-0000-0000-0000000FF1CE}" = Microsoft Office 2007 Primary Interop Assemblies
"{53F5C3EE-05ED-4830-994B-50B2F0D50FCE}" = Microsoft SQL Server Setup Support Files (English)
"{56BA241F-580C-43D2-8403-947241AAE633}" = center
"{56C049BE-79E9-4502-BEA7-9754A3E60F9B}" = neroxml
"{57F0ED40-8F11-41AA-B926-4A66D0D1A9CC}" = Microsoft Office Live Add-in 1.3
"{5FA793A6-0071-42C1-9355-8F69A428C44F}" = Microsoft Office Accounting ADP Payroll Addin
"{61BEA823-ECAF-49F1-8378-A59B3B8AD247}" = Microsoft Default Manager
"{6412CECE-8172-4BE5-935B-6CECACD2CA87}" = Windows Live Mail
"{65DA2EC9-0642-47E9-AAE2-B5267AA14D75}" = Activation Assistant for the 2007 Microsoft Office suites
"{7670D32F-DAE6-4E49-8C8B-B3F08B5B1686}" = Microsoft SQL Server Native Client
"{77F8A71E-3515-4832-B8B2-2F1EDBD2E0F1}" = Bing Bar
"{8A74E887-8F0F-4017-AF53-CBA42211AAA5}" = Microsoft Sync Framework Runtime Native v1.0 (x86)
"{8C2690CF-5B74-4F93-8139-7B5644CD6A3B}" = MobileMe Control Panel
"{8C711818-076E-475C-B95B-DF11CD9D8DBE}" = Microsoft Office Accounting Equifax Addin
"{8E5233E1-7495-44FB-8DEB-4BE906D59619}" = Junk Mail filter update
"{90120000-0015-0409-0000-0000000FF1CE}_PROHYBRIDR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0016-0409-0000-0000000FF1CE}_PROHYBRIDR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0018-0409-0000-0000000FF1CE}_PROHYBRIDR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0019-0409-0000-0000000FF1CE}_PROHYBRIDR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001A-0409-0000-0000000FF1CE}_PROHYBRIDR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001B-0409-0000-0000000FF1CE}_PROHYBRIDR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_PROHYBRIDR_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_PROHYBRIDR_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_PROHYBRIDR_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_PROHYBRIDR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_PROHYBRIDR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0117-0409-0000-0000000FF1CE}_PROHYBRIDR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90A40409-6000-11D3-8CFE-0150048383C9}" = Microsoft Office 2003 Web Components
"{91120000-0031-0000-0000-0000000FF1CE}" = Microsoft Office Professional Hybrid 2007
"{91120000-0031-0000-0000-0000000FF1CE}_PROHYBRIDR_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{91120000-0031-0000-0000-0000000FF1CE}_PROHYBRIDR_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{95120000-0122-0409-0000-0000000FF1CE}" = Microsoft Office Outlook Connector
"{A06275F4-324B-4E85-95E6-87B2CD729401}" = Windows Defender
"{A1F66FC9-11EE-4F2F-98C9-16F8D1E69FB7}" = Segoe UI
"{A43BF6A5-D5F0-4AAA-BF41-65995063EC44}" = MSXML 6.0 Parser
"{a9264802-8a7a-40fe-a135-5c6d204aed7a}.sdb" = Internet Explorer (Enable DEP)
"{A939D341-5A04-4E0A-BB55-3E65B386432D}" = Microsoft Office Small Business Connectivity Components
"{AC76BA86-7AD7-1033-7B44-AA0000000001}" = Adobe Reader X (10.0.1)
"{ACF60000-22B9-4CE9-98D6-2CCF359BAC07}" = ABBYY FineReader 6.0 Sprint
"{AFF7E080-1974-45BF-9310-10DE1A1F5ED0}" = Adobe AIR
"{B0717D5A-1976-482B-9ADF-F19631A541A4}" = Microsoft Office Accounting 2007
"{B10914FD-8812-47A4-85A1-50FCDE7F1F33}" = Windows Live Sync
"{B2544A03-10D0-4E5E-BA69-0362FFC20D18}" = OGA Notifier 2.0.0048.0
"{B32C4059-6E7A-41EF-AD20-56DF1872B923}" = Business Contact Manager for Outlook 2007 SP2
"{B57EAFF2-D6EE-4C6C-9175-ED9F17BFC1BC}" = Windows Live Messenger
"{BD64AF4A-8C80-4152-AD77-FCDDF05208AB}" = Microsoft Sync Framework Services Native v1.0 (x86)
"{BE94C681-68E2-4561-8ABC-8D2E799168B4}" = essentials
"{BFBCF96F-7361-486A-965C-54B17AC35421}" = ocr
"{C4124E95-5061-4776-8D5D-E3D931C778E1}" = Microsoft VC9 runtime libraries
"{CCA1EEA3-555E-4D05-AC46-4B49C6C5D887}" = Apple Mobile Device Support
"{D2C5E510-BE6D-42CC-9F61-E4F939078474}" = Lexmark Printable Web
"{D92FF8EB-BD77-40AE-B68B-A6BFC6F8661D}" = Windows Live Family Safety
"{DA5BDB2A-12F0-4343-8351-21AAEB293990}" = PreReq
"{DAEAFD68-BB4A-4507-A241-C8804D2EA66D}" = Apple Application Support
"{E0F274B7-592B-4669-8FB8-8D9825A09858}" = KODAK AiO Software
"{E6158D07-2637-4ECF-B576-37C489669174}" = Windows Live Call
"{E7004147-2CCA-431C-AA05-2AB166B9785D}" = QuickTime
"{E7084B89-69E0-46B3-A118-8F99D06988CD}" = Microsoft SQL Server VSS Writer
"{EE39FFBD-544E-49E4-A999-6819828EAE91}" = Windows Live Photo Gallery
"{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}" = Microsoft SQL Server 2005 Compact Edition [ENU]
"{F333A33D-125C-32A2-8DCE-5C5D14231E27}" = Visual C++ 2008 x86 Runtime - (v9.0.30729)
"{F333A33D-125C-32A2-8DCE-5C5D14231E27}.vc_x86runtime_30729_01" = Visual C++ 2008 x86 Runtime - v9.0.30729.01
"{FE24086F-3B0C-4C47-A874-97A7B8E2FBBE}" = aioscnnr
"{FF1C31AE-0CDC-40CE-AB85-406F8B70D643}" = Bonjour
"Activation Assistant for the 2007 Microsoft Office suites" = Activation Assistant for the 2007 Microsoft Office suites
"Adobe AIR" = Adobe AIR
"ATI Display Driver" = ATI Display Driver
"Avira AntiVir Desktop" = Avira AntiVir Personal - Free Antivirus
"Business Contact Manager" = Business Contact Manager for Outlook 2007 SP2
"CCleaner" = CCleaner
"Cisco Connect" = Cisco Connect
"KLiteCodecPack_is1" = K-Lite Codec Pack 3.2.5 Standard
"Lexmark 5600-6600 Series" = Lexmark 5600-6600 Series
"McAfee Security Scan" = McAfee Security Scan Plus
"Microsoft Office Accounting 2007" = Microsoft Office Accounting 2007
"Microsoft Office Accounting Equifax Addin" = Microsoft Office Accounting Equifax Addin
"Microsoft Office Accounting PayPal Addin" = Microsoft Office Accounting PayPal Addin
"Microsoft SQL Server 2005" = Microsoft SQL Server 2005
"Money2006a" = MSN Money Investment Toolbox
"Mozilla Firefox (3.6.16)" = Mozilla Firefox (3.6.16)
"MSNINST" = MSN
"NVIDIA" = NVIDIA Windows 2000/XP Display Drivers
"PROHYBRIDR" = 2007 Microsoft Office system
"PROSet" = Intel(R) Network Connections Drivers
"SoftwareUpdUtility" = Download Updater (AOL LLC)
"SP6" = Logitech SetPoint 6.0
"Spell Checker For OE 2.1" = Spell Checker For OE 2.1
"Windows Live OneCare safety scanner" = Windows Live OneCare safety scanner
"Google Chrome" = Google Chrome
[ Application Events ]
Error - 04/07/2011 12:33:58 AM | Computer Name = YOUR-55C7B0D99D | Source = MSSQL$MSSMLBIZ | ID = 17049
Description = Unable to cycle error log file from 'c:\Program Files\Microsoft SQL
Server\MSSQL.1\MSSQL\LOG\ERRORLOG.3' to 'c:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\LOG\ERRORLOG.4'
due to OS error '5(Access is denied.)'. A process outside of SQL Server may be
preventing SQL Server from reading the files. As a result, errorlog entries may
be lost and it may not be possible to view some SQL Server errorlogs. Make sure
no other processes have locked the file with write-only access."
Server\MSSQL.1\MSSQL\LOG\ERRORLOG.2' to 'c:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\LOG\ERRORLOG.3'
Server\MSSQL.1\MSSQL\LOG\ERRORLOG.1' to 'c:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\LOG\ERRORLOG.2'
Server\MSSQL.1\MSSQL\LOG\ERRORLOG' to 'c:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\LOG\ERRORLOG.1'
Error - 04/07/2011 12:34:04 AM | Computer Name = YOUR-55C7B0D99D | Source = MSSQL$MSSMLBIZ | ID = 17207
Description = FCB::Open: Operating system error 5(Access is denied.) occurred while
creating or opening file 'c:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\DATA\master.mdf'.
Diagnose and correct the operating system error, and retry the operation.
Error - 04/07/2011 12:34:04 AM | Computer Name = YOUR-55C7B0D99D | Source = MSSQL$MSSMLBIZ | ID = 17204
Description = FCB::Open failed: Could not open file c:\Program Files\Microsoft SQL
Server\MSSQL.1\MSSQL\DATA\master.mdf for file number 1. OS error: 5(Access is
denied.).
creating or opening file 'c:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\DATA\mastlog.ldf'.
Server\MSSQL.1\MSSQL\DATA\mastlog.ldf for file number 2. OS error: 5(Access is
denied.).
Error - 04/07/2011 12:37:09 AM | Computer Name = YOUR-55C7B0D99D | Source = Application Error | ID = 1000
Description = Faulting application jusched.exe, version 2.0.3.1, faulting module
user32.dll, version 5.1.2600.5512, fault address 0x000187f1.
Error - 04/07/2011 12:38:06 AM | Computer Name = YOUR-55C7B0D99D | Source = Application Error | ID = 1001
Description = Fault bucket -1980725657.
[ OSession Events ]
Error - 08/27/2009 8:12:56 PM | Computer Name = YOUR-55C7B0D99D | Source = Microsoft Office 12 Sessions | ID = 7001
Description = ID: 0, Application Name: Microsoft Office Word, Application Version:
12.0.4518.1014, Microsoft Office Version: 12.0.4518.1014. This session lasted 3595
seconds with 1920 seconds of active time. This session ended with a crash.
Error - 11/15/2009 5:05:39 PM | Computer Name = YOUR-55C7B0D99D | Source = Microsoft Office 12 Sessions | ID = 7001
12.0.6504.5000, Microsoft Office Version: 12.0.6425.1000. This session lasted 154
seconds with 120 seconds of active time. This session ended with a crash.
[ System Events ]
Error - 04/06/2011 8:51:48 PM | Computer Name = YOUR-55C7B0D99D | Source = Service Control Manager | ID = 7024
Description = The SQL Server (MSSMLBIZ) service terminated with service-specific
error 3417 (0xD59).
Error - 04/06/2011 8:53:08 PM | Computer Name = YOUR-55C7B0D99D | Source = Windows Update Agent | ID = 20
Description = Installation Failure: Windows failed to install the following update
with error 0x80070643: Microsoft SQL Server 2005 Express Edition Service Pack 4
(KB2463332).
Error - 04/07/2011 12:28:01 AM | Computer Name = YOUR-55C7B0D99D | Source = Service Control Manager | ID = 7024
error 3417 (0xD59).
Error - 04/07/2011 12:28:28 AM | Computer Name = YOUR-55C7B0D99D | Source = Windows Update Agent | ID = 20
(KB2463332).
Error - 04/07/2011 12:32:43 AM | Computer Name = YOUR-55C7B0D99D | Source = Service Control Manager | ID = 7001
Description = The TrueVector Internet Monitor service depends on the vsdatant service
which failed to start because of the following error: %%31
Error - 04/07/2011 12:32:43 AM | Computer Name = YOUR-55C7B0D99D | Source = Service Control Manager | ID = 7000
Description = The ZoneAlarm Toolbar ISWKL service failed to start due to the following
error: %%2
Description = The ZoneAlarm Toolbar IswSvc service depends on the ZoneAlarm Toolbar
ISWKL service which failed to start because of the following error: %%2
Description = The SeaPort service failed to start due to the following error: %%3
Error - 04/07/2011 12:33:05 AM | Computer Name = YOUR-55C7B0D99D | Source = Service Control Manager | ID = 7026
vsdatant
Error - 04/07/2011 12:34:04 AM | Computer Name = YOUR-55C7B0D99D | Source = Service Control Manager | ID = 7024
error 3417 (0xD59).
Next OTL Report...
Following in next post due to length the OTL.Txt report
Staples
Posts Posts : 14
Joined Joined : 2011-04-07
OS OS : XP Pro
Points Points : 20884
Part 2 of original Topic post re:Hotfix.exe Includes OTL.Txt report
Post by Staples on 9th April 2011, 1:55 am
From Staples...part 2 of Hotfix.exe and mess of a PC
OTL.Txt - Notepad
OTL logfile created on: 04/07/2011 12:57:05 AM - Run 1
PRC - [2011/04/06 22:50:03 | 000,580,608 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Billy\My Documents\Downloads\OTL GeekPolice.com
PRC - [2011/03/17 02:20:02 | 000,269,480 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\avguard.exe
PRC - [2011/03/09 13:29:16 | 000,366,000 | ---- | M] (Eastman Kodak Company) -- C:\Program Files\Kodak\AiO\Center\EKAiOHostService.exe
PRC - [2011/03/01 17:47:46 | 002,421,760 | ---- | M] (Eastman Kodak Company) -- C:\WINDOWS\system32\spool\drivers\w32x86\3\EKAiO2MUI.exe
PRC - [2010/11/03 10:46:33 | 000,135,336 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\sched.exe
PRC - [2010/11/03 10:46:32 | 000,281,768 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\avgnt.exe
PRC - [2010/01/29 17:20:26 | 000,112,208 | ---- | M] (Logitech, Inc.) -- C:\Program Files\Common Files\Logishrd\KHAL3\KHALMNPR.exe
PRC - [2010/01/27 07:30:16 | 001,312,848 | ---- | M] (Logitech, Inc.) -- C:\Program Files\Logitech\SetPointP\SetPoint.exe
PRC - [2010/01/15 08:49:20 | 000,255,536 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee Security Scan\2.0.181\SSScheduler.exe
PRC - [2010/01/14 22:11:00 | 000,076,968 | ---- | M] (Avira GmbH) -- C:\Program Files\Avira\AntiVir Desktop\avshadow.exe
PRC - [2009/10/16 16:53:44 | 000,094,208 | ---- | M] (Lexmark International, Inc.) -- C:\WINDOWS\system32\spool\drivers\w32x86\3\lxduserv.exe
PRC - [2009/10/16 12:06:30 | 000,589,824 | ---- | M] ( ) -- C:\WINDOWS\system32\lxducoms.exe
PRC - [2009/02/20 09:46:52 | 000,030,312 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft Small Business\Business Contact Manager\BcmSqlStartupSvc.exe
PRC - [2008/08/21 08:00:00 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
PRC - [2007/01/04 17:38:08 | 000,024,652 | ---- | M] (Viewpoint Corporation) -- C:\Program Files\Viewpoint\Common\ViewpointService.exe
PRC - [2006/11/03 19:20:12 | 000,866,584 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Windows Defender\MSASCui.exe
PRC - [2006/11/03 19:19:58 | 000,013,592 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Windows Defender\MsMpEng.exe
MOD - [2011/04/06 22:50:03 | 000,580,608 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Billy\My Documents\Downloads\OTL GeekPolice.com
MOD - [2010/08/23 12:12:02 | 001,054,208 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\comctl32.dll
SRV - File not found [Auto | Stopped] -- -- (vsmon)
SRV - File not found [Auto | Stopped] -- -- (SeaPort)
SRV - File not found [Auto | Stopped] -- -- (IswSvc)
SRV - File not found [On_Demand | Stopped] -- -- (BBSvc)
SRV - [2011/03/17 02:20:02 | 000,269,480 | ---- | M] (Avira GmbH) [Auto | Running] -- C:\Program Files\Avira\AntiVir Desktop\avguard.exe -- (AntiVirService)
SRV - [2011/03/09 13:29:16 | 000,366,000 | ---- | M] (Eastman Kodak Company) [Auto | Running] -- C:\Program Files\Kodak\AiO\Center\EKAiOHostService.exe -- (Kodak AiO Network Discovery Service)
SRV - [2010/11/03 10:46:33 | 000,135,336 | ---- | M] (Avira GmbH) [Auto | Running] -- C:\Program Files\Avira\AntiVir Desktop\sched.exe -- (AntiVirSchedulerService)
SRV - [2010/01/29 17:17:14 | 000,292,944 | ---- | M] (Logitech, Inc.) [On_Demand | Stopped] -- C:\Program Files\Common Files\Logishrd\Bluetooth\LBTServ.exe -- (LBTServ)
SRV - [2010/01/15 08:49:20 | 000,227,232 | ---- | M] (McAfee, Inc.) [On_Demand | Stopped] -- C:\Program Files\McAfee Security Scan\2.0.181\McCHSvc.exe -- (McComponentHostService)
SRV - [2009/10/16 16:53:44 | 000,094,208 | ---- | M] () [Auto | Running] -- C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\\lxduserv.exe -- (lxduCATSCustConnectService)
SRV - [2009/10/16 12:06:30 | 000,589,824 | ---- | M] ( ) [Auto | Running] -- C:\WINDOWS\System32\lxducoms.exe -- (lxdu_device)
SRV - [2009/02/20 09:46:52 | 000,030,312 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\Program Files\Microsoft Small Business\Business Contact Manager\BcmSqlStartupSvc.exe -- (BcmSqlStartupSvc)
SRV - [2007/01/04 17:38:08 | 000,024,652 | ---- | M] (Viewpoint Corporation) [Auto | Running] -- C:\Program Files\Viewpoint\Common\ViewpointService.exe -- (Viewpoint Manager Service)
SRV - [2006/11/03 19:19:58 | 000,013,592 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\Program Files\Windows Defender\MsMpEng.exe -- (WinDefend)
DRV - [2011/03/17 02:20:03 | 000,137,656 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\avipbb.sys -- (avipbb)
DRV - [2010/11/22 12:37:38 | 000,061,960 | ---- | M] (Avira GmbH) [File_System | Auto | Running] -- C:\WINDOWS\system32\drivers\avgntflt.sys -- (avgntflt)
DRV - [2009/11/10 07:55:24 | 000,079,504 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\LMouKE.Sys -- (LMouKE)
DRV - [2009/11/10 07:55:08 | 000,037,392 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\LMouFilt.Sys -- (LMouFilt)
DRV - [2009/11/10 07:54:52 | 000,035,984 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\LHidFilt.Sys -- (LHidFilt)
DRV - [2009/11/10 07:54:04 | 000,063,248 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\L8042mou.Sys -- (L8042mou)
DRV - [2009/11/10 07:53:56 | 000,020,240 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\L8042Kbd.sys -- (L8042Kbd)
DRV - [2009/09/16 11:22:48 | 000,214,664 | ---- | M] (McAfee, Inc.) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\mfehidk.sys -- (mfehidk)
DRV - [2009/09/16 11:22:48 | 000,079,816 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mfeavfk.sys -- (mfeavfk)
DRV - [2009/09/16 11:22:48 | 000,040,552 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mfesmfk.sys -- (mfesmfk)
DRV - [2009/09/16 11:22:48 | 000,035,272 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mfebopk.sys -- (mfebopk)
DRV - [2009/09/16 10:22:14 | 000,034,248 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mferkdk.sys -- (mferkdk)
DRV - [2009/08/05 23:48:42 | 000,054,752 | ---- | M] (Microsoft Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\fssfltr_tdi.sys -- (fssfltr)
DRV - [2009/05/11 12:49:19 | 000,011,608 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\Program Files\Avira\AntiVir Desktop\avgio.sys -- (avgio)
DRV - [2009/05/11 10:12:49 | 000,028,520 | ---- | M] (Avira GmbH) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\ssmdrv.sys -- (ssmdrv)
DRV - [2007/05/03 13:37:08 | 000,022,152 | ---- | M] (Maxtor Corp.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mxopswd.sys -- (MXOPSWD)
DRV - [2006/02/21 20:46:26 | 001,505,792 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ati2mtag.sys -- (ati2mtag)
DRV - [2004/02/09 12:06:22 | 000,015,360 | ---- | M] (Motorola Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\NetMotCM.sys -- (ndiscm)
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Default_Search_URL = [You must be registered and logged in to see this link.]
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,SearchAssistant = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page Redirect Cache = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page Redirect Cache AcceptLangs = en-us
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page Redirect Cache_TIMESTAMP = 62 13 C5 B7 61 B1 CB 01 [binary data]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Search,SearchAssistant = [You must be registered and logged in to see this link.]
IE - HKCU\..\URLSearchHook: {91da5e8a-3318-4f8c-b67e-5964de3ab546} - Reg Error: Key error. File not found
========== FireFox ==========
FF - prefs.js..browser.search.defaultthis.engineName: "ZoneAlarm Security Customized Web Search"
FF - prefs.js..browser.search.defaulturl: "http://search.conduit.com/ResultsExt.aspx?ctid=CT2645238&SearchSource=3&q={searchTerms}"
FF - prefs.js..browser.startup.homepage: "http://search.conduit.com/?ctid=CT2645238&SearchSource=13"
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:5.0.1
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:1.20.0.66
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:1.4
FF - prefs.js..extensions.enabledItems: {37fa1426-b82d-11db-8314-0800200c9a66}:2.7.5
FF - prefs.js..extensions.enabledItems: {1a0c9ebe-ddf9-4b76-b8a3-675c77874d37}:3.0
FF - prefs.js..extensions.enabledItems: {CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}:6.0.24
FF - prefs.js..keyword.URL: "http://search.conduit.com/ResultsExt.aspx?ctid=CT2645238&SearchSource=2&q="
FF - prefs.js..network.proxy.no_proxies_on: "*.local"
FF - prefs.js..network.proxy.type: 0
FF - HKLM\software\mozilla\Firefox\extensions\\{FFB96CC1-7EB3-449D-B827-DB661701C6BB}: C:\Program Files\CheckPoint\ZAForceField\TrustChecker
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.16\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2011/03/27 01:48:29 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.16\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2011/04/06 22:31:44 | 000,000,000 | ---D | M]
[2011/01/23 14:19:05 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Billy\Application Data\Mozilla\Extensions
[2011/04/07 00:34:53 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Billy\Application Data\Mozilla\Firefox\Profiles\f6h253z3.default\extensions
[2011/03/06 14:26:36 | 000,000,000 | ---D | M] (TwitterBar) -- C:\Documents and Settings\Billy\Application Data\Mozilla\Firefox\Profiles\f6h253z3.default\extensions\{1a0c9ebe-ddf9-4b76-b8a3-675c77874d37}
[2010/05/14 01:15:02 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\Documents and Settings\Billy\Application Data\Mozilla\Firefox\Profiles\f6h253z3.default\extensions\{20a82645-c095-46ed-80e3-08825760534b}
[2011/03/22 09:21:28 | 000,000,000 | ---D | M] (WebMail Notifier) -- C:\Documents and Settings\Billy\Application Data\Mozilla\Firefox\Profiles\f6h253z3.default\extensions\{37fa1426-b82d-11db-8314-0800200c9a66}
[2011/03/22 09:21:21 | 000,000,000 | ---D | M] (Add to Amazon Wish List Button) -- C:\Documents and Settings\Billy\Application Data\Mozilla\Firefox\Profiles\f6h253z3.default\extensions\amznUWL2@amazon.com
[2010/08/19 20:17:45 | 000,000,000 | ---D | M] (DeeperWeb for Google) -- C:\Documents and Settings\Billy\Application Data\Mozilla\Firefox\Profiles\f6h253z3.default\extensions\bizdom@wizbites.com
[2010/10/13 12:37:33 | 000,000,000 | ---D | M] (Разпознаване на устройство Logitech) -- C:\Documents and Settings\Billy\Application Data\Mozilla\Firefox\Profiles\f6h253z3.default\extensions\DeviceDetection@logitech.com
[2010/10/13 12:37:32 | 000,000,000 | ---D | M] (United States English Spellchecker) -- C:\Documents and Settings\Billy\Application Data\Mozilla\Firefox\Profiles\f6h253z3.default\extensions\en-US@dictionaries.addons.mozilla.org
[2010/04/28 12:50:19 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Billy\Application Data\Mozilla\Firefox\Profiles\f6h253z3.default\extensions\inthenews@mozilla.org
[2011/03/06 14:26:35 | 000,000,000 | ---D | M] (Lazarus: Form Recovery) -- C:\Documents and Settings\Billy\Application Data\Mozilla\Firefox\Profiles\f6h253z3.default\extensions\lazarus@interclue.com
[2011/04/06 22:24:00 | 000,000,000 | ---D | M] (No name found) -- C:\Program Files\Mozilla Firefox\extensions
[2010/11/28 04:22:56 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}
[2011/04/06 21:58:48 | 000,000,000 | ---D | M] (Java Console) -- C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}
[2011/04/06 21:58:07 | 000,472,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npdeployJava1.dll
O1 HOSTS File: ([2008/08/21 08:00:00 | 000,000,734 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
O2 - BHO: (no name) - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - No CLSID value found.
O2 - BHO: (no name) - {8A4A36C2-0535-4D2C-BD3D-496CB7EED6E3} - No CLSID value found.
O2 - BHO: (no name) - {91da5e8a-3318-4f8c-b67e-5964de3ab546} - No CLSID value found.
O2 - BHO: (Lexmark Printable Web) - {D2C5E510-BE6D-42CC-9F61-E4F939078474} - C:\Program Files\Lexmark Printable Web\bho.dll ()
O2 - BHO: (no name) - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - No CLSID value found.
O3 - HKLM\..\Toolbar: (no name) - {8dcb7100-df86-4384-8842-8fa844297b3f} - No CLSID value found.
O3 - HKLM\..\Toolbar: (no name) - {91da5e8a-3318-4f8c-b67e-5964de3ab546} - No CLSID value found.
O3 - HKLM\..\Toolbar: (no name) - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - No CLSID value found.
O3 - HKLM\..\Toolbar: (no name) - {EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} - No CLSID value found.
O3 - HKLM\..\Toolbar: (no name) - Locked - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {1017A80C-6F09-4548-A84D-EDD6AC9525F0} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {604BC32A-9680-40D1-9AC6-E06B23A1BA4C} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - No CLSID value found.
O4 - HKLM..\Run: [Adobe Reader Speed Launcher] C:\Program Files\Adobe\Reader 10.0\Reader\Reader_sl.exe (Adobe Systems Incorporated)
O4 - HKLM..\Run: [avgnt] C:\Program Files\Avira\AntiVir Desktop\avgnt.exe (Avira GmbH)
O4 - HKLM..\Run: [Conime] C:\WINDOWS\system32\conime.exe (Microsoft Corporation)
O4 - HKLM..\Run: [EfficientCalendarFree] File not found
O4 - HKLM..\Run: [EKAIO2StatusMonitor] C:\WINDOWS\system32\spool\drivers\w32x86\3\EKAiO2MUI.exe (Eastman Kodak Company)
O4 - HKLM..\Run: [EvtMgr6] C:\Program Files\Logitech\SetPointP\SetPoint.exe (Logitech, Inc.)
O4 - HKLM..\Run: [Kernel and Hardware Abstraction Layer] C:\WINDOWS\KHALMNPR.Exe (Logitech, Inc.)
O4 - HKLM..\Run: [NvCplDaemon] C:\WINDOWS\System32\NvCpl.dll (NVIDIA Corporation)
O4 - HKLM..\Run: [nwiz] C:\WINDOWS\System32\nwiz.exe (NVIDIA Corporation)
O4 - HKLM..\Run: [UserFaultCheck] File not found
O4 - HKCU..\Run: [NvMediaCenter] C:\WINDOWS\System32\NVMCTRAY.DLL (NVIDIA Corporation)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\McAfee Security Scan Plus.lnk = C:\Program Files\McAfee Security Scan\2.0.181\SSScheduler.exe (McAfee, Inc.)
O15 - HKCU\..Trusted Domains: internet ([]about in Trusted sites)
O15 - HKCU\..Trusted Domains: mcafee.com ([]http in Trusted sites)
O15 - HKCU\..Trusted Domains: mcafee.com ([]https in Trusted sites)
O15 - HKCU\..Trusted Domains: mozilla.com ([www] https in Trusted sites)
O15 - HKCU\..Trusted Domains: scottrade.com ([www] https in Trusted sites)
O16 - DPF: {0067DBFC-A752-458C-AE6E-B9C7E63D4824} [You must be registered and logged in to see this link.] (Device Detection)
O16 - DPF: {5AE58FCF-6F6A-49B2-B064-02492C66E3F4} [You must be registered and logged in to see this link.] (MUCatalogWebControl Class)
O16 - DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} [You must be registered and logged in to see this link.] (Windows Live Safety Center Base Module)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_24)
O16 - DPF: {CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_24)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_24)
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 167.206.254.1 167.206.254.2
O20 - Winlogon\Notify\AtiExtEvent: DllName - Ati2evxx.dll - C:\WINDOWS\System32\ati2evxx.dll (ATI Technologies Inc.)
O20 - Winlogon\Notify\LBTWlgn: DllName - c:\program files\common files\logishrd\bluetooth\LBTWlgn.dll - c:\Program Files\Common Files\Logishrd\Bluetooth\LBTWLgn.dll (Logitech, Inc.)
O28 - HKLM ShellExecuteHooks: {091EB208-39DD-417D-A5DD-7E2C2D8FB9CB} - C:\Program Files\Windows Defender\MpShHook.dll (Microsoft Corporation)
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2009/03/13 03:12:39 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O33 - MountPoints2\{b51efbd2-5a87-11de-897b-00096b76a610}\Shell - "" = AutoRun
O33 - MountPoints2\{b51efbd2-5a87-11de-897b-00096b76a610}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{b51efbd2-5a87-11de-897b-00096b76a610}\Shell\AutoRun\command - "" = E:\StormF1.exe
O33 - MountPoints2\{b51efbd3-5a87-11de-897b-00096b76a610}\Shell - "" = AutoRun
O33 - MountPoints2\{b51efbd3-5a87-11de-897b-00096b76a610}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{b51efbd3-5a87-11de-897b-00096b76a610}\Shell\AutoRun\command - "" = E:\StormF1.exe
O33 - MountPoints2\{b8bf7fab-633d-11de-8981-00096b76a610}\Shell - "" = AutoRun
O33 - MountPoints2\{b8bf7fab-633d-11de-8981-00096b76a610}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{b8bf7fab-633d-11de-8981-00096b76a610}\Shell\AutoRun\command - "" = F:\StormF1.exe
O33 - MountPoints2\{dcada168-6279-11de-897c-00096b76a610}\Shell - "" = AutoRun
O33 - MountPoints2\{dcada168-6279-11de-897c-00096b76a610}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{dcada168-6279-11de-897c-00096b76a610}\Shell\AutoRun\command - "" = E:\StormF1.exe
NetSvcs: 6to4 - File not found
NetSvcs: Ias - File not found
NetSvcs: Iprip - File not found
NetSvcs: Irmon - File not found
MsConfig - StartUpReg: EzPrint - hkey= - key= - C:\Program Files\Lexmark 5600-6600 Series\ezprint.exe (Lexmark International Inc.)
MsConfig - StartUpReg: lxdumon.exe - hkey= - key= - C:\Program Files\Lexmark 5600-6600 Series\lxdumon.exe ()
SafeBootMin: sermouse.sys - Driver
SafeBootMin: vga.sys - Driver
SafeBootMin: WinDefend - C:\Program Files\Windows Defender\MsMpEng.exe (Microsoft Corporation)
SafeBootNet: sermouse.sys - Driver
SafeBootNet: vga.sys - Driver
SafeBootNet: vsmon - File not found
SafeBootNet: WinDefend - C:\Program Files\Windows Defender\MsMpEng.exe (Microsoft Corporation)
ActiveX: {03F998B2-0E00-11D3-A498-00104B6EB52E} - Viewpoint Media Player
ActiveX: {10072CEC-8CC1-11D1-986E-00A0C955B42F} - Vector Graphics Rendering (VML)
ActiveX: {1B00725B-C455-4DE6-BFB6-AD540AD427CD} - Viewpoint Media Player
ActiveX: {2179C5D3-EBFF-11CF-B6FD-00AA00B4E220} - NetShow
ActiveX: {22d6f312-b0f6-11d0-94ab-0080c74c7e95} - Microsoft Windows Media Player 6.4
ActiveX: {283807B5-2C60-11D0-A31D-00AA00B92C03} - DirectAnimation
ActiveX: {36f8ec70-c29a-11d1-b5c7-0000f8051515} - Dynamic HTML Data Binding for Java
ActiveX: {3bf42070-b3b1-11d1-b5c5-0000f8051515} - Uniscribe
ActiveX: {4278c270-a269-11d1-b5bf-0000f8051515} - Advanced Authoring
ActiveX: {44BBA840-CC51-11CF-AAFA-00AA00B6015C} - "%ProgramFiles%\Outlook Express\setup50.exe" /APP:OE /CALLER:WINNT /user /install
ActiveX: {44BBA842-CC51-11CF-AAFA-00AA00B6015B} - rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\msnetmtg.inf,NetMtg.Install.PerUser.NT
ActiveX: {44BBA848-CC51-11CF-AAFA-00AA00B6015C} - DirectShow
ActiveX: {4f216970-c90c-11d1-b5c7-0000f8051515} - DirectAnimation Java Classes
ActiveX: {4f645220-306d-11d2-995d-00c04f98bbc9} - Microsoft Windows Script 5.7
ActiveX: {5056b317-8d4c-43ee-8543-b9d1e234b8f4} - Security Update for Windows XP (KB923789)
ActiveX: {5945c046-1e7d-11d1-bc44-00c04fd912be} - rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\msmsgs.inf,BLC.QuietInstall.PerUser
ActiveX: {5A8D6EE0-3E18-11D0-821E-444553540000} - ICW
ActiveX: {6BF52A52-394A-11d3-B153-00C04F79FAA6} - Microsoft Windows Media Player
ActiveX: {7131646D-CD3C-40F4-97B9-CD9E4E6262EF} - .NET Framework
ActiveX: {73fa19d0-2d75-11d2-995d-00c04f98bbc9} - Web Folders
ActiveX: {7790769C-0471-11d2-AF11-00C04FA35D02} - "%ProgramFiles%\Outlook Express\setup50.exe" /APP:WAB /CALLER:WINNT /user /install
ActiveX: {89820200-ECBD-11cf-8B85-00AA005B4383} - C:\WINDOWS\system32\ie4uinit.exe -BaseSettings
ActiveX: {89B4C1CD-B018-4511-B0A1-5476DBF70820} - c:\WINDOWS\system32\Rundll32.exe c:\WINDOWS\system32\mscories.dll,Install
ActiveX: {8b15971b-5355-4c82-8c07-7e181ea07608} - rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\fxsocm.inf,Fax.UnInstall.PerUser
ActiveX: {94de52c8-2d59-4f1b-883e-79663d2d9a8c} - rundll32.exe C:\WINDOWS\system32\Setup\FxsOcm.dll,XP_UninstallProvider
ActiveX: {ACC563BC-4266-43f0-B6ED-9D38C4202C7E} -
ActiveX: {C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F} - .NET Framework
ActiveX: {CC2A9BA0-3BDD-11D0-821E-444553540000} - Task Scheduler
ActiveX: {D27CDB6E-AE6D-11cf-96B8-444553540000} - Adobe Flash Player
ActiveX: <{12d0ed0d-0ee0-4f90-8827-78cefb8f4988} - C:\WINDOWS\system32\ieudinit.exe
ActiveX: >{22d6f312-b0f6-11d0-94ab-0080c74c7e95} - C:\WINDOWS\inf\unregmp2.exe /ShowWMP
ActiveX: >{26923b43-4d38-484f-9b9e-de460746276c} - C:\WINDOWS\system32\ie4uinit.exe -UserIconConfig
ActiveX: >{60B49E34-C7CC-11D0-8953-00A0C90347FF} - "C:\WINDOWS\system32\rundll32.exe" "C:\WINDOWS\system32\iedkcs32.dll",BrandIEActiveSetup SIGNUP
ActiveX: >{60B49E34-C7CC-11D0-8953-00A0C90347FF}MICROS - RunDLL32 IEDKCS32.DLL,BrandIE4 SIGNUP
ActiveX: >{881dd1c5-3dcf-431b-b061-f3f88e8be88a} - %systemroot%\system32\shmgrate.exe OCInstallUserConfigOE
Drivers32: msacm.iac2 - C:\WINDOWS\system32\iac25_32.ax (Intel Corporation)
Drivers32: msacm.l3acm - C:\WINDOWS\system32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
Drivers32: msacm.sl_anet - C:\WINDOWS\System32\sl_anet.acm (Sipro Lab Telecom Inc.)
Drivers32: msacm.trspch - C:\WINDOWS\System32\tssoft32.acm (DSP GROUP, INC.)
Drivers32: vidc.cvid - C:\WINDOWS\System32\iccvid.dll (Radius Inc.)
Drivers32: VIDC.FFDS - C:\WINDOWS\System32\ff_vfw.dll ()
Drivers32: vidc.iv31 - C:\WINDOWS\System32\ir32_32.dll ()
Drivers32: vidc.iv32 - C:\WINDOWS\System32\ir32_32.dll ()
Drivers32: vidc.iv41 - C:\WINDOWS\System32\ir41_32.ax (Intel Corporation)
Drivers32: vidc.iv50 - C:\WINDOWS\System32\ir50_32.dll (Intel Corporation)
CREATERESTOREPOINT
Restore point Set: OTL Restore Point (16902109354000384)
[2011/04/06 22:30:27 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Adobe
[2011/04/06 22:25:58 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Adobe AIR
[2011/04/06 22:25:22 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\McAfee Security Scan
[2011/04/06 22:25:11 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\McAfee Security Scan Plus
[2011/04/06 22:25:08 | 000,000,000 | ---D | C] -- C:\Program Files\McAfee Security Scan
[2011/04/06 22:00:17 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Java
[2011/04/06 21:58:30 | 000,073,728 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javacpl.cpl
[2011/04/06 21:58:29 | 000,157,472 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaws.exe
[2011/04/06 21:58:29 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaw.exe
[2011/04/06 21:58:29 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\java.exe
[2011/04/06 21:53:43 | 016,525,088 | ---- | C] (Sun Microsystems, Inc.) -- C:\Documents and Settings\Billy\Desktop\jre-6u24-windows-i586.exe
[2011/04/06 15:53:37 | 000,000,000 | RH-D | C] -- C:\Documents and Settings\Billy\Recent
[2011/04/05 12:53:07 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Billy\My Documents\mail stuff
[2011/04/05 12:53:01 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Billy\My Documents\music bits and pieces
[2011/04/05 12:10:47 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Billy\My Documents\text
[2011/04/05 12:10:41 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Billy\My Documents\pics and similar
[2011/04/05 12:10:34 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Billy\My Documents\downloads set ups etc
[2011/04/05 11:53:32 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Billy\Local Settings\Application Data\PCHealth
[2011/03/26 14:47:21 | 000,000,000 | ---D | C] -- C:\WINDOWS\Internet Logs
[2011/03/26 00:38:38 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Favorites
[2011/03/26 00:38:02 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Billy\Application Data\CheckPoint
[2011/03/26 00:36:57 | 000,000,000 | ---D | C] -- C:\Program Files\Conduit
[2011/03/26 00:36:32 | 000,000,000 | ---D | C] -- C:\Program Files\CheckPoint
[2011/03/24 23:04:17 | 000,000,000 | ---D | C] -- C:\Documents and Settings\LocalService\Application Data\Temp
[2011/03/23 22:58:26 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Billy\Local Settings\Application Data\Eastman_Kodak_Company
[2011/03/23 22:54:17 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Billy\Local Settings\Application Data\Eastman Kodak Company
[2011/03/23 22:53:01 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Start Menu\Programs\Kodak
[2011/03/23 22:51:44 | 000,000,000 | ---D | C] -- C:\WINDOWS\System32\kodak
[2011/03/23 22:49:55 | 000,611,328 | ---- | C] (Eastman Kodak Company) -- C:\WINDOWS\System32\EKAiO2MON.dll
[2011/03/23 22:49:55 | 000,126,464 | ---- | C] (Eastman Kodak Company) -- C:\WINDOWS\System32\EKAiO2COI03.dll
[2011/03/23 22:41:51 | 000,000,000 | ---D | C] -- C:\Program Files\Kodak
[2011/03/23 22:33:44 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Billy\Application Data\Temp
[2011/03/23 22:33:37 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Kodak
[2011/03/10 01:00:50 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\ODBC
[2011/02/27 00:03:25 | 000,446,464 | ---- | C] ( ) -- C:\WINDOWS\System32\LXDUhcp.dll
[2011/02/26 21:43:32 | 000,860,160 | ---- | C] ( ) -- C:\WINDOWS\System32\lxduusb1.dll
[2011/02/26 21:43:31 | 001,069,056 | ---- | C] ( ) -- C:\WINDOWS\System32\lxduserv.dll
[2011/02/26 21:43:31 | 000,684,032 | ---- | C] ( ) -- C:\WINDOWS\System32\lxduhbn3.dll
[2011/02/26 21:43:31 | 000,651,264 | ---- | C] ( ) -- C:\WINDOWS\System32\lxdupmui.dll
[2011/02/26 21:43:31 | 000,364,544 | ---- | C] ( ) -- C:\WINDOWS\System32\lxduinpa.dll
[2011/02/26 21:43:31 | 000,339,968 | ---- | C] ( ) -- C:\WINDOWS\System32\lxduiesc.dll
[2011/02/26 21:43:31 | 000,323,584 | ---- | C] ( ) -- C:\WINDOWS\System32\lxduih.exe
[2011/02/26 21:43:30 | 000,761,856 | ---- | C] ( ) -- C:\WINDOWS\System32\lxducomc.dll
[2011/02/26 21:43:30 | 000,589,824 | ---- | C] ( ) -- C:\WINDOWS\System32\lxducoms.exe
[2011/02/26 21:43:30 | 000,376,832 | ---- | C] ( ) -- C:\WINDOWS\System32\lxducomm.dll
[2011/02/26 21:43:30 | 000,364,544 | ---- | C] ( ) -- C:\WINDOWS\System32\lxducfg.exe
[2011/02/26 21:43:28 | 000,577,536 | ---- | C] ( ) -- C:\WINDOWS\System32\lxdulmpm.dll
[2009/10/15 22:32:46 | 000,409,600 | ---- | C] ( ) -- C:\WINDOWS\System32\lxducoin.dll
[9 C:\Documents and Settings\All Users\*.tmp files -> C:\Documents and Settings\All Users\*.tmp -> ]
[7 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
[6 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
[2011/04/07 01:03:00 | 000,000,422 | -H-- | M] () -- C:\WINDOWS\tasks\User_Feed_Synchronization-{5EE1835E-AF7A-4575-BA25-B6C033D51654}.job
[2011/04/07 00:49:00 | 000,000,978 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-3742509044-3434307102-661493048-1007UA.job
[2011/04/07 00:46:00 | 000,000,886 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
[2011/04/07 00:36:09 | 000,000,330 | -H-- | M] () -- C:\WINDOWS\tasks\MP Scheduled Scan.job
[2011/04/07 00:33:59 | 000,012,598 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
[2011/04/07 00:31:49 | 000,000,882 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
[2011/04/07 00:31:45 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
[2011/04/07 00:31:42 | 535,613,440 | -HS- | M] () -- C:\hiberfil.sys
[2011/04/06 22:31:45 | 000,001,745 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Adobe Reader X.lnk
[2011/04/06 22:25:12 | 000,001,619 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\McAfee Security Scan Plus.lnk
[2011/04/06 22:25:12 | 000,001,611 | ---- | M] () -- C:\Documents and Settings\All Users\Start Menu\Programs\Startup\McAfee Security Scan Plus.lnk
[2011/04/06 21:58:06 | 000,157,472 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaws.exe
[2011/04/06 21:58:06 | 000,145,184 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaw.exe
[2011/04/06 21:58:06 | 000,145,184 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\java.exe
[2011/04/06 21:58:06 | 000,073,728 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javacpl.cpl
[2011/04/06 21:58:05 | 000,472,808 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\deployJava1.dll
[2011/04/06 21:54:26 | 016,525,088 | ---- | M] (Sun Microsystems, Inc.) -- C:\Documents and Settings\Billy\Desktop\jre-6u24-windows-i586.exe
[2011/04/05 07:38:00 | 000,000,282 | ---- | M] () -- C:\WINDOWS\tasks\AppleSoftwareUpdate.job
[2011/04/05 04:49:00 | 000,000,926 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-3742509044-3434307102-661493048-1007Core.job
[2011/04/04 23:07:52 | 000,000,517 | ---- | M] () -- C:\Documents and Settings\Billy\Desktop\Shortcut to recorder audio.lnk
[2011/04/04 23:05:32 | 000,000,509 | ---- | M] () -- C:\Documents and Settings\Billy\Desktop\Shortcut to My Music.lnk
[2011/03/29 11:21:40 | 000,016,400 | ---- | M] (Logitech, Inc.) -- C:\WINDOWS\System32\drivers\LNonPnP.sys
[2011/03/26 00:36:06 | 000,004,212 | -H-- | M] () -- C:\WINDOWS\System32\zllictbl.dat
[2011/03/25 23:57:14 | 000,002,273 | ---- | M] () -- C:\Documents and Settings\Billy\Application Data\Microsoft\Internet Explorer\Quick Launch\Google Chrome.lnk
[2011/03/25 23:57:13 | 000,002,295 | ---- | M] () -- C:\Documents and Settings\Billy\Desktop\Google Chrome.lnk
[2011/03/23 22:57:43 | 000,001,870 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\KODAK AiO Home Center.lnk
[2011/03/17 02:20:03 | 000,137,656 | ---- | M] (Avira GmbH) -- C:\WINDOWS\System32\drivers\avipbb.sys
[2011/03/13 03:36:52 | 000,485,914 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
[2011/03/13 03:36:52 | 000,088,250 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
[2011/04/06 22:31:45 | 000,001,804 | ---- | C] () -- C:\Documents and Settings\All Users\Start Menu\Programs\Adobe Reader X.lnk
[2011/04/06 22:31:45 | 000,001,745 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Adobe Reader X.lnk
[2011/04/06 22:25:12 | 000,001,619 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\McAfee Security Scan Plus.lnk
[2011/04/06 22:25:12 | 000,001,611 | ---- | C] () -- C:\Documents and Settings\All Users\Start Menu\Programs\Startup\McAfee Security Scan Plus.lnk
[2011/04/04 23:07:52 | 000,000,517 | ---- | C] () -- C:\Documents and Settings\Billy\Desktop\Shortcut to recorder audio.lnk
[2011/04/04 23:05:32 | 000,000,509 | ---- | C] () -- C:\Documents and Settings\Billy\Desktop\Shortcut to My Music.lnk
[2011/03/26 00:36:06 | 000,004,212 | -H-- | C] () -- C:\WINDOWS\System32\zllictbl.dat
[2011/03/23 22:57:43 | 000,001,870 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\KODAK AiO Home Center.lnk
[2011/02/27 00:03:25 | 000,389,120 | ---- | C] () -- C:\WINDOWS\System32\LXDUinst.dll
[2011/02/26 21:43:32 | 000,040,960 | ---- | C] () -- C:\WINDOWS\System32\lxduvs.dll
[2011/02/26 21:43:30 | 000,208,896 | ---- | C] () -- C:\WINDOWS\System32\lxdugrd.dll
[2011/02/26 20:04:32 | 001,036,288 | ---- | C] () -- C:\WINDOWS\System32\lxdudrs.dll
[2011/02/26 20:04:32 | 000,081,920 | ---- | C] () -- C:\WINDOWS\System32\lxducaps.dll
[2011/02/26 20:04:32 | 000,069,632 | ---- | C] () -- C:\WINDOWS\System32\lxducnv4.dll
[2010/12/03 02:40:25 | 000,010,677 | ---- | C] () -- C:\WINDOWS\ePrompter.ini
[2010/09/08 03:31:34 | 000,000,000 | ---- | C] () -- C:\Documents and Settings\Billy\Local Settings\Application Data\prvlcl.dat
[2010/07/17 18:04:02 | 000,006,144 | ---- | C] () -- C:\Documents and Settings\Billy\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2010/04/11 09:40:06 | 000,161,816 | ---- | C] () -- C:\WINDOWS\RegGenieOnUninstall.exe
[2010/03/03 14:50:46 | 000,000,000 | ---- | C] () -- C:\WINDOWS\nsreg.dat
[2010/01/27 02:46:06 | 000,000,000 | ---- | C] () -- C:\WINDOWS\SetPointInstall.ini
[2010/01/09 22:50:57 | 000,056,896 | -H-- | C] () -- C:\WINDOWS\System32\mlfcache.dat
[2009/12/09 00:59:41 | 000,000,092 | ---- | C] () -- C:\Documents and Settings\Billy\Application Data\default.pls
[2009/12/09 00:58:47 | 000,000,069 | ---- | C] () -- C:\WINDOWS\NeroDigital.ini
[2009/08/03 16:07:42 | 000,403,816 | ---- | C] () -- C:\WINDOWS\System32\OGACheckControl.dll
[2009/08/03 16:07:42 | 000,230,768 | ---- | C] () -- C:\WINDOWS\System32\OGAEXEC.exe
[2009/07/12 19:48:05 | 000,000,754 | ---- | C] () -- C:\WINDOWS\WORDPAD.INI
[2009/06/27 00:25:05 | 000,010,752 | ---- | C] () -- C:\WINDOWS\System32\ff_vfw.dll
[2009/06/27 00:19:43 | 000,000,036 | -H-- | C] () -- C:\Documents and Settings\Billy\Application Data\swk.ini
[2009/03/13 05:15:06 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
[2009/03/13 03:16:33 | 000,002,048 | --S- | C] () -- C:\WINDOWS\bootstat.dat
[2009/03/13 03:08:51 | 000,022,816 | ---- | C] () -- C:\WINDOWS\System32\emptyregdb.dat
[2009/03/13 01:41:41 | 000,000,060 | ---- | C] () -- C:\WINDOWS\System32\Oeminfo.ini
[2009/03/13 01:41:02 | 000,485,914 | ---- | C] () -- C:\WINDOWS\System32\perfh009.dat
[2009/03/13 01:41:01 | 000,088,250 | ---- | C] () -- C:\WINDOWS\System32\perfc009.dat
[2009/03/13 01:40:58 | 000,000,741 | ---- | C] () -- C:\WINDOWS\System32\noise.dat
[2009/03/12 19:02:22 | 000,004,161 | ---- | C] () -- C:\WINDOWS\ODBCINST.INI
[2009/03/12 19:01:22 | 000,270,192 | ---- | C] () -- C:\WINDOWS\System32\FNTCACHE.DAT
[2008/08/21 08:00:00 | 013,107,200 | ---- | C] () -- C:\WINDOWS\System32\oembios.bin
[2008/08/21 08:00:00 | 000,673,088 | ---- | C] () -- C:\WINDOWS\System32\mlang.dat
[2008/08/21 08:00:00 | 000,272,128 | ---- | C] () -- C:\WINDOWS\System32\perfi009.dat
[2008/08/21 08:00:00 | 000,218,003 | ---- | C] () -- C:\WINDOWS\System32\dssec.dat
[2008/08/21 08:00:00 | 000,046,258 | ---- | C] () -- C:\WINDOWS\System32\mib.bin
[2008/08/21 08:00:00 | 000,028,626 | ---- | C] () -- C:\WINDOWS\System32\perfd009.dat
[2008/08/21 08:00:00 | 000,004,569 | ---- | C] () -- C:\WINDOWS\System32\secupd.dat
[2008/08/21 08:00:00 | 000,004,461 | ---- | C] () -- C:\WINDOWS\System32\oembios.dat
[2008/08/21 08:00:00 | 000,001,804 | ---- | C] () -- C:\WINDOWS\System32\Dcache.bin
[2008/08/05 17:37:40 | 000,460,199 | ---- | C] () -- C:\WINDOWS\sqlite3.dll
[2006/02/13 13:29:26 | 000,121,995 | ---- | C] () -- C:\WINDOWS\System32\atiicdxx.dat
< %systemroot%\Fonts\*.com >
[2006/04/18 15:39:28 | 000,026,040 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalMonospace.CompositeFont
[2006/06/29 14:53:56 | 000,026,489 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSansSerif.CompositeFont
[2006/04/18 15:39:28 | 000,029,779 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalSerif.CompositeFont
[2006/06/29 14:58:52 | 000,030,808 | ---- | M] () -- C:\WINDOWS\Fonts\GlobalUserInterface.CompositeFont
< %systemroot%\Fonts\*.dll >
< %systemroot%\Fonts\*.ini >
[2009/11/25 23:10:28 | 000,000,067 | -HS- | M] () -- C:\WINDOWS\Fonts\desktop.ini
< %systemroot%\Fonts\*.ini2 >
< %systemroot%\Fonts\*.exe >
< %systemroot%\system32\spool\prtprocs\w32x86\*.* >
[2011/03/01 17:54:12 | 000,051,200 | ---- | M] (Eastman Kodak Company) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\EKAiO2PPR.dll
[2008/07/06 08:06:10 | 000,089,088 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\filterpipelineprintproc.dll
[2009/10/16 17:07:26 | 000,155,648 | ---- | M] () -- C:\WINDOWS\system32\spool\prtprocs\w32x86\lxdudrpp.dll
[2008/07/06 06:50:03 | 000,597,504 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\spool\prtprocs\w32x86\printfilterpipelinesvc.exe
< %systemroot%\REPAIR\*.bak1 >
< %systemroot%\REPAIR\*.ini >
< %systemroot%\system32\*.jpg >
< %systemroot%\*.jpg >
< %systemroot%\*.png >
< %systemroot%\*.scr >
[2010/04/17 00:04:40 | 000,306,032 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\WLXPGSS.SCR
< %systemroot%\*._sy >
< %APPDATA%\Adobe\Update\*.* >
< %ALLUSERSPROFILE%\Favorites\*.* >
< %APPDATA%\Microsoft\*.* >
< %PROGRAMFILES%\*.* >
< %APPDATA%\Update\*.* >
< %PROGRAMFILES%\bak. /s >
< %systemroot%\system32\bak. /s >
< %ALLUSERSPROFILE%\Start Menu\*.lnk /x >
[2009/11/25 23:11:21 | 000,000,294 | -HS- | M] () -- C:\Documents and Settings\All Users\Start Menu\desktop.ini
< %systemroot%\system32\config\systemprofile\*.dat /x >
< %systemroot%\*.config >
< %systemroot%\system32\*.db >
[2008/06/23 18:36:24 | 000,773,120 | ---- | M] () -- C:\WINDOWS\system32\NEROINSTAEC43759.DB
[7 C:\WINDOWS\system32\*.tmp files -> C:\WINDOWS\system32\*.tmp -> ]
< %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x >
[2010/12/08 09:26:47 | 000,000,101 | ---- | M] () -- C:\Documents and Settings\Billy\Application Data\Microsoft\Internet Explorer\Quick Launch\$39.00 PM.URL
[2009/06/09 11:41:42 | 000,000,119 | -HS- | M] () -- C:\Documents and Settings\Billy\Application Data\Microsoft\Internet Explorer\Quick Launch\desktop.ini
< %USERPROFILE%\Desktop\*.exe >
[2010/01/08 14:13:24 | 001,146,184 | ---- | M] (Microsoft Corporation) -- C:\Documents and Settings\Billy\Desktop\setup-windows live.exe
< %PROGRAMFILES%\Common Files\*.* >
< %systemroot%\*.src >
< %systemroot%\install\*.* >
< %systemroot%\system32\DLL\*.* >
< %systemroot%\system32\HelpFiles\*.* >
< %systemroot%\system32\rundll\*.* >
< %systemroot%\winn32\*.* >
< %systemroot%\Java\*.* >
< %systemroot%\system32\test\*.* >
< %systemroot%\system32\Rundll32\*.* >
< %systemroot%\AppPatch\Custom\*.* >
[2010/04/08 19:21:44 | 000,000,698 | ---- | M] () -- C:\WINDOWS\AppPatch\Custom\{a9264802-8a7a-40fe-a135-5c6d204aed7a}.sdb
< %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x >
< %PROGRAMFILES%\PC-Doctor\Downloads\*.* >
< %PROGRAMFILES%\Internet Explorer\*.tmp >
< %PROGRAMFILES%\Internet Explorer\*.dat >
< %USERPROFILE%\My Documents\*.exe >
< %USERPROFILE%\*.exe >
< %systemroot%\ADDINS\*.* >
< %systemroot%\assembly\*.bak2 >
< %systemroot%\Config\*.* >
< %systemroot%\REPAIR\*.bak2 >
< %systemroot%\SECURITY\Database\*.sdb /x >
< %systemroot%\SYSTEM\*.bak2 >
< %systemroot%\Web\*.bak2 >
< %systemroot%\Driver Cache\*.* >
< %PROGRAMFILES%\Mozilla Firefox\*.exe >
[2011/03/24 00:06:03 | 000,107,480 | ---- | M] (Mozilla Foundation) -- C:\Program Files\Mozilla Firefox\crashreporter.exe
[2011/03/24 00:06:04 | 000,912,344 | ---- | M] (Mozilla Corporation) -- C:\Program Files\Mozilla Firefox\firefox.exe
[2011/03/24 00:06:06 | 000,016,856 | ---- | M] (Mozilla Corporation) -- C:\Program Files\Mozilla Firefox\plugin-container.exe
[2011/03/24 00:06:07 | 000,245,208 | ---- | M] (Mozilla Foundation) -- C:\Program Files\Mozilla Firefox\updater.exe
< %ProgramFiles%\Microsoft Common\*.* >
< %ProgramFiles%\TinyProxy. >
< %USERPROFILE%\Favorites\*.url /x >
[2009/06/08 19:23:21 | 000,000,122 | -HS- | M] () -- C:\Documents and Settings\Billy\Favorites\Desktop.ini
< %systemroot%\system32\*.bk >
< %systemroot%\*.te >
< %systemroot%\system32\system32\*.* >
< %ALLUSERSPROFILE%\*.dat /x >
[2011/02/27 00:05:00 | 000,000,252 | ---- | M] () -- C:\Documents and Settings\All Users\FastPics.log
[2009/11/06 13:38:03 | 093,226,280 | ---- | M] (Apple Inc.) -- C:\Documents and Settings\All Users\iTunesSetup.exe
[2011/03/13 13:52:58 | 000,002,756 | ---- | M] () -- C:\Documents and Settings\All Users\lxdu.log
[2011/02/27 00:12:20 | 000,000,496 | ---- | M] () -- C:\Documents and Settings\All Users\lxduDiagnostics.log
[2011/02/13 13:21:14 | 000,374,668 | ---- | M] () -- C:\Documents and Settings\All Users\lxduJSW.log
[2009/06/30 20:08:05 | 000,000,000 | ---- | M] () -- C:\Documents and Settings\All Users\UpdaterLog.txt
< %systemroot%\*. /mp /s >
< %systemroot%\system32\*.dll /lockedfiles >
< %systemroot%\system32\*.exe /lockedfiles >
< %systemroot%\system32\drivers\*.sys /lockedfiles >
< %systemroot%\System32\config\*.sav >
[2009/11/25 17:56:35 | 000,524,288 | ---- | M] () -- C:\WINDOWS\system32\config\default.sav
[2009/11/25 22:45:45 | 000,057,344 | ---- | M] () -- C:\WINDOWS\system32\config\security.sav
[2009/11/25 17:56:35 | 029,548,544 | ---- | M] () -- C:\WINDOWS\system32\config\software.sav
[2009/11/25 17:56:37 | 005,242,880 | ---- | M] () -- C:\WINDOWS\system32\config\system.sav
< %systemroot%\system32\*.sys >
[2008/08/21 08:00:00 | 000,009,029 | ---- | M] () -- C:\WINDOWS\system32\ansi.sys
[2008/08/21 08:00:00 | 000,027,097 | ---- | M] () -- C:\WINDOWS\system32\country.sys
[2008/08/21 08:00:00 | 000,004,768 | ---- | M] () -- C:\WINDOWS\system32\himem.sys
[2008/08/21 08:00:00 | 000,042,809 | ---- | M] () -- C:\WINDOWS\system32\key01.sys
[2008/08/21 08:00:00 | 000,042,537 | ---- | M] () -- C:\WINDOWS\system32\keyboard.sys
[2008/08/21 08:00:00 | 000,027,866 | ---- | M] () -- C:\WINDOWS\system32\ntdos.sys
[2008/08/21 08:00:00 | 000,029,146 | ---- | M] () -- C:\WINDOWS\system32\ntdos404.sys
[2008/08/21 08:00:00 | 000,029,370 | ---- | M] () -- C:\WINDOWS\system32\ntdos411.sys
[2008/08/21 08:00:00 | 000,029,274 | ---- | M] () -- C:\WINDOWS\system32\ntdos412.sys
[2008/08/21 08:00:00 | 000,029,146 | ---- | M] () -- C:\WINDOWS\system32\ntdos804.sys
[2008/08/21 08:00:00 | 000,033,840 | ---- | M] () -- C:\WINDOWS\system32\ntio.sys
[2008/08/21 08:00:00 | 000,034,560 | ---- | M] () -- C:\WINDOWS\system32\ntio404.sys
[2008/08/21 08:00:00 | 000,035,648 | ---- | M] () -- C:\WINDOWS\system32\ntio411.sys
[2008/08/21 08:00:00 | 000,035,424 | ---- | M] () -- C:\WINDOWS\system32\ntio412.sys
[2008/08/21 08:00:00 | 000,034,560 | ---- | M] () -- C:\WINDOWS\system32\ntio804.sys
[2008/08/21 08:00:00 | 000,017,664 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\watchdog.sys
[2010/12/31 09:10:33 | 001,854,976 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\win32k.sys
< %systemroot%\system32\drivers\*.dll >
[2006/02/21 20:09:36 | 000,040,960 | ---- | M] (ATI Technologies Inc.) -- C:\WINDOWS\system32\drivers\ati2erec.dll
[2008/04/14 06:41:56 | 000,021,504 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\drivers\hidserv.dll
< %systemroot%\system32\drivers\*.ini >
< %systemroot%\system32\drivers\*.exe >
< %systemroot%\system32\Spool\prtprocs\w32x86\*.dll >
< %SYSTEMDRIVE%\*.* >
[2008/08/21 08:00:00 | 000,260,288 | R--- | M] () -- C:\$LDR$
[2009/03/13 03:12:39 | 000,000,000 | ---- | M] () -- C:\AUTOEXEC.BAT
[2009/11/25 23:05:48 | 000,000,211 | -HS- | M] () -- C:\boot.ini
[2008/12/15 19:46:00 | 000,057,856 | ---- | M] () -- C:\CabExtractor.exe
[2009/03/13 03:12:39 | 000,000,000 | ---- | M] () -- C:\CONFIG.SYS
[2009/03/12 14:31:51 | 000,000,168 | ---- | M] () -- C:\DeleteContent.bat
[2011/02/15 16:06:35 | 000,000,269 | ---- | M] () -- C:\faxfile.log
[2009/03/13 03:12:39 | 000,000,000 | RHS- | M] () -- C:\IO.SYS
[2010/06/05 14:47:22 | 000,001,363 | -H-- | M] () -- C:\IPH.PH
[2011/04/06 22:19:50 | 000,020,311 | ---- | M] () -- C:\JavaRa.log
[2009/10/27 08:32:50 | 000,000,086 | ---- | M] () -- C:\lxdujswx.log
[2009/03/13 03:12:39 | 000,000,000 | RHS- | M] () -- C:\MSDOS.SYS
[2008/08/21 08:00:00 | 000,047,564 | RHS- | M] () -- C:\NTDETECT.COM
[2008/08/21 08:00:00 | 000,250,048 | RHS- | M] () -- C:\ntldr
[2011/04/07 00:31:38 | 805,306,368 | -HS- | M] () -- C:\pagefile.sys
[2008/08/21 08:00:00 | 000,480,367 | R--- | M] () -- C:\txtsetup.sif
< %PROGRAMFILES%\*. >
[2010/11/29 13:09:56 | 000,000,000 | ---D | M] -- C:\Program Files\Abbyy FineReader 6.0 Sprint
[2009/03/13 03:51:50 | 000,000,000 | ---D | M] -- C:\Program Files\Activation Assistant for the 2007 Microsoft Office suites
[2011/04/06 22:30:27 | 000,000,000 | ---D | M] -- C:\Program Files\Adobe
[2009/11/05 20:25:32 | 000,000,000 | ---D | M] -- C:\Program Files\Apple Software Update
[2010/10/05 18:42:52 | 000,000,000 | ---D | M] -- C:\Program Files\Avira
[2011/02/26 19:53:15 | 000,000,000 | ---D | M] -- C:\Program Files\Bonjour
[2011/03/26 00:36:32 | 000,000,000 | ---D | M] -- C:\Program Files\CheckPoint
[2011/03/26 13:43:14 | 000,000,000 | ---D | M] -- C:\Program Files\Cisco Systems
[2011/04/06 22:30:27 | 000,000,000 | ---D | M] -- C:\Program Files\Common Files
[2011/03/26 00:36:57 | 000,000,000 | ---D | M] -- C:\Program Files\Conduit
[2011/02/26 19:55:45 | 000,000,000 | ---D | M] -- C:\Program Files\Google
[2010/12/21 03:31:44 | 000,000,000 | ---D | M] -- C:\Program Files\InstallShield Installation Information
[2011/02/10 03:04:20 | 000,000,000 | ---D | M] -- C:\Program Files\Internet Explorer
[2010/09/29 09:40:11 | 000,000,000 | ---D | M] -- C:\Program Files\iPod
[2010/09/29 09:41:49 | 000,000,000 | ---D | M] -- C:\Program Files\iTunes
[2011/01/15 17:48:34 | 000,000,000 | ---D | M] -- C:\Program Files\Java
[2009/06/27 00:25:05 | 000,000,000 | ---D | M] -- C:\Program Files\K-Lite Codec Pack
[2011/03/23 22:45:10 | 000,000,000 | ---D | M] -- C:\Program Files\Kodak
[2011/03/01 13:16:52 | 000,000,000 | ---D | M] -- C:\Program Files\Lexmark 5600-6600 Series
[2011/02/27 00:44:05 | 000,000,000 | ---D | M] -- C:\Program Files\Lexmark Printable Web
[2011/02/27 00:04:12 | 000,000,000 | ---D | M] -- C:\Program Files\Lexmark Toolbar
[2010/11/29 12:58:28 | 000,000,000 | ---D | M] -- C:\Program Files\Lexmark Tools for Office
[2010/04/18 13:38:59 | 000,000,000 | ---D | M] -- C:\Program Files\Logitech
[2010/12/21 03:30:31 | 000,000,000 | ---D | M] -- C:\Program Files\Maxtor
[2011/04/06 22:25:08 | 000,000,000 | ---D | M] -- C:\Program Files\McAfee Security Scan
[2009/06/09 14:39:13 | 000,000,000 | ---D | M] -- C:\Program Files\Messenger
[2011/03/26 13:20:54 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft
[2009/03/13 03:13:09 | 000,000,000 | ---D | M] -- C:\Program Files\microsoft frontpage
[2010/10/11 02:38:30 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Money 2006
[2009/03/13 03:45:47 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Office
[2010/01/08 14:26:27 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Office Outlook Connector
[2011/02/22 21:57:05 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Silverlight
[2009/03/13 03:50:05 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Small Business
[2011/04/07 00:27:55 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft SQL Server
[2010/01/08 14:23:29 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft SQL Server Compact Edition
[2010/01/08 14:25:01 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Sync Framework
[2009/03/13 03:22:54 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Visual Studio
[2009/10/29 07:26:30 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Windows 7 Upgrade Advisor
[2009/10/27 08:13:35 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Works
[2009/03/13 03:45:46 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft.NET
[2010/08/12 02:03:29 | 000,000,000 | ---D | M] -- C:\Program Files\Movie Maker
[2011/03/28 12:51:42 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox
[2009/08/09 03:16:40 | 000,000,000 | ---D | M] -- C:\Program Files\MSBuild
[2010/01/27 00:01:26 | 000,000,000 | ---D | M] -- C:\Program Files\MSN
[2009/03/13 03:08:10 | 000,000,000 | ---D | M] -- C:\Program Files\MSN Gaming Zone
[2011/03/23 02:08:46 | 000,000,000 | ---D | M] -- C:\Program Files\MSN Toolbar
[2010/01/27 00:01:09 | 000,000,000 | ---D | M] -- C:\Program Files\MSN Toolbar Installer
[2009/06/14 03:04:19 | 000,000,000 | ---D | M] -- C:\Program Files\MSXML 6.0
[2009/03/13 03:10:01 | 000,000,000 | ---D | M] -- C:\Program Files\NetMeeting
[2009/03/13 03:10:23 | 000,000,000 | ---D | M] -- C:\Program Files\Online Services
[2010/12/15 11:22:26 | 000,000,000 | ---D | M] -- C:\Program Files\Outlook Express
[2011/02/26 19:53:26 | 000,000,000 | ---D | M] -- C:\Program Files\QuickTime
[2009/08/09 03:16:17 | 000,000,000 | ---D | M] -- C:\Program Files\Reference Assemblies
[2010/09/08 08:22:09 | 000,000,000 | ---D | M] -- C:\Program Files\Safari
[2011/02/28 09:20:03 | 000,000,000 | ---D | M] -- C:\Program Files\ScottradeELITE
[2010/10/28 19:25:13 | 000,000,000 | ---D | M] -- C:\Program Files\Seagate
[2009/09/13 22:50:47 | 000,000,000 | ---D | M] -- C:\Program Files\Viewpoint
[2009/06/09 23:51:13 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Defender
[2010/11/06 13:13:24 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Live
[2010/09/06 22:20:16 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Live Safety Center
[2010/01/30 18:47:57 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Live SkyDrive
[2009/11/15 14:52:00 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Media Connect 2
[2011/02/26 19:53:30 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Media Player
[2009/03/13 03:08:05 | 000,000,000 | ---D | M] -- C:\Program Files\Windows NT
[2009/03/13 03:13:09 | 000,000,000 | ---D | M] -- C:\Program Files\xerox
< %appdata%\*.* >
[2009/12/10 01:54:39 | 000,000,092 | ---- | M] () -- C:\Documents and Settings\Billy\Application Data\default.pls
[2009/03/12 19:02:00 | 000,000,062 | -HS- | M] () -- C:\Documents and Settings\Billy\Application Data\desktop.ini
[2009/06/27 00:19:43 | 000,000,036 | -H-- | M] () -- C:\Documents and Settings\Billy\Application Data\swk.ini
< MD5 for: AGP440.SYS >
[2008/08/21 08:00:00 | 020,056,462 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp3.cab:AGP440.sys
[2008/08/21 08:00:00 | 020,056,462 | ---- | M] () .cab file -- C:\WINDOWS\I386\sp3.cab:AGP440.sys
[2008/04/13 20:06:40 | 000,042,368 | ---- | M] (Microsoft Corporation) MD5=08FD04AA961BDC77FB983F328334E3D7 -- C:\WINDOWS\system32\drivers\AGP440.SYS
< MD5 for: ATAPI.SYS >
[2008/08/21 08:00:00 | 020,056,462 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp3.cab:atapi.sys
[2008/08/21 08:00:00 | 020,056,462 | ---- | M] () .cab file -- C:\WINDOWS\I386\sp3.cab:atapi.sys
[2008/08/21 08:00:00 | 000,096,512 | ---- | M] (Microsoft Corporation) MD5=9F3A2F5AA6875C72BF062C712CFA2674 -- C:\WINDOWS\system32\drivers\atapi.sys
< MD5 for: DISK.SYS >
[2008/08/21 08:00:00 | 020,056,462 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp3.cab:disk.sys
[2008/08/21 08:00:00 | 020,056,462 | ---- | M] () .cab file -- C:\WINDOWS\I386\sp3.cab:disk.sys
[2008/08/21 08:00:00 | 000,036,352 | ---- | M] (Microsoft Corporation) MD5=044452051F3E02E7963599FC8F4F3E25 -- C:\WINDOWS\system32\drivers\disk.sys
< MD5 for: EVENTLOG.DLL >
[2008/08/21 08:00:00 | 000,056,320 | ---- | M] (Microsoft Corporation) MD5=6D4FEB43EE538FC5428CC7F0565AA656 -- C:\WINDOWS\system32\dllcache\eventlog.dll
[2008/08/21 08:00:00 | 000,056,320 | ---- | M] (Microsoft Corporation) MD5=6D4FEB43EE538FC5428CC7F0565AA656 -- C:\WINDOWS\system32\eventlog.dll
< MD5 for: NETLOGON.DLL >
[2008/08/21 08:00:00 | 000,407,040 | ---- | M] (Microsoft Corporation) MD5=1B7F071C51B77C272875C3A23E1E4550 -- C:\WINDOWS\system32\dllcache\netlogon.dll
[2008/08/21 08:00:00 | 000,407,040 | ---- | M] (Microsoft Corporation) MD5=1B7F071C51B77C272875C3A23E1E4550 -- C:\WINDOWS\system32\netlogon.dll
< MD5 for: SCECLI.DLL >
[2008/08/21 08:00:00 | 000,181,248 | ---- | M] (Microsoft Corporation) MD5=A86BB5E61BF3E39B62AB4C7E7085A084 -- C:\WINDOWS\system32\dllcache\scecli.dll
[2008/08/21 08:00:00 | 000,181,248 | ---- | M] (Microsoft Corporation) MD5=A86BB5E61BF3E39B62AB4C7E7085A084 -- C:\WINDOWS\system32\scecli.dll
< MD5 for: USBSTOR.SYS >
[2008/08/21 08:00:00 | 020,056,462 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp3.cab:usbstor.sys
[2008/08/21 08:00:00 | 020,056,462 | ---- | M] () .cab file -- C:\WINDOWS\I386\sp3.cab:usbstor.sys
[2008/08/21 08:00:00 | 000,026,368 | ---- | M] (Microsoft Corporation) MD5=A32426D9B14A089EAA1D922E0C5801A9 -- C:\WINDOWS\system32\drivers\usbstor.sys
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install\\LastSuccessTime: 2011-04-07 04:28:28
[b]
Staples
Posts Posts : 14
OS OS : XP Pro
Re: Bumpng it Hotfix.exe still a problem
Post by Sneakyone on 9th April 2011, 4:00 am
Please run OTL.exe.
    :OTL
    :commands
    [emptytemp]
    [resethosts]
  • Close OTL.exe
Sneakyone
Posts Posts : 2707
Joined Joined : 2010-01-10
Points Points : 56094
Post by Staples on 11th April 2011, 2:48 am
Thanks so much for taking my case. I feel like a client talking to his attorney.
I dont to screw it up before I start so I must ask.
After I run the OTL as shown, do you want me to post it and than do the Combofix.exe thing?
I am not sure if you want to see the OTL reports first.
Yeah, I'm a bit anal, but I confuse easily.
Staples
Staples
Posts Posts : 14
Joined Joined : 2011-04-07
OS OS : XP Pro
Points Points : 20884
Post by Staples on 13th April 2011, 5:56 am
OK, phase 1, as fr as I understand is complete, ran the otl suggestion and pasted results following.
will do combofix when hear back or in the morning
thanks
Staples
All processes killed
========== OTL ==========
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}\ not found.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5C255C8A-E604-49b4-9D64-90988571CECB}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{5C255C8A-E604-49b4-9D64-90988571CECB}\ not found.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{8A4A36C2-0535-4D2C-BD3D-496CB7EED6E3}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{8A4A36C2-0535-4D2C-BD3D-496CB7EED6E3}\ not found.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{91da5e8a-3318-4f8c-b67e-5964de3ab546}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{91da5e8a-3318-4f8c-b67e-5964de3ab546}\ not found.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{d2ce3e00-f94a-4740-988e-03dc2f38c34f}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{d2ce3e00-f94a-4740-988e-03dc2f38c34f}\ not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\{8dcb7100-df86-4384-8842-8fa844297b3f} not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{8dcb7100-df86-4384-8842-8fa844297b3f}\ not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\{91da5e8a-3318-4f8c-b67e-5964de3ab546} not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}\ not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\{EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107} not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{EE2AC4E5-B0B0-4EC6-88A9-BCA1A32AB107}\ not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\Locked not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{1017A80C-6F09-4548-A84D-EDD6AC9525F0} not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{1017A80C-6F09-4548-A84D-EDD6AC9525F0}\ not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{604BC32A-9680-40D1-9AC6-E06B23A1BA4C} not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{604BC32A-9680-40D1-9AC6-E06B23A1BA4C}\ not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\EfficientCalendarFree not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\UserFaultCheck not found.
Starting removal of ActiveX control {E2883E8F-472F-4FB0-9522-AC9BF37916A7}
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{E2883E8F-472F-4FB0-9522-AC9BF37916A7}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{b51efbd2-5a87-11de-897b-00096b76a610}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{b51efbd2-5a87-11de-897b-00096b76a610}\ not found.
File E:\StormF1.exe not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{b51efbd3-5a87-11de-897b-00096b76a610}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{b51efbd3-5a87-11de-897b-00096b76a610}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{b8bf7fab-633d-11de-8981-00096b76a610}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{b8bf7fab-633d-11de-8981-00096b76a610}\ not found.
File F:\StormF1.exe not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2\{dcada168-6279-11de-897c-00096b76a610}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{dcada168-6279-11de-897c-00096b76a610}\ not found.
[EMPTYTEMP]
User: All Users
User: Billy
->Temp folder emptied: 1811219 bytes
->Temporary Internet Files folder emptied: 501412 bytes
->Java cache emptied: 17847732 bytes
->FireFox cache emptied: 115718088 bytes
->Google Chrome cache emptied: 24523215 bytes
->Apple Safari cache emptied: 0 bytes
->Flash cache emptied: 2191 bytes
User: Default User
->Temporary Internet Files folder emptied: 65804 bytes
->Flash cache emptied: 56466 bytes
User: LocalService
->Temp folder emptied: 1056792 bytes
->Temporary Internet Files folder emptied: 439666 bytes
User: NetworkService
->Temp folder emptied: 3300236 bytes
->Temporary Internet Files folder emptied: 65938 bytes
%systemroot% .tmp files removed: 4803252 bytes
%systemroot%\System32 .tmp files removed: 6444049 bytes
Windows Temp folder emptied: 4031 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 62244408 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33170 bytes
RecycleBin emptied: 46103 bytes
Total Files Cleaned = 228.00 mb
C:\WINDOWS\System32\drivers\etc\Hosts moved successfully.
HOSTS file reset successfully
OTL by OldTimer - Version 3.2.22.3 log created on 04132011_013754
Staples
Posts Posts : 14
OS OS : XP Pro
Post by Staples on 14th April 2011, 7:20 pm
Sneakyone:
following is the combo fix report
As an FYI. I had many errors, blue screens, dark screens with monitor going dark that is. I either waited and waited or pushed on/off button a number of times.
I had seemingly been frozen many times and had to hit
control/alt/delete a few times, only to see the task mgr tell me that 'autoscan' is running. Most of the time with extremely high Cpu usage
I tried as best I could to write down the number of errors or notices or any type of info that showed on the screen
I am not going to try and even decipher them or list them unless you ask for what I was able to get.
This I can say, I left the PC running last night with a blue screen as the task mgr said that autoscan was running as before. when I went back this morning, there was no change.
I hope this report as well as the previously post OTL one can give some insight into this mess of mine.
I look forward to your reply
ComboFix 11-04-13.03 - Billy 04/14/2011 1:16.1.1 - x86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.511.147 [GMT -4:00]
Running from: c:\documents and settings\Billy\desktop\commy.exe
AV: AntiVir Desktop *Disabled/Updated* {AD166499-45F9-482A-A743-FDD3350758C7}
FW: ZoneAlarm Firewall *Enabled* {829BDA32-94B3-44F4-8446-F8FCFF809F8B}
c:\windows\Downloaded Program Files\Temp
c:\windows\RegGenieOnUninstall.exe
c:\windows\sqlite3.dll
c:\windows\system\oeminfo.ini
c:\windows\system32\arp.exe
c:\windows\system32\SCardSvr.exe
c:\windows\system32\setup.exe
c:\windows\regedit.exe . . . is infected!! . . .Failed to restore. Attempting to replace on reboot
Infected copy of c:\windows\regedit.exe was found and disinfected
Restored copy from - c:\system volume information\_restore{6BCB7078-80B8-4D50-8C23-6D3BAEE2FE8F}\RP637\A0104574.exe
((((((((((((((((((((((((( Files Created from 2011-03-14 to 2011-04-14 )))))))))))))))))))))))))))))))
2011-04-13 05:12 . 2011-04-13 05:12 -------- dc----w- C:\_OTL
2011-04-10 18:14 . 2011-04-10 18:14 -------- d-----w- c:\documents and settings\NetworkService\Application Data\McAfee
2011-04-08 12:18 . 2011-03-23 14:11 6792528 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Windows Defender\Definition Updates\{72EBDA2E-EF20-4A4E-8AF9-33A21A4B8FDB}\mpengine.dll
2011-04-07 02:30 . 2011-04-07 02:30 -------- d-----w- c:\program files\Common Files\Adobe
2011-04-07 02:25 . 2011-04-07 02:25 -------- d-----w- c:\program files\Common Files\Adobe AIR
2011-04-07 02:25 . 2011-04-07 02:25 -------- dc----w- c:\documents and settings\All Users\Application Data\McAfee Security Scan
2011-04-07 02:25 . 2011-04-10 18:13 -------- d-----w- c:\program files\McAfee Security Scan
2011-04-07 02:00 . 2011-04-07 02:00 -------- d-----w- c:\program files\Common Files\Java
2011-04-07 01:58 . 2011-04-07 01:58 73728 ----a-w- c:\windows\system32\javacpl.cpl
2011-04-05 15:53 . 2011-04-05 15:53 -------- d-----w- c:\documents and settings\Billy\Local Settings\Application Data\PCHealth
2011-03-26 19:01 . 2011-03-26 19:01 -------- d-----w- c:\windows\system32\wbem\Repository
2011-03-26 18:47 . 2011-03-26 18:47 -------- d-----w- c:\windows\Internet Logs
2011-03-26 04:38 . 2011-03-28 04:31 -------- d-----w- c:\documents and settings\Billy\Application Data\CheckPoint
2011-03-26 04:36 . 2011-03-26 04:36 -------- d-----w- c:\program files\Conduit
2011-03-26 04:36 . 2011-03-26 04:36 -------- d-----w- c:\program files\CheckPoint
2011-03-25 03:04 . 2011-03-25 03:04 -------- d-----w- c:\documents and settings\LocalService\Application Data\Temp
2011-03-24 02:58 . 2011-03-24 03:59 -------- d-----w- c:\documents and settings\Billy\Local Settings\Application Data\Eastman_Kodak_Company
2011-03-24 02:54 . 2011-03-24 02:54 -------- d-----w- c:\documents and settings\Billy\Local Settings\Application Data\Eastman Kodak Company
2011-03-24 02:51 . 2011-03-24 02:51 -------- d-----w- c:\windows\system32\kodak
2011-03-24 02:49 . 2011-03-01 21:54 51200 ----a-w- c:\windows\system32\Spool\prtprocs\w32x86\EKAiO2PPR.dll
2011-03-24 02:49 . 2011-03-01 21:47 126464 ----a-w- c:\windows\system32\EKAiO2COI03.dll
2011-03-24 02:49 . 2011-03-01 21:47 611328 ----a-w- c:\windows\system32\EKAiO2MON.dll
2011-03-24 02:41 . 2011-03-24 02:45 -------- d-----w- c:\program files\Kodak
2011-03-24 02:33 . 2011-03-24 02:33 -------- d-----w- c:\documents and settings\Billy\Application Data\Temp
2011-03-24 02:33 . 2011-04-14 16:12 -------- dc----w- c:\documents and settings\All Users\Application Data\Kodak
2011-04-07 01:58 . 2010-05-18 16:30 472808 ----a-w- c:\windows\system32\deployJava1.dll
2011-03-29 15:21 . 2010-04-18 17:53 16400 ----a-w- c:\windows\system32\drivers\LNonPnP.sys
2011-03-23 14:11 . 2009-06-10 03:52 6792528 ----a-w- c:\documents and settings\All Users\Application Data\Microsoft\Windows Defender\Definition Updates\Backup\mpengine.dll
2011-03-17 06:20 . 2010-10-05 22:43 137656 ----a-w- c:\windows\system32\drivers\avipbb.sys
2011-02-09 13:53 . 2008-08-21 12:00 270848 ----a-w- c:\windows\system32\sbe.dll
2011-02-09 13:53 . 2008-08-21 12:00 186880 ----a-w- c:\windows\system32\encdec.dll
2011-02-02 22:11 . 2009-10-16 18:05 222080 ------w- c:\windows\system32\MpSigStub.exe
2011-02-02 07:58 . 2009-03-13 07:07 2067456 ----a-w- c:\windows\system32\mstscax.dll
2011-01-27 11:57 . 2009-03-13 07:07 677888 ----a-w- c:\windows\system32\mstsc.exe
2011-01-21 14:44 . 2008-08-21 12:00 439296 ----a-w- c:\windows\system32\shimgvw.dll
------- Sigcheck -------
[-] 2008-08-21 . 9F3A2F5AA6875C72BF062C712CFA2674 . 96512 . . [5.1.2600.5512] . . c:\windows\system32\drivers\atapi.sys
[-] 2008-08-21 . B153AFFAC761E7F5FCFA822B9C4E97BC . 14336 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\asyncmac.sys
[-] 2008-08-21 . B153AFFAC761E7F5FCFA822B9C4E97BC . 14336 . . [5.1.2600.5512] . . c:\windows\system32\drivers\asyncmac.sys
[-] 2008-08-21 . DA1F27D85E0D1525F6621372E7B685E9 . 4224 . . [5.1.2600.0] . . c:\windows\system32\dllcache\beep.sys
[-] 2008-08-21 . DA1F27D85E0D1525F6621372E7B685E9 . 4224 . . [5.1.2600.0] . . c:\windows\system32\drivers\beep.sys
[-] 2008-04-14 . 463C1EC80CD17420A542B7F36A36F128 . 24576 . . [5.1.2600.5512] . . c:\windows\system32\ReinstallBackups\0005\DriverFiles\i386\kbdclass.sys
[-] 2008-04-14 . 463C1EC80CD17420A542B7F36A36F128 . 24576 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\kbdclass.sys
[-] 2008-04-14 . 463C1EC80CD17420A542B7F36A36F128 . 24576 . . [5.1.2600.5512] . . c:\windows\system32\drivers\kbdclass.sys
[-] 2008-08-21 . 1DF7F42665C94B825322FAE71721130D . 182656 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ndis.sys
[-] 2008-08-21 . 1DF7F42665C94B825322FAE71721130D . 182656 . . [5.1.2600.5512] . . c:\windows\system32\drivers\ndis.sys
[-] 2008-08-21 . 78A08DD6A8D65E697C18E1DB01C5CDCA . 574976 . . [5.1.2600.5512] . . c:\windows\I386\NTFS.SYS
[-] 2008-08-21 . 78A08DD6A8D65E697C18E1DB01C5CDCA . 574976 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ntfs.sys
[-] 2008-08-21 . 78A08DD6A8D65E697C18E1DB01C5CDCA . 574976 . . [5.1.2600.5512] . . c:\windows\system32\drivers\ntfs.sys
[-] 2008-08-21 . 73C1E1F395918BC2C6DD67AF7591A3AD . 2944 . . [5.1.2600.0] . . c:\windows\system32\dllcache\null.sys
[-] 2008-08-21 . 73C1E1F395918BC2C6DD67AF7591A3AD . 2944 . . [5.1.2600.0] . . c:\windows\system32\drivers\null.sys
[-] 2008-08-21 . 93EA8D04EC73A85DB02EB8805988F733 . 361344 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB951748$\tcpip.sys
[-] 2008-06-20 . AD978A1B783B5719720CFF204B666C8E . 361600 . . [5.1.2600.5625] . . c:\windows\$hf_mig$\KB951748\SP3QFE\tcpip.sys
[-] 2008-06-20 . AD978A1B783B5719720CFF204B666C8E . 361600 . . [5.1.2600.5625] . . c:\windows\SoftwareDistribution\Download\ff0686f2f699fa07ed5ad0848fa3055b\sp3qfe\tcpip.sys
[-] 2008-06-20 . 9AEFA14BD6B182D61E3119FA5F436D3D . 361600 . . [5.1.2600.5625] . . c:\windows\system32\dllcache\tcpip.sys
[-] 2008-06-20 . 9AEFA14BD6B182D61E3119FA5F436D3D . 361600 . . [5.1.2600.5625] . . c:\windows\system32\drivers\tcpip.sys
[-] 2008-08-21 . A06CE3399D16DB864F55FAEB1F1927A9 . 77824 . . [5.1.2600.5512] . . c:\windows\system32\browser.dll
[-] 2008-08-21 . A06CE3399D16DB864F55FAEB1F1927A9 . 77824 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\browser.dll
[-] 2008-08-21 . BF2466B3E18E970D8A976FB95FC1CA85 . 13312 . . [5.1.2600.5512] . . c:\windows\system32\lsass.exe
[-] 2008-08-21 . BF2466B3E18E970D8A976FB95FC1CA85 . 13312 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\lsass.exe
[-] 2008-08-21 . 13E67B55B3ABD7BF3FE7AAE5A0F9A9DE . 198144 . . [5.1.2600.5512] . . c:\windows\system32\netman.dll
[-] 2008-08-21 . 13E67B55B3ABD7BF3FE7AAE5A0F9A9DE . 198144 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\netman.dll
[-] 2008-08-21 12:00 . 1280A158C722FA95A80FB7AEBE78FA7D . 792064 . . [2001.12.4414.700] . . c:\windows\system32\comres.dll
[-] 2008-08-21 12:00 . 1280A158C722FA95A80FB7AEBE78FA7D . 792064 . . [2001.12.4414.700] . . c:\windows\system32\dllcache\comres.dll
[-] 2008-08-21 . 574738F61FCA2935F5265DC4E5691314 . 409088 . . [6.7.2600.5512] . . c:\windows\system32\qmgr.dll
[-] 2008-08-21 . 574738F61FCA2935F5265DC4E5691314 . 409088 . . [6.7.2600.5512] . . c:\windows\system32\dllcache\qmgr.dll
[-] 2009-02-09 . 6B27A5C03DFB94B4245739065431322C . 401408 . . [5.1.2600.5755] . . c:\windows\system32\rpcss.dll
[-] 2009-02-09 . 6B27A5C03DFB94B4245739065431322C . 401408 . . [5.1.2600.5755] . . c:\windows\system32\dllcache\rpcss.dll
[-] 2009-02-09 . 9222562D44021B988B9F9F62207FB6F2 . 401408 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3QFE\rpcss.dll
[-] 2008-08-21 . 2589FE6015A316C0F5D5112B4DA7B509 . 399360 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB956572$\rpcss.dll
[-] 2009-02-06 . 65DF52F5B8B6E9BBD183505225C37315 . 110592 . . [5.1.2600.5755] . . c:\windows\system32\services.exe
[-] 2009-02-06 . 65DF52F5B8B6E9BBD183505225C37315 . 110592 . . [5.1.2600.5755] . . c:\windows\system32\dllcache\services.exe
[-] 2009-02-06 . 020CEAAEDC8EB655B6506B8C70D53BB6 . 110592 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3QFE\services.exe
[-] 2008-08-21 . 0E776ED5F7CC9F94299E70461B7B8185 . 108544 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB956572$\services.exe
[-] 2010-08-17 . 258DD5D4283FD9F9A7166BE9AE45CE73 . 58880 . . [5.1.2600.6024] . . c:\windows\$hf_mig$\KB2347290\SP3QFE\spoolsv.exe
[-] 2010-08-17 . 60784F891563FB1B767F70117FC2428F . 58880 . . [5.1.2600.6024] . . c:\windows\system32\spoolsv.exe
[-] 2010-08-17 . 60784F891563FB1B767F70117FC2428F . 58880 . . [5.1.2600.6024] . . c:\windows\system32\dllcache\spoolsv.exe
[-] 2008-08-21 . D8E14A61ACC1D4A6CD0D38AEBAC7FA3B . 57856 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB2347290$\spoolsv.exe
[-] 2008-08-21 . ED0EF0A136DEC83DF69F04118870003E . 507904 . . [5.1.2600.5512] . . c:\windows\system32\winlogon.exe
[-] 2008-08-21 . ED0EF0A136DEC83DF69F04118870003E . 507904 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\winlogon.exe
[-] 2010-08-23 . 93AFB83FBC1F9443CAC722FCA63D73BF . 617472 . . [5.82] . . c:\windows\system32\comctl32.dll
[-] 2010-08-23 . 93AFB83FBC1F9443CAC722FCA63D73BF . 617472 . . [5.82] . . c:\windows\system32\dllcache\comctl32.dll
[-] 2010-08-23 . 736B12B725AEB2B07F0241A9F680CB10 . 1054208 . . [6.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\comctl32.dll
[-] 2008-08-21 . 06F247492BC786CE5C24A23E178C711A . 617472 . . [5.82] . . c:\windows\$NtUninstallKB2296011$\comctl32.dll
[-] 2008-08-21 . AEF3D788DBF40C7C4D204EA45EB0C505 . 921088 . . [6.0] . . c:\windows\I386\ASMS\6000\MSFT\WINDOWS\COMMON\CONTROLS\COMCTL32.DLL
[-] 2008-08-21 . AEF3D788DBF40C7C4D204EA45EB0C505 . 921088 . . [6.0] . . c:\windows\WinSxS\InstallTemp\62708\comctl32.dll
[-] 2008-08-21 . AEF3D788DBF40C7C4D204EA45EB0C505 . 921088 . . [6.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.0.0_x-ww_1382d70a\comctl32.dll
[-] 2008-08-21 . BD38D1EBE24A46BD3EDA059560AFBA12 . 1054208 . . [6.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
[-] 2008-08-21 . 3D4E199942E29207970E04315D02AD3B . 62464 . . [5.1.2600.5512] . . c:\windows\system32\cryptsvc.dll
[-] 2008-08-21 . 3D4E199942E29207970E04315D02AD3B . 62464 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\cryptsvc.dll
[-] 2008-08-21 12:00 . 19A799805B24990867B00C120D300C3A . 246272 . . [2001.12.4414.701] . . c:\windows\$NtUninstallKB950974$\es.dll
[-] 2008-07-07 20:26 . D4991D98F2DB73C60D042F1AEF79EFAE . 253952 . . [2001.12.4414.706] . . c:\windows\system32\es.dll
[-] 2008-07-07 20:26 . D4991D98F2DB73C60D042F1AEF79EFAE . 253952 . . [2001.12.4414.706] . . c:\windows\system32\dllcache\es.dll
[-] 2008-07-07 20:23 . F17F6226BDC0CD5F0BEF0DAF84D29BEC . 253952 . . [2001.12.4414.706] . . c:\windows\$hf_mig$\KB950974\SP3QFE\es.dll
[-] 2008-08-21 . 0DA85218E92526972A821587E6A8BF8F . 110080 . . [5.1.2600.5512] . . c:\windows\system32\imm32.dll
[-] 2008-08-21 . 0DA85218E92526972A821587E6A8BF8F . 110080 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\imm32.dll
[-] 2009-03-21 . B921FB870C9AC0D509B2CCABBBBE95F3 . 989696 . . [5.1.2600.5781] . . c:\windows\system32\kernel32.dll
[-] 2009-03-21 . B921FB870C9AC0D509B2CCABBBBE95F3 . 989696 . . [5.1.2600.5781] . . c:\windows\system32\dllcache\kernel32.dll
[-] 2009-03-21 . DA11D9D6ECBDF0F93436A4B7C13F7BEC . 991744 . . [5.1.2600.5781] . . c:\windows\$hf_mig$\KB959426\SP3QFE\kernel32.dll
[-] 2008-08-21 . C24B983D211C34DA8FCC1AC38477971D . 989696 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB959426$\kernel32.dll
[-] 2008-08-21 . 2DC5A8019E2387987905F77C664E4BE2 . 19968 . . [5.1.2600.5512] . . c:\windows\system32\linkinfo.dll
[-] 2008-08-21 . 2DC5A8019E2387987905F77C664E4BE2 . 19968 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\linkinfo.dll
[-] 2008-08-21 . 012DF358CEBAA23ACB26D82077820817 . 22016 . . [5.1.2600.5512] . . c:\windows\system32\lpk.dll
[-] 2008-08-21 . 012DF358CEBAA23ACB26D82077820817 . 22016 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\lpk.dll
[-] 2011-02-22 . 3422847AA07E37076A87D0B7D5044DC6 . 5964800 . . [8.00.6001.23141] . . c:\windows\SoftwareDistribution\Download\4a68e5ecf881bfdf9f622e39f79b4af0\SP3QFE\mshtml.dll
[-] 2011-02-22 . C2EF2335F1B6C2BE20A67D9098F6C9A1 . 5962240 . . [8.00.6001.19046] . . c:\windows\SoftwareDistribution\Download\4a68e5ecf881bfdf9f622e39f79b4af0\SP3GDR\mshtml.dll
[-] 2010-12-20 . 1EDCEC5D649DBAC37ED9FFB5A14CEB0C . 5961216 . . [8.00.6001.19019] . . c:\windows\system32\mshtml.dll
[-] 2010-12-20 . 1EDCEC5D649DBAC37ED9FFB5A14CEB0C . 5961216 . . [8.00.6001.19019] . . c:\windows\system32\dllcache\mshtml.dll
[-] 2010-12-20 . 2A2C070EC691CE410533A1DA7AA3CD86 . 5962240 . . [8.00.6001.23111] . . c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\mshtml.dll
[-] 2010-11-06 . 864E69F32656A7121444BA0193D7B64B . 5960704 . . [8.00.6001.23091] . . c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\mshtml.dll
[-] 2010-11-06 . D7CCA87057901C87ED8CC40DDCC7FA1B . 5959168 . . [8.00.6001.18999] . . c:\windows\ie8updates\KB2482017-IE8\mshtml.dll
[-] 2010-09-10 . DE41132DA8E5A3CD57201C6F2175EC05 . 5957120 . . [8.00.6001.18975] . . c:\windows\ie8updates\KB2416400-IE8\mshtml.dll
[-] 2010-09-10 . 8A03CC037E6B7D1796192815231B0C3F . 5958656 . . [8.00.6001.23067] . . c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\mshtml.dll
[-] 2010-06-24 . 94DC7E938C57F3C3D1BC4A0F68FC5830 . 5954560 . . [8.00.6001.23037] . . c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\mshtml.dll
[-] 2010-06-24 . 4D7EF94795384CD2BBAAB078B7929FEA . 5951488 . . [8.00.6001.18939] . . c:\windows\ie8updates\KB2360131-IE8\mshtml.dll
[-] 2010-05-06 . C7B7A88CC7D7ABA5C395145BF92F46F7 . 5950976 . . [8.00.6001.18928] . . c:\windows\ie8updates\KB2183461-IE8\mshtml.dll
[-] 2010-05-06 . 9BE28F749A7FE7F8F177C6AA2E9DA609 . 5953024 . . [8.00.6001.23019] . . c:\windows\$hf_mig$\KB982381-IE8\SP3QFE\mshtml.dll
[-] 2010-05-04 . F247F7AC6713066D4C71721BDC73FC2E . 3600384 . . [7.00.6000.17063] . . c:\windows\ie8\mshtml.dll
[-] 2010-05-04 . C466BDCDFAE6F6EFD618F34BA90B1923 . 3603456 . . [7.00.6000.21264] . . c:\windows\$hf_mig$\KB982381-IE7\SP3QFE\mshtml.dll
[-] 2010-02-25 . 974772C74DA7C7A8E7C813A9908A845F . 5946880 . . [8.00.6001.22995] . . c:\windows\$hf_mig$\KB980182-IE8\SP3QFE\mshtml.dll
[-] 2010-01-05 . 3B8259EF10C0F1425395981E40ED0EAA . 3599360 . . [7.00.6000.16981] . . c:\windows\ie7updates\KB982381-IE7\mshtml.dll
[-] 2010-01-05 . 1673677DBD70142DB1294F1B6FC3323E . 3602944 . . [7.00.6000.21183] . . c:\windows\$hf_mig$\KB978207-IE7\SP3QFE\mshtml.dll
[-] 2009-12-21 . E6B64C6C729BBC38AB7CC92CE33F97A5 . 5945856 . . [8.00.6001.22967] . . c:\windows\$hf_mig$\KB978207-IE8\SP3QFE\mshtml.dll
[-] 2009-10-29 . 89A9658515A18E673034369E043FAB01 . 3598336 . . [7.00.6000.16945] . . c:\windows\ie7updates\KB978207-IE7\mshtml.dll
[-] 2009-10-29 . 8B48737260C273C9B0DACA84EA1CCDBD . 3602432 . . [7.00.6000.21148] . . c:\windows\$hf_mig$\KB976325-IE7\SP3QFE\mshtml.dll
[-] 2009-10-29 . C0F9AC6FAB2C788FFEE3E69585A0E93F . 5944320 . . [8.00.6001.22945] . . c:\windows\$hf_mig$\KB976325-IE8\SP3QFE\mshtml.dll
[-] 2009-10-21 . 36145D2D908FB8A24772F04842366918 . 3598336 . . [7.00.6000.16939] . . c:\windows\ie7updates\KB976325-IE7\mshtml.dll
[-] 2009-10-21 . E6453EE08B283419171889786D057A75 . 3602432 . . [7.00.6000.21142] . . c:\windows\$hf_mig$\KB976749-IE7\SP3QFE\mshtml.dll
[-] 2009-09-25 . 601E18A9A8F0D0ED39692B593212378F . 3070976 . . [6.00.2900.5880] . . c:\windows\SoftwareDistribution\Download\95b0eb6de61f9c4758f6dd82521ed694\sp3gdr\mshtml.dll
[-] 2009-09-25 . 37F578776552FA076EA6085F0365209C . 3072512 . . [6.00.2900.5880] . . c:\windows\$hf_mig$\KB974455\SP3QFE\mshtml.dll
[-] 2009-08-29 . EDAD55105DDD067AE3906011F297267C . 3600384 . . [7.00.6000.21115] . . c:\windows\SoftwareDistribution\Download\d0d6ed29e882a2ff5905d66f68fd56c0\SP3QFE\mshtml.dll
[-] 2009-08-29 . E52A845DCE011D56B12B8F3F4606F956 . 3598336 . . [7.00.6000.16915] . . c:\windows\ie7updates\KB976749-IE7\mshtml.dll
[-] 2009-08-29 . E52A845DCE011D56B12B8F3F4606F956 . 3598336 . . [7.00.6000.16915] . . c:\windows\SoftwareDistribution\Download\d0d6ed29e882a2ff5905d66f68fd56c0\SP3GDR\mshtml.dll
[-] 2009-08-29 . EDAD55105DDD067AE3906011F297267C . 3600384 . . [7.00.6000.21115] . . c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\mshtml.dll
[-] 2009-07-19 . F6098CC1B1C3858D53F20F3CB5774F3B . 3600384 . . [7.00.6000.21089] . . c:\windows\$hf_mig$\KB972260-IE7\SP3QFE\mshtml.dll
[-] 2009-04-29 . C6FD770D518FB024245A0EE217D72BC1 . 3598336 . . [7.00.6000.21045] . . c:\windows\$hf_mig$\KB969897-IE7\SP3QFE\mshtml.dll
[-] 2009-04-29 . 2B4315EC9E3124408A2A5074C4B97700 . 3596288 . . [7.00.6000.16850] . . c:\windows\ie7updates\KB972260-IE7\mshtml.dll
[-] 2009-03-08 . D469A0EBA2EF5C6BEE8065B7E3196E5E . 5937152 . . [8.00.6001.18702] . . c:\windows\ie8updates\KB982381-IE8\mshtml.dll
[-] 2009-02-20 . 2F70F2F74C40397D031016FA162981C2 . 3068416 . . [6.00.2900.5764] . . c:\windows\SoftwareDistribution\Download\38cc9246b0b2808f85d733169eec82d4\sp3gdr\mshtml.dll
[-] 2009-02-20 . 1618A4A2C5DD8164B8295190C8EA6544 . 3068416 . . [6.00.2900.5764] . . c:\windows\SoftwareDistribution\Download\38cc9246b0b2808f85d733169eec82d4\sp3qfe\mshtml.dll
[-] 2008-08-21 . A706E122B398FE1AB85CB9B75D044223 . 3066880 . . [6.00.2900.5512] . . c:\windows\ie7\mshtml.dll
[-] 2007-08-13 . C6EC2493346ED8888A549F59210A8ED3 . 3578368 . . [7.00.5730.13] . . c:\windows\ie7updates\KB974455-IE7\mshtml.dll
[-] 2007-08-13 . C6EC2493346ED8888A549F59210A8ED3 . 3578368 . . [7.00.5730.13] . . c:\windows\ie7updates\KB969897-IE7\mshtml.dll
[-] 2008-08-21 . 4200BE3808F6406DBE45A7B88DAE5035 . 322560 . . [7.0.2600.0] . . c:\windows\I386\ASMS\7000\MSFT\WINDOWS\MSWINCRT\MSVCRT.DLL
[-] 2008-08-21 . 355EDBB4D412B01F1740C17E3F50FA00 . 343040 . . [7.0.2600.5512] . . c:\windows\system32\msvcrt.dll
[-] 2008-08-21 . 355EDBB4D412B01F1740C17E3F50FA00 . 343040 . . [7.0.2600.5512] . . c:\windows\system32\dllcache\msvcrt.dll
[-] 2008-08-21 . 4200BE3808F6406DBE45A7B88DAE5035 . 322560 . . [7.0.2600.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.CPlusPlusRuntime_6595b64144ccf1df_7.0.0.0_x-ww_2726e76a\msvcrt.dll
[-] 2008-08-21 . D7075E95AA599EE77B7A89D39296BD3D . 343040 . . [7.0.2600.5512] . . c:\windows\WinSxS\x86_Microsoft.Windows.CPlusPlusRuntime_6595b64144ccf1df_7.0.2600.5512_x-ww_3fd60d63\msvcrt.dll
[-] 2008-08-21 . B4138E99236F0F57D4CF49BAE98A0746 . 245248 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB951748$\mswsock.dll
[-] 2008-06-20 . 832E4DD8964AB7ACC880B2837CB1ED20 . 245248 . . [5.1.2600.5625] . . c:\windows\system32\mswsock.dll
[-] 2008-06-20 . 832E4DD8964AB7ACC880B2837CB1ED20 . 245248 . . [5.1.2600.5625] . . c:\windows\system32\dllcache\mswsock.dll
[-] 2008-06-20 . FCEE5FCB99F7C724593365C706D28388 . 245248 . . [5.1.2600.5625] . . c:\windows\$hf_mig$\KB951748\SP3QFE\mswsock.dll
[-] 2008-06-20 . FCEE5FCB99F7C724593365C706D28388 . 245248 . . [5.1.2600.5625] . . c:\windows\SoftwareDistribution\Download\ff0686f2f699fa07ed5ad0848fa3055b\sp3qfe\mswsock.dll
[-] 2008-06-20 . 943337D786A56729263071623BBB9DE5 . 245248 . . [5.1.2600.5625] . . c:\windows\SoftwareDistribution\Download\ff0686f2f699fa07ed5ad0848fa3055b\sp3gdr\mswsock.dll
[-] 2008-08-21 . 1B7F071C51B77C272875C3A23E1E4550 . 407040 . . [5.1.2600.5512] . . c:\windows\system32\netlogon.dll
[-] 2008-08-21 . 1B7F071C51B77C272875C3A23E1E4550 . 407040 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\netlogon.dll
[-] 2008-08-21 . 50A166237A0FA771261275A405646CC0 . 17408 . . [6.00.2900.5512] . . c:\windows\system32\powrprof.dll
[-] 2008-08-21 . 50A166237A0FA771261275A405646CC0 . 17408 . . [6.00.2900.5512] . . c:\windows\system32\dllcache\powrprof.dll
[-] 2008-08-21 . A86BB5E61BF3E39B62AB4C7E7085A084 . 181248 . . [5.1.2600.5512] . . c:\windows\system32\scecli.dll
[-] 2008-08-21 . A86BB5E61BF3E39B62AB4C7E7085A084 . 181248 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\scecli.dll
[-] 2008-08-21 . 96E1C926F22EE1BFBAE82901A35F6BF3 . 5120 . . [5.1.2600.5512] . . c:\windows\system32\sfc.dll
[-] 2008-08-21 . 96E1C926F22EE1BFBAE82901A35F6BF3 . 5120 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\sfc.dll
[-] 2008-08-21 . 27C6D03BCDB8CFEB96B716F3D8BE3E18 . 14336 . . [5.1.2600.5512] . . c:\windows\system32\svchost.exe
[-] 2008-08-21 . 27C6D03BCDB8CFEB96B716F3D8BE3E18 . 14336 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\svchost.exe
[-] 2008-08-21 . 3CB78C17BB664637787C9A1C98F79C38 . 249856 . . [5.1.2600.5512] . . c:\windows\system32\tapisrv.dll
[-] 2008-08-21 . 3CB78C17BB664637787C9A1C98F79C38 . 249856 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\tapisrv.dll
[-] 2008-08-21 . B26B135FF1B9F60C9388B4A7D16F600B . 578560 . . [5.1.2600.5512] . . c:\windows\system32\user32.dll
[-] 2008-08-21 . B26B135FF1B9F60C9388B4A7D16F600B . 578560 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\user32.dll
[-] 2008-08-21 . A93AEE1928A9D7CE3E16D24EC7380F89 . 26112 . . [5.1.2600.5512] . . c:\windows\system32\userinit.exe
[-] 2008-08-21 . A93AEE1928A9D7CE3E16D24EC7380F89 . 26112 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\userinit.exe
[-] 2011-02-22 . A9FA95F0D7F511959AC721E4843E5967 . 919552 . . [8.00.6001.23139] . . c:\windows\SoftwareDistribution\Download\4a68e5ecf881bfdf9f622e39f79b4af0\SP3QFE\wininet.dll
[-] 2011-02-22 . F192D49EEFE297FA858B2C774BA2291D . 916480 . . [8.00.6001.19044] . . c:\windows\SoftwareDistribution\Download\4a68e5ecf881bfdf9f622e39f79b4af0\SP3GDR\wininet.dll
[-] 2010-12-20 . 88014D62B5E3CDB0AC67948D86C926C8 . 916480 . . [8.00.6001.19019] . . c:\windows\system32\wininet.dll
[-] 2010-12-20 . 88014D62B5E3CDB0AC67948D86C926C8 . 916480 . . [8.00.6001.19019] . . c:\windows\system32\dllcache\wininet.dll
[-] 2010-12-20 . 5504B4ECCE892EB82CD2C5FA71940AC1 . 919552 . . [8.00.6001.23111] . . c:\windows\$hf_mig$\KB2482017-IE8\SP3QFE\wininet.dll
[-] 2010-11-06 . 9357C4249F4810FB0E49C13387A8A77C . 919552 . . [8.00.6001.23084] . . c:\windows\$hf_mig$\KB2416400-IE8\SP3QFE\wininet.dll
[-] 2010-11-06 . 306A2B05EA9846278113964DC6E2C940 . 916480 . . [8.00.6001.18992] . . c:\windows\ie8updates\KB2482017-IE8\wininet.dll
[-] 2010-09-10 . 36FE8ABC59AAFBE20CBE54BC372F9429 . 916480 . . [8.00.6001.18968] . . c:\windows\ie8updates\KB2416400-IE8\wininet.dll
[-] 2010-09-10 . 0555E190DCD06B8998E6DDCA42DAEB82 . 919552 . . [8.00.6001.23060] . . c:\windows\$hf_mig$\KB2360131-IE8\SP3QFE\wininet.dll
[-] 2010-06-24 . 60237E50D575FBA9BEC9BC043F157149 . 919040 . . [8.00.6001.23037] . . c:\windows\$hf_mig$\KB2183461-IE8\SP3QFE\wininet.dll
[-] 2010-06-24 . D3DEB6B2B424AC93DE3801EAEB21A9A5 . 916480 . . [8.00.6001.18939] . . c:\windows\ie8updates\KB2360131-IE8\wininet.dll
[-] 2010-05-06 . 2D9C7B010409372C34F725DA5CCED083 . 916480 . . [8.00.6001.18923] . . c:\windows\ie8updates\KB2183461-IE8\wininet.dll
[-] 2010-05-06 . C1490F68B44AF8B781F52F12F564625D . 919040 . . [8.00.6001.23014] . . c:\windows\$hf_mig$\KB982381-IE8\SP3QFE\wininet.dll
[-] 2010-05-04 . 83306356DE710DA87ED91A6AF6233214 . 832512 . . [7.00.6000.17055] . . c:\windows\ie8\wininet.dll
[-] 2010-05-04 . 506B3DCB9C26070072E3047C6910F844 . 841216 . . [7.00.6000.21256] . . c:\windows\$hf_mig$\KB982381-IE7\SP3QFE\wininet.dll
[-] 2010-02-25 . 4458D59F2B0369F4D3B137541D284041 . 919040 . . [8.00.6001.22995] . . c:\windows\$hf_mig$\KB980182-IE8\SP3QFE\wininet.dll
[-] 2010-01-05 . 21E7890F1EC89BEF0AF7C08D730AE317 . 832512 . . [7.00.6000.16981] . . c:\windows\ie7updates\KB982381-IE7\wininet.dll
[-] 2010-01-05 . E7B99465DE2EDCF29784B7600BF6FAE8 . 841216 . . [7.00.6000.21183] . . c:\windows\$hf_mig$\KB978207-IE7\SP3QFE\wininet.dll
[-] 2009-12-21 . 5E1F666B8955FD77E65D65C4C4D882A3 . 916480 . . [8.00.6001.22967] . . c:\windows\$hf_mig$\KB978207-IE8\SP3QFE\wininet.dll
[-] 2009-10-29 . 7C599DEC022BEF6E3C9F4DB4FC164E8B . 832512 . . [7.00.6000.16945] . . c:\windows\ie7updates\KB978207-IE7\wininet.dll
[-] 2009-10-29 . 6AF52998B90F72FF2325D84D90EDA1CC . 916480 . . [8.00.6001.22945] . . c:\windows\$hf_mig$\KB976325-IE8\SP3QFE\wininet.dll
[-] 2009-10-29 . CA5CB4F174592090FBECFEAD9B51BB90 . 841216 . . [7.00.6000.21148] . . c:\windows\$hf_mig$\KB976325-IE7\SP3QFE\wininet.dll
[-] 2009-09-25 . 178CF0F58C9907633AAB633860B68973 . 667136 . . [6.00.2900.5880] . . c:\windows\SoftwareDistribution\Download\95b0eb6de61f9c4758f6dd82521ed694\sp3gdr\wininet.dll
[-] 2009-09-25 . 406D33F9B30FFC0EEFC7C55562839931 . 668672 . . [6.00.2900.5880] . . c:\windows\$hf_mig$\KB974455\SP3QFE\wininet.dll
[-] 2009-08-29 . DB111200015F08DDDB8857E11C6A80E3 . 832512 . . [7.00.6000.16915] . . c:\windows\ie7updates\KB976325-IE7\wininet.dll
[-] 2009-08-29 . DB111200015F08DDDB8857E11C6A80E3 . 832512 . . [7.00.6000.16915] . . c:\windows\SoftwareDistribution\Download\d0d6ed29e882a2ff5905d66f68fd56c0\SP3GDR\wininet.dll
[-] 2009-08-29 . A5885AF9BFBD942B828E6020AD326517 . 840704 . . [7.00.6000.21115] . . c:\windows\$hf_mig$\KB974455-IE7\SP3QFE\wininet.dll
[-] 2009-08-29 . A5885AF9BFBD942B828E6020AD326517 . 840704 . . [7.00.6000.21115] . . c:\windows\SoftwareDistribution\Download\d0d6ed29e882a2ff5905d66f68fd56c0\SP3QFE\wininet.dll
[-] 2009-06-29 . 4C6B4138165A4C53FE8A5B1D809526C3 . 828928 . . [7.00.6000.21073] . . c:\windows\$hf_mig$\KB972260-IE7\SP3QFE\wininet.dll
[-] 2009-04-29 . 8E2D471157B0DF329D8D0EA5D83B0DDB . 827392 . . [7.00.6000.16850] . . c:\windows\ie7updates\KB972260-IE7\wininet.dll
[-] 2009-04-29 . 62CCA075F44015147B8971DAFFBCFF76 . 828928 . . [7.00.6000.21045] . . c:\windows\$hf_mig$\KB969897-IE7\SP3QFE\wininet.dll
[-] 2009-03-08 . 6CE32F7778061CCC5814D5E0F282D369 . 914944 . . [8.00.6001.18702] . . c:\windows\ie8updates\KB982381-IE8\wininet.dll
[-] 2009-02-20 . 5B6A3EB7BB2F338BC2CB9F2FA4AAEA9E . 666112 . . [6.00.2900.5764] . . c:\windows\SoftwareDistribution\Download\38cc9246b0b2808f85d733169eec82d4\sp3gdr\wininet.dll
[-] 2009-02-20 . 711FEABED387B29FF7ED61BC6806A06C . 667648 . . [6.00.2900.5764] . . c:\windows\SoftwareDistribution\Download\38cc9246b0b2808f85d733169eec82d4\sp3qfe\wininet.dll
[-] 2008-08-21 . 7A4F775ABB2F1C97DEF3E73AFA2FAEDD . 666112 . . [6.00.2900.5512] . . c:\windows\ie7\wininet.dll
[-] 2007-08-13 . A4A0FC92358F39538A6494C42EF99FE9 . 818688 . . [7.00.5730.13] . . c:\windows\ie7updates\KB974455-IE7\wininet.dll
[-] 2007-08-13 . A4A0FC92358F39538A6494C42EF99FE9 . 818688 . . [7.00.5730.13] . . c:\windows\ie7updates\KB969897-IE7\wininet.dll
[-] 2008-08-21 . 2CCC474EB85CEAA3E1FA1726580A3E5A . 82432 . . [5.1.2600.5512] . . c:\windows\system32\ws2_32.dll
[-] 2008-08-21 . 2CCC474EB85CEAA3E1FA1726580A3E5A . 82432 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ws2_32.dll
[-] 2008-08-21 . 9789E95E1D88EEB4B922BF3EA7779C28 . 19968 . . [5.1.2600.5512] . . c:\windows\system32\ws2help.dll
[-] 2008-08-21 . 9789E95E1D88EEB4B922BF3EA7779C28 . 19968 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ws2help.dll
[-] 2008-08-21 . 12896823FB95BFB3DC9B46BCAEDC9923 . 1033728 . . [6.00.2900.5512] . . c:\windows\explorer.exe
[-] 2008-08-21 . 12896823FB95BFB3DC9B46BCAEDC9923 . 1033728 . . [6.00.2900.5512] . . c:\windows\system32\dllcache\explorer.exe
[-] 2010-07-16 . 7A6A7900B5E322763430BA6FD9A31224 . 1288192 . . [5.1.2600.6010] . . c:\windows\system32\ole32.dll
[-] 2010-07-16 . 7A6A7900B5E322763430BA6FD9A31224 . 1288192 . . [5.1.2600.6010] . . c:\windows\system32\dllcache\ole32.dll
[-] 2010-07-16 . 8D51FB47062F2A1A9EFECCEF338A4C46 . 1289216 . . [5.1.2600.6010] . . c:\windows\$hf_mig$\KB979687\SP3QFE\ole32.dll
[-] 2008-08-21 . ECCE74BC6168375016450A86A164D976 . 1287168 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB979687$\ole32.dll
[-] 2010-04-16 . 9E03DC5AB51CFD0190541CE2038D819D . 406016 . . [1.0420.2600.5969] . . c:\windows\system32\usp10.dll
[-] 2010-04-16 . 9E03DC5AB51CFD0190541CE2038D819D . 406016 . . [1.0420.2600.5969] . . c:\windows\system32\dllcache\usp10.dll
[-] 2010-04-16 . F8894BCC961D461674002B4BAE7AECC1 . 406016 . . [1.0420.2600.5969] . . c:\windows\$hf_mig$\KB981322\SP3QFE\usp10.dll
[-] 2008-08-21 . 7D7D8501F3CB45D0408CDEFA08CDAEFF . 406016 . . [1.0420.2600.5512] . . c:\windows\$NtUninstallKB981322$\usp10.dll
[-] 2008-08-21 . 3805DF0AC4296A34BA4BF93B346CC378 . 171008 . . [5.1.2600.5512] . . c:\windows\system32\srsvc.dll
[-] 2008-08-21 . 3805DF0AC4296A34BA4BF93B346CC378 . 171008 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\srsvc.dll
[-] 2008-08-21 . F92E1076C42FCD6DB3D72D8CFE9816D5 . 13824 . . [5.1.2600.5512] . . c:\windows\system32\wscntfy.exe
[-] 2008-08-21 . F92E1076C42FCD6DB3D72D8CFE9816D5 . 13824 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\wscntfy.exe
[-] 2008-08-21 . 295D21F14C335B53CB8154E5B1F892B9 . 129024 . . [5.1.2600.5512] . . c:\windows\system32\xmlprov.dll
[-] 2008-08-21 . 295D21F14C335B53CB8154E5B1F892B9 . 129024 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\xmlprov.dll
[-] 2008-08-21 . 6D4FEB43EE538FC5428CC7F0565AA656 . 56320 . . [5.1.2600.5512] . . c:\windows\system32\eventlog.dll
[-] 2008-08-21 . 6D4FEB43EE538FC5428CC7F0565AA656 . 56320 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\eventlog.dll
[-] 2008-08-21 . 9DD07AF82244867CA36681EA2D29CE79 . 1614848 . . [5.1.2600.5512] . . c:\windows\system32\sfcfiles.dll
[-] 2008-08-21 . 9DD07AF82244867CA36681EA2D29CE79 . 1614848 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\sfcfiles.dll
[-] 2008-08-21 . 5F1D5F88303D4A4DBC8E5F97BA967CC3 . 15360 . . [5.1.2600.5512] . . c:\windows\system32\ctfmon.exe
[-] 2008-08-21 . 5F1D5F88303D4A4DBC8E5F97BA967CC3 . 15360 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ctfmon.exe
[-] 2009-07-27 . 99BC0B50F511924348BE19C7C7313BBF . 135168 . . [6.00.2900.5853] . . c:\windows\system32\shsvcs.dll
[-] 2009-07-27 . 99BC0B50F511924348BE19C7C7313BBF . 135168 . . [6.00.2900.5853] . . c:\windows\system32\dllcache\shsvcs.dll
[-] 2009-07-27 . 888CD7B39C37E13A2419BECFAAF0A28C . 135168 . . [6.00.2900.5853] . . c:\windows\$hf_mig$\KB971029\SP3QFE\shsvcs.dll
[-] 2008-08-21 . 1926899BF9FFE2602B63074971700412 . 135168 . . [6.00.2900.5512] . . c:\windows\$NtUninstallKB971029$\shsvcs.dll
[-] 2008-08-21 . 5B19B557B0C188210A56A6B699D90B8F . 59904 . . [5.1.2600.5512] . . c:\windows\system32\regsvc.dll
[-] 2008-08-21 . 5B19B557B0C188210A56A6B699D90B8F . 59904 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\regsvc.dll
[-] 2008-08-21 . 0A9A7365A1CA4319AA7C1D6CD8E4EAFA . 192512 . . [5.1.2600.5512] . . c:\windows\system32\schedsvc.dll
[-] 2008-08-21 . 0A9A7365A1CA4319AA7C1D6CD8E4EAFA . 192512 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\schedsvc.dll
[-] 2008-08-21 . 0A5679B3714EDAB99E357057EE88FCA6 . 71680 . . [5.1.2600.5512] . . c:\windows\system32\ssdpsrv.dll
[-] 2008-08-21 . 0A5679B3714EDAB99E357057EE88FCA6 . 71680 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ssdpsrv.dll
[-] 2008-08-21 . FF3477C03BE7201C294C35F684B3479F . 295424 . . [5.1.2600.5512] . . c:\windows\system32\termsrv.dll
[-] 2008-08-21 . FF3477C03BE7201C294C35F684B3479F . 295424 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\termsrv.dll
[-] 2008-08-21 . 3CB32D3B8CBE79899D63280BB7A83CD9 . 344064 . . [5.1.2600.5512] . . c:\windows\system32\hnetcfg.dll
[-] 2008-08-21 . 3CB32D3B8CBE79899D63280BB7A83CD9 . 344064 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\hnetcfg.dll
[-] 2008-08-21 . D8849F77C0B66226335A59D26CB4EDC6 . 167936 . . [5.1.2600.5512] . . c:\windows\system32\appmgmts.dll
[-] 2008-08-21 . D8849F77C0B66226335A59D26CB4EDC6 . 167936 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\appmgmts.dll
[-] 2008-08-21 . 9859C0F6936E723E4892D7141B1327D5 . 11648 . . [5.1.2600.0] . . c:\windows\system32\drivers\acpiec.sys
[-] 2008-08-21 12:00 . 8BED39E3C35D6A489438B8141717A557 . 142592 . . [5.1.2601.3142] . . c:\windows\system32\drivers\aec.sys
[-] 2008-04-14 . 08FD04AA961BDC77FB983F328334E3D7 . 42368 . . [5.1.2600.5512] . . c:\windows\system32\drivers\AGP440.SYS
[-] 2008-08-21 . 3BB22519A194418D5FEC05D800A19AD0 . 36608 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\ip6fw.sys
[-] 2008-08-21 . 3BB22519A194418D5FEC05D800A19AD0 . 36608 . . [5.1.2600.5512] . . c:\windows\system32\drivers\ip6fw.sys
[-] 2010-09-18 07:18 . 842900DEDBC8E3E8DBCCCB298FD88F65 . 953856 . . [4.1.6151] . . c:\windows\$hf_mig$\KB2387149\SP3QFE\mfc40u.dll
[-] 2010-09-18 06:53 . E76A5C202E68AF5A322D16B5A78F48B9 . 953856 . . [4.1.6151] . . c:\windows\system32\mfc40u.dll
[-] 2010-09-18 06:53 . E76A5C202E68AF5A322D16B5A78F48B9 . 953856 . . [4.1.6151] . . c:\windows\system32\dllcache\mfc40u.dll
[-] 2008-08-21 12:00 . CDDD4416B2B4C7295FE3FDB6DDE57E4E . 927504 . . [4.1.0.61] . . c:\windows\$NtUninstallKB2387149$\mfc40u.dll
[-] 2008-08-21 . 986B1FF5814366D71E0AC5755C88F2D3 . 33792 . . [5.1.2600.5512] . . c:\windows\system32\msgsvc.dll
[-] 2008-08-21 . 986B1FF5814366D71E0AC5755C88F2D3 . 33792 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\msgsvc.dll
[-] 2008-08-21 12:00 . C7E39EA41233E9F5B86C8DA3A9F1E4A8 . 52224 . . [9.0.1.56] . . c:\windows\$NtUninstallWMFDist11$\mspmsnsv.dll
[-] 2008-08-21 12:00 . C7E39EA41233E9F5B86C8DA3A9F1E4A8 . 52224 . . [9.0.1.56] . . c:\windows\RegisteredPackages\{30C7234B-6482-4A55-A11D-ECD9030313F2}$BACKUP$\System\MsPMSNSv.dll
[-] 2006-10-19 02:47 . C51B4A5C05A5475708E3C81C7765B71D . 27136 . . [11.0.5721.5145] . . c:\windows\system32\mspmsnsv.dll
[-] 2006-10-19 02:47 . C51B4A5C05A5475708E3C81C7765B71D . 27136 . . [11.0.5721.5145] . . c:\windows\system32\dllcache\mspmsnsv.dll
[-] 2004-08-11 06:45 . A477391B7A8B0A0DAABADB17CF533A4B . 25088 . . [10.0.3790.3646] . . c:\windows\RegisteredPackages\{30C7234B-6482-4A55-A11D-ECD9030313F2}\MsPMSNSv.dll
[-] 2010-12-09 . F67CD97282E0ABFAF91A9A1359B16F2D . 2069376 . . [5.1.2600.6055] . . c:\windows\$hf_mig$\KB2393802\SP3QFE\ntkrnlpa.exe
[-] 2010-12-09 . 84FF488E249DBD2050EB39EA81C6F5C2 . 2069376 . . [5.1.2600.6055] . . c:\windows\Driver Cache\i386\ntkrnlpa.exe
[-] 2010-12-09 . 84FF488E249DBD2050EB39EA81C6F5C2 . 2069376 . . [5.1.2600.6055] . . c:\windows\system32\ntkrnlpa.exe
[-] 2010-12-09 . 84FF488E249DBD2050EB39EA81C6F5C2 . 2069376 . . [5.1.2600.6055] . . c:\windows\system32\dllcache\ntkrnlpa.exe
[-] 2010-04-28 . 756362706DE8BC92F11E197C98A73844 . 2066944 . . [5.1.2600.5973] . . c:\windows\$hf_mig$\KB981852\SP3QFE\ntkrnlpa.exe
[-] 2010-04-27 . DC57ABED7BDE1487E658968B4423BED7 . 2066816 . . [5.1.2600.5973] . . c:\windows\$NtUninstallKB2393802$\ntkrnlpa.exe
[-] 2010-02-16 . A046C627EC20456E2959B7BD628E1FD0 . 2066816 . . [5.1.2600.5938] . . c:\windows\$NtUninstallKB981852$\ntkrnlpa.exe
[-] 2010-02-16 . DED8B5A89B085284634502E9D75AC78C . 2066944 . . [5.1.2600.5938] . . c:\windows\$hf_mig$\KB979683\SP3QFE\ntkrnlpa.exe
[-] 2009-12-09 . FFDCE1EEA79C678C40237D4E031E5B51 . 2066176 . . [5.1.2600.5913] . . c:\windows\$hf_mig$\KB977165\SP3QFE\ntkrnlpa.exe
[-] 2009-12-08 . A6683E23468776F75EB2D8C6A02AAD3B . 2066048 . . [5.1.2600.5913] . . c:\windows\$NtUninstallKB979683$\ntkrnlpa.exe
[-] 2009-08-04 . 363B2BBEE0AEDC9E5433616D0AD0236A . 2066176 . . [5.1.2600.5857] . . c:\windows\$hf_mig$\KB971486\SP3QFE\ntkrnlpa.exe
[-] 2009-08-04 . 7437BA6F538E89381A2E3643AED296C7 . 2066048 . . [5.1.2600.5857] . . c:\windows\$NtUninstallKB977165$\ntkrnlpa.exe
[-] 2009-02-06 . 607352B9CB3D708C67F6039097801B5A . 2066176 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3QFE\ntkrnlpa.exe
[-] 2008-08-21 . 109F8E3E3C82E337BB71B6BC9B895D61 . 2065792 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB971486$\ntkrnlpa.exe
[-] 2008-08-21 12:00 . 156F64A3345BD23C600655FB4D10BC08 . 435200 . . [5.1.2400.5512] . . c:\windows\system32\ntmssvc.dll
[-] 2008-08-21 12:00 . 156F64A3345BD23C600655FB4D10BC08 . 435200 . . [5.1.2400.5512] . . c:\windows\system32\dllcache\ntmssvc.dll
[-] 2008-08-21 . 1EBAFEB9A3FBDC41B8D9C7F0F687AD91 . 185856 . . [5.1.2600.5512] . . c:\windows\system32\upnphost.dll
[-] 2008-08-21 . 1EBAFEB9A3FBDC41B8D9C7F0F687AD91 . 185856 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\upnphost.dll
[-] 2008-08-21 . 4D83ED8BDDEC431FC8AD907B47CFB6E3 . 367616 . . [5.3.2600.5512] . . c:\windows\system32\dsound.dll
[-] 2008-08-21 . 4D83ED8BDDEC431FC8AD907B47CFB6E3 . 367616 . . [5.3.2600.5512] . . c:\windows\system32\dllcache\dsound.dll
[-] 2008-08-21 . 0607CBC6FA20114CB491EFE4B2F9EFAD . 1689088 . . [5.03.2600.5512] . . c:\windows\system32\d3d9.dll
[-] 2008-08-21 . 0607CBC6FA20114CB491EFE4B2F9EFAD . 1689088 . . [5.03.2600.5512] . . c:\windows\system32\dllcache\d3d9.dll
[-] 2008-08-21 . A340CD71EB535A3DD751B5F28723E50C . 279552 . . [5.03.2600.5512] . . c:\windows\system32\ddraw.dll
[-] 2008-08-21 . A340CD71EB535A3DD751B5F28723E50C . 279552 . . [5.03.2600.5512] . . c:\windows\system32\dllcache\ddraw.dll
[-] 2008-08-21 12:00 . 5652F6CE1D9E9D8068B9D29BC21B5409 . 84992 . . [5.1.2600.5512] . . c:\windows\system32\olepro32.dll
[-] 2008-08-21 12:00 . 5652F6CE1D9E9D8068B9D29BC21B5409 . 84992 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\olepro32.dll
[-] 2008-08-21 . DBE2B62353660ECCA0D75EA307A717E9 . 39936 . . [5.1.2600.5512] . . c:\windows\system32\perfctrs.dll
[-] 2008-08-21 . DBE2B62353660ECCA0D75EA307A717E9 . 39936 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\perfctrs.dll
[-] 2008-08-21 . C7CE131408739B0B3A318BE2D0032719 . 18944 . . [5.1.2600.5512] . . c:\windows\system32\version.dll
[-] 2008-08-21 . C7CE131408739B0B3A318BE2D0032719 . 18944 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\version.dll
[-] 2010-12-09 . A531BBD3DE13121C1380ED7DC99082DB . 2192768 . . [5.1.2600.6055] . . c:\windows\$hf_mig$\KB2393802\SP3QFE\ntoskrnl.exe
[-] 2010-12-09 . 64C1ADF6DF629F340C5A439FE0EF8ED1 . 2192768 . . [5.1.2600.6055] . . c:\windows\Driver Cache\i386\ntoskrnl.exe
[-] 2010-12-09 . 64C1ADF6DF629F340C5A439FE0EF8ED1 . 2192768 . . [5.1.2600.6055] . . c:\windows\system32\ntoskrnl.exe
[-] 2010-12-09 . 64C1ADF6DF629F340C5A439FE0EF8ED1 . 2192768 . . [5.1.2600.6055] . . c:\windows\system32\dllcache\ntoskrnl.exe
[-] 2010-04-28 . 472059774023F80EB7227EAF9A7ACDA1 . 2189952 . . [5.1.2600.5973] . . c:\windows\$NtUninstallKB2393802$\ntoskrnl.exe
[-] 2010-04-27 . A2ABBEC40CDB57454645D06B7EBD22F5 . 2190080 . . [5.1.2600.5973] . . c:\windows\$hf_mig$\KB981852\SP3QFE\ntoskrnl.exe
[-] 2010-02-17 . D41C3CBAD0E1C0728D1CDFD541F60CFA . 2189952 . . [5.1.2600.5938] . . c:\windows\$NtUninstallKB981852$\ntoskrnl.exe
[-] 2010-02-16 . E1F653A542449D54FA2D27463D99B6B6 . 2190080 . . [5.1.2600.5938] . . c:\windows\$hf_mig$\KB979683\SP3QFE\ntoskrnl.exe
[-] 2009-12-09 . 05BE3D9A71972223AFF6A3C823BA51B1 . 2189312 . . [5.1.2600.5913] . . c:\windows\$hf_mig$\KB977165\SP3QFE\ntoskrnl.exe
[-] 2009-12-08 . 78EC47F9B9A3A1D539262D8834C896CE . 2189184 . . [5.1.2600.5913] . . c:\windows\$NtUninstallKB979683$\ntoskrnl.exe
[-] 2009-08-05 . 8415D9C7C050E7022AED8ABF281BE4A6 . 2189184 . . [5.1.2600.5857] . . c:\windows\$NtUninstallKB977165$\ntoskrnl.exe
[-] 2009-08-04 . FDE779EA1A564EBFE16F4E0F82B61BAD . 2189312 . . [5.1.2600.5857] . . c:\windows\$hf_mig$\KB971486\SP3QFE\ntoskrnl.exe
[-] 2009-02-07 . EFE8EACE83EAAD5849A7A548FB75B584 . 2189184 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3QFE\ntoskrnl.exe
[-] 2008-08-21 . 0C89243C7C3EE199B96FCC16990E0679 . 2188928 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB971486$\ntoskrnl.exe
[-] 2008-08-21 . 54AF4B1D5459500EF0937F6D33B1914F . 175104 . . [5.1.2600.5512] . . c:\windows\system32\w32time.dll
[-] 2008-08-21 . 54AF4B1D5459500EF0937F6D33B1914F . 175104 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\w32time.dll
[-] 2008-08-21 . 8BAD69CBAC032D4BBACFCE0306174C30 . 333824 . . [5.1.2600.5512] . . c:\windows\system32\wiaservc.dll
[-] 2008-08-21 . 8BAD69CBAC032D4BBACFCE0306174C30 . 333824 . . [5.1.2600.5512] . . c:\windows\system32\dllcache\wiaservc.dll
"NvMediaCenter"="c:\windows\system32\NVMCTRAY.DLL" [2003-07-28 49152]
"Google Update"="c:\documents and settings\Billy\Local Settings\Application Data\Google\Update\GoogleUpdate.exe" [2009-12-03 135664]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2003-07-28 4841472]
"nwiz"="nwiz.exe" [2003-07-28 323584]
"Microsoft Default Manager"="c:\program files\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" [2009-07-17 288080]
"Kernel and Hardware Abstraction Layer"="KHALMNPR.EXE" [2008-10-10 69632]
"AppleSyncNotifier"="c:\program files\Common Files\Apple\Mobile Device Support\AppleSyncNotifier.exe" [2010-09-22 47904]
"EvtMgr6"="c:\program files\Logitech\SetPointP\SetPoint.exe" [2010-01-27 1312848]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2010-09-08 421888]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2010-09-24 421160]
"avgnt"="c:\program files\Avira\AntiVir Desktop\avgnt.exe" [2010-11-03 281768]
"Conime"="c:\windows\system32\conime.exe" [2008-08-21 27648]
"EKAIO2StatusMonitor"="c:\windows\System32\spool\DRIVERS\W32X86\3\EKAiO2MUI.exe" [2011-03-01 2421760]
"SunJavaUpdateSched"="c:\program files\Common Files\Java\Java Update\jusched.exe" [2010-10-29 249064]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 10.0\Reader\Reader_sl.exe" [2011-01-30 35736]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2010-11-10 932288]
"DWQueuedReporting"="c:\progra~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" [2008-11-04 435096]
McAfee Security Scan Plus.lnk - c:\program files\McAfee Security Scan\2.0.181\SSScheduler.exe [2010-1-15 255536]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\LBTWlgn]
2010-01-29 21:17 64592 ----a-w- c:\program files\Common Files\Logishrd\Bluetooth\LBTWLgn.dll
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\EzPrint]
2010-02-04 10:10 131752 ----a-w- c:\program files\Lexmark 5600-6600 Series\ezprint.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\lxdumon.exe]
2010-02-04 10:10 676520 ----a-w- c:\program files\Lexmark 5600-6600 Series\lxdumon.exe
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\ZoneLabsFirewall]
"EnableFirewall"= 0 (0x0)
"c:\\WINDOWS\\system32\\usmt\\migwiz.exe"=
"c:\\Program Files\\MSN\\MsnInstaller\\msninst.exe"=
"c:\\Program Files\\Microsoft Small Business\\Small Business Accounting 2007\\SBAAccountantHost.exe"=
"c:\\Program Files\\Outlook Express\\msimn.exe"=
"c:\\WINDOWS\\system32\\dxdiag.exe"=
"c:\\WINDOWS\\system32\\dpnsvr.exe"=
"c:\\Program Files\\Windows Live\\Sync\\WindowsLiveSync.exe"=
"c:\\WINDOWS\\system32\\lxducoms.exe"=
"c:\\Program Files\\Kodak\\AiO\\Center\\AiOHomeCenter.exe"=
"c:\\Program Files\\Kodak\\AiO\\Center\\Kodak.Statistics.exe"=
"c:\\Program Files\\Kodak\\AiO\\Center\\NetworkPrinterDiscovery.exe"=
"c:\\Program Files\\Kodak\\AiO\\Firmware\\KodakAiOUpdater.exe"=
"c:\\Documents and Settings\\All Users\\Application Data\\Kodak\\Installer\\Setup.exe"=
"9322:TCP"= 9322:TCP:EKDiscovery
"5353:UDP"= 5353:UDP:Bonjour Port 5353
R2 AntiVirSchedulerService;Avira AntiVir Scheduler;c:\program files\Avira\AntiVir Desktop\sched.exe [10/05/2010 6:43 PM 135336]
R2 Kodak AiO Network Discovery Service;Kodak AiO Network Discovery Service;c:\program files\Kodak\AiO\Center\EKAiOHostService.exe [03/09/2011 1:29 PM 366000]
R2 lxdu_device;lxdu_device;c:\windows\system32\lxducoms.exe -service --> c:\windows\system32\lxducoms.exe -service [?]
R2 lxduCATSCustConnectService;lxduCATSCustConnectService;c:\windows\system32\spool\drivers\w32x86\3\lxduserv.exe [02/26/2011 9:43 PM 94208]
R2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\Viewpoint\Common\ViewpointService.exe [09/13/2009 10:50 PM 24652]
S2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [02/26/2010 2:33 PM 135664]
S2 ISWKL;ZoneAlarm Toolbar ISWKL;\??\c:\program files\CheckPoint\ZAForceField\ISWKL.sys --> c:\program files\CheckPoint\ZAForceField\ISWKL.sys [?]
S2 IswSvc;ZoneAlarm Toolbar IswSvc;"c:\program files\CheckPoint\ZAForceField\IswSvc.exe" --> c:\program files\CheckPoint\ZAForceField\IswSvc.exe [?]
S2 WinDefend;Windows Defender;c:\program files\Windows Defender\MsMpEng.exe [11/03/2006 7:19 PM 13592]
S3 BBSvc;Bing Bar Update Service;"c:\program files\Microsoft\BingBar\BBSvc.EXE" --> c:\program files\Microsoft\BingBar\BBSvc.EXE [?]
S3 McComponentHostService;McAfee Security Scan Component Host Service;c:\program files\McAfee Security Scan\2.0.181\McCHSvc.exe [01/15/2010 8:49 AM 227232]
2011-04-13 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 17:34]
2011-04-14 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2010-02-26 18:33]
2011-04-14 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2011-04-13 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-3742509044-3434307102-661493048-1007Core.job
- c:\documents and settings\Billy\Local Settings\Application Data\Google\Update\GoogleUpdate.exe [2009-12-03 02:31]
2011-04-14 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-3742509044-3434307102-661493048-1007UA.job
2011-04-14 c:\windows\Tasks\User_Feed_Synchronization-{5EE1835E-AF7A-4575-BA25-B6C033D51654}.job
- c:\windows\system32\msfeedssync.exe [2007-08-13 08:31]
Trusted Zone: internet
Trusted Zone: mcafee.com
Trusted Zone: mozilla.com\www
Trusted Zone: scottrade.com\www
DPF: {0067DBFC-A752-458C-AE6E-B9C7E63D4824} - [You must be registered and logged in to see this link.]
FF - ProfilePath - c:\documents and settings\Billy\Application Data\Mozilla\Firefox\Profiles\f6h253z3.default\
FF - prefs.js: network.proxy.type - 0
FF - Ext: Default: {972ce4c6-7e08-4474-a285-3208198ce6fd} - c:\program files\Mozilla Firefox\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}
FF - Ext: Java Console: {CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA} - c:\program files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}
FF - Ext: United States English Spellchecker: [You must be registered and logged in to see this link.] - %profile%\extensions\en-US@dictionaries.addons.mozilla.org
FF - Ext: Add to Amazon Wish List Button: [You must be registered and logged in to see this link.] - %profile%\extensions\amznUWL2@amazon.com
FF - Ext: WebMail Notifier: {37fa1426-b82d-11db-8314-0800200c9a66} - %profile%\extensions\{37fa1426-b82d-11db-8314-0800200c9a66}
FF - Ext: TwitterBar: {1a0c9ebe-ddf9-4b76-b8a3-675c77874d37} - %profile%\extensions\{1a0c9ebe-ddf9-4b76-b8a3-675c77874d37}
FF - user.js: yahoo.homepage.dontask - true
URLSearchHooks-{91da5e8a-3318-4f8c-b67e-5964de3ab546} - (no file)
Rootkit scan 2011-04-14 12:15
[HKEY_USERS\S-1-5-21-3742509044-3434307102-661493048-1007\Software\Microsoft\SystemCertificates\AddressBook*]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10k_ActiveX.exe,-101"
"Enabled"=dword:00000001
@="c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10k_ActiveX.exe"
@="IFlashBroker4"
"Version"="1.0"
- - - - - - - > 'winlogon.exe'(656)
c:\program files\common files\logishrd\bluetooth\LBTWlgn.dll
- - - - - - - > 'explorer.exe'(3436)
c:\program files\Avira\AntiVir Desktop\avguard.exe
c:\program files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
c:\program files\Microsoft Small Business\Business Contact Manager\BcmSqlStartupSvc.exe
c:\program files\Avira\AntiVir Desktop\avshadow.exe
c:\program files\Microsoft SQL Server\90\Shared\sqlbrowser.exe
c:\program files\Microsoft SQL Server\90\Shared\sqlwriter.exe
c:\program files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE
c:\program files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe
c:\program files\Common Files\LogiShrd\KHAL3\KHALMNPR.EXE
Completion time: 2011-04-14 12:27:06 - machine was rebooted
ComboFix-quarantined-files.txt 2011-04-14 16:27
Pre-Run: 5,718,102,016 bytes free
Post-Run: 5,575,593,984 bytes free
- - End Of File - - A9F65BAEE99EB3D9C22704BA89398E12
Staples
Posts Posts : 14
OS OS : XP Pro
48 hours
Post by Staples on 17th April 2011, 3:42 am
BUMPS
Staples
Posts Posts : 14
OS OS : XP Pro
Bump...I hope I'm not ticking anyone off, but I read you are supposed to do this
Post by Staples on 20th April 2011, 2:51 am
Please if any of the super geeks (compliment) read this and I did something wrong or neglected something, please let me know
staples
Staples
Posts Posts : 14
OS OS : XP Pro
Re: Bumpng it Hotfix.exe still a problem
Post by Belahzur on 20th April 2011, 9:42 pm
Sneaky is away for a few days.
It would be best to format the machine as of now, the malware has too much damage that isn't easily repaired.
Points Points : 245079
reply to your reply hotfix.exe
Post by Staples on 21st April 2011, 2:30 pm
thank you so much for your reply.
I had no idea honestly what was included in all that information I posted. Sneaky and I never got that far in our discussions since it took me a few days to get it done, and now goes and sneaks away for a few days!
what I am saying is I really do not know exactly, OK just not exactly, but hardly an idea about your suggestion.
My own ignorance is the cause. I have a small idea but really just a guess about starting to format my machine now. something never touched upon.
My malware has too much damage. I'm sorry, but again, so much of this stuff is way over my head.
sorry but I feel like someone needs to hold my hand thru this
I look forward to your replay
Staples
Staples
Posts Posts : 14
Joined Joined : 2011-04-07
OS OS : XP Pro
Points Points : 20884
Post by Belahzur on 21st April 2011, 8:08 pm
Heh not to worry, formatting isn't all that hard, it's just wiping the HDD and starting over again.
This guide will help. [You must be registered and logged in to see this link.]
Post by Staples on 22nd April 2011, 2:42 am
I am really interested in knowing what the hell is going on in this thing. really as a matter of personal growth as a person before I do anything
Partly put of curiosity and not to make the same mistakes over again.
Also I have read alot of these posts like this for a long time with posting logs and such.
reformatting always seemed like a last ditch kind of thing. Even something I have done before. On a different PC
Should I be adding other programs or is that after? I dont feel I truly know what the heck happened or what kind of menace I have unleashed.
In addition, I would really like to know, depending on what it or they are if I could have transferred it to my new laptop. I haven't even set the thing up yet, but moved over my document stuff.
I want to make sure I didn't hit double jeopardy
thanks and I hope I made some kind of sense
staples
Staples
Posts Posts : 14
OS OS : XP Pro
Post by Staples on 22nd April 2011, 5:28 pm
actually, I JUST READ THE LINKS PROVIDED AND THEY ACTUALLY HAVE MORE QUESTIONS ABOUT WHAT i HAVE THAN i HAVE A CLUE OF.
iF i SCANNED IT CORRECTLY, i NEED TO HAVE AN IDEA OF WHAT i USE MY PC FOR AND WHAT IS INFECTING IT.
i AM NOT SURE TO DO THIS
i GUESS THATS WHY i'M HERE FOR HELP
STAPLES
caps all by mistake, sory
Staples
Posts Posts : 14
OS OS : XP Pro
Post by Belahzur on 22nd April 2011, 8:24 pm
Basically the malware has messed with your catroot and it's more of a pain to repair so it's wise to format now and I can't be sure it can be repaired fully due to the damage that has been done.
Post by Staples on 28th April 2011, 3:53 pm
I'm sorry, but this is not an answer to my problem.
this is going from A to Z with nothing in the middle and I'm going to reformat based on exactly....what?
I see you are a big upper class Geek Policeman, so i did expect more from you than a seemingly shortcut.
In the absence of any news or help, I did an anti malware bytes thing and it found 2 files, which were quarantined and deleted, all scans since than are clean spy.password or something similar. I changed many of my important pw's and realized just now, I need to do more
Every Avira scan nightly is clean
a full windows defender scan is clean.
OK, whats next.
I'm sorry, but I am not just going to reformat based on this.
I got one of those weird fake notices with some fake anti virus program to fix all these issues they found...knew right away it was bogus and got rid of it.
My memory has been increased by the pc, virtual memory.
Lately all it does is grind and grind away.
I repeatedly get a 'jusched' .exe I believe. I can't close when reboot. I close it manually, and I know its part of Java, but is it important and or necessary.Every time I send the error msg also and report it...big woop.
When I rebooted this am, the big pretty logo that came on the screen was 'JUST Windows XP...not professional. Yet some of or all of the logs say windows XP professional.
As stated in my original post, that is a recurring oddity.
Is it possible to have both on this system. If not, OK all you guys who know better can stop laughing, as thats why I am here, looking for help, not a total amputation. I'd like to try some medicines or treatments before you take the leg...OK?
I put this in caps as I hope it is the jist.
IF GeekPolice IS WILLING TO WORK WITH ME ON THIS, PLEASE TELL ME WHAT OR WHERE TO BEGIN.
DO I START ALL OVER OR TAKE ADVICE FROM HERE ON OUT.
If can't or do not think it is worth it, please let me know and I will thank you, but disappointingly have to try elsewhere with the other monster sites.
staples
PS: I stil have 6 issues of hotfix.exe in windows prefetch and 1 in windows\SQL9
Staples
Posts Posts : 14
OS OS : XP Pro
Last bump attempt,,,excuse scattered typos with caps lock HOTFIX.exe..still
Post by Staples on 4th May 2011, 3:25 am
Dear GeekPolice
Last Bump
Am I to assume that I am wasting my time for a respectable response?
Please, if so let me know as I can go try someplace else. Which I find unfortunate, as I liKed what i HAD READ BEFORE JOINING.
THIS WAS THE VERY FIRST SITE OF THIS TYPE i HAD EVER USED, OR SAY TRIED TO USE FOR SOME EXPERT HELP FOR MY COMPUTER PROBLEMS.
fwiw, IT DEFINITELY APPEARS THAT SOMEHOW BOTH WINDOWS xp AND WINDOWS xp PROFESSIONAL ARE EITHER RUNNING, OR IN MY MACHINE.
different logos POP UP FOR BOTH AT DIFFERENT TIMES.
if COURSE IT COULD BE A LOGO GLITCH , BUT THERE ARE MORE ODD OCCURRENCES THAN THAT.
that ISN'T WHY i CAME HERE ORIGINALLY THOUGH
i LOOK FORWARD TO A RESPONSE, thank you
sTAPLES
dAMN sorry about the stupid caps thing again
Staples
Posts Posts : 14
OS OS : XP Pro
Post by Belahzur on 4th May 2011, 2:28 pm
The only issue is the catroot. It is damaged, however it shouldn't make much difference in daily usage, it should still be fine if you don't format, but I can't promise that, there may still be 1 or 2 problems.
