MS Removal Tool Problem
Post by rjuneau on 2nd April 2011, 11:15 pm
MS Removal Tool showed up on my PC today. I downloaded & tried to run OTL.com, but it won't let me. Can I run OTL in safemode or something.
rjuneau
Posts Posts : 37
Joined Joined : 2009-08-13
Points Points : 27099
Re: MS Removal Tool Problem
Post by Superdave on 3rd April 2011, 1:38 am
Please download Malwarebytes Anti-Malware from [You must be registered and logged in to see this link.]
Please try to run OTL after doing the above and post the logs.
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83231
Post by rjuneau on 3rd April 2011, 1:33 pm
I can download mbam-setup.exe just fine, but when I try to run it, I get a pop up that says "MS Removal Tool Warning! Application cannot be executed. The file mbam-setup.exe is infected. Please activate your antivirus software.
Then it wants $59.95 for a 1-year license.
rjuneau
Posts Posts : 37
Post by rjuneau on 3rd April 2011, 1:34 pm
I installed mbam-setup.exe using safemode with networking and am running it now in safemode. Is this OK?
rjuneau
Posts Posts : 37
Post by rjuneau on 3rd April 2011, 2:34 pm
Log from MBAM:
Malwarebytes' Anti-Malware 1.50.1.1100
Database version: 6255
Windows 6.1.7600 (Safe Mode)
Internet Explorer 8.0.7600.16385
4/3/2011 9:31:18 AM
mbam-log-2011-04-03 (09-31-18).txt
Scan type: Full scan (C:\|)
Objects scanned: 304429
Time elapsed: 29 minute(s), 41 second(s)
Registry Values Infected: 1
Files Infected: 1
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce\pCp01804nAkCi01804 (Trojan.Downloader) -> Value: pCp01804nAkCi01804 -> Quarantined and deleted successfully.
c:\programdata\pcp01804nakci01804\pcp01804nakci01804.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
rjuneau
Posts Posts : 37
Post by rjuneau on 3rd April 2011, 2:49 pm
When MBAM finished, I restarted the computer, not in sfe mode, & ran OTL. Here is the log:
OTL logfile created on: 4/3/2011 9:37:56 AM - Run 1
OTL by OldTimer - Version 3.2.22.3 Folder = C:\Users\Rick Juneau\Desktop
64bit- Home Premium Edition (Version = 6.1.7600) - Type = NTWorkstation
Internet Explorer (Version = 8.0.7600.16385)
6.00 Gb Total Physical Memory | 4.00 Gb Available Physical Memory | 76.00% Memory free
11.00 Gb Paging File | 10.00 Gb Available in Paging File | 86.00% Paging File free
%SystemDrive% = C: | %SystemRoot% = C:\Windows | %ProgramFiles% = C:\Program Files (x86)
Drive C: | 920.49 Gb Total Space | 878.59 Gb Free Space | 95.45% Space Free | Partition Type: NTFS
Drive D: | 10.92 Gb Total Space | 1.59 Gb Free Space | 14.55% Space Free | Partition Type: NTFS
Drive E: | 30.25 Mb Total Space | 0.00 Mb Free Space | 0.00% Space Free | Partition Type: CDFS
Computer Name: RICKS-HP | User Name: Rick Juneau | Logged in as Administrator.
Boot Mode: Normal | Scan Mode: Current user | Include 64bit Scans
PRC - [2011/04/02 18:04:35 | 000,580,608 | ---- | M] (OldTimer Tools) -- C:\Users\Rick Juneau\Desktop\OTL.com
PRC - [2010/10/14 18:27:38 | 000,092,216 | ---- | M] (Hewlett-Packard Company) -- C:\Program Files (x86)\Hewlett-Packard\Shared\HPDrvMntSvc.exe
PRC - [2010/05/28 17:23:34 | 000,160,328 | ---- | M] (Siber Systems) -- C:\Program Files (x86)\Siber Systems\AI RoboForm\robotaskbaricon.exe
PRC - [2010/02/04 05:10:48 | 000,025,256 | ---- | M] () -- C:\Program Files (x86) (x86)\Lexmark 5600-6600 Series\lxdumsdmon.exe
PRC - [2010/02/04 05:10:44 | 000,676,520 | ---- | M] () -- C:\Program Files (x86) (x86)\Lexmark 5600-6600 Series\lxdumon.exe
PRC - [2010/01/18 11:27:10 | 000,139,944 | ---- | M] () -- C:\Program Files (x86)\Lexmark Pro800-Pro900 Series\ezprint.exe
PRC - [2010/01/18 11:26:56 | 000,770,728 | ---- | M] () -- C:\Program Files (x86)\Lexmark Pro800-Pro900 Series\lxecmon.exe
PRC - [2009/12/01 20:49:52 | 000,210,216 | ---- | M] (CyberLink) -- c:\Program Files (x86)\Hewlett-Packard\TouchSmart\Media\Kernel\CLML\CLMLSvc.exe
PRC - [2009/11/18 03:04:10 | 000,893,192 | ---- | M] (Logitech, Inc.) -- C:\Program Files\Logitech\SetPointP\LU\LogitechUpdate.exe
PRC - [2009/11/18 03:03:52 | 000,337,160 | ---- | M] (Logitech, Inc.) -- C:\Program Files\Logitech\SetPointP\LU\LULnchr.exe
PRC - [2009/09/13 00:09:10 | 000,103,768 | ---- | M] (Citrix Systems, Inc.) -- C:\Program Files (x86)\Citrix\ICA Client\concentr.exe
PRC - [2009/09/13 00:09:04 | 000,550,232 | ---- | M] (Citrix Systems, Inc.) -- C:\Program Files (x86)\Citrix\ICA Client\wfcrun32.exe
PRC - [2009/08/24 21:11:15 | 000,656,896 | ---- | M] (Hewlett-Packard) -- C:\Program Files (x86)\Hewlett-Packard\HP Remote Solution\HP_Remote_Solution.exe
PRC - [2009/03/05 16:07:20 | 002,260,480 | RHS- | M] (Safer-Networking Ltd.) -- C:\Program Files (x86)\Spybot - Search & Destroy\TeaTimer.exe
PRC - [2009/01/26 15:31:10 | 001,153,368 | ---- | M] (Safer Networking Ltd.) -- C:\Program Files (x86)\Spybot - Search & Destroy\SDWinSec.exe
PRC - [2008/11/20 13:47:28 | 000,062,768 | ---- | M] (Hewlett-Packard) -- C:\Program Files (x86)\Hewlett-Packard\HP Odometer\hpsysdrv.exe
MOD - [2011/04/02 18:04:35 | 000,580,608 | ---- | M] (OldTimer Tools) -- C:\Users\Rick Juneau\Desktop\OTL.com
MOD - [2011/03/09 16:54:14 | 000,018,176 | ---- | M] (McAfee, Inc.) -- c:\Program Files (x86)\McAfee\SiteAdvisor\sahook.dll
MOD - [2010/08/21 00:21:32 | 001,680,896 | ---- | M] (Microsoft Corporation) -- C:\Windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16661_none_420fe3fa2b8113bd\comctl32.dll
MOD - [2009/07/13 20:16:14 | 000,040,960 | ---- | M] (Microsoft Corporation) -- C:\Windows\SysWOW64\sfc_os.dll
MOD - [2009/07/13 20:15:44 | 002,340,864 | ---- | M] (Microsoft Corporation) -- C:\Windows\SysWOW64\msi.dll
MOD - [2009/07/13 20:15:44 | 000,015,872 | ---- | M] (Microsoft Corporation) -- C:\Windows\SysWOW64\msiltcfg.dll
MOD - [2009/07/13 20:10:22 | 000,002,560 | ---- | M] (Microsoft Corporation) -- C:\Windows\SysWOW64\sfc.dll
SRV:64bit: - [2010/10/13 23:28:54 | 000,245,352 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\McAfee\SystemCore\mfefire.exe -- (mfefire)
SRV:64bit: - [2010/10/13 23:28:54 | 000,200,056 | ---- | M] () [Unknown | Running] -- C:\Program Files\Common Files\McAfee\SystemCore\\mcshield.exe -- (McShield)
SRV:64bit: - [2010/10/13 23:28:54 | 000,149,032 | ---- | M] (McAfee, Inc.) [Unknown | Running] -- C:\Windows\SysNative\mfevtps.exe -- (mfevtp)
SRV:64bit: - [2010/10/07 21:34:28 | 000,509,416 | ---- | M] (McAfee, Inc.) [On_Demand | Stopped] -- C:\Program Files\McAfee\VirusScan\mcods.exe -- (McODS)
SRV:64bit: - [2010/03/10 11:14:44 | 000,355,440 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe -- (McProxy)
SRV:64bit: - [2010/03/10 11:14:44 | 000,355,440 | ---- | M] (McAfee, Inc.) [Auto | Start_Pending] -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe -- (McNASvc)
SRV:64bit: - [2010/03/10 11:14:44 | 000,355,440 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe -- (McNaiAnn)
SRV:64bit: - [2010/03/10 11:14:44 | 000,355,440 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe -- (mcmscsvc)
SRV:64bit: - [2010/03/10 11:14:44 | 000,355,440 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe -- (McMPFSvc)
SRV:64bit: - [2010/01/29 16:18:20 | 000,357,456 | ---- | M] (Logitech, Inc.) [On_Demand | Stopped] -- C:\Program Files\Common Files\LogiShrd\Bluetooth\LBTServ.exe -- (LBTServ)
SRV:64bit: - [2010/01/07 15:37:03 | 001,052,328 | ---- | M] ( ) [Auto | Running] -- C:\Windows\SysNative\lxeccoms.exe -- (lxec_device)
SRV:64bit: - [2010/01/07 15:36:58 | 000,033,960 | ---- | M] () [Auto | Running] -- C:\Windows\SysNative\spool\DRIVERS\x64\3\\lxecserv.exe -- (lxecCATSCustConnectService)
SRV:64bit: - [2009/07/13 20:41:27 | 001,011,712 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Windows Defender\MpSvc.dll -- (WinDefend)
SRV - [2011/02/16 15:49:08 | 000,101,048 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files (x86)\McAfee\SiteAdvisor\McSACore.exe -- (McAfee SiteAdvisor Service)
SRV - [2010/10/14 18:27:38 | 000,092,216 | ---- | M] (Hewlett-Packard Company) [Auto | Running] -- C:\Program Files (x86)\Hewlett-Packard\Shared\HPDrvMntSvc.exe -- (HPDrvMntSvc.exe)
SRV - [2010/04/16 18:09:06 | 000,246,520 | ---- | M] (WildTangent, Inc.) [On_Demand | Stopped] -- C:\Program Files (x86)\HP Games\HP Game Console\GameConsoleService.exe -- (GameConsoleService)
SRV - [2010/03/18 13:16:28 | 000,130,384 | ---- | M] (Microsoft Corporation) [Auto | Stopped] -- C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe -- (clr_optimization_v4.0.30319_32)
SRV - [2010/01/07 15:36:50 | 000,598,696 | ---- | M] ( ) [Auto | Running] -- C:\Windows\SysWow64\lxeccoms.exe -- (lxec_device)
SRV - [2009/06/10 16:23:09 | 000,066,384 | ---- | M] (Microsoft Corporation) [Disabled | Stopped] -- C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe -- (clr_optimization_v2.0.50727_32)
SRV - [2009/01/26 15:31:10 | 001,153,368 | ---- | M] (Safer Networking Ltd.) [Auto | Running] -- C:\Program Files (x86)\Spybot - Search & Destroy\SDWinSec.exe -- (SBSDWSCService)
DRV:64bit: - [2010/10/13 23:28:54 | 000,529,128 | ---- | M] (McAfee, Inc.) [Kernel | Boot | Running] -- C:\Windows\SysNative\drivers\mfehidk.sys -- (mfehidk)
DRV:64bit: - [2010/10/13 23:28:54 | 000,441,328 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\mfefirek.sys -- (mfefirek)
DRV:64bit: - [2010/10/13 23:28:54 | 000,283,360 | ---- | M] (McAfee, Inc.) [Kernel | System | Running] -- C:\Windows\SysNative\drivers\mfewfpk.sys -- (mfewfpk)
DRV:64bit: - [2010/10/13 23:28:54 | 000,190,136 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\mfeavfk.sys -- (mfeavfk)
DRV:64bit: - [2010/10/13 23:28:54 | 000,121,248 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\mfeapfk.sys -- (mfeapfk)
DRV:64bit: - [2010/10/13 23:28:54 | 000,094,864 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\mferkdet.sys -- (mferkdet)
DRV:64bit: - [2010/10/13 23:28:54 | 000,075,032 | ---- | M] (McAfee, Inc.) [Kernel | System | Running] -- C:\Windows\SysNative\drivers\mfenlfk.sys -- (mfenlfk)
DRV:64bit: - [2010/10/13 23:28:54 | 000,062,800 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\cfwids.sys -- (cfwids)
DRV:64bit: - [2010/02/17 17:52:42 | 000,049,480 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\mfesmfk.sys -- (mfesmfk)
DRV:64bit: - [2010/02/17 17:45:32 | 000,040,904 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\mferkdk.sys -- (mferkdk)
DRV:64bit: - [2009/11/10 06:53:16 | 000,058,384 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\LMouFilt.Sys -- (LMouFilt)
DRV:64bit: - [2009/11/10 06:53:00 | 000,056,336 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\LHidFilt.Sys -- (LHidFilt)
DRV:64bit: - [2009/09/08 19:13:16 | 000,087,600 | ---- | M] (Citrix Systems, Inc.) [Kernel | System | Running] -- C:\Windows\SysNative\drivers\ctxusbm.sys -- (ctxusbm)
DRV:64bit: - [2009/07/30 12:12:56 | 000,339,744 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\nvmf6264.sys -- (NVNET)
DRV:64bit: - [2009/07/13 20:52:21 | 000,106,576 | ---- | M] (Advanced Micro Devices) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\amdsata.sys -- (amdsata)
DRV:64bit: - [2009/07/13 20:52:21 | 000,028,752 | ---- | M] (Advanced Micro Devices) [Kernel | Boot | Running] -- C:\Windows\SysNative\drivers\amdxata.sys -- (amdxata)
DRV:64bit: - [2009/07/13 20:52:20 | 000,194,128 | ---- | M] (AMD Technologies Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\amdsbs.sys -- (amdsbs)
DRV:64bit: - [2009/07/13 20:48:04 | 000,065,600 | ---- | M] (LSI Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\lsi_sas2.sys -- (LSI_SAS2)
DRV:64bit: - [2009/07/13 20:47:48 | 000,077,888 | ---- | M] (Hewlett-Packard Company) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\HpSAMD.sys -- (HpSAMD)
DRV:64bit: - [2009/07/13 20:45:55 | 000,024,656 | ---- | M] (Promise Technology) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\stexstor.sys -- (stexstor)
DRV:64bit: - [2009/07/13 19:39:20 | 000,023,040 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\WSDPrint.sys -- (WSDPrintDevice)
DRV:64bit: - [2009/06/10 15:38:56 | 000,000,308 | ---- | M] () [File_System | On_Demand | Running] -- C:\Windows\SysNative\wbem\ntfs.mof -- (Ntfs)
DRV:64bit: - [2009/06/10 15:34:33 | 003,286,016 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\evbda.sys -- (ebdrv)
DRV:64bit: - [2009/06/10 15:34:28 | 000,468,480 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\bxvbda.sys -- (b06bdrv)
DRV:64bit: - [2009/06/10 15:34:23 | 000,270,848 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\b57nd60a.sys -- (b57nd60a)
DRV:64bit: - [2009/06/10 15:31:59 | 000,031,232 | ---- | M] (Hauppauge Computer Works, Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\hcw85cir.sys -- (hcw85cir)
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = [You must be registered and logged in to see this link.]
IE:64bit: - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = [You must be registered and logged in to see this link.]
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Search_URL = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Search,Default_Search_URL = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Search,SearchAssistant = [You must be registered and logged in to see this link.]
FF - HKLM\software\mozilla\Firefox\Extensions\\{B7082FAA-CB62-4872-9106-E42DD88EDE45}: C:\Program Files (x86)\McAfee\SiteAdvisor [2011/04/01 17:16:28 | 000,000,000 | ---D | M]
O1 HOSTS File: ([2009/06/10 16:00:26 | 000,000,824 | ---- | M]) - C:\Windows\SysNative\drivers\etc\hosts
O2:64bit: - BHO: (scriptproxy) - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\Common Files\McAfee\SystemCore\ScriptSn.20110120180711.dll (McAfee, Inc.)
O2:64bit: - BHO: (McAfee SiteAdvisor BHO) - {B164E929-A1B6-4A06-B104-2CD0E90A88FF} - c:\Program Files (x86)\McAfee\SiteAdvisor\x64\McIEPlg.dll (McAfee, Inc.)
O2 - BHO: (Spybot-S&D IE Protection) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll (Safer Networking Limited)
O2 - BHO: (no name) - {724d43a9-0d85-11d4-9908-00400523e39a} - C:\Program Files (x86)\Siber Systems\AI RoboForm\roboform.dll (Siber Systems Inc.)
O2 - BHO: (scriptproxy) - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files (x86)\Common Files\McAfee\SystemCore\ScriptSn.20110120180711.dll (McAfee, Inc.)
O2 - BHO: (McAfee SiteAdvisor BHO) - {B164E929-A1B6-4A06-B104-2CD0E90A88FF} - c:\Program Files (x86)\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
O2 - BHO: (Lexmark Printable Web) - {D2C5E510-BE6D-42CC-9F61-E4F939078474} - C:\Program Files\Lexmark Printable Web\bho.dll ()
O2 - BHO: (Microsoft Live Search Toolbar Helper) - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - c:\Program Files (x86)\MSN\Toolbar\3.0.0566.0\msneshellx.dll (Microsoft Corp.)
O3:64bit: - HKLM\..\Toolbar: (McAfee SiteAdvisor Toolbar) - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\Program Files (x86)\McAfee\SiteAdvisor\x64\McIEPlg.dll (McAfee, Inc.)
O3 - HKLM\..\Toolbar: (McAfee SiteAdvisor Toolbar) - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\Program Files (x86)\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
O3 - HKLM\..\Toolbar: (Microsoft Live Search Toolbar) - {1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - c:\Program Files (x86)\MSN\Toolbar\3.0.0566.0\msneshellx.dll (Microsoft Corp.)
O3 - HKLM\..\Toolbar: (&RoboForm) - {724d43a0-0d85-11d4-9908-00400523e39a} - C:\Program Files (x86)\Siber Systems\AI RoboForm\roboform.dll (Siber Systems Inc.)
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {1017A80C-6F09-4548-A84D-EDD6AC9525F0} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {604BC32A-9680-40D1-9AC6-E06B23A1BA4C} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (&RoboForm) - {724D43A0-0D85-11D4-9908-00400523E39A} - C:\Program Files (x86)\Siber Systems\AI RoboForm\roboform.dll (Siber Systems Inc.)
O4:64bit: - HKLM..\Run: [EvtMgr6] C:\Program Files\Logitech\SetPointP\SetPoint.exe (Logitech, Inc.)
O4:64bit: - HKLM..\Run: [EzPrint] C:\Program Files (x86)\Lexmark Pro800-Pro900 Series\ezprint.exe ()
O4:64bit: - HKLM..\Run: [lxecmon.exe] C:\Program Files (x86)\Lexmark Pro800-Pro900 Series\lxecmon.exe ()
O4:64bit: - HKLM..\Run: [NvCplDaemon] C:\Windows\SysNative\NvCpl.dll (NVIDIA Corporation)
O4:64bit: - HKLM..\Run: [PC-Doctor for Windows localizer] C:\Program Files\PC-Doctor for Windows\localizer.exe (PC-Doctor, Inc.)
O4:64bit: - HKLM..\Run: [SmartMenu] C:\Program Files\Hewlett-Packard\HP MediaSmart\SmartMenu.exe ()
O4 - HKLM..\Run: [] File not found
O4 - HKLM..\Run: [ConnectionCenter] C:\Program Files (x86)\Citrix\ICA Client\concentr.exe (Citrix Systems, Inc.)
O4 - HKLM..\Run: [HP Remote Solution] C:\Program Files (x86)\Hewlett-Packard\HP Remote Solution\HP_Remote_Solution.exe (Hewlett-Packard)
O4 - HKLM..\Run: [hpsysdrv] c:\Program Files (x86)\Hewlett-Packard\HP Odometer\hpsysdrv.exe (Hewlett-Packard)
O4 - HKLM..\Run: [Lexmark Pro800-Pro900 Series] C:\Program Files (x86)\Lexmark Pro800-Pro900 Series\fm3032.exe ()
O4 - HKLM..\Run: [lxduamon] C:\Program Files (x86) (x86)\Lexmark 5600-6600 Series\lxduamon.exe ()
O4 - HKLM..\Run: [lxdumon.exe] C:\Program Files (x86) (x86)\Lexmark 5600-6600 Series\lxdumon.exe ()
O4 - HKLM..\Run: [mcui_exe] C:\Program Files\McAfee.com\Agent\mcagent.exe (McAfee, Inc.)
O4 - HKCU..\Run: [RoboForm] C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboTaskBarIcon.exe (Siber Systems)
O4 - HKCU..\Run: [SpybotSD TeaTimer] C:\Program Files (x86)\Spybot - Search & Destroy\TeaTimer.exe (Safer-Networking Ltd.)
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktop = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktopChanges = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorAdmin = 5
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorUser = 3
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: PromptOnSecureDesktop = 0
O8:64bit: - Extra context menu item: Customize Menu - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComCustomizeIEMenu.html ()
O8:64bit: - Extra context menu item: Fill Forms - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComFillForms.html ()
O8:64bit: - Extra context menu item: RoboForm Toolbar - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html ()
O8:64bit: - Extra context menu item: Save Forms - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComSavePass.html ()
O8 - Extra context menu item: Add to Google Photos Screensa&ver - C:\Windows\SysWow64\GPhotos.scr (Google Inc.)
O8 - Extra context menu item: Customize Menu - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComCustomizeIEMenu.html ()
O8 - Extra context menu item: Fill Forms - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComFillForms.html ()
O8 - Extra context menu item: RoboForm Toolbar - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html ()
O8 - Extra context menu item: Save Forms - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComSavePass.html ()
O9 - Extra Button: Fill Forms - {320AF880-6646-11D3-ABEE-C5DBF3571F46} - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComFillForms.html ()
O9 - Extra 'Tools' menuitem : Fill Forms - {320AF880-6646-11D3-ABEE-C5DBF3571F46} - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComFillForms.html ()
O9 - Extra Button: Save - {320AF880-6646-11D3-ABEE-C5DBF3571F49} - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComSavePass.html ()
O9 - Extra 'Tools' menuitem : Save Forms - {320AF880-6646-11D3-ABEE-C5DBF3571F49} - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComSavePass.html ()
O9 - Extra Button: RoboForm - {724d43aa-0d85-11d4-9908-00400523e39a} - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html ()
O9 - Extra 'Tools' menuitem : RoboForm Toolbar - {724d43aa-0d85-11d4-9908-00400523e39a} - C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html ()
O9 - Extra 'Tools' menuitem : Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll (Safer Networking Limited)
O13 - gopher Prefix: missing
O16 - DPF: {7530BFB8-7293-4D34-9923-61A11451AFC5} [You must be registered and logged in to see this link.] (OnlineScanner Control)
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.1
O18:64bit: - Protocol\Handler\dssrequest {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\Program Files (x86)\McAfee\SiteAdvisor\x64\McIEPlg.dll (McAfee, Inc.)
O18:64bit: - Protocol\Handler\http\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\http\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\https\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\https\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\livecall {828030A1-22C1-4009-854F-8E305202313F} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\msdaipp - No CLSID value found
O18:64bit: - Protocol\Handler\msdaipp\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\msdaipp\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\ms-itss {0A9007C0-4076-11D3-8789-0000F8105754} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\msnim {828030A1-22C1-4009-854F-8E305202313F} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\mso-offdap11 {32505114-5902-49B2-880A-1F7738E5A384} - Reg Error: Key error. File not found
O18:64bit: - Protocol\Handler\sacore {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\Program Files (x86)\McAfee\SiteAdvisor\x64\McIEPlg.dll (McAfee, Inc.)
O18:64bit: - Protocol\Handler\wlmailhtml {03C514A3-1EFB-4856-9F99-10D7BE1653C0} - Reg Error: Key error. File not found
O18 - Protocol\Handler\dssrequest {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\Program Files (x86)\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
O18 - Protocol\Handler\http\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files (x86)\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
O18 - Protocol\Handler\http\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files (x86)\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
O18 - Protocol\Handler\https\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files (x86)\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
O18 - Protocol\Handler\https\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files (x86)\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
O18 - Protocol\Handler\msdaipp\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files (x86)\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
O18 - Protocol\Handler\msdaipp\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - C:\Program Files (x86)\Common Files\System\Ole DB\MSDAIPP.DLL (Microsoft Corporation)
O18 - Protocol\Handler\sacore {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\Program Files (x86)\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
O18:64bit: - Protocol\Filter\text/xml {807553E5-5146-11D5-A672-00B0D022E945} - Reg Error: Key error. File not found
O20:64bit: - HKLM Winlogon: Shell - (explorer.exe) - C:\Windows\explorer.exe (Microsoft Corporation)
O20:64bit: - HKLM Winlogon: VMApplet - (SystemPropertiesPerformance.exe) - C:\Windows\SysNative\SystemPropertiesPerformance.exe (Microsoft Corporation)
O20:64bit: - HKLM Winlogon: VMApplet - (/pagefile) - File not found
O20 - HKLM Winlogon: Shell - (explorer.exe) - C:\Windows\SysWow64\explorer.exe (Microsoft Corporation)
O20 - HKLM Winlogon: VMApplet - (/pagefile) - File not found
O21:64bit: - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - CLSID or File not found.
O21 - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - CLSID or File not found.
O32 - HKLM CDRom: AutoRun - 1
O33 - MountPoints2\{24f309e9-788e-11df-aebe-7071bc09c092}\Shell - "" = AutoRun
O33 - MountPoints2\{24f309e9-788e-11df-aebe-7071bc09c092}\Shell\AutoRun\command - "" = K:\LaunchU3.exe -a
O35:64bit: - HKLM\..comfile [open] -- "%1" %*
O35:64bit: - HKLM\..exefile [open] -- "%1" %*
O37:64bit: - HKLM\...com [@ = comfile] -- "%1" %*
O37:64bit: - HKLM\...exe [@ = exefile] -- "%1" %*
[2011/04/03 09:42:17 | 000,000,000 | ---D | C] -- C:\Users\Rick Juneau\AppData\Local\Logishrd
[2011/04/03 09:42:11 | 000,000,000 | ---D | C] -- C:\Windows\LastGood
[2011/04/03 09:41:30 | 000,000,000 | ---D | C] -- C:\Program Files\Logitech
[2011/04/03 09:38:23 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Common Files\Adobe
[2011/04/03 09:38:00 | 000,000,000 | -HSD | C] -- C:\Config.Msi
[2011/04/03 09:36:36 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\McAfee
[2011/04/03 08:20:33 | 007,734,240 | ---- | C] (Malwarebytes Corporation ) -- C:\Users\Rick Juneau\Desktop\mbam-setup.exe
[2011/04/02 18:04:34 | 000,580,608 | ---- | C] (OldTimer Tools) -- C:\Users\Rick Juneau\Desktop\OTL.com
[2011/04/02 16:41:33 | 000,000,000 | ---D | C] -- C:\ProgramData\pCp01804nAkCi01804
[2011/03/09 07:31:21 | 001,540,608 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\DWrite.dll
[2011/03/09 07:31:21 | 001,074,176 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\DWrite.dll
[2011/03/09 07:31:21 | 000,902,656 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\d2d1.dll
[2011/03/09 07:31:21 | 000,739,840 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\d2d1.dll
[2011/03/09 07:31:18 | 001,118,720 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\sbe.dll
[2011/03/09 07:31:18 | 000,961,024 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\CPFilters.dll
[2011/03/09 07:31:18 | 000,723,968 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\EncDec.dll
[2011/03/09 07:31:18 | 000,642,048 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\CPFilters.dll
[2011/03/09 07:31:18 | 000,534,528 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\EncDec.dll
[2011/03/09 07:31:18 | 000,259,072 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\mpg2splt.ax
[2011/03/09 07:31:17 | 000,850,432 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\sbe.dll
[2011/03/09 07:31:17 | 000,199,680 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\mpg2splt.ax
[2011/03/09 07:31:16 | 003,138,048 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\mstscax.dll
[2011/03/09 07:31:16 | 002,690,560 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\mstscax.dll
[2011/03/09 07:31:16 | 001,097,216 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysNative\mstsc.exe
[2011/03/09 07:31:16 | 001,034,240 | ---- | C] (Microsoft Corporation) -- C:\Windows\SysWow64\mstsc.exe
[2011/03/08 11:01:15 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Microsoft Streets & Trips
[2011/03/08 11:01:15 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Microsoft Location Finder
[2010/12/02 16:49:51 | 000,364,544 | ---- | C] ( ) -- C:\Windows\SysWow64\lxecinpa.dll
[2010/12/02 16:49:51 | 000,344,064 | ---- | C] ( ) -- C:\Windows\SysWow64\lxeciesc.dll
[2010/12/02 16:49:50 | 000,643,072 | ---- | C] ( ) -- C:\Windows\SysWow64\lxecpmui.dll
[2010/12/02 16:49:49 | 001,048,576 | ---- | C] ( ) -- C:\Windows\SysWow64\lxecserv.dll
[2010/12/02 16:49:49 | 000,847,872 | ---- | C] ( ) -- C:\Windows\SysWow64\lxecusb1.dll
[2010/12/02 16:49:48 | 000,688,128 | ---- | C] ( ) -- C:\Windows\SysWow64\lxechbn3.dll
[2010/12/02 16:49:48 | 000,598,696 | ---- | C] ( ) -- C:\Windows\SysWow64\lxeccoms.exe
[2010/12/02 16:49:48 | 000,577,536 | ---- | C] ( ) -- C:\Windows\SysWow64\lxeclmpm.dll
[2010/12/02 16:49:48 | 000,324,264 | ---- | C] ( ) -- C:\Windows\SysWow64\lxecih.exe
[2010/12/02 16:49:47 | 000,802,816 | ---- | C] ( ) -- C:\Windows\SysWow64\lxeccomc.dll
[2010/12/02 16:49:47 | 000,373,416 | ---- | C] ( ) -- C:\Windows\SysWow64\lxeccfg.exe
[2010/12/02 16:49:47 | 000,372,736 | ---- | C] ( ) -- C:\Windows\SysWow64\lxeccomm.dll
[2011/04/03 09:44:47 | 000,015,792 | -H-- | M] () -- C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-5P-1.C7483456-A289-439d-8115-601632D005A0
[2011/04/03 09:44:47 | 000,015,792 | -H-- | M] () -- C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-5P-0.C7483456-A289-439d-8115-601632D005A0
[2011/04/03 09:42:12 | 000,018,960 | ---- | M] (Logitech, Inc.) -- C:\Windows\SysNative\drivers\LNonPnP.sys
[2011/04/03 09:41:58 | 000,726,316 | ---- | M] () -- C:\Windows\SysNative\PerfStringBackup.INI
[2011/04/03 09:41:58 | 000,623,940 | ---- | M] () -- C:\Windows\SysNative\perfh009.dat
[2011/04/03 09:41:58 | 000,106,316 | ---- | M] () -- C:\Windows\SysNative\perfc009.dat
[2011/04/03 09:39:32 | 000,002,016 | ---- | M] () -- C:\Users\Public\Desktop\Adobe Reader 9.lnk
[2011/04/03 09:36:36 | 000,001,830 | ---- | M] () -- C:\Users\Public\Desktop\McAfee Security Center.lnk
[2011/04/03 09:35:41 | 000,067,584 | --S- | M] () -- C:\Windows\bootstat.dat
[2011/04/03 09:35:37 | 334,942,207 | -HS- | M] () -- C:\hiberfil.sys
[2011/04/03 08:49:38 | 000,001,115 | ---- | M] () -- C:\Users\Public\Desktop\Malwarebytes' Anti-Malware.lnk
[2011/04/03 08:20:33 | 007,734,240 | ---- | M] (Malwarebytes Corporation ) -- C:\Users\Rick Juneau\Desktop\mbam-setup.exe
[2011/04/02 17:57:48 | 000,000,356 | ---- | M] () -- C:\Windows\tasks\HPCeeScheduleForRick Juneau.job
[2011/03/31 19:01:53 | 000,000,497 | ---- | M] () -- C:\Users\Rick Juneau\Desktop\Desktop.lnk
[2011/03/22 20:56:10 | 003,849,384 | ---- | M] () -- C:\Users\Rick Juneau\Desktop\03-22-2011 08;55;52PM.JPG
[2011/03/10 04:18:41 | 000,347,536 | ---- | M] () -- C:\Windows\SysNative\FNTCACHE.DAT
[2011/03/08 11:08:09 | 000,002,737 | ---- | M] () -- C:\Users\Rick Juneau\Desktop\Microsoft Streets & Trips 2007 with GPS Locator.lnk
[2011/04/03 09:38:28 | 000,002,016 | ---- | C] () -- C:\Users\Public\Desktop\Adobe Reader 9.lnk
[2011/04/03 09:38:27 | 000,002,441 | ---- | C] () -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Reader 9.lnk
[2011/04/03 08:49:38 | 000,001,115 | ---- | C] () -- C:\Users\Public\Desktop\Malwarebytes' Anti-Malware.lnk
[2011/03/31 19:01:53 | 000,000,497 | ---- | C] () -- C:\Users\Rick Juneau\Desktop\Desktop.lnk
[2011/03/22 20:56:09 | 003,849,384 | ---- | C] () -- C:\Users\Rick Juneau\Desktop\03-22-2011 08;55;52PM.JPG
[2011/03/08 11:08:09 | 000,002,737 | ---- | C] () -- C:\Users\Rick Juneau\Desktop\Microsoft Streets & Trips 2007 with GPS Locator.lnk
[2011/03/08 11:03:21 | 000,002,737 | ---- | C] () -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Streets & Trips 2007 with GPS Locator.lnk
[2010/12/14 11:09:59 | 000,014,115 | ---- | C] () -- C:\Windows\twspmm.ini
[2010/12/02 16:49:52 | 000,344,064 | ---- | C] () -- C:\Windows\SysWow64\lxeccomx.dll
[2010/12/02 16:49:52 | 000,331,776 | ---- | C] () -- C:\Windows\SysWow64\LXECinst.dll
[2010/12/02 16:49:51 | 000,106,496 | ---- | C] () -- C:\Windows\SysWow64\lxecinsr.dll
[2010/12/02 16:49:51 | 000,057,344 | ---- | C] () -- C:\Windows\SysWow64\lxecjswr.dll
[2010/12/02 16:49:51 | 000,036,864 | ---- | C] () -- C:\Windows\SysWow64\lxeccur.dll
[2010/12/02 16:49:50 | 000,323,584 | ---- | C] () -- C:\Windows\SysWow64\lxecins.dll
[2010/12/02 16:49:50 | 000,262,144 | ---- | C] () -- C:\Windows\SysWow64\lxecinsb.dll
[2010/12/02 16:49:50 | 000,090,112 | ---- | C] () -- C:\Windows\SysWow64\lxeccub.dll
[2010/12/02 16:49:49 | 000,253,952 | ---- | C] () -- C:\Windows\SysWow64\lxeccu.dll
[2010/12/02 16:48:43 | 000,299,008 | ---- | C] () -- C:\Windows\SysWow64\LXECsm.dll
[2010/12/02 16:48:43 | 000,023,552 | ---- | C] () -- C:\Windows\SysWow64\LXECsmr.dll
[2010/06/11 19:10:19 | 001,036,288 | ---- | C] () -- C:\Windows\SysWow64\lxdudrs.dll
[2010/06/11 19:10:19 | 000,081,920 | ---- | C] () -- C:\Windows\SysWow64\lxducaps.dll
[2010/06/11 19:10:19 | 000,069,632 | ---- | C] () -- C:\Windows\SysWow64\lxducnv4.dll
[2010/05/28 16:12:16 | 000,000,376 | ---- | C] () -- C:\Windows\ODBC.INI
[2009/09/29 18:25:16 | 000,013,312 | ---- | C] () -- C:\Windows\LPRES.DLL
[2009/07/14 00:38:36 | 000,067,584 | --S- | C] () -- C:\Windows\bootstat.dat
[2009/07/13 21:35:51 | 000,000,741 | ---- | C] () -- C:\Windows\SysWow64\NOISE.DAT
[2009/07/13 21:34:42 | 000,215,943 | ---- | C] () -- C:\Windows\SysWow64\dssec.dat
[2009/07/13 19:10:29 | 000,043,131 | ---- | C] () -- C:\Windows\mib.bin
[2009/07/13 18:42:10 | 000,064,000 | ---- | C] () -- C:\Windows\SysWow64\BWContextHandler.dll
[2009/07/13 16:03:59 | 000,364,544 | ---- | C] () -- C:\Windows\SysWow64\msjetoledb40.dll
[2009/06/10 16:26:10 | 000,673,088 | ---- | C] () -- C:\Windows\SysWow64\mlang.dat
[2003/01/07 16:05:08 | 000,002,695 | ---- | C] () -- C:\Windows\SysWow64\OUTLPERF.INI
@Alternate Data Stream - 118 bytes -> C:\ProgramData\Temp:5C321E34
rjuneau
Posts Posts : 37
Post by Superdave on 3rd April 2011, 6:57 pm
am running it now in safemode. Is this OK?.
Yes. That's the best way to run it. Please run it again in Normal Mode and post the log.
I don't see the other OTL log named Extras.txt Please try to find it and post it.
* Open OTL
* Copy and Paste the following text in the codebox into the Custom Scans/Fixes window.
:OTL
:COMMANDS
[resethosts]
[purity]
[emptytemp]
[start explorer]
* Click Run Fix
* OTLI2 may ask to reboot the machine. Please do so if asked.
* Click OK
* A report will open. Copy and Paste that report in your next reply.
Download ComboFix by sUBs from one of the below links. Be sure to save it to the Desktop.
If you are using Firefox, make sure that your download settings are as follows:
Close any open web browsers (Firefox, Internet Explorer, etc) before starting ComboFix.
Temporarily disable your anti-virus, and any anti-spyware real-time protection before performing a scan. Click [You must be registered and logged in to see this link.] to see a list of security programs that should be disabled and how to disable them.
Right-click combofix.exe and select Run as Administrator and follow the prompts.
When finished, ComboFix will produce a log for you.
Post the ComboFix log and a new HijackThis log in your next reply.
NOTE: Do not mouseclick ComboFix's window while it is running. That may cause it to stall.
Remember to re-enable your anti-virus and anti-spyware protection when ComboFix is complete.
Captain
Captain
Posts Posts : 4202
Post by rjuneau on 3rd April 2011, 8:46 pm
File Extras.txt from OTL
OTL Extras logfile created on: 4/3/2011 9:37:56 AM - Run 1
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\]
.url[@ = InternetShortcut] -- C:\Windows\SysNative\rundll32.exe (Microsoft Corporation)
.cpl [@ = cplfile] -- C:\Windows\SysWow64\control.exe (Microsoft Corporation)
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\\shell\[command]\command]
batfile [open] -- "%1" %* File not found
cmdfile [open] -- "%1" %* File not found
comfile [open] -- "%1" %* File not found
exefile [open] -- "%1" %* File not found
InternetShortcut [open] -- "C:\Windows\System32\rundll32.exe" "C:\Windows\System32\ieframe.dll",OpenURL %l (Microsoft Corporation)
InternetShortcut [print] -- "C:\Windows\System32\rundll32.exe" "C:\Windows\System32\mshtml.dll",PrintHTML "%1" (Microsoft Corporation)
piffile [open] -- "%1" %* File not found
scrfile [config] -- "%1" File not found
scrfile [install] -- rundll32.exe desk.cpl,InstallScreenSaver %l File not found
scrfile [open] -- "%1" /S File not found
Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1 File not found
Folder [open] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
Folder [explore] -- Reg Error: Value error.
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
"cval" = 1
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc]
"VistaSp1" = 28 4D B2 76 41 04 CA 01 [binary data]
"AntiVirusOverride" = 0
"AntiSpywareOverride" = 0
"FirewallOverride" = 0
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc\Vol]
"DisableNotifications" = 0
"EnableFirewall" = 1
64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
"{071c9b48-7c32-4621-a0ac-3f809523288f}" = Microsoft Visual C++ 2005 Redistributable (x64)
"{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}" = Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148
"{8220EEFE-38CD-377E-8595-13398D740ACE}" = Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17
"{88E60521-1E4E-4785-B9F1-1798A4BD0C30}" = HP MediaSmart SmartMenu
"{95120000-00B9-0409-1000-0000000FF1CE}" = Microsoft Application Error Reporting
"{BCA9334F-B6C9-4F65-9A73-AC5A329A4D04}" = PlayReady PC Runtime amd64
"{F5B09CFD-F0B2-36AF-8DF4-1DF6B63FC7B4}" = Microsoft .NET Framework 4 Client Profile
"Lexmark Pro800-Pro900 Series" = Lexmark Pro800-Pro900 Series
"NVIDIA Drivers" = NVIDIA Drivers
"PC-Doctor for Windows" = Hardware Diagnostic Tools
"SP6" = Logitech SetPoint 6.15
"{07FA4960-B038-49EB-891B-9F95930AA544}" = HP Customer Experience Enhancements
"{08DB3902-2CE0-474D-BCE3-0177766CE9F1}" = HP Support Assistant
"{0BCA9EFD-F2D6-4638-B053-8693BA0404BE}" = Citrix online plug-in (Web)
"{178832DE-9DE0-4C87-9F82-9315A9B03985}" = Windows Live Writer
"{17B4760F-334B-475D-829F-1A3E94A6A4E6}" = HP Setup
"{1896E712-2B3D-45eb-BCE9-542742A51032}" = PictureMover
"{1FBF6C24-C1FD-4101-A42B-0C564F9E8E79}" = CyberLink DVD Suite Deluxe
"{254C37AA-6B72-4300-84F6-98A82419187E}" = ActiveCheck component for HP Active Support Library
"{3023EBDA-BF1B-4831-B347-E5018555F26E}" = Movie Theme Pack for HP MediaSmart Video
"{35021DFB-F9CA-402A-89A2-47F91E506465}" = HP MediaSmart/TouchSmart Netflix
"{3B4E636E-9D65-4D67-BA61-189800823F52}" = Windows Live Communications Platform
"{3EE9BCAE-E9A9-45E5-9B1C-83A4D357E05C}" = eReg
"{40BF1E83-20EB-11D8-97C5-0009C5020658}" = Power2Go
"{40FB8D7C-6FF8-4AF2-BC8B-0B1DB32AF04B}" = HP Advisor
"{44B2A0AB-412E-4F8C-B058-D1E8AECCDFF5}" = Recovery Manager
"{45338B07-A236-4270-9A77-EBB4115517B5}" = Windows Live Sign-in Assistant
"{55392E52-1AAD-44C4-BE49-258FFE72434F}" = Citrix online plug-in (USB)
"{570C2A84-A145-4DF0-AE9D-012584DF09DC}" = SPCA1528 PC Driver
"{6412CECE-8172-4BE5-935B-6CECACD2CA87}" = Windows Live Mail
"{669D4A35-146B-4314-89F1-1AC3D7B88367}" = HPAsset component for HP Active Support Library
"{7FC8C210-A319-4835-A87D-B935EFB4C148}" = Microsoft Live Search Toolbar
"{81128EE8-8EAD-4DB0-85C6-17C2CE50FF71}" = Windows Live Essentials
"{812424AC-A8B5-44E6-8D48-07E939D1AD9A}" = Citrix online plug-in (HDX)
"{84EBDF39-4B33-49D7-A0BD-EB6E2C4E81C1}" = Windows Live Sync
"{91120409-6000-11D3-8CFE-0150048383C9}" = Microsoft Office Standard Edition 2003
"{9DEF9686-CCB2-47B7-BF83-B49EA21FA016}" = HP MediaSmart Demo
"{A85FD55B-891B-4314-97A5-EA96C0BD80B5}" = Windows Live Messenger
"{AC76BA86-7AD7-1033-7B44-A94000000001}" = Adobe Reader 9.4.3
"{ACF60000-22B9-4CE9-98D6-2CCF359BAC07}" = ABBYY FineReader 6.0 Sprint
"{B194272D-1F92-46DF-99EB-8D5CE91CB4EC}" = Adobe AIR
"{B2EE25B9-5B00-4ACF-94F0-92433C28C39E}" = HP MediaSmart Music/Photo/Video
"{B4092C6D-E886-4CB2-BA68-FE5A88D31DE6}_is1" = Spybot - Search & Destroy
"{B8AC1A89-FFD1-4F97-8051-E505A160F562}" = HP Odometer
"{B9A03B7B-E0FF-4FB3-BA83-762E58A1B0AA}" = HP Support Information
"{C59C179C-668D-49A9-B6EA-0121CCFC1243}" = LabelPrint
"{C611CF88-969D-43E6-A877-D6D6439DD081}" = HP Remote Solution
"{C82185E8-C27B-4EF4-2007-4444BC2C2B6D}" = Microsoft Streets & Trips 2007 with GPS Locator
"{CB099890-1D5F-11D5-9EA9-0050BAE317E1}" = PowerDirector
"{CC8E94A2-55C7-4460-953C-2A790180578C}" = LightScribe System Software
"{CF53CF7C-D996-43EB-9904-DBED57C25625}" = Citrix online plug-in (DV)
"{D2C5E510-BE6D-42CC-9F61-E4F939078474}" = Lexmark Printable Web
"{D46D081B-F60E-467E-A7C4-117B70D76731}" = HP Update
"{D6C75F0B-3BC1-4FC9-B8C5-3F7E8ED059CA}" = Windows Live Photo Gallery
"{DCCAD079-F92C-44DA-B258-624FC6517A5A}" = HP MediaSmart DVD
"{DF802C05-4660-418c-970C-B988ADB1D316}" = Microsoft Live Search Toolbar
"{E2DFE069-083E-4631-9B6C-43C48E991DE5}" = Junk Mail filter update
"{E9E34215-82EF-4909-BE2F-F581F0DC9062}" = DirectX for Managed Code Update (Summer 2004)
"{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}" = Microsoft SQL Server 2005 Compact Edition [ENU]
"{F6BD194C-4190-4D73-B1B1-C48C99921BFE}" = Windows Live Call
"{F8131A35-47FD-27AD-116D-0E79AF5DE5EE}" = Acrobat.com
"{FB4BB287-37F9-4E27-9C4D-2D3882E08EFF}" = DVD Menu Pack for HP MediaSmart Video
"Adobe AIR" = Adobe AIR
"AI RoboForm" = AI RoboForm (All Users)
"CitrixOnlinePluginPackWeb" = Citrix online plug-in - web
"ESET Online Scanner" = ESET Online Scanner v3
"HP Remote Solution" = HP Remote Solution
"InstallShield_{1FBF6C24-C1FD-4101-A42B-0C564F9E8E79}" = CyberLink DVD Suite Deluxe
"InstallShield_{3023EBDA-BF1B-4831-B347-E5018555F26E}" = Movie Theme Pack for HP MediaSmart Video
"InstallShield_{40BF1E83-20EB-11D8-97C5-0009C5020658}" = Power2Go
"InstallShield_{B2EE25B9-5B00-4ACF-94F0-92433C28C39E}" = HP MediaSmart Music/Photo/Video
"InstallShield_{C59C179C-668D-49A9-B6EA-0121CCFC1243}" = LabelPrint
"InstallShield_{CB099890-1D5F-11D5-9EA9-0050BAE317E1}" = PowerDirector
"InstallShield_{DCCAD079-F92C-44DA-B258-624FC6517A5A}" = HP MediaSmart DVD
"InstallShield_{FB4BB287-37F9-4E27-9C4D-2D3882E08EFF}" = DVD Menu Pack for HP MediaSmart Video
"MoffFreeCalc_is1" = Moffsoft FreeCalc
"MSC" = McAfee SecurityCenter
"Picasa 3" = Picasa 3
"SpywareBlaster_is1" = SpywareBlaster 4.3
"WildTangent hp Master Uninstall" = HP Games
Error reading Event Logs: The Event Service is not operating properly or the Event Logs are corrupt!
rjuneau
Posts Posts : 37
Post by rjuneau on 3rd April 2011, 8:58 pm
Now I will run the combofix.
Here are the results from the OTL Run Fix:
All processes killed
========== OTL ==========
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5C255C8A-E604-49b4-9D64-90988571CECB}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{5C255C8A-E604-49b4-9D64-90988571CECB}\ not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{1017A80C-6F09-4548-A84D-EDD6AC9525F0} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{1017A80C-6F09-4548-A84D-EDD6AC9525F0}\ not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{604BC32A-9680-40D1-9AC6-E06B23A1BA4C} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{604BC32A-9680-40D1-9AC6-E06B23A1BA4C}\ not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\ deleted successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\\VMApplet:/pagefile deleted successfully.
64bit-Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ShellServiceObjectDelayLoad\\WebCheck deleted successfully.
64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E6FB5E20-DE35-11CF-9C87-00AA005127ED}\ not found.
C:\Windows\System32\drivers\etc\Hosts moved successfully.
HOSTS file reset successfully
[EMPTYTEMP]
User: All Users
User: Default
->Temporary Internet Files folder emptied: 33170 bytes
->Flash cache emptied: 56504 bytes
User: Default User
->Temporary Internet Files folder emptied: 0 bytes
User: Public
User: Rick Juneau
->Temp folder emptied: 219745559 bytes
->Temporary Internet Files folder emptied: 587294241 bytes
->Flash cache emptied: 12792565 bytes
%systemroot% .tmp files removed: 0 bytes
%systemroot%\System32 (64bit) .tmp files removed: 0 bytes
Windows Temp folder emptied: 20079066 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 67563 bytes
RecycleBin emptied: 76558 bytes
Total Files Cleaned = 801.00 mb
OTL by OldTimer - Version 3.2.22.3 log created on 04032011_154901
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\X0WO13CE\&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3306&content1=babes&content2=Thongbabe&type=local&type2=local&tile=266531910&transactionID=513252300[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\X0WO13CE\&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3328&content1=babes&content2=Thongbabe&type=local&type2=local&tile=266531910&transactionID=513252300[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\X0WO13CE\&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3330&content1=babes&content2=Thongbabe&type=local&type2=local&tile=266531910&transactionID=513252300[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\X0WO13CE\affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=5014&content1=home&content2=main[1].html&type=national&type2=national&tile=977960929&transactionID=977960929 not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\X0WO13CE\LA&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3340&content1=gallery&content2=82581&type=local&type2=local&tile=678204598&transactionID=678204598[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\X0WO13CE\market=NEWORLEANS-LA&format=NEWSTALK&pagepos=5014&content1=local&content2=cc-common_babes_thong[1].html&type=national&type2=national&tile=769425871&transactionID=769425871 not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\X0WO13CE\market=NEWORLEANS-LA&format=NEWSTALK&pagepos=5050&content1=local&content2=cc-common_babes_botd1[1].html&type=national&type2=national&tile=271700058&transactionID=271700058 not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\X0WO13CE\NS-LA&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3310&content1=home&content2=main[1].html&type=local&type2=local&tile=630989435&transactionID=630989435 not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\X0WO13CE\rket=NEWORLEANS-LA&format=NEWSTALK&pagepos=5050&content1=local&content2=cc-common_gallery_index[1].html&type=national&type2=national&tile=123602260&transactionID=123602260 not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\X0WO13CE\S-LA&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3306&content1=babes&content2=Rbabe&type=local&type2=local&tile=151503807&transactionID=996232473[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5OYXKGM2\affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=5050&content1=home&content2=main[1].html&type=national&type2=national&tile=952010921&transactionID=952010921 not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5OYXKGM2\iliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3340&content1=gallery&content2=82581&type=national&type2=national&tile=331874301&transactionID=331874301[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5OYXKGM2\market=NEWORLEANS-LA&format=NEWSTALK&pagepos=5014&content1=local&content2=cc-common_babes_botd1[1].html&type=national&type2=national&tile=944797155&transactionID=944797155 not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5OYXKGM2\market=NEWORLEANS-LA&format=NEWSTALK&pagepos=5014&content1=local&content2=cc-common_gallery_index[1].html&type=national&type2=national&tile=44967500&transactionID=44967500 not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5OYXKGM2\market=NEWORLEANS-LA&format=NEWSTALK&pagepos=5050&content1=local&content2=cc-common_babes_botd2[1].html&type=national&type2=national&tile=307227782&transactionID=307227782 not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5OYXKGM2\S-LA&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3330&content1=babes&content2=Rbabe&type=local&type2=local&tile=151503807&transactionID=996232473[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5LY67317\&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3305&content1=babes&content2=Thongbabe&type=local&type2=local&tile=266531910&transactionID=513252300[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5LY67317\-LA&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3306&content1=babes&content2=PGbabe&type=local&type2=local&tile=683836093&transactionID=864254044[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5LY67317\-LA&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3328&content1=babes&content2=PGbabe&type=local&type2=local&tile=683836093&transactionID=864254044[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5LY67317\ffiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3328&content1=babes&content2=Rbabe&type=national&type2=national&tile=151503807&transactionID=996232473[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5LY67317\LA&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3340&content1=gallery&content2=82581&type=local&type2=local&tile=737976400&transactionID=737976400[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5LY67317\m&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=5050&content1=local&content2=cc-common_babes_botd2[1].html&type=national&type2=national&tile=99273726&transactionID=99273726 not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5LY67317\market=NEWORLEANS-LA&format=NEWSTALK&pagepos=5014&content1=local&content2=cc-common_babes_botd2[1].html&type=national&type2=national&tile=636678307&transactionID=636678307 not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\5LY67317\market=NEWORLEANS-LA&format=NEWSTALK&pagepos=5050&content1=local&content2=cc-common_babes_thong[1].html&type=national&type2=national&tile=936748093&transactionID=936748093 not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\2QMT2JMH\-LA&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3305&content1=babes&content2=PGbabe&type=local&type2=local&tile=683836093&transactionID=864254044[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\2QMT2JMH\-LA&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3330&content1=babes&content2=PGbabe&type=local&type2=local&tile=683836093&transactionID=864254044[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\2QMT2JMH\ffiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3330&content1=babes&content2=Rbabe&type=national&type2=national&tile=473604645&transactionID=276410330[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\2QMT2JMH\market=NEWORLEANS-LA&format=NEWSTALK&pagepos=5014&content1=local&content2=cc-common_babes_botd2[1].html&type=national&type2=national&tile=102066471&transactionID=102066471 not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\2QMT2JMH\S-LA&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3305&content1=babes&content2=Rbabe&type=local&type2=local&tile=151503807&transactionID=996232473[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\2QMT2JMH\S-LA&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3305&content1=babes&content2=Rbabe&type=local&type2=local&tile=473604645&transactionID=276410330[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\2QMT2JMH\S-LA&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3306&content1=babes&content2=Rbabe&type=local&type2=local&tile=473604645&transactionID=276410330[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\Low\Temporary Internet Files\Content.IE5\2QMT2JMH\S-LA&affiliate=wrno-fm&market=NEWORLEANS-LA&format=NEWSTALK&pagepos=3328&content1=babes&content2=Rbabe&type=local&type2=local&tile=473604645&transactionID=276410330[1].htm not found!
C:\Users\Rick Juneau\AppData\Local\Temp\FXSAPIDebugLogFile.txt moved successfully.
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\~DF36C5048967AB09EF.TMP not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\~DF42AA6FABEB4BEA86.TMP not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\~DFAFEE9A55BF93D7B4.TMP not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Temp\~DFD08FFA7D502AB74B.TMP not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\JIMPN5SQ\likebox[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\JIMPN5SQ\t26573-ms-removal-tool-problem[1].htm not found!
File\Folder C:\Users\Rick Juneau\AppData\Local\Microsoft\Windows\Temporary Internet Files\Low\Content.IE5\7CJ40T0I\geekpolice_net[1].htm not found!
rjuneau
Posts Posts : 37
Joined Joined : 2009-08-13
Points Points : 27099
Re: MS Removal Tool Problem
Post by rjuneau on 3rd April 2011, 9:21 pm
Will run HijackThis for log.
Log from ComboFix:
ComboFix 11-04-03.01 - Rick Juneau 04/03/2011 16:07:57.1.4 - x64
Microsoft Windows 7 Home Premium 6.1.7600.0.1252.1.1033.18.5887.4579 [GMT -5:00]
Running from: c:\users\Rick Juneau\Desktop\ComboFix.exe
AV: McAfee Anti-Virus and Anti-Spyware *Disabled/Updated* {86355677-4064-3EA7-ABB3-1B136EB04637}
FW: McAfee Firewall *Disabled* {BE0ED752-0A0B-3FFF-80EC-B2269063014C}
SP: McAfee Anti-Virus and Anti-Spyware *Disabled/Updated* {3D54B793-665E-3129-9103-206115370C8A}
SP: Windows Defender *Disabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
* Created a new restore point
-------\Service_WMPNetworkSvc
((((((((((((((((((((((((( Files Created from 2011-03-03 to 2011-04-03 )))))))))))))))))))))))))))))))
2011-04-03 20:49 . 2011-04-03 20:49 -------- d-----w- C:\_OTL
2011-04-03 16:15 . 2011-04-03 16:15 53248 ----a-r- c:\users\Rick Juneau\AppData\Roaming\Microsoft\Installer\{3EE9BCAE-E9A9-45E5-9B1C-83A4D357E05C}\ARPPRODUCTICON.exe
2011-04-03 14:42 . 2011-04-03 14:42 -------- d-----w- c:\users\Rick Juneau\AppData\Local\Logishrd
2011-04-03 14:41 . 2011-04-03 14:41 -------- d-----w- c:\program files\Logitech
2011-04-03 14:38 . 2011-04-03 14:38 -------- d-----w- c:\program files (x86)\Common Files\Adobe
2011-04-02 21:41 . 2011-04-03 14:31 -------- d-----w- c:\programdata\pCp01804nAkCi01804
2011-03-08 16:01 . 2011-03-08 16:02 -------- d-----w- c:\program files (x86)\Microsoft Streets & Trips
2011-03-08 16:01 . 2011-03-08 16:01 -------- d-----w- c:\program files (x86)\Microsoft Location Finder
2011-04-03 14:42 . 2010-05-31 15:03 18960 ----a-w- c:\windows\system32\drivers\LNonPnP.sys
2011-01-26 06:53 . 2011-02-26 05:27 982912 ----a-w- c:\windows\system32\drivers\dxgkrnl.sys
2011-01-26 06:53 . 2011-02-26 05:27 265088 ----a-w- c:\windows\system32\drivers\dxgmms1.sys
2011-01-26 06:31 . 2011-02-26 05:27 144384 ----a-w- c:\windows\system32\cdd.dll
2011-01-07 08:07 . 2011-02-26 05:26 662528 ----a-w- c:\windows\system32\XpsPrint.dll
2011-01-07 08:07 . 2011-02-26 05:26 475648 ----a-w- c:\windows\system32\XpsGdiConverter.dll
2011-01-07 08:06 . 2011-02-26 05:26 46080 ----a-w- c:\windows\system32\atmlib.dll
2011-01-07 07:31 . 2011-02-26 05:26 442880 ----a-w- c:\windows\SysWow64\XpsPrint.dll
2011-01-07 07:31 . 2011-02-26 05:26 288256 ----a-w- c:\windows\SysWow64\XpsGdiConverter.dll
2011-01-07 07:27 . 2011-02-26 05:26 34304 ----a-w- c:\windows\SysWow64\atmlib.dll
2011-01-07 05:49 . 2011-02-26 05:26 366080 ----a-w- c:\windows\system32\atmfd.dll
2011-01-07 05:33 . 2011-02-26 05:26 294400 ----a-w- c:\windows\SysWow64\atmfd.dll
2011-01-05 06:20 . 2011-02-26 05:27 612352 ----a-w- c:\windows\system32\vbscript.dll
2011-01-05 05:37 . 2011-02-26 05:27 428032 ----a-w- c:\windows\SysWow64\vbscript.dll
2011-01-05 04:00 . 2011-02-26 05:28 3127808 ----a-w- c:\windows\system32\win32k.sys
"HPADVISOR"="c:\program files (x86)\Hewlett-Packard\HP Advisor\HPAdvisor.exe" [2009-09-29 1685048]
"LightScribe Control Panel"="c:\program files (x86)\Common Files\LightScribe\LightScribeControlPanel.exe" [2009-08-20 2363392]
"RoboForm"="c:\program files (x86)\Siber Systems\AI RoboForm\RoboTaskBarIcon.exe" [2010-05-28 160328]
"SpybotSD TeaTimer"="c:\program files (x86)\Spybot - Search & Destroy\TeaTimer.exe" [2009-03-05 2260480]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run]
"hpsysdrv"="c:\program files (x86)\hewlett-packard\HP odometer\hpsysdrv.exe" [2008-11-20 62768]
"HP Software Update"="c:\program files (x86)\HP\HP Software Update\HPWuSchd2.exe" [2008-12-08 54576]
"lxdumon.exe"="c:\program files (x86) (x86)\Lexmark 5600-6600 Series\lxdumon.exe" [2010-02-04 676520]
"lxduamon"="c:\program files (x86) (x86)\Lexmark 5600-6600 Series\lxduamon.exe" [2010-02-04 16040]
"Lexmark Pro800-Pro900 Series"="c:\program files (x86)\Lexmark Pro800-Pro900 Series\fm3032.exe" [2010-01-18 316072]
"mcui_exe"="c:\program files\McAfee.com\Agent\mcagent.exe" [2010-11-23 1484856]
"ConnectionCenter"="c:\program files (x86)\Citrix\ICA Client\concentr.exe" [2009-09-13 103768]
"Adobe Reader Speed Launcher"="c:\program files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2011-01-31 35760]
"Adobe ARM"="c:\program files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2010-09-21 932288]
PictureMover.lnk - c:\program files (x86)\PictureMover\Bin\PictureMover.exe [2009-6-3 430080]
"ConsentPromptBehaviorAdmin"= 5 (0x5)
"ConsentPromptBehaviorUser"= 3 (0x3)
"PromptOnSecureDesktop"= 0 (0x0)
[HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\windows nt\currentversion\drivers32]
"aux"=wdmaud.drv
R2 Ca1528av;SPCA1528 Video Camera Service;c:\windows\system32\Drivers\Ca1528av.sys [x]
R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
R2 clr_optimization_v4.0.30319_64;Microsoft .NET Framework NGEN v4.0.30319_X64;c:\windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe [2010-03-18 138576]
R3 Bulk1528;SPCA1528 Still Camera Service;c:\windows\system32\Drivers\Bulk1528.sys [x]
R3 mferkdet;McAfee Inc. mferkdet;c:\windows\system32\drivers\mferkdet.sys [x]
R3 WatAdminSvc;Windows Activation Technologies Service;c:\windows\system32\Wat\WatAdminSvc.exe [x]
R3 WSDPrintDevice;WSD Print Support via UMB;c:\windows\system32\DRIVERS\WSDPrint.sys [x]
S1 ctxusbm;Citrix USB Monitor Driver;c:\windows\system32\DRIVERS\ctxusbm.sys [x]
S1 mfenlfk;McAfee NDIS Light Filter;c:\windows\system32\DRIVERS\mfenlfk.sys [x]
S1 mfewfpk;McAfee Inc. mfewfpk;c:\windows\system32\drivers\mfewfpk.sys [x]
S2 HPDrvMntSvc.exe;HP Quick Synchronization Service;c:\program files (x86)\Hewlett-Packard\Shared\HPDrvMntSvc.exe [2010-10-14 92216]
S2 lxec_device;lxec_device;c:\windows\system32\lxeccoms.exe [2010-01-07 1052328]
S2 lxecCATSCustConnectService;lxecCATSCustConnectService;c:\windows\system32\spool\DRIVERS\x64\3\\lxecserv.exe [2010-01-07 33960]
S2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service;c:\program files (x86)\McAfee\SiteAdvisor\McSACore.exe [2011-02-16 101048]
S2 McMPFSvc;McAfee Personal Firewall Service;c:\program files\Common Files\McAfee\McSvcHost\McSvHost.exe [2010-03-10 355440]
S2 McNaiAnn;McAfee VirusScan Announcer;c:\program files\Common Files\McAfee\McSvcHost\McSvHost.exe [2010-03-10 355440]
S2 mfefire;McAfee Firewall Core Service;c:\program files\Common Files\McAfee\SystemCore\\mfefire.exe [2010-10-14 245352]
S2 mfevtp;McAfee Validation Trust Protection Service;c:\windows\system32\mfevtps.exe [x]
S2 SBSDWSCService;SBSD Security Center Service;c:\program files (x86)\Spybot - Search & Destroy\SDWinSec.exe [2009-01-26 1153368]
S3 cfwids;McAfee Inc. cfwids;c:\windows\system32\drivers\cfwids.sys [x]
S3 mfefirek;McAfee Inc. mfefirek;c:\windows\system32\drivers\mfefirek.sys [x]
*Deregistered* - mfeavfk01
2011-04-03 c:\windows\Tasks\HPCeeScheduleForRick Juneau.job
- c:\program files (x86)\Hewlett-Packard\HP Ceement\HPCEE.exe [2009-10-07 12:22]
2011-02-28 c:\windows\Tasks\PCDRScheduledMaintenance-Delay.job
- c:\program files\PC-Doctor for Windows\pcdrcui.exe [2009-09-18 07:11]
2011-02-28 c:\windows\Tasks\PCDRScheduledMaintenance.job
--------- x86-64 -----------
"combofix"="c:\combofix\CF22175.cfxxe" [X]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2009-07-18 16334368]
"SmartMenu"="c:\program files\Hewlett-Packard\HP MediaSmart\SmartMenu.exe" [2009-09-15 610360]
"PC-Doctor for Windows localizer"="c:\program files\PC-Doctor for Windows\localizer.exe" [2009-09-17 95728]
"lxecmon.exe"="c:\program files (x86)\Lexmark Pro800-Pro900 Series\lxecmon.exe" [2010-01-18 770728]
"EzPrint"="c:\program files (x86)\Lexmark Pro800-Pro900 Series\ezprint.exe" [2010-01-18 139944]
"EvtMgr6"="c:\program files\Logitech\SetPointP\SetPoint.exe" [2010-06-26 1609296]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]
"LoadAppInit_DLLs"=0x0
uLocal Page = c:\windows\system32\blank.htm
mLocal Page = c:\windows\SysWOW64\blank.htm
IE: Customize Menu - [You must be registered and logged in to see this link.] files (x86)\Siber Systems\AI RoboForm\RoboFormComCustomizeIEMenu.html
IE: Fill Forms - [You must be registered and logged in to see this link.] files (x86)\Siber Systems\AI RoboForm\RoboFormComFillForms.html
IE: RoboForm Toolbar - [You must be registered and logged in to see this link.] files (x86)\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html
IE: Save Forms - [You must be registered and logged in to see this link.] files (x86)\Siber Systems\AI RoboForm\RoboFormComSavePass.html
Wow6432Node-HKLM-Run-HP Remote Solution - %ProgramFiles%\Hewlett-Packard\HP Remote Solution\HP_Remote_Solution.exe
AddRemove-{08DB3902-2CE0-474D-BCE3-0177766CE9F1} - c:\program files (x86)\InstallShield Installation Information\{08DB3902-2CE0-474D-BCE3-0177766CE9F1}\setup.exe
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil10n_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\LocalServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil10n_ActiveX.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\TypeLib]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}]
@="Shockwave Flash Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\InprocServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash10n.ocx"
"ThreadingModel"="Apartment"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus]
@="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ProgID]
@="ShockwaveFlash.ShockwaveFlash.10"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash10n.ocx, 1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\TypeLib]
@="{D27CDB6B-AE6D-11cf-96B8-444553540000}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="ShockwaveFlash.ShockwaveFlash"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}]
@="Macromedia Flash Factory Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\InprocServer32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ProgID]
@="FlashFactory.FlashFactory.1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\TypeLib]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="FlashFactory.FlashFactory"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}]
@="IFlashBroker4"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\TypeLib]
"Version"="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\McAfee]
"SymbolicLinkValue"=hex(6):5c,00,72,00,65,00,67,00,69,00,73,00,74,00,72,00,79,
00,5c,00,6d,00,61,00,63,00,68,00,69,00,6e,00,65,00,5c,00,53,00,6f,00,66,00,\
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\PCW\Security]
@Denied: (Full) (Everyone)
c:\program files (x86)\Common Files\LightScribe\LSSrvc.exe
c:\program files (x86)\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
c:\windows\SysWOW64\rundll32.exe
c:\program files (x86)\Hewlett-Packard\HP Remote Solution\HP_Remote_Solution.exe
c:\program files (x86) (x86)\Lexmark 5600-6600 Series\lxduMsdMon.exe
c:\program files (x86)\Citrix\ICA Client\wfcrun32.exe
c:\program files\Logitech\SetPointP\LU\LULnchr.exe
c:\program files\Logitech\SetPointP\LU\LogitechUpdate.exe
c:\program files (x86)\Hewlett-Packard\TouchSmart\Media\Kernel\CLML\CLMLSvc.exe
Completion time: 2011-04-03 16:18:33 - machine was rebooted
ComboFix-quarantined-files.txt 2011-04-03 21:18
Pre-Run: 945,213,829,120 bytes free
Post-Run: 944,550,277,120 bytes free
- - End Of File - - 5A8D110F91EE5BCF37C99A63004E6718
rjuneau
Posts Posts : 37
Post by rjuneau on 3rd April 2011, 9:34 pm
HijackThis Log:
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 4:33:27 PM, on 4/3/2011
Platform: Windows 7 (WinNT 6.00.3504)
MSIE: Internet Explorer v8.00 (8.00.7600.16722)
C:\Program Files (x86)\Hewlett-Packard\HP Advisor\HPAdvisor.exe
C:\Program Files (x86)\Common Files\LightScribe\LightScribeControlPanel.exe
C:\Program Files (x86)\Siber Systems\AI RoboForm\robotaskbaricon.exe
C:\Program Files (x86)\Hewlett-Packard\HP Odometer\hpsysdrv.exe
C:\Program Files (x86)\hp\HP Software Update\hpwuschd2.exe
C:\Program Files (x86) (x86)\Lexmark 5600-6600 Series\lxduMsdMon.exe
C:\Program Files (x86)\Citrix\ICA Client\wfcrun32.exe
C:\Program Files\Logitech\SetPointP\LU\LULnchr.exe
C:\Program Files\Logitech\SetPointP\LU\LogitechUpdate.exe
c:\Program Files (x86)\Hewlett-Packard\TouchSmart\Media\Kernel\CLML\CLMLSvc.exe
C:\Program Files (x86)\Internet Explorer\iexplore.exe
C:\Windows\SysWOW64\Macromed\Flash\FlashUtil10n_ActiveX.exe
C:\Program Files (x86)\Trend Micro\HiJackThis\HiJackThis.exe
C:\Windows\SysWOW64\DllHost.exe
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll
O2 - BHO: RoboForm - {724d43a9-0d85-11d4-9908-00400523e39a} - C:\Program Files (x86)\Siber Systems\AI RoboForm\roboform.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files (x86)\Common Files\McAfee\SystemCore\ScriptSn.20110120180711.dll
O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: McAfee SiteAdvisor BHO - {B164E929-A1B6-4A06-B104-2CD0E90A88FF} - c:\PROGRA~2\mcafee\SITEAD~1\mcieplg.dll
O2 - BHO: Lexmark Printable Web - {D2C5E510-BE6D-42CC-9F61-E4F939078474} - C:\Program Files\Lexmark Printable Web\bho.dll
O2 - BHO: Microsoft Live Search Toolbar Helper - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - c:\Program Files (x86)\MSN\Toolbar\3.0.0566.0\msneshellx.dll
O3 - Toolbar: Microsoft Live Search Toolbar - {1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - c:\Program Files (x86)\MSN\Toolbar\3.0.0566.0\msneshellx.dll
O3 - Toolbar: &RoboForm - {724d43a0-0d85-11d4-9908-00400523e39a} - C:\Program Files (x86)\Siber Systems\AI RoboForm\roboform.dll
O3 - Toolbar: McAfee SiteAdvisor Toolbar - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\PROGRA~2\mcafee\SITEAD~1\mcieplg.dll
O4 - HKLM\..\Run: [hpsysdrv] c:\program files (x86)\hewlett-packard\HP odometer\hpsysdrv.exe
O4 - HKLM\..\Run: [HP Software Update] c:\Program Files (x86)\HP\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [lxdumon.exe] "C:\Program Files (x86) (x86)\Lexmark 5600-6600 Series\lxdumon.exe"
O4 - HKLM\..\Run: [lxduamon] "C:\Program Files (x86) (x86)\Lexmark 5600-6600 Series\lxduamon.exe"
O4 - HKLM\..\Run: [Lexmark Pro800-Pro900 Series] "C:\Program Files (x86)\Lexmark Pro800-Pro900 Series\fm3032.exe" /s
O4 - HKLM\..\Run: [mcui_exe] "C:\Program Files\McAfee.com\Agent\mcagent.exe" /runkey
O4 - HKLM\..\Run: [ConnectionCenter] "C:\Program Files (x86)\Citrix\ICA Client\concentr.exe" /startup
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKCU\..\Run: [HPADVISOR] C:\Program Files (x86)\Hewlett-Packard\HP Advisor\HPAdvisor.exe view=DOCKVIEW
O4 - HKCU\..\Run: [LightScribe Control Panel] C:\Program Files (x86)\Common Files\LightScribe\LightScribeControlPanel.exe -hidden
O4 - HKCU\..\Run: [RoboForm] "C:\Program Files (x86)\Siber Systems\AI RoboForm\RoboTaskBarIcon.exe"
O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files (x86)\Spybot - Search & Destroy\TeaTimer.exe
O4 - Global Startup: PictureMover.lnk = C:\Program Files (x86)\PictureMover\Bin\PictureMover.exe
O8 - Extra context menu item: Customize Menu - [You must be registered and logged in to see this link.] Files (x86)\Siber Systems\AI RoboForm\RoboFormComCustomizeIEMenu.html
O8 - Extra context menu item: Fill Forms - [You must be registered and logged in to see this link.] Files (x86)\Siber Systems\AI RoboForm\RoboFormComFillForms.html
O8 - Extra context menu item: RoboForm Toolbar - [You must be registered and logged in to see this link.] Files (x86)\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html
O8 - Extra context menu item: Save Forms - [You must be registered and logged in to see this link.] Files (x86)\Siber Systems\AI RoboForm\RoboFormComSavePass.html
O9 - Extra button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra 'Tools' menuitem: &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files (x86)\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra button: Fill Forms - {320AF880-6646-11D3-ABEE-C5DBF3571F46} - [You must be registered and logged in to see this link.] Files (x86)\Siber Systems\AI RoboForm\RoboFormComFillForms.html
O9 - Extra 'Tools' menuitem: Fill Forms - {320AF880-6646-11D3-ABEE-C5DBF3571F46} - [You must be registered and logged in to see this link.] Files (x86)\Siber Systems\AI RoboForm\RoboFormComFillForms.html
O9 - Extra button: Save - {320AF880-6646-11D3-ABEE-C5DBF3571F49} - [You must be registered and logged in to see this link.] Files (x86)\Siber Systems\AI RoboForm\RoboFormComSavePass.html
O9 - Extra 'Tools' menuitem: Save Forms - {320AF880-6646-11D3-ABEE-C5DBF3571F49} - [You must be registered and logged in to see this link.] Files (x86)\Siber Systems\AI RoboForm\RoboFormComSavePass.html
O9 - Extra button: RoboForm - {724d43aa-0d85-11d4-9908-00400523e39a} - [You must be registered and logged in to see this link.] Files (x86)\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html
O9 - Extra 'Tools' menuitem: RoboForm Toolbar - {724d43aa-0d85-11d4-9908-00400523e39a} - [You must be registered and logged in to see this link.] Files (x86)\Siber Systems\AI RoboForm\RoboFormComShowToolbar.html
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files (x86)\Spybot - Search & Destroy\SDHelper.dll
O16 - DPF: {7530BFB8-7293-4D34-9923-61A11451AFC5} (OnlineScanner Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - [You must be registered and logged in to see this link.]
O18 - Protocol: dssrequest - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~2\mcafee\SITEAD~1\mcieplg.dll
O18 - Protocol: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~2\mcafee\SITEAD~1\mcieplg.dll
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\Windows\System32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\fxsresm.dll,-118 (Fax) - Unknown owner - C:\Windows\system32\fxssvc.exe (file missing)
O23 - Service: GameConsoleService - WildTangent, Inc. - C:\Program Files (x86)\HP Games\HP Game Console\GameConsoleService.exe
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files (x86)\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: HP Health Check Service - Hewlett-Packard Company - C:\Program Files (x86)\Hewlett-Packard\HP Health Check\hphc_service.exe
O23 - Service: HP Quick Synchronization Service (HPDrvMntSvc.exe) - Hewlett-Packard Company - C:\Program Files (x86)\Hewlett-Packard\Shared\HPDrvMntSvc.exe
O23 - Service: HP Software Framework Service (hpqwmiex) - Hewlett-Packard Company - C:\Program Files (x86)\Hewlett-Packard\Shared\hpqwmiex.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Logitech Bluetooth Service (LBTServ) - Logitech, Inc. - C:\Program Files\Common Files\LogiShrd\Bluetooth\lbtserv.exe
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - c:\Program Files (x86)\Common Files\LightScribe\LSSrvc.exe
O23 - Service: lxecCATSCustConnectService - Lexmark International, Inc. - C:\Windows\system32\spool\DRIVERS\x64\3\\lxecserv.exe
O23 - Service: lxec_device - - C:\Windows\system32\lxeccoms.exe
O23 - Service: McAfee SiteAdvisor Service - McAfee, Inc. - C:\Program Files (x86)\McAfee\SiteAdvisor\McSACore.exe
O23 - Service: McAfee Personal Firewall Service (McMPFSvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Services (mcmscsvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee VirusScan Announcer (McNaiAnn) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\Program Files\McAfee\VirusScan\mcods.exe
O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McShield - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mcshield.exe
O23 - Service: McAfee Firewall Core Service (mfefire) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mfefire.exe
O23 - Service: McAfee Validation Trust Protection Service (mfevtp) - Unknown owner - C:\Windows\system32\mfevtps.exe (file missing)
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\Windows\system32\nvvsvc.exe (file missing)
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: SBSD Security Center Service (SBSDWSCService) - Safer Networking Ltd. - C:\Program Files (x86)\Spybot - Search & Destroy\SDWinSec.exe
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\Windows\system32\sppsvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\Wat\WatUX.exe,-601 (WatAdminSvc) - Unknown owner - C:\Windows\system32\Wat\WatAdminSvc.exe (file missing)
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\Windows\system32\wbengine.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
End of file - 13028 bytes
rjuneau
Posts Posts : 37
Post by Superdave on 4th April 2011, 12:10 am
Please download the [You must be registered and logged in to see this link.] and save it to your desktop.
You will need to enter your name, e-mail address and location in order to access the download page.
  • Once you have downloaded the file, double click the sarsfx icon
  • Review the licence agreement and click on the Accept button
  • The scanner will prompt you to extract the files to C:\SOPHTEMP - DO NOT change this location, simply click the Install button
  • Once the files have been extracted; using Windows Explorer, navigate to C:\SOPHTEMP and double click on the blue shield icon called sargui
  • Ensure that there are checkmarks next to Running processes, Windows registry and Local hard drives, then click Start scan
  • Allow the program to scan your computer - please be patient as it may take some time
  • Once the scan has completed a window will pop-up with the results of the scan - click OK to this
  • In the main window, you will see each of the entries found by the scan (if any)
    • If the scanner generated any warning messages, please click on each warning and copy and paste the text of it into this thread for me to review
    • Once you have posted any warning messages here, you can close the scanner and wait for me to get back to you
  • If you have not had any warnings, any entries which can be cleaned up by the scanner will have a box with a green checkmark in it next to the entry
  • To clean up these entries click on the Clean up checked items button
  • If you accidentally check a file NOT recommended for clean up, you will get a warning message and if necessary can re-select the entries you want to clean up
  • Once you have cleaned the selected files, you will be prompted to re-boot your computer - please do so
  • When you have re-booted, please post a fresh HijackThis log into this thread and tell me how your computer is running now
Captain
Captain
Posts Posts : 4202
Joined Joined : 2010-02-01
Points Points : 83231
