xp sp3 only boots to desktop in a folder...need help
Post by hamza786 on Thu 31 Mar 2011, 11:22 am
I have a Windows XP sp2 dell computer running fine until this afternoon where it was very slow and I had to reboot. Upon reboot it boot with no icons on the desktop, strangely enough all the desktop icons appear in a folder which pops up immediately after login. I can start some of the programs from that folder. Also I have lost the network connectivity where it complains about not having RPC service....please help.
hamza786
Operating System : xp
Re: xp sp3 only boots to desktop in a folder...need help
Post by hamza786 on Thu 31 Mar 2011, 12:17 pm
The desktop has reverted back to its origonal state after running sfc /scannow. The scan completed on a reboot and now it is asking me for a windows xp cd for writing the files to dllcache. I am not able to find the origonal cd...is there a way to get around this.
Also is there a way to find out what really happened, or caused the failure in the first place?
hamza786
Post by Sneakyone on Thu 31 Mar 2011, 2:56 pm
Sounds like a problem with explorer.exe.
Please download OTL to your Desktop. (If you already have it downloaded, then just follow the instructions below).
    %systemroot%\*. /mp /s
    %systemroot%\system32\*.sys
    %SYSTEMDRIVE%\*.*
    %PROGRAMFILES%\*.
    %appdata%\*.*
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    ahcix86.sys
    KR10N.sys
    disk.sys
    nvstor32.sys
    ahcix86s.sys
    nvrd32.sys
    symmpi.sys
    adp3132.sys
    mv61xx.sys
    usbstor.sys
    /md5stop
    CREATERESTOREPOINT
Sneakyone
Tech Officer
Tech Officer
Post by Sponsored content Today at 11:33 am
