Help urgent please-System Restore not working
Post by IPrani on Tue Mar 29, 2011 5:53 am
For past month or so have been trying to do a system restore on my computer but when I try...it would not and instead it would shut down after I tell it too......then bring up "preparing to restore box and in one sec shut down and restart. On restart it would boot up and then say restoration unsuccessful. I am cluless why its doing this. Ontop of that it since past hour the computer screen has been zigzag screen and I would have to shutdown and restart....Help would be really appreciated.
I do not have a Windows recovery CD if it comes to me having to do a recovery. My laptop netpad mini computer is an ASUS EeePC
IPrani
Posts Posts : 8
Joined Joined : 2011-02-10
Points Points : 21339
Re: Help urgent please-System Restore not working
Post by Nazzgull on Tue Mar 29, 2011 8:24 am
It look like you have a software problem. I'm pretty sure that reinstalling Windows should solve all your problems. Anyway, you don't have CD. I suggest you to get one, at least from your friends, just for repair process and they can took cd back. I am unable to help you without CD.
Let me know if you catch up some dics.
Regards,
Points Points : 40455
Post by IPrani on Thu Mar 31, 2011 1:22 am
not have been able too but is there any way I can restore computer to factory default settings using any of the function buttons and wil that solve this problem?
IPrani
Posts Posts : 8
Post by YehiaPC on Thu Mar 31, 2011 9:21 am
Well i can provide you with a W7 copy,which doesn't require booting or CD's
It's just like an .exe , you click it and it does it job by its self.
@ Nazzgull : Let me know please if i can post links ?
Wish you best of luck.
YehiaPC
Posts Posts : 77
Joined Joined : 2011-03-29
OS OS : W7
Points Points : 20960
