Registry Problem
Registry Problem
Post by Geek3 on Thu 17 Mar 2011, 2:15 pm
I am having troubles using my Windows XP System Restore tool. I am running on Windows XP SP3.
I have ran a Malwarebytes Anti-Malware full scan and it has found nothing. Also, I have ESET Smart Security 4 and it found nothing. Therefore, I believe it has to do something with my registry.
I even tried System Restore using safe mode, but still there is no luck. It's the same as if I started it with Windows starting normally.
Some of the symptoms:
- My computer's internet now only gets limited connectivity and I cannot connect to the internet.
- Also, when I launch system restore, I get some error messages concerning debugging.
This includes:
(A run-time error has occurred)
Line: 1545
Error: Unspecified Error
Line: 1968
Line: 636
- From time to time, I get svchost errors that give me a countdown of 1 minute then my computer automatically shuts off.
Any help is greatly appreciated. I hope my issue gets resolved soon.
Geek3
Operating System : XP
Re: Registry Problem
Post by Nazzgull on Fri 18 Mar 2011, 8:37 pm
Hi and welcome to GeekPolice.net
Please insert your Windows XP CD in CD/DVD Drive and follow instructions bellow:
Go to Start > Run > type CMD and press Enter.
In Command Prompt window plea type next command and press Enter to start it.
SFC /SCANNOW
It should scan your computer for damaged, or missing system files and replace/add new one from installation disc.
After that, please download CCLeaner and run Registry Repair process > Fix all errors and restart your computer.
Let me know if you still have problems.
Regards,
Visit us on social networks : GeekPolice on Facebook! - GeekPolice on Twitter!
Tech Advisor
Tech Advisor
Operating System : Windows 7 Professional 64bit
Post by Geek3 on Sat 19 Mar 2011, 10:35 am
Thanks for your reply.
I have tried this process before you have recommended it. However, there was still no luck.
I have resolved the problem by inserting the Windows XP disc and do a repair installation. It fixed some of the issues and I'll take care of the rest.
Thanks again.
Geek3
Post by Sponsored content Today at 11:31 am
