Router Connection Problems
Post by Rodel Ituralde on 16th February 2011, 2:03 am
Hi guys.
I'll try to cut my story short so that I don't leave you confused. Smile
Basically, this is the original setup for internet at home:
1. 2 Routers (Netgear and Telstra BIG) downstairs (each is on a different internet account).
2. The main router (Netgear) downstairs is plugged into a computer.
3. An ethernet cable is connected to that router and goes upstairs to another router (TP Link).
4. All computers upstairs connect to the router upstairs wirelessly.
For the months leading up to January 2011 this setup worked fine.....And then the problems began. Please (puppy eyes)
To begin with the TP Link router started to drop internet at random intervals. So, after a week of that happening I decided to change the ethernet cable with a new one in case the old cable was faulty. No change. The internet kept dropping out. So I began to wonder which router was the issue. To be on the safe side I decided to buy a Belkin router (compatible with 2 story houses) and installed that downstairs. The old Netgear router was put aside with the TP Link router still in place upstairs. No success. In fact, I had no internet downstairs at random intervals as well. Can't Believe It
So I decided perhaps it was the TP Link router upstairs. I switched it with the old Netgear router from downstairs and tried again. Again, no internet upstairs and no internet downstairs. HOWEVER, once I disconnected the upstairs router, I had wireless internet from the new Belkin router downstairs and it gave perfect internet via ethernet cable to the connected computer.
So what went wrong? Start of January it was fine. Now if I plug in a router upstairs I lose internet to both routers (upstairs and downstairs).
I have replaced the cords, changed routers, bought a new router, reset the wireless networks, etc with no luck. Does anyone have ideas or suggestions I could try to find out what the issue is?
Thanks. Smile
Rodel Ituralde
Posts Posts : 387
Joined Joined : 2011-01-27
OS OS : Windows 7 Home Edition 32-bit, Windows 7 Home Edition 64-bit and Ubuntu 10.4
Protection Protection : avast!, SpywareBlaster, MBAM
Points Points : 23042
Re: Router Connection Problems
Post by Rodel Ituralde on 19th February 2011, 10:59 pm
bump Smile
Rodel Ituralde
Posts Posts : 387
