Help with virus removal
Post by wrestler514 on Wed 02 Feb 2011, 8:52 am
Whenever i try to open up windows or other spyware removal software i get an error message titled " Palidium Pro" and this will not let me open anything saying i have malicious attacks on my OS or something along those lines.........Can anyone help walk me through removing this and any other spyware or viruses that maybe on my computer.
wrestler514
Operating System : XP
Re: Help with virus removal
Post by Superdave on Wed 02 Feb 2011, 10:51 am
Please download and run the below tool named Rkill (courtesy of BleepingComputer.com) which may help allow other programs to run.
Save Rkill to your desktop.
There are 3 different versions. If one of them won't run then download and try to run the other one.
Vista and Win7 users need to right click Rkill and choose Run as Administrator
You only need to get one of these to run, not all of them. You may get warnings from your antivirus about this tool, ignore them or shutdown your antivirus.
* Rkill.exe
* Rkill.com
* Rkill.scr
Once you've gotten one of them to run then try to immediately run the following.
SUPERAntiSpyware
Download SuperAntispyware Free Edition (SAS)
* If you encounter any problems while downloading the updates, manually download and unzip them from here
•Scan for tracking cookies
Please leave the others unchecked
Tech Staff
Tech Staff
Post by wrestler514 on Sat 19 Feb 2011, 9:02 am
Generated 02/10/2011 at 05:30 PM
Application Version : 4.48.1000
Core Rules Database Version : 6375
Trace Rules Database Version: 4187
Scan type : Complete Scan
Total Scan Time : 01:43:40
Memory items scanned : 459
Memory threats detected : 0
Registry items scanned : 7422
Registry threats detected : 1358
File items scanned : 67465
File threats detected : 404
Trojan.Agent/Gen-CDesc[Gen]
[bwefhcgl] C:\DOCUME~1\ADMINI~1\LOCALS~1\TEMP\LGHMTWFFR\KHTHOJWTSBL.EXE
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\LOCAL SETTINGS\TEMP\00103004.EXE
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\LOCAL SETTINGS\TEMP\LGHMTWFFR\KHTHOJWTSBL.EXE
C:\SYSTEM VOLUME INFORMATION\_RESTORE{BC4371B6-2E7A-462A-91AD-5BF999D1ED91}\RP793\A0134923.EXE
C:\WINDOWS\TEMP\0.08816413391728539.EXE
C:\WINDOWS\Prefetch\KHTHOJWTSBL.EXE-0215EDF2.pf
Trojan.Agent/Gen-AVCPack
[{1AFA6809-5BB1-B391-0F5A-7F0F24DBFBB3}] C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\APPLICATION DATA\UVTIO\YVRU.EXE
Trojan.Agent/Gen-VirTool[Red]
[lprrkeel] C:\DOCUME~1\ADMINI~1\LOCALS~1\TEMP\YFUCWCDXV\LEBYQGRLAJB.EXE
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\LOCAL SETTINGS\TEMP\0.4932574688454239.EXE
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\LOCAL SETTINGS\TEMP\0.737294236416081.EXE
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\LOCAL SETTINGS\TEMP\YFUCWCDXV\LEBYQGRLAJB.EXE
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\LOCAL SETTINGS\TEMPORARY INTERNET FILES\CONTENT.IE5\FVLRVTWW\KQFLCNCMHL[1].EXE
Adware.Tracking Cookie
C:\Documents and Settings\Administrator\Cookies\administrator@insightexpressai[2].txt
150.memecounter.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
a.ads1.msn.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
a.ads2.msads.net [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
adsatt.espn.go.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
advprotraffic.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
b.ads2.msads.net [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
babbasex.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
bannerfarm.ace.advertising.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
banners.securedataimages.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
broadcast.piximedia.fr [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
cdn-[You must be registered and logged in to see this link.] [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
cdn4.specificclick.net [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
chat.adultfriendfinder.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
cheapbastardsbigpornwarehouse.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
content3.pornkolt.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
core.insightexpressai.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
countdownpage.createyourcountdown.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
crackle.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
ec.atdmt.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
embed.pornrabbit.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
espn360.channelfinder.net [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
files.adbrite.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
flvplayer2.hardsextube.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
googleads.g.doubleclick.net [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
ia.media-imdb.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
indieclick.3janecdn.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
interclick.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
m1.2mdn.net [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
macromedia.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
maxporn.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media-macys.pictela.net [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media.camelmedia.net [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media.dormitory.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media.entertonement.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media.mtvnservices.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media.nbclosangeles.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media.resulthost.org [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media.scanscout.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media.tattomedia.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media.thewb.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media.underarmour.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media.wfrv.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media0.fux.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media1.break.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
media1.pornbase.org [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
mediaforgews.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
mediaplex.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
mediaserver.vrxstudios.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
msnbcmedia.msn.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
naiadsystems.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
nederporn.tv [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
objects.tremormedia.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
pornminded.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
pornoprinzen.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
pov-porn-tube.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
s0.2mdn.net [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
secure-us.imrworldwide.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
serving-sys.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
sex.healthguru.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
spe.atdmt.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
static.community.livesex.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
static.nicheflixxx.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
static.pornturbo.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
static.sexsearch.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
static.sexsearchcom.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
static.xxxbunker.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
static.xxxmatch.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
static.youporn.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
tour.f***.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
udn.specificclick.net [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
video.pornorama.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
video.redorbit.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
videos.allelitepass.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
vidii.hardsextube.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
wwwstatic.megaporn.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
xxxstash.com [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
xxxtv.us.to [ C:\Documents and Settings\Administrator\Application Data\Macromedia\Flash Player\#SharedObjects\CS673LVL ]
.atdmt.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.doubleclick.net [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.realmedia.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.network.realmedia.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.statcounter.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.collective-media.net [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
ad.yieldmanager.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.invitemedia.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.adbrite.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.advertising.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.zedo.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.adinterax.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.yieldmanager.net [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.247realmedia.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
counter.surfcounters.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.charter.122.2o7.net [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.ehg-chartercommunications.hitbox.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.serving-sys.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.specificclick.net [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.interclick.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.trafficmp.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.lfstmedia.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
bridge2.admarketplace.net [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.ads.pointroll.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.fastclick.net [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.overture.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.advertise.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
d.dmcpmtrack.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.casalemedia.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.burstnet.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
rotator.adjuggler.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.ru4.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.media6degrees.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.harrenmedianetwork.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.imrworldwide.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.questionmarket.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.specificmedia.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.apmebf.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.mediaplex.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.clicksor.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
[You must be registered and logged in to see this link.] [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.burstbeacon.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
dc.tremormedia.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.adxpose.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.tribalfusion.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.insightexpressai.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.bs.serving-sys.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
n-traffic.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
click.scour.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.lucidmedia.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.legolas-media.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.richmedia.yahoo.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.revsci.net [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.pro-market.net [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.apartmentfinder.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.viacom.adbureau.net [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.ero-advertising.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
nederporn.tv [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
1xxx.cqcounter.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.adxpansion.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.adultadworld.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.at.atwola.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.tacoda.at.atwola.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
vidasco.rotator.hadj7.adjuggler.net [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.dmtracker.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.adecn.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
affiliate.gmtracker.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
wrestler514
Post by wrestler514 on Sat 19 Feb 2011, 9:03 am
.bet.122.2o7.net [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
.clickboothlnk.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
publishers.clickbooth.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
statse.webtrendslive.com [ C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\jye5e5gx.default\cookies.sqlite ]
C:\Documents and Settings\Administrator\Local Settings\Temp\Cookies\administrator@ad.yieldmanager[1].txt
C:\Documents and Settings\Administrator\Local Settings\Temp\Cookies\administrator@ads.pointroll[1].txt
C:\Documents and Settings\Administrator\Local Settings\Temp\Cookies\administrator@apmebf[1].txt
C:\Documents and Settings\Administrator\Local Settings\Temp\Cookies\administrator@atdmt[1].txt
C:\Documents and Settings\Administrator\Local Settings\Temp\Cookies\administrator@content.yieldmanager.edgesuite[1].txt
C:\Documents and Settings\Administrator\Local Settings\Temp\Cookies\administrator@content.yieldmanager[1].txt
C:\Documents and Settings\Administrator\Local Settings\Temp\Cookies\administrator@doubleclick[1].txt
C:\Documents and Settings\Administrator\Local Settings\Temp\Cookies\administrator@mediaplex[1].txt
C:\Documents and Settings\Administrator\Local Settings\Temp\Cookies\administrator@questionmarket[2].txt
C:\Documents and Settings\Administrator\Local Settings\Temp\Cookies\administrator@trafficmp[1].txt
cdn4.specificclick.net [ C:\Documents and Settings\LocalService\Application Data\Macromedia\Flash Player\#SharedObjects\LN2K6JGM ]
media.mtvnservices.com [ C:\Documents and Settings\LocalService\Application Data\Macromedia\Flash Player\#SharedObjects\LN2K6JGM ]
media.scanscout.com [ C:\Documents and Settings\LocalService\Application Data\Macromedia\Flash Player\#SharedObjects\LN2K6JGM ]
media1.break.com [ C:\Documents and Settings\LocalService\Application Data\Macromedia\Flash Player\#SharedObjects\LN2K6JGM ]
objects.tremormedia.com [ C:\Documents and Settings\LocalService\Application Data\Macromedia\Flash Player\#SharedObjects\LN2K6JGM ]
secure-us.imrworldwide.com [ C:\Documents and Settings\LocalService\Application Data\Macromedia\Flash Player\#SharedObjects\LN2K6JGM ]
media.scanscout.com [ C:\Documents and Settings\NetworkService\Application Data\Macromedia\Flash Player\#SharedObjects\S7CMW5TS ]
media1.break.com [ C:\Documents and Settings\NetworkService\Application Data\Macromedia\Flash Player\#SharedObjects\S7CMW5TS ]
objects.tremormedia.com [ C:\Documents and Settings\NetworkService\Application Data\Macromedia\Flash Player\#SharedObjects\S7CMW5TS ]
secure-us.imrworldwide.com [ C:\Documents and Settings\NetworkService\Application Data\Macromedia\Flash Player\#SharedObjects\S7CMW5TS ]
Adware.MyWebSearch/FunWebProducts
HKLM\SOFTWARE\FunWebProducts
HKLM\SOFTWARE\FunWebProducts\Installer
HKLM\SOFTWARE\FunWebProducts\Installer#Dir
HKLM\SOFTWARE\FunWebProducts\Installer#PluginPath
HKLM\SOFTWARE\FunWebProducts\Installer#CurInstall
HKLM\SOFTWARE\FunWebProducts\Installer#sr
HKLM\SOFTWARE\FunWebProducts\Installer#pl
C:\Program Files\FunWebProducts\Installr\1.bin\F3EZSETP.DLL
C:\Program Files\FunWebProducts\Installr\1.bin\F3PLUGIN.DLL
C:\Program Files\FunWebProducts\Installr\1.bin\NPFUNWEB.DLL
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\DESKTOP\RETROGAMER.EXE
Browser Hijacker.Internet Explorer Settings Hijack
HKU\S-1-5-21-839522115-1606980848-1708537768-500\Software\Microsoft\Internet Explorer\SearchScopes#URL [ [You must be registered and logged in to see this link.] ]
Malware.Trace
C:\Documents and Settings\Administrator\Local Settings\Application Data\SYSSVC.EXE
C:\Documents and Settings\Administrator\Application Data\ASDFASFAS.BAT
HKU\S-1-5-21-839522115-1606980848-1708537768-500\Software\qni8hj710fdl
Backdoor.Bot[ZBot]
HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{19127ad2-394b-70f5-c650-b97867baa1f7}
HKU\S-1-5-21-839522115-1606980848-1708537768-500\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{19127ad2-394b-70f5-c650-b97867baa1f7}
HKU\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{19127ad2-394b-70f5-c650-b97867baa1f7}
HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{43bf8cd1-c5d5-2230-7bb2-98f22c2b7dc6}
HKU\S-1-5-21-839522115-1606980848-1708537768-500\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{43bf8cd1-c5d5-2230-7bb2-98f22c2b7dc6}
HKU\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{43bf8cd1-c5d5-2230-7bb2-98f22c2b7dc6}
Security.HiJack[ImageFileExecutionOptions]
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\A.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\A.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AAVGAPI.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AAVGAPI.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AAWTRAY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AAWTRAY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ABOUT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ABOUT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AD-AWARE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AD-AWARE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ADAWARE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ADAWARE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ADVXDWIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ADVXDWIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ADWAREPRJ.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ADWAREPRJ.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AGENT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AGENT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AGENTSVR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AGENTSVR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AGENTW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AGENTW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ALERTSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ALERTSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ALEVIR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ALEVIR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ALOGSERV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ALOGSERV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ALPHAAV
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ALPHAAV#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ALPHAAV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ALPHAAV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ALUSCHEDULERSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ALUSCHEDULERSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AMON9X.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AMON9X.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTI-VIRUS PROFESSIONAL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTI-VIRUS PROFESSIONAL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTISPYWARXP2009.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTISPYWARXP2009.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUSPLUS
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUSPLUS#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUSPLUS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUSPLUS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUSPRO_2010.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUSPRO_2010.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUSXP
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUSXP#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUSXP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUSXP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUSXPPRO2009.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUSXPPRO2009.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUS_PRO.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTIVIRUS_PRO.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ANTS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\APIMONITOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\APIMONITOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\APLICA32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\APLICA32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ARR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ARR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ARRAKIS3.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ARRAKIS3.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHAVAST.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHAVAST.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHBUG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHBUG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHCHEST.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHCHEST.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHCNSNT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHCNSNT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHDISP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHDISP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHLOGV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHLOGV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHMAISV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHMAISV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHPOPWZ.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHPOPWZ.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHQUICK.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHQUICK.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHSERV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHSERV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHSIMP2.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHSIMP2.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHSIMPL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHSIMPL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHSKPCC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHSKPCC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHSKPCK.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHSKPCK.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHUPD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHUPD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHWEBSV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASHWEBSV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASWCHLIC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASWCHLIC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASWREGSVR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASWREGSVR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASWRUNDLL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASWRUNDLL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASWUPDSV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ASWUPDSV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ATCON.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ATCON.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ATGUARD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ATGUARD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ATRO55EN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ATRO55EN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ATUPDATER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ATUPDATER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ATWATCH.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ATWATCH.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AU.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AU.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AUPDATE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AUPDATE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AUTO-PROTECT.NAV80TRY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AUTO-PROTECT.NAV80TRY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AUTOTRACE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AUTOTRACE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AUTOUPDATE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AUTOUPDATE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AV360.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AV360.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVADMIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVADMIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVCARE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVCARE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVCENTER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVCENTER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVCIMAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVCIMAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVCONFIG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVCONFIG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVENGINE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVENGINE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGCC32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGCC32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGCHK.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGCHK.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGCMGR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGCMGR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGCSRVX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGCSRVX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGDUMPX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGDUMPX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGEMC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGEMC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGIPROXY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGIPROXY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGNSX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGNSX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGNT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGNT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGRSX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGRSX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGSCANX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGSCANX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGSERV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGSERV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGSERV9.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGSERV9.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGSRMAX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGSRMAX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGTRAY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGTRAY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGUI.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGUI.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGUPD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGUPD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGWDSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVGWDSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVKPOP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVKPOP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVKSERVICE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVKSERVICE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVKWCTL9.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVKWCTL9.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVLTMAIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVLTMAIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVMAILC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVMAILC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVMCDLG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVMCDLG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVNOTIFY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVNOTIFY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVSYNMGR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVSYNMGR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVUPGSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVUPGSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVWEBGRD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVWEBGRD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVWIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVWIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVWINNT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVWINNT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVWSC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVWSC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVWUPD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVWUPD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVWUPSRV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVWUPSRV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVXMONITOR9X.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVXMONITOR9X.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVXMONITORNT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVXMONITORNT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVXQUAR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AVXQUAR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\B.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\B.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BACKWEB.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BACKWEB.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BARGAINS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BARGAINS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDAGENT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDAGENT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDFVCL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDFVCL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDFVWIZ.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDFVWIZ.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDINPROCPATCH.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDINPROCPATCH.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDMCON.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDMCON.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDMSNSCAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDMSNSCAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDREINIT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDREINIT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDSUBWIZ.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDSUBWIZ.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDSURVEY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDSURVEY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDTKEXEC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDTKEXEC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDWIZREG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BDWIZREG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BD_PROFESSIONAL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BD_PROFESSIONAL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BEAGLE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BEAGLE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BELT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BELT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BIDEF.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BIDEF.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BIDSERVER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BIDSERVER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BIPCP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BIPCP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BIPCPEVALSETUP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BIPCPEVALSETUP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BISP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BISP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BLINK.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BLINK.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BLSS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BLSS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BOOTCONF.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BOOTCONF.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BOOTWARN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BOOTWARN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BORG2.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BORG2.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BPC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BPC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BRASIL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BRASIL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BRASTK.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BRASTK.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BRW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BRW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BS120.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BS120.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BSPATCH.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BSPATCH.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BUNDLE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BUNDLE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BVT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\BVT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\C.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\C.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CAVSCAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CAVSCAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CCAPP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CCAPP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CCEVTMGR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CCEVTMGR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CCPXYSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CCPXYSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CCSVCHST.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CCSVCHST.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CDP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CDP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CFD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CFD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CFGWIZ.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CFGWIZ.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CFP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CFP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CFPCONFG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CFPCONFG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CFPLOGVW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CFPLOGVW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CFPUPDAT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CFPUPDAT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CLEAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CLEAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CLEANIELOW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CLEANIELOW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CLEANPC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CLEANPC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CLICK.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CLICK.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CMD32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CMD32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CMDAGENT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CMDAGENT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CMESYS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CMESYS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CMGRDIAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CMGRDIAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CMON016.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CMON016.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CONNECTIONMONITOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CONNECTIONMONITOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CONTROL
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CONTROL#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CPD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CPD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CPF9X206.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CPF9X206.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CPFNT206.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CPFNT206.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CRASHREP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CRASHREP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CSC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CSC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CSSCONFG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CSSCONFG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CSSUPDAT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CSSUPDAT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CSSURF.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CSSURF.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CTRL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CTRL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CWNB181.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CWNB181.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CWNTDWMO.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\CWNTDWMO.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\D.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\D.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DATEMANAGER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DATEMANAGER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DCOMX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DCOMX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DEFALERT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DEFALERT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DEFSCANGUI.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DEFSCANGUI.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DEFWATCH.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DEFWATCH.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DELOEMINFS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DELOEMINFS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DEPUTY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DEPUTY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DIVX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DIVX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DLLCACHE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DLLCACHE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DLLREG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DLLREG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DOORS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DOORS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DOP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DOP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DPF.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DPF.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DPFSETUP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DPFSETUP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DPPS2.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DPPS2.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DRIVERCTRL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DRIVERCTRL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DRWATSON.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DRWATSON.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DRWEB32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DRWEB32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DRWEBUPW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DRWEBUPW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DSSAGENT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DSSAGENT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EFPEADM.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EFPEADM.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EMSW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EMSW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ENT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ENT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ESCANHNT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ESCANHNT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ESCANV95.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ESCANV95.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ESPWATCH.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ESPWATCH.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ETHEREAL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ETHEREAL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ETRUSTCIPE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ETRUSTCIPE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EVPN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EVPN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EXANTIVIRUS-CNET.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EXANTIVIRUS-CNET.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EXE.AVXW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EXE.AVXW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EXPERT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EXPERT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EXPLORE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\EXPLORE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FACT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FACT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FAMEH32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FAMEH32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FAST.EXE
wrestler514
Operating System : XP
Re: Help with virus removal
Post by wrestler514 on Sat 19 Feb 2011, 9:05 am
Options\FAST.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FCH32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FCH32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FIH32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FIH32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FIREWALL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FIREWALL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FIXCFG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FIXCFG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FIXFP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FIXFP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FNRB32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FNRB32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FP-WIN_TRIAL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FP-WIN_TRIAL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FRMWRK32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FRMWRK32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSAA.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSAA.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSAV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSAV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSAV32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSAV32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSAV530STBYB.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSAV530STBYB.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSAV530WTBYB.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSAV530WTBYB.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSAV95.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSAV95.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSGK32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSGK32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSM32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSM32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSMA32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSMA32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSMB32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FSMB32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GATOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GATOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GAV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GAV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GBMENU.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GBMENU.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GBN976RL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GBN976RL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GBPOLL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GBPOLL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GENERICS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GENERICS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GMT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GMT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GUARD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GUARD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GUARDDOG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GUARDDOG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GUARDGUI.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\GUARDGUI.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HACKTRACERSETUP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HACKTRACERSETUP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HBINST.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HBINST.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HBSRV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HBSRV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HISTORY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HISTORY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HOMEAV2010.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HOMEAV2010.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HOTACTIO.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HOTACTIO.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HOTPATCH.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HOTPATCH.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HTLOG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HTLOG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HTPATCH.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HTPATCH.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HWPE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HWPE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HXDL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HXDL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HXIUL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\HXIUL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IAMSTATS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IAMSTATS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IDENTITY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IDENTITY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IDLE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IDLE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IEDLL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IEDLL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IEDRIVER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IEDRIVER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IESHOW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IESHOW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IFW2000.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\IFW2000.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INETLNFO.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INETLNFO.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INFUS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INFUS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INFWIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INFWIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INIT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INIT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INIT32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INIT32.EXE #Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INSTALL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INSTALL.EXE#ApplicationGoo
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INSTALL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INSTALL[1].EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INSTALL[1].EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INSTALL[2].EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INSTALL[2].EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INSTALL[3].EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INSTALL[3].EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INSTALL[4].EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INSTALL[4].EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INSTALL[5].EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INSTALL[5].EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INTDEL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INTDEL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INTREN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\INTREN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ISTSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ISTSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\JAMMER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\JAMMER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\JDBGMRG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\JDBGMRG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\JSRCGEN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\JSRCGEN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KAVLITE40ENG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KAVLITE40ENG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KAVPERS40ENG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KAVPERS40ENG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KAVPF.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KAVPF.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KAZZA.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KAZZA.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KEENVALUE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KEENVALUE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KERIO-PF-213-EN-WIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KERIO-PF-213-EN-WIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KERIO-WRL-421-EN-WIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KERIO-WRL-421-EN-WIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KERIO-WRP-421-EN-WIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KERIO-WRP-421-EN-WIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KILLPROCESSSETUP161.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\KILLPROCESSSETUP161.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LAUNCHER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LAUNCHER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LDNETMON.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LDNETMON.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LDPRO.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LDPRO.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LDPROMENU.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LDPROMENU.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LDSCAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LDSCAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LICMGR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LICMGR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LIVESRV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LIVESRV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LNETINFO.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LNETINFO.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LOADER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LOADER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LOCALNET.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LOCALNET.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LOCKDOWN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LOCKDOWN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LORDPE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LORDPE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LSETUP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LSETUP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LUAU.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LUAU.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LUCOMSERVER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LUCOMSERVER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LUINIT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LUINIT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LUSPT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\LUSPT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MALWAREREMOVAL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MALWAREREMOVAL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MAPISVC32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MAPISVC32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCAGENT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCAGENT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCMNHDLR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCMNHDLR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCMSCSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCMSCSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCNASVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCNASVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCPROXY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCPROXY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCSACORE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCSACORE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCSHELL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCSHELL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCSHIELD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCSHIELD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCSYSMON.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCSYSMON.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCTOOL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCTOOL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCUPDATE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCUPDATE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCVSRTE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCVSRTE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCVSSHLD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MCVSSHLD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MFIN32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MFIN32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MFW2EN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MFW2EN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MFWENG3.02D30.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MFWENG3.02D30.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MGAVRTCL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MGAVRTCL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MGAVRTE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MGAVRTE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MGHTML.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MGHTML.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MGUI.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MGUI.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MINILOG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MINILOG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MMOD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MMOD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MONITOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MONITOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MOSTAT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MOSTAT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MPFAGENT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MPFAGENT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MPFSERVICE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MPFSERVICE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MPFSRV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MPFSRV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MRFLUX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MRFLUX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MRT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MRT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSA.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSA.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSAPP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSAPP.EXE#Debugger
wrestler514
Post by wrestler514 on Sat 19 Feb 2011, 9:06 am
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSBB.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSBB.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSBLAST.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSBLAST.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSCACHE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSCACHE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSCCN32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSCCN32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSCMAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSCMAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSCONFIG
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSCONFIG#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSDM.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSDM.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSDOS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSDOS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSFWSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSFWSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSIEXEC16.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSIEXEC16.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSLAUGH.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSLAUGH.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSMGT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSMGT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSMSGRI32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSMSGRI32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSSMMC32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSSMMC32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSSYS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSSYS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSVXD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MSVXD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MU0311AD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MU0311AD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MWATCH.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\MWATCH.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NAV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NAV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NAVAP.NAVAPSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NAVAP.NAVAPSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NAVDX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NAVDX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NAVSTUB.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NAVSTUB.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NC2000.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NC2000.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NCINST4.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NCINST4.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NDD32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NDD32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NEOMONITOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NEOMONITOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NEOWATCHLOG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NEOWATCHLOG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETARMOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETARMOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETD32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETD32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETINFO.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETINFO.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETMON.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETMON.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETSCANPRO.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETSCANPRO.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETSPYHUNTER-1.2.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETSPYHUNTER-1.2.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETUTILS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NETUTILS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NISSERV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NISSERV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NOD32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NOD32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NORTON_INTERNET_SECU_3.0_407.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NORTON_INTERNET_SECU_3.0_407.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NOTSTART.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NOTSTART.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NPF40_TW_98_NT_ME_2K.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NPF40_TW_98_NT_ME_2K.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NPFMESSENGER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NPFMESSENGER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NPROTECT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NPROTECT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NPSCHECK.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NPSCHECK.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NPSSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NPSSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NSCHED32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NSCHED32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NSSYS32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NSSYS32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NSTASK32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NSTASK32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NSUPDATE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NSUPDATE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NTRTSCAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NTRTSCAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NTVDM.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NTVDM.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NTXCONFIG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NTXCONFIG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NUI.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NUI.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NVARCH16.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NVARCH16.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NVSVC32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NVSVC32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NWINST4.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NWINST4.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NWSERVICE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NWSERVICE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NWTOOL16.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\NWTOOL16.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OACAT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OACAT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OAHLP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OAHLP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OAREG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OAREG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OASRV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OASRV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OAUI.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OAUI.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OAVIEW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OAVIEW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OCHEALTHMON.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OCHEALTHMON.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ODSW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ODSW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OLLYDBG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OLLYDBG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ONSRVR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ONSRVR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OPTIMIZE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OPTIMIZE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OSTRONET.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OSTRONET.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OTFIX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OTFIX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OUTPOST.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OUTPOST.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OUTPOSTINSTALL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OUTPOSTINSTALL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OUTPOSTPROINSTALL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OUTPOSTPROINSTALL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OZN695M5.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\OZN695M5.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PADMIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PADMIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PANIXK.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PANIXK.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PATCH.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PATCH.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PAV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PAV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PAVFNSVR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PAVFNSVR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PAVPROXY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PAVPROXY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PAVPRSRV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PAVPRSRV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PAVSRV51.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PAVSRV51.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PCIP10117_0.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PCIP10117_0.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PCSCAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PCSCAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PCTSAUXS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PCTSAUXS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PCTSGUI.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PCTSGUI.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PCTSSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PCTSSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PCTSTRAY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PCTSTRAY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PC_ANTISPYWARE2010.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PC_ANTISPYWARE2010.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PDFNDR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PDFNDR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PDSETUP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PDSETUP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PERAVIR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PERAVIR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PERISCOPE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PERISCOPE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PERSONALGUARD
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PERSONALGUARD#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PERSONALGUARD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PERSONALGUARD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PERSWF.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PERSWF.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PF2.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PF2.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PFWADMIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PFWADMIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PGMONITR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PGMONITR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PINGSCAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PINGSCAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PLATIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PLATIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\POP3TRAP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\POP3TRAP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\POPROXY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\POPROXY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\POPSCAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\POPSCAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PORTDETECTIVE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PORTDETECTIVE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PORTMONITOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PORTMONITOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\POWERSCAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\POWERSCAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PPINUPDT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PPINUPDT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PPTBC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PPTBC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PPVSTOP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PPVSTOP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PRIZESURFER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PRIZESURFER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PRMT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PRMT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PRMVR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PRMVR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROCDUMP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROCDUMP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROCESSMONITOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROCESSMONITOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROCEXPLORERV1.0.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROCEXPLORERV1.0.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROGRAMAUDITOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROGRAMAUDITOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROPORT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROPORT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROTECTOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROTECTOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROTECTX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PROTECTX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSANCU.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSANCU.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSANHOST.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSANHOST.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSANTOMANAGER.EXE
wrestler514
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSANTOMANAGER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSCTRLS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSCTRLS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSIMSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSIMSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSKSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSKSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSPF.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSPF.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSUNMAIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PSUNMAIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PURGE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\PURGE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\QCONSOLE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\QCONSOLE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\QH.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\QH.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\QSERVER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\QSERVER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\QUICK HEAL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\QUICK HEAL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\QUICKHEALCLEANER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\QUICKHEALCLEANER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RAPAPP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RAPAPP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RAV8WIN32ENG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RAV8WIN32ENG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RAY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RAY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RB32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RB32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RCSYNC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RCSYNC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\REALMON.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\REALMON.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\REGED.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\REGED.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\REGEDT32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\REGEDT32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RESCUE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RESCUE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RESCUE32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RESCUE32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RRGUARD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RRGUARD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RSCDWLD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RSCDWLD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RSHELL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RSHELL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RTVSCAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RTVSCAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RTVSCN95.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RTVSCN95.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RULAUNCH.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RULAUNCH.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RWG
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RWG#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RWG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\RWG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAFETYKEEPER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAFETYKEEPER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAHAGENT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAHAGENT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAVE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAVE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAVEARMOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAVEARMOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAVEDEFENSE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAVEDEFENSE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAVEKEEP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAVEKEEP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAVENOW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SAVENOW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SBSERV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SBSERV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SCAM32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SCAM32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SECCENTER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SECCENTER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SECURE VETERAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SECURE VETERAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SECUREVETERAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SECUREVETERAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SECURITY CENTER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SECURITY CENTER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SECURITYFIGHTER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SECURITYFIGHTER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SECURITYSOLDIER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SECURITYSOLDIER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SETLOADORDER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SETLOADORDER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SETUPVAMEEVAL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SETUPVAMEEVAL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SETUP_FLOWPROTECTOR_US.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SETUP_FLOWPROTECTOR_US.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SGSSFW32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SGSSFW32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SH.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SH.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SHELLSPYINSTALL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SHELLSPYINSTALL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SHIELD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SHIELD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SHN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SHN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SHOWBEHIND.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SHOWBEHIND.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SIGNCHECK.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SIGNCHECK.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SMART.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SMART.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SMARTPROTECTOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SMARTPROTECTOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SMRTDEFP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SMRTDEFP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SMS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SMS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SMSS32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SMSS32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SNETCFG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SNETCFG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SOAP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SOAP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SOFI.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SOFI.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SOFTSAFENESS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SOFTSAFENESS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPERM.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPERM.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPF.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPF.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPOLER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPOLER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPOOLCV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPOOLCV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPOOLSV32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPOOLSV32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPYWAREXPGUARD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPYWAREXPGUARD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPYXX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SPYXX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SREXE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SREXE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SRNG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SRNG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SS3EDIT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SS3EDIT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SSGRATE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SSGRATE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SSG_4104.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SSG_4104.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ST2.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ST2.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\START.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\START.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\STCLOADER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\STCLOADER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SUPFTRL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SUPFTRL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SUPPORT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SUPPORT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SUPPORTER5.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SUPPORTER5.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SVCHOSTC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SVCHOSTC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SVCHOSTS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SVCHOSTS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SVSHOST.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SVSHOST.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SWEEPNET.SWEEPSRV.SYS.SWNETSUP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SWEEPNET.SWEEPSRV.SYS.SWNETSUP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SYMLCSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SYMLCSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SYMPROXYSVC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SYMPROXYSVC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SYMTRAY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SYMTRAY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SYSTEM.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SYSTEM.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SYSTEM32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SYSTEM32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SYSUPD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\SYSUPD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TAPINSTALL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TAPINSTALL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TAUMON.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TAUMON.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TCM.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TCM.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TDS-3.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TDS-3.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TEEKIDS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TEEKIDS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TFAK.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TFAK.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TFAK5.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TFAK5.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TGBOB.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TGBOB.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TITANIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TITANIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TITANINXP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TITANINXP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TPSRV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TPSRV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TRICKLER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TRICKLER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TRJSCAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TRJSCAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TRJSETUP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TRJSETUP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TROJANTRAP3.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TROJANTRAP3.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TRUSTWARRIOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TRUSTWARRIOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TSADBOT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TSADBOT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TSC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TSC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TVMD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TVMD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TVTMD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\TVTMD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\UISCAN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\UISCAN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\UNDOBOOT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\UNDOBOOT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\UPDAT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\UPDAT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\UPGRAD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\UPGRAD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\UPGREPL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\UPGREPL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\UTPOST.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\UTPOST.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VBCMSERV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VBCMSERV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VBCONS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VBCONS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VBUST.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VBUST.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VBWIN9X.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VBWIN9X.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VBWINNTW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VBWINNTW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VCSETUP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VCSETUP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VET32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VET32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VFSETUP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VFSETUP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VIR-HELP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VIR-HELP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VIRUSMDPERSONALFIREWALL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VIRUSMDPERSONALFIREWALL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VISTHAUX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VISTHAUX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VISTHLIC.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VISTHLIC.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VISTHUPD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VISTHUPD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VNLAN300.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VNLAN300.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VNPC3000.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VNPC3000.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VPC32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VPC32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VPC42.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VPC42.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VPFW30S.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VPFW30S.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VPTRAY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VPTRAY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSCENU6.02D30.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSCENU6.02D30.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSCHED.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSCHED.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSISETUP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSISETUP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSMAIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSMAIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSMON.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSMON.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSSERV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSSERV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSWIN9XE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSWIN9XE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSWINNTSE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSWINNTSE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSWINPERSE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\VSWINPERSE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\W32DSM89.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\W32DSM89.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\W3ASBAS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\W3ASBAS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\W9X.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\W9X.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WATCHDOG.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WATCHDOG.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WEBDAV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WEBDAV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WEBPROXY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WEBPROXY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WEBTRAP.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WEBTRAP.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WHOSWATCHINGME.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WHOSWATCHINGME.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WIMMUN32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WIMMUN32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WIN-BUGSFIX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WIN-BUGSFIX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WIN32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WIN32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WIN32US.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WIN32US.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINACTIVE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINACTIVE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINAV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINAV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINDLL32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINDLL32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINDOW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINDOW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINDOWS POLICE PRO.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINDOWS POLICE PRO.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINDOWS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINDOWS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WININETD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WININETD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WININITX.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WININITX.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINLOGIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINLOGIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINMAIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINMAIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINPPR32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINPPR32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINRECON.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINRECON.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSERVN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSERVN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSSK32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSSK32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSSNOTIFY.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSSNOTIFY.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSSUI.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSSUI.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSTART.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSTART.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSTART001.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINSTART001.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINTSK32.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINTSK32.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINUPDATE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WINUPDATE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WKUFIND.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WKUFIND.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WNAD.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WNAD.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WNT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WNT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WRADMIN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WRADMIN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WRCTRL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WRCTRL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WSBGATE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WSBGATE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WSCFXAS.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WSCFXAS.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WSCFXAV.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WSCFXAV.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WSCFXFW.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WSCFXFW.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WSCTOOL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WSCTOOL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WUPDATER.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WUPDATER.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WUPDT.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WUPDT.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WYVERNWORKSFIREWALL.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\WYVERNWORKSFIREWALL.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\XPDELUXE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\XPDELUXE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\XPF202EN.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\XPF202EN.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\XP_ANTISPYWARE.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\XP_ANTISPYWARE.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ZAPRO.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ZAPRO.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ZAPSETUP3001.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ZAPSETUP3001.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ZATUTOR.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ZATUTOR.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ZONALM2601.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ZONALM2601.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\~1.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\~1.EXE#Debugger
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\~2.EXE
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\~2.EXE#Debugger
Rogue.Palladium
C:\Documents and Settings\Administrator\Application Data\completescan_pal
C:\Documents and Settings\Administrator\Application Data\install_pal
C:\Documents and Settings\Administrator\Application Data\palladium.exe
C:\Documents and Settings\Administrator\Application Data\uid_pal
Rogue.MySecurityShield
C:\Documents and Settings\Administrator\Application Data\MY SECURITY SHIELD\cookies.sqlite
C:\Documents and Settings\Administrator\Application Data\MY SECURITY SHIELD\Instructions.ini
C:\Documents and Settings\Administrator\Application Data\MICROSOFT\INTERNET EXPLORER\QUICK LAUNCH\MY SECURITY SHIELD.LNK
C:\Documents and Settings\All Users\Application Data\FA32D6
C:\DOCUMENTS AND SETTINGS\ALL USERS\APPLICATION DATA\FA32D6\MSFA3_2129.EXE
Rogue.SystemTool
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\System Tool2011
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\System Tool2011#DisplayName
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\System Tool2011#ShortcutPath
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\System Tool2011#UninstallString
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\System Tool2011#DisplayIcon
Trojan.Agent/Gen-FakeSpy[Broad-1]
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\LOCAL SETTINGS\APPLICATION DATA\IULFIB\DWMRSYSGUARD.EXE
Trojan.Agent/Gen-FraudLoad
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\LOCAL SETTINGS\APPLICATION DATA\TJYMENCWJ\ARGNHKSTSSD.EXE
Rootkit.Agent/Gen-Oltrex
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\LOCAL SETTINGS\TEMP\97.TMP
Rogue.PalladiumPro
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\LOCAL SETTINGS\TEMP\JH.EXE
Adware.Agent/Gen-Zango
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\LOCAL SETTINGS\TEMP\OLSWB+SL.EXE.PART
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\LOCAL SETTINGS\TEMP\ZCUY4YIR.EXE.PART
Trojan.Agent/Gen
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\LOCAL SETTINGS\TEMP\_25.TMP
C:\DOCUMENTS AND SETTINGS\ADMINISTRATOR\MSTSC.EXE
C:\SYSTEM VOLUME INFORMATION\_RESTORE{BC4371B6-2E7A-462A-91AD-5BF999D1ED91}\RP794\A0134929.DLL
Trojan.Agent/Gen-FakeAlert[HotFix]
C:\SYSTEM VOLUME INFORMATION\_RESTORE{BC4371B6-2E7A-462A-91AD-5BF999D1ED91}\RP793\A0134925.EXE
Adware.Smart-Browser
C:\SYSTEM VOLUME INFORMATION\_RESTORE{BC4371B6-2E7A-462A-91AD-5BF999D1ED91}\RP793\A0134926.DLL
Trojan.Agent/Gen-Banker
C:\SYSTEM VOLUME INFORMATION\_RESTORE{BC4371B6-2E7A-462A-91AD-5BF999D1ED91}\RP848\A0157853.EXE
Trojan.Unclassified/17PHolmes-A
C:\WINDOWS\17PHOLMES2000352.EXE
C:\WINDOWS\SYSTEM32\0070.DLL
wrestler514
Operating System : XP
Re: Help with virus removal
Post by wrestler514 on Sat 19 Feb 2011, 9:07 am
This is the log from the super antispyware............should i run the malware immediately or wait for further instruction.
Thanks for the help.
wrestler514
Post by Superdave on Sat 19 Feb 2011, 1:47 pm
I'm required to inform you of this:
One or more of the identified infections is a backdoor trojan.
This allows hackers to remotely control your computer, steal critical system information and Download and Execute files
Read this article: Danger: Remote Access Trojans.
If your computer was used for online banking, has credit card information or other sensitive data on it, all passwords should be changed immediately to include those used for banking, email, eBay and forums. You should consider them to be compromised. They should be changed by using a different computer and not the infected one! If not, an attacker may get the new passwords and transaction information. Banking and credit card institutions should be notified of the possible security breach.
I would counsel you to disconnect this PC from the Internet immediately.
Though the Trojan has been identified and can be killed, because of it's backdoor functionality, your PC is very likely compromised and there is no way to be sure your computer can ever again be trusted. Many experts in the security community believe that once infected with this type of Trojan, the best course of action would be a reformat and reinstall of the OS. Please read these for more information:
How Do I Handle Possible Identify Theft, Internet Fraud and CC Fraud?
When Should I Format, How Should I Reinstall?
We can attempt to clean this machine but i can't guarantee that it will be 100% secure afterwards.
Should you have any questions, please feel free to ask.
Please let us know what you have decided to do in your next post
Tech Staff
Tech Staff
Post by Sponsored content Today at 2:29 pm
