Printer won't print correctly
Post by Diane Cunningham on 29th January 2011, 11:48 pm
Am having a problem with printer all of a sudden. It's new ink, but is printing in what I call grey scale. I've done all I know as far as checking the setting and everything seems to be okay. I am only using black ink, however left the empty color jet in the printer (if that makes a difference).
In the properties this is what the settings are now:
Black and White is checked
Graphic quality- High
Advanced Printing features- Enabled
Color printing mode- monochrome
Halftoning- Autoselect
Printer Features- BJ cartridge Black
Brightness- Normal
It's a Canon BJC 2100
Hope I gave you enough information to tell me something! I've tried printing with the format on Bold, and not bold- and seems to be the same pretty much either way. There were 2 cartridges at purchase time, and tried both of them and that too made no difference. Any suggestions?
Thank you
Diane Cunningham
Posts Posts : 20
Joined Joined : 2011-01-02
OS OS : WinXP 2002 sp3
Points Points : 21890
Re: Printer won't print correctly
Post by Jan2011 on 3rd February 2011, 3:19 pm
If I understand this right, you have only a black ink cartridge. If so, it won't print colors. When using the term grey scale, are you saying that what should be black is really some what lighter? Not deep black?
If so, I see you checked settings and checked Black and White, and also set to monochrome. I'm wondering if there's another setting somewhere. Sometimes, printers have two sets of options, one in the Printer section and one in the Print options of the application that you're using.
Jan2011
Posts Posts : 616
Joined Joined : 2011-01-17
Points Points : 25595
Post by Diane Cunningham on 3rd February 2011, 8:33 pm
The setting I mentioned above are from within the control panel, printers and faxes, preferences (advanced). And yes- the grey scale I mentioned - it prints medium to light grey, not deep black.
Thank you
Diane Cunningham
Posts Posts : 20
Post by Jan2011 on 3rd February 2011, 9:57 pm
I pulled down the manual and I really don't see the options you're referring to.
It says to open the Printer dialog box and click on the Main tab.
From there you can select uncheck Grayscale Print.
Can you get to that window? It's on page 93 of the manual.
Jan2011
Posts Posts : 616
Post by Diane Cunningham on 3rd February 2011, 10:05 pm
I think I figured it out meanwhile. It's my mothers' machine- so it's a little unfamiliar to me... but I think I got it- if not I'll find her manual like you stated.
Thank you so much for your time.
Diane Cunningham
Posts Posts : 20
Post by Jan2011 on 3rd February 2011, 11:11 pm
You're welcome. Let us know what you find out.
Jan2011
Posts Posts : 616
