Antivirus System Pro weirdness (Please Help!)
Post by via on Sat 22 Jan 2011, 10:03 am
I'm pretty sure that I've got some form of the Antivirus System Pro virus on my computer. While all the symptoms are the same, the actual window that pops up looks different than the one shown [You must be registered and logged in to see this link.]. I've managed to regain access to the internet on my infected computer by messing with the proxy settings on my browser. I also just successfully installed Malwarebytes' Anti-Malware. My problem is that I can't open it. Like the other files on my computer, it says that the "Application cannot be executed. The file mbam.exe is infected. Do you want to activate your antivirus software now?"
How can I run this program? I'm so close...
Operating System : Windows XP
Re: Antivirus System Pro weirdness (Please Help!)
Post by Superdave on Sat 22 Jan 2011, 10:41 am
Please download and run the below tool named Rkill (courtesy of which may help allow other programs to run.
Save Rkill to your desktop.
There are 4 different versions. If one of them won't run then download and try to run the other one.
Vista and Win7 users need to right click Rkill and choose Run as Administrator
You only need to get one of these to run, not all of them. You may get warnings from your antivirus about this tool, ignore them or shutdown your antivirus.
* Rkill.exe
* Rkill.scr
Once you've gotten one of them to run then try to immediately run the following.
Download SuperAntispyware Free Edition (SAS)
* If you encounter any problems while downloading the updates, manually download and unzip them from here
•Scan for tracking cookies
Please leave the others unchecked
Tech Staff
Tech Staff
