AVG not installing-Reason Smart Engine
Post by rsjenkins02 on Thu Jan 13, 2011 2:28 pm
I have been battling this Smart Engine for 3 days now. I have did the RKill/Malware guide. Malware does not show any infections as of now, however I still cannot install AVG it states that Smart Engine is not compatible. I'm not sure if this is a left over instance of this or what it is. I might add I have ran CCLeaner, SpyDocter and Regestry Mechanic. Any help would be greatly appreciated.
rsjenkins02
OS : windows 7
Re: AVG not installing-Reason Smart Engine
Post by Belahzur on Fri Jan 14, 2011 1:14 am
Post by rsjenkins02 on Fri Jan 14, 2011 1:32 am
Belahzur,
I finally got it after running several anti-virus/mal-ware programs. Thanks for the quick response, much appreciated.
rsjenkins02
OS : windows 7
