wireless mouse not working
Post by blueyze on 3rd January 2011, 2:50 am
I bought a wireless Dynex mouse for my laptop. I installed it per the instructions and it shows connected to the laptop but will not move my mouse. What am I missing? I even swapped the batteries even though they were new to start with. I am using Windows 7.
blueyze
Posts Posts : 51
Joined Joined : 2009-02-02
Points Points : 28987
Re: wireless mouse not working
Post by Nazzgull on 4th January 2011, 12:31 am
Are you sure that Windows 7 support your model of mouse ?
If you have driver for it, install it.
Points Points : 40475
Post by blueyze on 5th January 2011, 4:49 am
The mouse is compatible with XP and Windows 7. Yes, I installed the drivers. I have never used a wireless mouse and wasn't sure if I missed something. I have tried it on my desktop (XP) and not working there either. I bought a new one, and it works fine. Just a bad mouse.
blueyze
Posts Posts : 51
