Yet another malware problem.
Post by Coldplasma819 on Mon Dec 27, 2010 8:39 pm
Hello, im sure you guys remember me.
Today I turned on my computer after an AVG update and restart to bring up the World of Warcraft launcher/updater. I was soon met with a window from AVG Identity Guard that malware was detected and the afflicted file was something close to the world of warcraft updater/launcher .exe. I was asked if I wanted to allow the file or move it to the vault to quarantine. I chose to move it to the vault and I was prompted with a restart. When my PC tried restarting, all I got was a black screen and my fan powering up high, with error lights 1, 3, and 4 showing up on my system. Now whenever I go to turn on my PC, my fan instantly kicks up to its highest setting with error lights 1,3 and 4 appearing, nothing else. :sad:
It seems that the malware infection can travel through my router as well, for when I tried turning my PC on, while having my dad's on, my dad's computer was met with a memory dump screen, and I was forced to reboot. My dad's pc however works fine when my PC is off, as you can tell.
Coldplasma819
Posts Posts : 46
Joined Joined : 2010-07-28
OS OS : Windows Vista Home Premium
Points Points : 23874
Re: Yet another malware problem.
Post by Belahzur on Mon Dec 27, 2010 9:38 pm
Helllo.
Points Points : 245059
Post by Coldplasma819 on Mon Dec 27, 2010 11:19 pm
I'm unable to download OTL to the infected pc's desktop for the pc does not even start up or get to the boot screen.
Coldplasma819
Posts Posts : 46
Post by Coldplasma819 on Tue Dec 28, 2010 1:31 am
Ok, update, Dell tech support is going to send out a new gfx card to me within the next day or two. When it is installed, and if there is a virus, I will upload the OTL log then.
Coldplasma819
Posts Posts : 46
Post by Belahzur on Tue Dec 28, 2010 10:12 pm
Okay. Smile
