Internet Connection on computer went dead (Not a simple fix.. please help!)
Post by Joey Jiggles on Mon Dec 27, 2010 7:57 pm
Hey guys,
Our work laptop's internet went completely dead. I have no reason for it. I have tried repairing the connection and it just can not find the wireless network. I even tried getting a connection when we hard wire the Ethernet cable.. NOTHING. I checked to make sure the utility card is enable and working.. i have done everything. We have other computers that are working fine off the internet so we have narrowed it down to being an internal problem on this particular computer.
Looking forward to hearing your process.
Thank you!
Joey Jiggles
OS : Windows XP
# Likes : 0
Re: Internet Connection on computer went dead (Not a simple fix.. please help!)
Post by Nazzgull on Thu Dec 30, 2010 9:59 am
Try to use WinSockFix from link bellow :
OS : Windows 7 Professional
# Likes : 1
Post by INeedHelp on Thu Dec 30, 2010 9:47 pm
I'm just curious but have you tried updating your drivers? Since only your work laptop does not connect to the internet
INeedHelp
OS : Windows Vista Ultimate 64-Bit/Windows 7 Pro x64-bit/Windows XP Pro SP3
# Likes : 0
Post by Joey Jiggles on Mon Jan 03, 2011 9:24 pm
Thank you for your response. I have not updated the drivers. I will def. give that a shot tomorrow at work and I will do the winsockfix! I will update you tomorrow!
Joey Jiggles
OS : Windows XP
# Likes : 0
Post by Nazzgull on Tue Jan 04, 2011 12:18 am
Let me know if your problem gone.
# Likes : 1
Post by Joey Jiggles on Tue Jan 04, 2011 6:13 pm
Ok, so I went to my device Manager and was unable to update my drivers. I forgot sort of what I was doing, but when I tried it asked me for a disc and only God knows where that is.
Now we have another problem. I downloaded the sockfix on my flashdrive and put it on the computer. Everything seemed to work smoothly and it told me to reboot. It froze to a black screen after a while of waiting so I turned my computer off. My computer is getting stuck saying windows as if it is trying to start up but just can't. What now!?
Joey Jiggles
OS : Windows XP
# Likes : 0
Post by Joey Jiggles on Tue Jan 04, 2011 6:18 pm
It worked!!!
Thank you!
Joey Jiggles
OS : Windows XP
# Likes : 0
