System not running right - Im in the academy
Post by Twist154 on 14th December 2010, 2:45 am
This has just started as of Saturday Dec 11th. - I have always been able to run my D-Link media server application. "I start the program" "Then hover over the application in the start bar and it disappears" "Also I was unable to open certain websites through firefox. They would just close my browser" I have updated both Comodo and Malwarebytes and ran both. Please review my OTL report and advise
Twist154
Posts Posts : 39
Joined Joined : 2009-08-29
OS OS : 7 Ultimate
Points Points : 27004
Re: System not running right - Im in the academy
Post by Belahzur on 14th December 2010, 11:46 pm
Please post your OTL logs then. Smile
Points Points : 245111
Post by Twist154 on 15th December 2010, 12:38 am
[You must be registered and logged in to see this link.] wrote:Please post your OTL logs then. Smile
I uploaded them in my original post?.? hmmm When I pasted the log into the post it said there were to many characters. So I attached the doc to the original post.
Twist154
Posts Posts : 39
OS OS : 7 Ultimate
Post by Belahzur on 15th December 2010, 11:50 pm
There is no attachment in your first post. If they wont post/attach, can you please upload them both to [You must be registered and logged in to see this link.] and post the share URL.
Post by Twist154 on 16th December 2010, 1:04 am
Ok,
Twist154
Posts Posts : 39
OS OS : 7 Ultimate
Post by Belahzur on 16th December 2010, 1:28 am
Post by Twist154 on 16th December 2010, 3:39 am
Malwarebytes' Anti-Malware 1.50
Database version: 5324
Windows 6.1.7600
Internet Explorer 8.0.7600.16385
12/15/2010 10:39:07 PM
mbam-log-2010-12-15 (22-39-07).txt
Scan type: Quick scan
Objects scanned: 153791
Time elapsed: 2 minute(s), 25 second(s)
Twist154
Posts Posts : 39
OS OS : 7 Ultimate
Post by Twist154 on 16th December 2010, 4:16 am
I still cannot get my D-Link media server software to start up. I click on it. It goes to the start bar. When I hoover over it in the start bar with my mouse it disappears. I have removed the software, checked my registry to make sure its gone. reinstalled and it still does the same thing. I have also looked through the blocked section of my firewall just making sure I had not blocked anything and the program is not running in processes or services.. Nothing is keeping it from opening but it vanishes on me. Let me think
Twist154
Posts Posts : 39
OS OS : 7 Ultimate
Post by Belahzur on 17th December 2010, 12:02 am
Post by Twist154 on 18th December 2010, 4:36 pm
Ok, I tried running combo fix many times unsuccessfully... First it said my Comodo was still running and could interrupt. I disabled everything and still received that pop up. So I uninstall Comodo on my machine and try to run again. I still receive the pop up saying that Comodo is running on my machine and could interrupt the combo fix scan. Combo Fix freezes up every time it tries to run even with Comodo uninstalled.
Twist154
Posts Posts : 39
OS OS : 7 Ultimate
Post by Belahzur on 18th December 2010, 11:50 pm
  • Restart your computer
  • Select the first option, to run Windows in Safe Mode, then press Enter.
  • Choose your usual account.
Try running Combofix in Safe Mode, see if it works now.
Post by Twist154 on 19th December 2010, 5:05 pm
[You must be registered and logged in to see this link.] wrote:Hello.
Ok i tried running it in safe mode as well and still no luck. I let it run all night only to wake up to the same screen. Bring it on
Twist154
Posts Posts : 39
OS OS : 7 Ultimate
Post by Belahzur on 19th December 2010, 8:22 pm
Okay run these 2 tools for me instead, it will check for the infections I wanted Combofix to check.
Download [You must be registered and logged in to see this link.] to your desktop.
  • Double click MBRCheck.exe to run (Vista and Windows 7 users, right click and select Run as Administrator).
  • It will show a black screen with some data on it.
  • A report called MBRcheckxxxx.txt will be on your desktop
  • Open this report and post its content in your next reply.
Please download TDSSKiller from [You must be registered and logged in to see this link.] and save it to your Desktop.
  • Doubleclick TDSSKiller.exe to run the tool
  • Click the Start Scan button
  • After the scan has finished, click the Close button
Note:It will also create a log in the C:\ directory.
Please post both logs.
Post by Twist154 on 19th December 2010, 9:17 pm
MBRCheck, version 1.2.3
(c) 2010, AD
Command-line:
Windows Version: Windows 7 Ultimate Edition
Windows Information: (build 7600), 32-bit
Base Board Manufacturer: BIOSTAR Group
BIOS Manufacturer: American Megatrends Inc.
System Manufacturer: BIOSTAR Group
System Product Name: TF8200 A2+
Logical Drives Mask: 0x0000003c
Kernel Drivers (total 165):
0x82E00000 \SystemRoot\system32\ntkrnlpa.exe
0x83210000 \SystemRoot\system32\halmacpi.dll
0x80BA2000 \SystemRoot\system32\kdcom.dll
0x8B83A000 \SystemRoot\system32\mcupdate_AuthenticAMD.dll
0x8B845000 \SystemRoot\system32\PSHED.dll
0x8B856000 \SystemRoot\system32\BOOTVID.dll
0x8B85E000 \SystemRoot\system32\CLFS.SYS
0x8B8A0000 \SystemRoot\system32\CI.dll
0x8B94B000 \SystemRoot\system32\drivers\Wdf01000.sys
0x8B9BC000 \SystemRoot\system32\drivers\WDFLDR.SYS
0x8BA09000 \SystemRoot\System32\Drivers\spnr.sys
0x8BAFC000 \SystemRoot\System32\Drivers\WMILIB.SYS
0x8BB05000 \SystemRoot\System32\Drivers\SCSIPORT.SYS
0x8BB2B000 \SystemRoot\system32\DRIVERS\ACPI.sys
0x8BB73000 \SystemRoot\system32\DRIVERS\msisadrv.sys
0x8BB7B000 \SystemRoot\system32\DRIVERS\vdrvroot.sys
0x8BB86000 \SystemRoot\system32\DRIVERS\pci.sys
0x8BBB0000 \SystemRoot\System32\drivers\partmgr.sys
0x8BBC1000 \SystemRoot\system32\DRIVERS\volmgr.sys
0x8BC1A000 \SystemRoot\System32\drivers\volmgrx.sys
0x8BC65000 \SystemRoot\system32\DRIVERS\pciide.sys
0x8BC6C000 \SystemRoot\system32\DRIVERS\PCIIDEX.SYS
0x8BC7A000 \SystemRoot\System32\drivers\mountmgr.sys
0x8BC90000 \SystemRoot\system32\DRIVERS\atapi.sys
0x8BC99000 \SystemRoot\system32\DRIVERS\ataport.SYS
0x8BCBC000 \SystemRoot\system32\DRIVERS\amdxata.sys
0x8BCC5000 \SystemRoot\system32\drivers\fltmgr.sys
0x8BCF9000 \SystemRoot\system32\drivers\fileinfo.sys
0x8BE36000 \SystemRoot\System32\Drivers\Ntfs.sys
0x8BF65000 \SystemRoot\System32\Drivers\msrpc.sys
0x8BF90000 \SystemRoot\System32\Drivers\ksecdd.sys
0x8BFA3000 \SystemRoot\System32\Drivers\cng.sys
0x8BE00000 \SystemRoot\System32\drivers\pcw.sys
0x8BE0E000 \SystemRoot\System32\Drivers\Fs_Rec.sys
0x8BD0A000 \SystemRoot\system32\drivers\ndis.sys
0x8BDC1000 \SystemRoot\system32\drivers\NETIO.SYS
0x8BBD1000 \SystemRoot\System32\Drivers\ksecpkg.sys
0x8C03F000 \SystemRoot\System32\drivers\tcpip.sys
0x8C188000 \SystemRoot\System32\drivers\fwpkclnt.sys
0x8C1B9000 \SystemRoot\system32\DRIVERS\vmstorfl.sys
0x8C000000 \SystemRoot\system32\DRIVERS\volsnap.sys
0x8C1C2000 \SystemRoot\System32\Drivers\spldr.sys
0x8C1CA000 \SystemRoot\System32\drivers\rdyboost.sys
0x8BE17000 \SystemRoot\System32\Drivers\mup.sys
0x8C1F7000 \SystemRoot\System32\drivers\hwpolicy.sys
0x8B9CA000 \SystemRoot\System32\DRIVERS\fvevol.sys
0x8BC00000 \SystemRoot\system32\DRIVERS\disk.sys
0x8B800000 \SystemRoot\system32\DRIVERS\CLASSPNP.SYS
0x9041F000 \SystemRoot\system32\DRIVERS\cdrom.sys
0x9043E000 \SystemRoot\System32\Drivers\Null.SYS
0x90445000 \SystemRoot\System32\Drivers\Beep.SYS
0x9044C000 \SystemRoot\System32\drivers\vga.sys
0x90458000 \SystemRoot\System32\drivers\VIDEOPRT.SYS
0x90479000 \SystemRoot\System32\drivers\watchdog.sys
0x90486000 \SystemRoot\System32\DRIVERS\RDPCDD.sys
0x9048E000 \SystemRoot\system32\drivers\rdpencdd.sys
0x90496000 \SystemRoot\system32\drivers\rdprefmp.sys
0x9049E000 \SystemRoot\System32\Drivers\Msfs.SYS
0x904A9000 \SystemRoot\System32\Drivers\Npfs.SYS
0x904B7000 \SystemRoot\system32\DRIVERS\tdx.sys
0x904CE000 \SystemRoot\system32\DRIVERS\TDI.SYS
0x904D9000 \SystemRoot\system32\drivers\afd.sys
0x90533000 \SystemRoot\System32\DRIVERS\netbt.sys
0x90565000 \SystemRoot\system32\DRIVERS\wfplwf.sys
0x9056C000 \SystemRoot\system32\DRIVERS\pacer.sys
0x9058B000 \SystemRoot\system32\DRIVERS\netbios.sys
0x90599000 \SystemRoot\system32\DRIVERS\serial.sys
0x905B3000 \SystemRoot\system32\DRIVERS\wanarp.sys
0x905C6000 \SystemRoot\system32\DRIVERS\termdd.sys
0x905D6000 \SystemRoot\System32\Drivers\SCDEmu.SYS
0x9161B000 \SystemRoot\system32\DRIVERS\rdbss.sys
0x9165C000 \SystemRoot\system32\drivers\nsiproxy.sys
0x91666000 \SystemRoot\system32\DRIVERS\mssmbios.sys
0x91670000 \SystemRoot\System32\drivers\discache.sys
0x9167C000 \SystemRoot\system32\drivers\csc.sys
0x916E0000 \SystemRoot\System32\Drivers\dfsc.sys
0x916F8000 \SystemRoot\system32\DRIVERS\blbdrive.sys
0x91706000 \SystemRoot\system32\DRIVERS\tunnel.sys
0x91727000 \SystemRoot\system32\DRIVERS\amdppm.sys
0x91738000 \SystemRoot\system32\DRIVERS\serenum.sys
0x91742000 \SystemRoot\system32\DRIVERS\parport.sys
0x9175A000 \SystemRoot\system32\DRIVERS\nvsmu.sys
0x91763000 \SystemRoot\system32\DRIVERS\usbohci.sys
0x9176D000 \SystemRoot\system32\DRIVERS\USBPORT.SYS
0x917B8000 \SystemRoot\system32\DRIVERS\usbehci.sys
0x917C7000 \SystemRoot\system32\DRIVERS\HDAudBus.sys
0x92035000 \SystemRoot\system32\DRIVERS\nvlddmkm.sys
0x9298B000 \SystemRoot\system32\DRIVERS\nvBridge.kmd
0x91A1A000 \SystemRoot\System32\drivers\dxgkrnl.sys
0x91AD1000 \SystemRoot\System32\drivers\dxgmms1.sys
0x91B0A000 \SystemRoot\system32\DRIVERS\Rt86win7.sys
0x91B2F000 \SystemRoot\System32\Drivers\a2jmja1n.SYS
0x91B68000 \SystemRoot\system32\DRIVERS\wmiacpi.sys
0x91B71000 \SystemRoot\system32\DRIVERS\CompositeBus.sys
0x91B7E000 \SystemRoot\system32\DRIVERS\serscan.sys
0x91B86000 \SystemRoot\system32\DRIVERS\AgileVpn.sys
0x91B98000 \SystemRoot\system32\DRIVERS\rasl2tp.sys
0x91BB0000 \SystemRoot\system32\DRIVERS\ndistapi.sys
0x91BBB000 \SystemRoot\system32\DRIVERS\ndiswan.sys
0x91BDD000 \SystemRoot\system32\DRIVERS\raspppoe.sys
0x91A00000 \SystemRoot\system32\DRIVERS\raspptp.sys
0x9298D000 \SystemRoot\system32\DRIVERS\rassstp.sys
0x91BF5000 \SystemRoot\system32\DRIVERS\hamachi.sys
0x929A4000 \SystemRoot\system32\DRIVERS\rdpbus.sys
0x929AE000 \SystemRoot\system32\DRIVERS\kbdclass.sys
0x929BB000 \SystemRoot\system32\DRIVERS\mouclass.sys
0x91BFA000 \SystemRoot\system32\DRIVERS\swenum.sys
0x929C8000 \SystemRoot\system32\DRIVERS\ks.sys
0x92000000 \SystemRoot\system32\DRIVERS\umbus.sys
0x91C29000 \SystemRoot\system32\DRIVERS\usbhub.sys
0x91C6D000 \SystemRoot\System32\Drivers\NDProxy.SYS
0x92E3B000 \SystemRoot\system32\drivers\RTKVHDA.sys
0x930E2000 \SystemRoot\system32\drivers\portcls.sys
0x93111000 \SystemRoot\system32\drivers\drmk.sys
0x9312A000 \SystemRoot\system32\drivers\HdAudio.sys
0x9317A000 \SystemRoot\system32\DRIVERS\cdfs.sys
0x93190000 \SystemRoot\system32\DRIVERS\hidusb.sys
0x9319B000 \SystemRoot\system32\DRIVERS\HIDCLASS.SYS
0x931AE000 \SystemRoot\system32\DRIVERS\HIDPARSE.SYS
0x931B5000 \SystemRoot\system32\DRIVERS\USBD.SYS
0x931B7000 \SystemRoot\system32\DRIVERS\mouhid.sys
0x95910000 \SystemRoot\System32\win32k.sys
0x931C2000 \SystemRoot\System32\drivers\Dxapi.sys
0x931CC000 \SystemRoot\system32\DRIVERS\usbccgp.sys
0x931E3000 \SystemRoot\System32\Drivers\Lycosa.sys
0x931E7000 \SystemRoot\system32\DRIVERS\kbdhid.sys
0x92E00000 \SystemRoot\system32\drivers\usbaudio.sys
0x96E14000 \SystemRoot\system32\DRIVERS\VX3000.sys
0x96FF2000 \SystemRoot\system32\DRIVERS\STREAM.SYS
0x96E00000 \SystemRoot\system32\DRIVERS\monitor.sys
0x92E14000 \SystemRoot\System32\Drivers\crashdmp.sys
0x92E21000 \SystemRoot\System32\Drivers\dump_dumpata.sys
0x96E0B000 \SystemRoot\System32\Drivers\dump_atapi.sys
0x91C7E000 \SystemRoot\System32\Drivers\dump_dumpfve.sys
0x95B70000 \SystemRoot\System32\TSDDD.dll
0x95B80000 \SystemRoot\System32\ATMFD.DLL
0x91C8F000 \SystemRoot\system32\drivers\luafv.sys
0x91CAA000 \SystemRoot\system32\drivers\WudfPf.sys
0x95800000 \SystemRoot\System32\cdd.dll
0x91CC4000 \SystemRoot\system32\DRIVERS\lltdio.sys
0x91CD4000 \SystemRoot\system32\DRIVERS\nwifi.sys
0x91D1A000 \SystemRoot\system32\DRIVERS\ndisuio.sys
0x91D2A000 \SystemRoot\system32\DRIVERS\rspndr.sys
0x91D3D000 \SystemRoot\system32\drivers\HTTP.sys
0x91DC2000 \SystemRoot\system32\DRIVERS\bowser.sys
0x91DDB000 \SystemRoot\System32\drivers\mpsdrv.sys
0x91C00000 \SystemRoot\system32\DRIVERS\mrxsmb.sys
0x9C402000 \SystemRoot\system32\DRIVERS\mrxsmb10.sys
0x9C43D000 \SystemRoot\system32\DRIVERS\mrxsmb20.sys
0x9C458000 \SystemRoot\system32\DRIVERS\parvdm.sys
0x9C45F000 \SystemRoot\System32\Drivers\adfs.SYS
0x9C470000 \SystemRoot\system32\drivers\peauth.sys
0x9C507000 \SystemRoot\System32\Drivers\secdrv.SYS
0x9C511000 \SystemRoot\System32\DRIVERS\srvnet.sys
0x9C532000 \SystemRoot\System32\drivers\tcpipreg.sys
0x9C53F000 \SystemRoot\System32\DRIVERS\srv2.sys
0x9C58E000 \SystemRoot\System32\DRIVERS\srv.sys
0x9200E000 \SystemRoot\System32\drivers\ipnat.sys
0x9C5DF000 \??\C:\Windows\system32\drivers\mbam.sys
0xA5471000 \SystemRoot\system32\DRIVERS\asyncmac.sys
0x77AA0000 \Windows\System32\ntdll.dll
0x47ED0000 \Windows\System32\smss.exe
0x77CE0000 \Windows\System32\apisetschema.dll
0x00290000 \Windows\System32\autochk.exe
0x10000000 \Program Files\DAEMON Tools Lite\Engine.dll
Processes (total 65):
0 System Idle Process
4 System
316 C:\Windows\System32\smss.exe
452 csrss.exe
524 C:\Windows\System32\wininit.exe
532 csrss.exe
572 C:\Windows\System32\services.exe
588 C:\Windows\System32\lsass.exe
596 C:\Windows\System32\lsm.exe
704 C:\Windows\System32\svchost.exe
768 C:\Windows\System32\nvvsvc.exe
808 C:\Windows\System32\svchost.exe
868 C:\Windows\System32\svchost.exe
904 C:\Windows\System32\svchost.exe
932 C:\Windows\System32\svchost.exe
1020 C:\Windows\System32\winlogon.exe
1120 C:\Windows\System32\svchost.exe
1240 C:\Windows\System32\svchost.exe
1488 C:\Windows\System32\spoolsv.exe
1536 C:\Windows\System32\svchost.exe
1580 C:\Windows\System32\nvvsvc.exe
1688 C:\Windows\System32\svchost.exe
1744 C:\Program Files\LogMeIn Hamachi\hamachi-2.exe
1780 C:\Windows\System32\svchost.exe
1804 C:\Program Files\Microsoft LifeCam\MSCamS32.exe
1836 C:\Windows\System32\svchost.exe
1996 C:\Windows\System32\svchost.exe
2024 C:\Windows\System32\PnkBstrA.exe
128 C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
392 C:\Windows\System32\nvSCPAPISvr.exe
988 C:\Program Files\TeamViewer\Version5\TeamViewer_Service.exe
1376 C:\Program Files\Common Files\microsoft shared\Windows Live\WLIDSVC.EXE
2284 C:\Program Files\Common Files\microsoft shared\Windows Live\WLIDSVCM.EXE
2468 C:\Windows\System32\alg.exe
2568 C:\Windows\System32\SearchIndexer.exe
2604 C:\Windows\System32\svchost.exe
2816 C:\Windows\System32\svchost.exe
3800 C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe
3936 C:\Program Files\Malwarebytes' Anti-Malware\mbamservice.exe
3996 C:\Windows\System32\svchost.exe
4036 C:\Program Files\Windows Media Player\wmpnetwk.exe
3140 C:\Windows\System32\dwm.exe
1364 C:\Windows\explorer.exe
3440 C:\Windows\System32\taskhost.exe
3476 C:\Program Files\Realtek\Audio\HDA\RtHDVCpl.exe
2732 C:\Program Files\HP\HP Software Update\hpwuschd2.exe
3372 C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe
1392 C:\Program Files\Common Files\Java\Java Update\jusched.exe
2988 C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
3032 C:\Program Files\HP\Digital Imaging\bin\hpqste08.exe
3624 C:\Program Files\HP\Digital Imaging\bin\hpqbam08.exe
3532 C:\Windows\System32\svchost.exe
3380 C:\Program Files\HP\Digital Imaging\bin\hpqgpc01.exe
2720 dllhost.exe
5704 C:\Windows\System32\svchost.exe
2800 C:\Windows\System32\audiodg.exe
4724 C:\Program Files\Mozilla Firefox\firefox.exe
4476 C:\Program Files\Mozilla Firefox\plugin-container.exe
5552 C:\Windows\System32\SearchProtocolHost.exe
4992 C:\Windows\System32\SearchFilterHost.exe
3556
4756
4864 C:\Users\Twister\Desktop\MBRCheck.exe
5920 C:\Windows\System32\conhost.exe
976 C:\Windows\System32\dllhost.exe
\\.\C: --> \\.\PhysicalDrive0 at offset 0x00000000`00007e00 (NTFS)
\\.\E: --> \\.\PhysicalDrive1 at offset 0x00000000`00100000
PhysicalDrive0 Model Number: WDCWD6000HLHX-01JJPV0, Rev: 04.05G04
PhysicalDrive1 Model Number: WDCWD1001FALS-00E8B0, Rev: 05.00K05
Size Device Name MBR Status
558 GB \\.\PhysicalDrive0 Windows 7 MBR code detected
SHA1: 4379A3D43019B46FA357F7DD6A53B45A3CA8FB79
931 GB \\.\PhysicalDrive1 Windows 7 MBR code detected
Done!
Twist154
Posts Posts : 39
OS OS : 7 Ultimate
Post by Twist154 on 19th December 2010, 9:19 pm
2010/12/19 16:18:06.0438 TDSS rootkit removing tool 2.4.12.0 Dec 16 2010 09:46:46
2010/12/19 16:18:06.0438 ================================================================================
2010/12/19 16:18:06.0438 SystemInfo:
2010/12/19 16:18:06.0438 OS Version: 6.1.7600 ServicePack: 0.0
2010/12/19 16:18:06.0438 Product type: Workstation
2010/12/19 16:18:06.0438 ComputerName: TWISTER-PC
2010/12/19 16:18:06.0440 UserName: Twister
2010/12/19 16:18:06.0440 Windows directory: C:\Windows
2010/12/19 16:18:06.0440 System windows directory: C:\Windows
2010/12/19 16:18:06.0440 Processor architecture: Intel x86
2010/12/19 16:18:06.0440 Number of processors: 4
2010/12/19 16:18:06.0440 Page size: 0x1000
2010/12/19 16:18:06.0440 Boot type: Normal boot
2010/12/19 16:18:06.0440 ================================================================================
2010/12/19 16:18:07.0634 Initialize success
2010/12/19 16:18:51.0139 ================================================================================
2010/12/19 16:18:51.0139 Scan started
2010/12/19 16:18:51.0139 Mode: Manual;
2010/12/19 16:18:51.0436 1394ohci (6d2aca41739bfe8cb86ee8e85f29697d) C:\Windows\system32\DRIVERS\1394ohci.sys
2010/12/19 16:18:51.0458 ACPI (f0e07d144c8685b8774bc32fc8da4df0) C:\Windows\system32\DRIVERS\ACPI.sys
2010/12/19 16:18:51.0479 AcpiPmi (98d81ca942d19f7d9153b095162ac013) C:\Windows\system32\DRIVERS\acpipmi.sys
2010/12/19 16:18:51.0503 adfs (6d7f09cd92a9fef3a8efce66231fdd79) C:\Windows\system32\drivers\adfs.sys
2010/12/19 16:18:51.0528 adp94xx (21e785ebd7dc90a06391141aac7892fb) C:\Windows\system32\DRIVERS\adp94xx.sys
2010/12/19 16:18:51.0545 adpahci (0c676bc278d5b59ff5abd57bbe9123f2) C:\Windows\system32\DRIVERS\adpahci.sys
2010/12/19 16:18:51.0557 adpu320 (7c7b5ee4b7b822ec85321fe23a27db33) C:\Windows\system32\DRIVERS\adpu320.sys
2010/12/19 16:18:51.0592 AFD (ddc040fdb01ef1712a6b13e52afb104c) C:\Windows\system32\drivers\afd.sys
2010/12/19 16:18:51.0612 agp440 (507812c3054c21cef746b6ee3d04dd6e) C:\Windows\system32\DRIVERS\agp440.sys
2010/12/19 16:18:51.0624 aic78xx (8b30250d573a8f6b4bd23195160d8707) C:\Windows\system32\DRIVERS\djsvs.sys
2010/12/19 16:18:51.0647 aliide (0d40bcf52ea90fc7df2aeab6503dea44) C:\Windows\system32\DRIVERS\aliide.sys
2010/12/19 16:18:51.0662 amdagp (3c6600a0696e90a463771c7422e23ab5) C:\Windows\system32\DRIVERS\amdagp.sys
2010/12/19 16:18:51.0671 amdide (cd5914170297126b6266860198d1d4f0) C:\Windows\system32\DRIVERS\amdide.sys
2010/12/19 16:18:51.0687 AmdK8 (00dda200d71bac534bf56a9db5dfd666) C:\Windows\system32\DRIVERS\amdk8.sys
2010/12/19 16:18:51.0704 AmdPPM (3cbf30f5370fda40dd3e87df38ea53b6) C:\Windows\system32\DRIVERS\amdppm.sys
2010/12/19 16:18:51.0716 amdsata (2101a86c25c154f8314b24ef49d7fbc2) C:\Windows\system32\DRIVERS\amdsata.sys
2010/12/19 16:18:51.0733 amdsbs (ea43af0c423ff267355f74e7a53bdaba) C:\Windows\system32\DRIVERS\amdsbs.sys
2010/12/19 16:18:51.0750 amdxata (b81c2b5616f6420a9941ea093a92b150) C:\Windows\system32\DRIVERS\amdxata.sys
2010/12/19 16:18:51.0759 AppID (feb834c02ce1e84b6a38f953ca067706) C:\Windows\system32\drivers\appid.sys
2010/12/19 16:18:51.0786 arc (2932004f49677bd84dbc72edb754ffb3) C:\Windows\system32\DRIVERS\arc.sys
2010/12/19 16:18:51.0797 arcsas (5d6f36c46fd283ae1b57bd2e9feb0bc7) C:\Windows\system32\DRIVERS\arcsas.sys
2010/12/19 16:18:51.0818 AsyncMac (add2ade1c2b285ab8378d2daaf991481) C:\Windows\system32\DRIVERS\asyncmac.sys
2010/12/19 16:18:51.0830 atapi (338c86357871c167a96ab976519bf59e) C:\Windows\system32\DRIVERS\atapi.sys
2010/12/19 16:18:51.0856 b06bdrv (1a231abec60fd316ec54c66715543cec) C:\Windows\system32\DRIVERS\bxvbdx.sys
2010/12/19 16:18:51.0869 b57nd60x (bd8869eb9cde6bbe4508d869929869ee) C:\Windows\system32\DRIVERS\b57nd60x.sys
2010/12/19 16:18:51.0888 Beep (505506526a9d467307b3c393dedaf858) C:\Windows\system32\drivers\Beep.sys
2010/12/19 16:18:51.0907 blbdrive (2287078ed48fcfc477b05b20cf38f36f) C:\Windows\system32\DRIVERS\blbdrive.sys
2010/12/19 16:18:51.0920 bowser (fcafaef6798d7b51ff029f99a9898961) C:\Windows\system32\DRIVERS\bowser.sys
2010/12/19 16:18:51.0929 BrFiltLo (9f9acc7f7ccde8a15c282d3f88b43309) C:\Windows\system32\DRIVERS\BrFiltLo.sys
2010/12/19 16:18:51.0945 BrFiltUp (56801ad62213a41f6497f96dee83755a) C:\Windows\system32\DRIVERS\BrFiltUp.sys
2010/12/19 16:18:51.0963 Brserid (845b8ce732e67f3b4133164868c666ea) C:\Windows\System32\Drivers\Brserid.sys
2010/12/19 16:18:51.0978 BrSerWdm (203f0b1e73adadbbb7b7b1fabd901f6b) C:\Windows\System32\Drivers\BrSerWdm.sys
2010/12/19 16:18:51.0990 BrUsbMdm (bd456606156ba17e60a04e18016ae54b) C:\Windows\System32\Drivers\BrUsbMdm.sys
2010/12/19 16:18:52.0005 BrUsbSer (af72ed54503f717a43268b3cc5faec2e) C:\Windows\System32\Drivers\BrUsbSer.sys
2010/12/19 16:18:52.0014 BTHMODEM (ed3df7c56ce0084eb2034432fc56565a) C:\Windows\system32\DRIVERS\bthmodem.sys
2010/12/19 16:18:52.0035 cdfs (77ea11b065e0a8ab902d78145ca51e10) C:\Windows\system32\DRIVERS\cdfs.sys
2010/12/19 16:18:52.0049 cdrom (ba6e70aa0e6091bc39de29477d866a77) C:\Windows\system32\DRIVERS\cdrom.sys
2010/12/19 16:18:52.0063 circlass (3fe3fe94a34df6fb06e6418d0f6a0060) C:\Windows\system32\DRIVERS\circlass.sys
2010/12/19 16:18:52.0084 CLFS (635181e0e9bbf16871bf5380d71db02d) C:\Windows\system32\CLFS.sys
2010/12/19 16:18:52.0101 CmBatt (dea805815e587dad1dd2c502220b5616) C:\Windows\system32\DRIVERS\CmBatt.sys
2010/12/19 16:18:52.0112 cmdide (c537b1db64d495b9b4717b4d6d9edbf2) C:\Windows\system32\DRIVERS\cmdide.sys
2010/12/19 16:18:52.0129 CNG (1b675691ed940766149c93e8f4488d68) C:\Windows\system32\Drivers\cng.sys
2010/12/19 16:18:52.0141 Compbatt (a6023d3823c37043986713f118a89bee) C:\Windows\system32\DRIVERS\compbatt.sys
2010/12/19 16:18:52.0159 CompositeBus (f1724ba27e97d627f808fb0ba77a28a6) C:\Windows\system32\DRIVERS\CompositeBus.sys
2010/12/19 16:18:52.0172 crcdisk (2c4ebcfc84a9b44f209dff6c6e6c61d1) C:\Windows\system32\DRIVERS\crcdisk.sys
2010/12/19 16:18:52.0208 CSC (27c9490bdd0ae48911ab8cf1932591ed) C:\Windows\system32\drivers\csc.sys
2010/12/19 16:18:52.0236 DfsC (8e09e52ee2e3ceb199ef3dd99cf9e3fb) C:\Windows\system32\Drivers\dfsc.sys
2010/12/19 16:18:52.0254 discache (1a050b0274bfb3890703d490f330c0da) C:\Windows\system32\drivers\discache.sys
2010/12/19 16:18:52.0268 Disk (565003f326f99802e68ca78f2a68e9ff) C:\Windows\system32\DRIVERS\disk.sys
2010/12/19 16:18:52.0301 drmkaud (b918e7c5f9bf77202f89e1a9539f2eb4) C:\Windows\system32\drivers\drmkaud.sys
2010/12/19 16:18:52.0333 DXGKrnl (8b6c3464d7fac176500061dbfff42ad4) C:\Windows\System32\drivers\dxgkrnl.sys
2010/12/19 16:18:52.0394 ebdrv (024e1b5cac09731e4d868e64dbfb4ab0) C:\Windows\system32\DRIVERS\evbdx.sys
2010/12/19 16:18:52.0454 elxstor (0ed67910c8c326796faa00b2bf6d9d3c) C:\Windows\system32\DRIVERS\elxstor.sys
2010/12/19 16:18:52.0470 ErrDev (8fc3208352dd3912c94367a206ab3f11) C:\Windows\system32\DRIVERS\errdev.sys
2010/12/19 16:18:52.0493 exfat (2dc9108d74081149cc8b651d3a26207f) C:\Windows\system32\drivers\exfat.sys
2010/12/19 16:18:52.0504 fastfat (7e0ab74553476622fb6ae36f73d97d35) C:\Windows\system32\drivers\fastfat.sys
2010/12/19 16:18:52.0520 fdc (e817a017f82df2a1f8cfdbda29388b29) C:\Windows\system32\DRIVERS\fdc.sys
2010/12/19 16:18:52.0542 FileInfo (6cf00369c97f3cf563be99be983d13d8) C:\Windows\system32\drivers\fileinfo.sys
2010/12/19 16:18:52.0558 Filetrace (42c51dc94c91da21cb9196eb64c45db9) C:\Windows\system32\drivers\filetrace.sys
2010/12/19 16:18:52.0572 flpydisk (87907aa70cb3c56600f1c2fb8841579b) C:\Windows\system32\DRIVERS\flpydisk.sys
2010/12/19 16:18:52.0592 FltMgr (7520ec808e0c35e0ee6f841294316653) C:\Windows\system32\drivers\fltmgr.sys
2010/12/19 16:18:52.0620 FsDepends (1a16b57943853e598cff37fe2b8cbf1d) C:\Windows\system32\drivers\FsDepends.sys
2010/12/19 16:18:52.0631 Fs_Rec (a574b4360e438977038aae4bf60d79a2) C:\Windows\system32\drivers\Fs_Rec.sys
2010/12/19 16:18:52.0653 fvevol (dafbd9fe39197495aed6d51f3b85b5d2) C:\Windows\system32\DRIVERS\fvevol.sys
2010/12/19 16:18:52.0664 gagp30kx (65ee0c7a58b65e74ae05637418153938) C:\Windows\system32\DRIVERS\gagp30kx.sys
2010/12/19 16:18:52.0689 hamachi (833051c6c6c42117191935f734cfbd97) C:\Windows\system32\DRIVERS\hamachi.sys
2010/12/19 16:18:52.0714 hcw85cir (c44e3c2bab6837db337ddee7544736db) C:\Windows\system32\drivers\hcw85cir.sys
2010/12/19 16:18:52.0736 HdAudAddService (3530cad25deba7dc7de8bb51632cbc5f) C:\Windows\system32\drivers\HdAudio.sys
2010/12/19 16:18:52.0756 HDAudBus (717a2207fd6f13ad3e664c7d5a43c7bf) C:\Windows\system32\DRIVERS\HDAudBus.sys
2010/12/19 16:18:52.0773 HidBatt (1d58a7f3e11a9731d0eaaaa8405acc36) C:\Windows\system32\DRIVERS\HidBatt.sys
2010/12/19 16:18:52.0784 HidBth (89448f40e6df260c206a193a4683ba78) C:\Windows\system32\DRIVERS\hidbth.sys
2010/12/19 16:18:52.0793 HidIr (cf50b4cf4a4f229b9f3c08351f99ca5e) C:\Windows\system32\DRIVERS\hidir.sys
2010/12/19 16:18:52.0808 HidUsb (25072fb35ac90b25f9e4e3bacf774102) C:\Windows\system32\DRIVERS\hidusb.sys
2010/12/19 16:18:52.0855 HpSAMD (295fdc419039090eb8b49ffdbb374549) C:\Windows\system32\DRIVERS\HpSAMD.sys
2010/12/19 16:18:52.0885 HTTP (c531c7fd9e8b62021112787c4e2c5a5a) C:\Windows\system32\drivers\HTTP.sys
2010/12/19 16:18:52.0906 hwpolicy (8305f33cde89ad6c7a0763ed0b5a8d42) C:\Windows\system32\drivers\hwpolicy.sys
2010/12/19 16:18:52.0915 i8042prt (f151f0bdc47f4a28b1b20a0818ea36d6) C:\Windows\system32\DRIVERS\i8042prt.sys
2010/12/19 16:18:52.0935 iaStorV (934af4d7c5f457b9f0743f4299b77b67) C:\Windows\system32\DRIVERS\iaStorV.sys
2010/12/19 16:18:52.0956 iirsp (4173ff5708f3236cf25195fecd742915) C:\Windows\system32\DRIVERS\iirsp.sys
2010/12/19 16:18:53.0041 IntcAzAudAddService (0a0e3c041c20c4175e1cc6580138ca38) C:\Windows\system32\drivers\RTKVHDA.sys
2010/12/19 16:18:53.0091 intelide (a0f12f2c9ba6c72f3987ce780e77c130) C:\Windows\system32\DRIVERS\intelide.sys
2010/12/19 16:18:53.0110 intelppm (3b514d27bfc4accb4037bc6685f766e0) C:\Windows\system32\DRIVERS\intelppm.sys
2010/12/19 16:18:53.0132 IpFilterDriver (709d1761d3b19a932ff0238ea6d50200) C:\Windows\system32\DRIVERS\ipfltdrv.sys
2010/12/19 16:18:53.0152 IPMIDRV (e4454b6c37d7ffd5649611f6496308a7) C:\Windows\system32\DRIVERS\IPMIDrv.sys
2010/12/19 16:18:53.0170 IPNAT (a5fa468d67abcdaa36264e463a7bb0cd) C:\Windows\system32\drivers\ipnat.sys
2010/12/19 16:18:53.0181 IRENUM (42996cff20a3084a56017b7902307e9f) C:\Windows\system32\drivers\irenum.sys
2010/12/19 16:18:53.0191 isapnp (1f32bb6b38f62f7df1a7ab7292638a35) C:\Windows\system32\DRIVERS\isapnp.sys
2010/12/19 16:18:53.0205 iScsiPrt (ed46c223ae46c6866ab77cdc41c404b7) C:\Windows\system32\DRIVERS\msiscsi.sys
2010/12/19 16:18:53.0226 kbdclass (adef52ca1aeae82b50df86b56413107e) C:\Windows\system32\DRIVERS\kbdclass.sys
2010/12/19 16:18:53.0240 kbdhid (3d9f0ebf350edcfd6498057301455964) C:\Windows\system32\DRIVERS\kbdhid.sys
2010/12/19 16:18:53.0255 KSecDD (e36a061ec11b373826905b21be10948f) C:\Windows\system32\Drivers\ksecdd.sys
2010/12/19 16:18:53.0272 KSecPkg (365c6154bbbc5377173f1ca7bfb6cc59) C:\Windows\system32\Drivers\ksecpkg.sys
2010/12/19 16:18:53.0310 lltdio (f7611ec07349979da9b0ae1f18ccc7a6) C:\Windows\system32\DRIVERS\lltdio.sys
2010/12/19 16:18:53.0338 LSI_FC (eb119a53ccf2acc000ac71b065b78fef) C:\Windows\system32\DRIVERS\lsi_fc.sys
2010/12/19 16:18:53.0351 LSI_SAS (8ade1c877256a22e49b75d1cc9161f9c) C:\Windows\system32\DRIVERS\lsi_sas.sys
2010/12/19 16:18:53.0368 LSI_SAS2 (dc9dc3d3daa0e276fd2ec262e38b11e9) C:\Windows\system32\DRIVERS\lsi_sas2.sys
2010/12/19 16:18:53.0383 LSI_SCSI (0a036c7d7cab643a7f07135ac47e0524) C:\Windows\system32\DRIVERS\lsi_scsi.sys
2010/12/19 16:18:53.0402 luafv (6703e366cc18d3b6e534f5cf7df39cee) C:\Windows\system32\drivers\luafv.sys
2010/12/19 16:18:53.0431 LycoFltr (f90bde6e9c7b6015edf1dc99a97b00c9) C:\Windows\system32\Drivers\Lycosa.sys
2010/12/19 16:18:53.0462 MBAMProtector (9b5cc6c481bdd00a963829b892623247) C:\Windows\system32\drivers\mbam.sys
2010/12/19 16:18:53.0485 megasas (0fff5b045293002ab38eb1fd1fc2fb74) C:\Windows\system32\DRIVERS\megasas.sys
2010/12/19 16:18:53.0504 MegaSR (dcbab2920c75f390caf1d29f675d03d6) C:\Windows\system32\DRIVERS\MegaSR.sys
2010/12/19 16:18:53.0529 Modem (f001861e5700ee84e2d4e52c712f4964) C:\Windows\system32\drivers\modem.sys
2010/12/19 16:18:53.0551 monitor (79d10964de86b292320e9dfe02282a23) C:\Windows\system32\DRIVERS\monitor.sys
2010/12/19 16:18:53.0567 mouclass (fb18cc1d4c2e716b6b903b0ac0cc0609) C:\Windows\system32\DRIVERS\mouclass.sys
2010/12/19 16:18:53.0584 mouhid (2c388d2cd01c9042596cf3c8f3c7b24d) C:\Windows\system32\DRIVERS\mouhid.sys
2010/12/19 16:18:53.0599 mountmgr (921c18727c5920d6c0300736646931c2) C:\Windows\system32\drivers\mountmgr.sys
2010/12/19 16:18:53.0613 mpio (2af5997438c55fb79d33d015c30e1974) C:\Windows\system32\DRIVERS\mpio.sys
2010/12/19 16:18:53.0623 mpsdrv (ad2723a7b53dd1aacae6ad8c0bfbf4d0) C:\Windows\system32\drivers\mpsdrv.sys
2010/12/19 16:18:53.0644 MRxDAV (b1be47008d20e43da3adc37c24cdb89d) C:\Windows\system32\drivers\mrxdav.sys
2010/12/19 16:18:53.0674 mrxsmb (f1b6aa08497ea86ca6ef6f7a08b0bfb8) C:\Windows\system32\DRIVERS\mrxsmb.sys
2010/12/19 16:18:53.0692 mrxsmb10 (5613358b4050f46f5a9832da8050d6e4) C:\Windows\system32\DRIVERS\mrxsmb10.sys
2010/12/19 16:18:53.0706 mrxsmb20 (25c9792778d80feb4c8201e62281bfdf) C:\Windows\system32\DRIVERS\mrxsmb20.sys
2010/12/19 16:18:53.0726 msahci (4326d168944123f38dd3b2d9c37a0b12) C:\Windows\system32\DRIVERS\msahci.sys
2010/12/19 16:18:53.0749 msdsm (455029c7174a2dbb03dba8a0d8bddd9a) C:\Windows\system32\DRIVERS\msdsm.sys
2010/12/19 16:18:53.0775 Msfs (daefb28e3af5a76abcc2c3078c07327f) C:\Windows\system32\drivers\Msfs.sys
2010/12/19 16:18:53.0790 mshidkmdf (3e1e5767043c5af9367f0056295e9f84) C:\Windows\System32\drivers\mshidkmdf.sys
2010/12/19 16:18:53.0804 msisadrv (0a4e5757ae09fa9622e3158cc1aef114) C:\Windows\system32\DRIVERS\msisadrv.sys
2010/12/19 16:18:53.0835 MSKSSRV (8c0860d6366aaffb6c5bb9df9448e631) C:\Windows\system32\drivers\MSKSSRV.sys
2010/12/19 16:18:53.0853 MSPCLOCK (3ea8b949f963562cedbb549eac0c11ce) C:\Windows\system32\drivers\MSPCLOCK.sys
2010/12/19 16:18:53.0865 MSPQM (f456e973590d663b1073e9c463b40932) C:\Windows\system32\drivers\MSPQM.sys
2010/12/19 16:18:53.0884 MsRPC (0e008fc4819d238c51d7c93e7b41e560) C:\Windows\system32\drivers\MsRPC.sys
2010/12/19 16:18:53.0898 mssmbios (fc6b9ff600cc585ea38b12589bd4e246) C:\Windows\system32\DRIVERS\mssmbios.sys
2010/12/19 16:18:53.0910 MSTEE (b42c6b921f61a6e55159b8be6cd54a36) C:\Windows\system32\drivers\MSTEE.sys
2010/12/19 16:18:53.0924 MTConfig (33599130f44e1f34631cea241de8ac84) C:\Windows\system32\DRIVERS\MTConfig.sys
2010/12/19 16:18:53.0942 Mup (159fad02f64e6381758c990f753bcc80) C:\Windows\system32\Drivers\mup.sys
2010/12/19 16:18:53.0971 mv2 (4cb5d3a5902a92606408a36865a04d53) C:\Windows\system32\DRIVERS\mv2.sys
2010/12/19 16:18:54.0000 NativeWifiP (26384429fcd85d83746f63e798ab1480) C:\Windows\system32\DRIVERS\nwifi.sys
2010/12/19 16:18:54.0028 NDIS (23759d175a0a9baaf04d05047bc135a8) C:\Windows\system32\drivers\ndis.sys
2010/12/19 16:18:54.0046 NdisCap (0e1787aa6c9191d3d319e8bafe86f80c) C:\Windows\system32\DRIVERS\ndiscap.sys
2010/12/19 16:18:54.0069 NdisTapi (e4a8aec125a2e43a9e32afeea7c9c888) C:\Windows\system32\DRIVERS\ndistapi.sys
2010/12/19 16:18:54.0085 Ndisuio (b30ae7f2b6d7e343b0df32e6c08fce75) C:\Windows\system32\DRIVERS\ndisuio.sys
2010/12/19 16:18:54.0100 NdisWan (267c415eadcbe53c9ca873dee39cf3a4) C:\Windows\system32\DRIVERS\ndiswan.sys
2010/12/19 16:18:54.0117 NDProxy (af7e7c63dcef3f8772726f86039d6eb4) C:\Windows\system32\drivers\NDProxy.sys
2010/12/19 16:18:54.0136 NetBIOS (80b275b1ce3b0e79909db7b39af74d51) C:\Windows\system32\DRIVERS\netbios.sys
2010/12/19 16:18:54.0150 NetBT (dd52a733bf4ca5af84562a5e2f963b91) C:\Windows\system32\DRIVERS\netbt.sys
2010/12/19 16:18:54.0189 nfrd960 (1d85c4b390b0ee09c7a46b91efb2c097) C:\Windows\system32\DRIVERS\nfrd960.sys
2010/12/19 16:18:54.0204 Npfs (1db262a9f8c087e8153d89bef3d2235f) C:\Windows\system32\drivers\Npfs.sys
2010/12/19 16:18:54.0223 nsiproxy (e9a0a4d07e53d8fea2bb8387a3293c58) C:\Windows\system32\drivers\nsiproxy.sys
2010/12/19 16:18:54.0250 Ntfs (3795dcd21f740ee799fb7223234215af) C:\Windows\system32\drivers\Ntfs.sys
2010/12/19 16:18:54.0272 Null (f9756a98d69098dca8945d62858a812c) C:\Windows\system32\drivers\Null.sys
2010/12/19 16:18:54.0443 nvlddmkm (10999adf4c796fe23e1b891ef3441a13) C:\Windows\system32\DRIVERS\nvlddmkm.sys
2010/12/19 16:18:54.0609 nvraid (3f3d04b1d08d43c16ea7963954ec768d) C:\Windows\system32\DRIVERS\nvraid.sys
2010/12/19 16:18:54.0641 nvsmu (f13618f0cb1e95232f4c2401592a59e9) C:\Windows\system32\DRIVERS\nvsmu.sys
2010/12/19 16:18:54.0654 nvstor (c99f251a5de63c6f129cf71933aced0f) C:\Windows\system32\DRIVERS\nvstor.sys
2010/12/19 16:18:54.0670 nv_agp (5a0983915f02bae73267cc2a041f717d) C:\Windows\system32\DRIVERS\nv_agp.sys
2010/12/19 16:18:54.0706 ohci1394 (08a70a1f2cdde9bb49b885cb817a66eb) C:\Windows\system32\DRIVERS\ohci1394.sys
2010/12/19 16:18:54.0736 Parport (2ea877ed5dd9713c5ac74e8ea7348d14) C:\Windows\system32\DRIVERS\parport.sys
2010/12/19 16:18:54.0748 partmgr (ff4218952b51de44fe910953a3e686b9) C:\Windows\system32\drivers\partmgr.sys
2010/12/19 16:18:54.0764 Parvdm (eb0a59f29c19b86479d36b35983daadc) C:\Windows\system32\DRIVERS\parvdm.sys
2010/12/19 16:18:54.0784 pci (c858cb77c577780ecc456a892e7e7d0f) C:\Windows\system32\DRIVERS\pci.sys
2010/12/19 16:18:54.0798 pciide (afe86f419014db4e5593f69ffe26ce0a) C:\Windows\system32\DRIVERS\pciide.sys
2010/12/19 16:18:54.0808 pcmcia (f396431b31693e71e8a80687ef523506) C:\Windows\system32\DRIVERS\pcmcia.sys
2010/12/19 16:18:54.0820 pcw (250f6b43d2b613172035c6747aeeb19f) C:\Windows\system32\drivers\pcw.sys
2010/12/19 16:18:54.0843 PEAUTH (9e0104ba49f4e6973749a02bf41344ed) C:\Windows\system32\drivers\peauth.sys
2010/12/19 16:18:54.0922 PptpMiniport (631e3e205ad6d86f2aed6a4a8e69f2db) C:\Windows\system32\DRIVERS\raspptp.sys
2010/12/19 16:18:54.0932 Processor (85b1e3a0c7585bc4aae6899ec6fcf011) C:\Windows\system32\DRIVERS\processr.sys
2010/12/19 16:18:54.0955 Psched (6270ccae2a86de6d146529fe55b3246a) C:\Windows\system32\DRIVERS\pacer.sys
2010/12/19 16:18:54.0984 ql2300 (ab95ecf1f6659a60ddc166d8315b0751) C:\Windows\system32\DRIVERS\ql2300.sys
2010/12/19 16:18:55.0009 ql40xx (b4dd51dd25182244b86737dc51af2270) C:\Windows\system32\DRIVERS\ql40xx.sys
2010/12/19 16:18:55.0025 QWAVEdrv (584078ca1b95ca72df2a27c336f9719d) C:\Windows\system32\drivers\qwavedrv.sys
2010/12/19 16:18:55.0041 RasAcd (30a81b53c766d0133bb86d234e5556ab) C:\Windows\system32\DRIVERS\rasacd.sys
2010/12/19 16:18:55.0058 RasAgileVpn (57ec4aef73660166074d8f7f31c0d4fd) C:\Windows\system32\DRIVERS\AgileVpn.sys
2010/12/19 16:18:55.0094 Rasl2tp (d9f91eafec2815365cbe6d167e4e332a) C:\Windows\system32\DRIVERS\rasl2tp.sys
2010/12/19 16:18:55.0118 RasPppoe (0fe8b15916307a6ac12bfb6a63e45507) C:\Windows\system32\DRIVERS\raspppoe.sys
2010/12/19 16:18:55.0135 RasSstp (44101f495a83ea6401d886e7fd70096b) C:\Windows\system32\DRIVERS\rassstp.sys
2010/12/19 16:18:55.0156 rdbss (835d7e81bf517a3b72384bdcc85e1ce6) C:\Windows\system32\DRIVERS\rdbss.sys
2010/12/19 16:18:55.0171 rdpbus (0d8f05481cb76e70e1da06ee9f0da9df) C:\Windows\system32\DRIVERS\rdpbus.sys
2010/12/19 16:18:55.0185 RDPCDD (1e016846895b15a99f9a176a05029075) C:\Windows\system32\DRIVERS\RDPCDD.sys
2010/12/19 16:18:55.0207 RDPDR (c5ff95883ffef704d50c40d21cfb3ab5) C:\Windows\system32\drivers\rdpdr.sys
2010/12/19 16:18:55.0227 RDPENCDD (5a53ca1598dd4156d44196d200c94b8a) C:\Windows\system32\drivers\rdpencdd.sys
2010/12/19 16:18:55.0243 RDPREFMP (44b0a53cd4f27d50ed461dae0c0b4e1f) C:\Windows\system32\drivers\rdprefmp.sys
2010/12/19 16:18:55.0260 RDPWD (801371ba9782282892d00aadb08ee367) C:\Windows\system32\drivers\RDPWD.sys
2010/12/19 16:18:55.0275 rdyboost (4ea225bf1cf05e158853f30a99ca29a7) C:\Windows\system32\drivers\rdyboost.sys
2010/12/19 16:18:55.0306 rspndr (032b0d36ad92b582d869879f5af5b928) C:\Windows\system32\DRIVERS\rspndr.sys
2010/12/19 16:18:55.0333 RT2500 (e2988349fe0567cbe4161cc653575a8e) C:\Windows\system32\DRIVERS\RT2500.sys
2010/12/19 16:18:55.0356 RTL8167 (7dfd48e24479b68b258d8770121155a0) C:\Windows\system32\DRIVERS\Rt86win7.sys
2010/12/19 16:18:55.0373 s3cap (5423d8437051e89dd34749f242c98648) C:\Windows\system32\DRIVERS\vms3cap.sys
2010/12/19 16:18:55.0391 sbp2port (34ee0c44b724e3e4ce2eff29126de5b5) C:\Windows\system32\DRIVERS\sbp2port.sys
2010/12/19 16:18:55.0415 SCDEmu (612a3d69e603dbbe5c3c1079186a0393) C:\Windows\system32\drivers\SCDEmu.sys
2010/12/19 16:18:55.0428 scfilter (a95c54b2ac3cc9c73fcdf9e51a1d6b51) C:\Windows\system32\DRIVERS\scfilter.sys
2010/12/19 16:18:55.0458 secdrv (90a3935d05b494a5a39d37e71f09a677) C:\Windows\system32\drivers\secdrv.sys
2010/12/19 16:18:55.0488 Serenum (9ad8b8b515e3df6acd4212ef465de2d1) C:\Windows\system32\DRIVERS\serenum.sys
2010/12/19 16:18:55.0503 Serial (5fb7fcea0490d821f26f39cc5ea3d1e2) C:\Windows\system32\DRIVERS\serial.sys
2010/12/19 16:18:55.0522 sermouse (79bffb520327ff916a582dfea17aa813) C:\Windows\system32\DRIVERS\sermouse.sys
2010/12/19 16:18:55.0545 sffdisk (9f976e1eb233df46fce808d9dea3eb9c) C:\Windows\system32\DRIVERS\sffdisk.sys
2010/12/19 16:18:55.0559 sffp_mmc (932a68ee27833cfd57c1639d375f2731) C:\Windows\system32\DRIVERS\sffp_mmc.sys
2010/12/19 16:18:55.0574 sffp_sd (4f1e5b0fe7c8050668dbfade8999aefb) C:\Windows\system32\DRIVERS\sffp_sd.sys
2010/12/19 16:18:55.0588 sfloppy (db96666cc8312ebc45032f30b007a547) C:\Windows\system32\DRIVERS\sfloppy.sys
2010/12/19 16:18:55.0604 sisagp (2565cac0dc9fe0371bdce60832582b2e) C:\Windows\system32\DRIVERS\sisagp.sys
2010/12/19 16:18:55.0627 SiSRaid2 (a9f0486851becb6dda1d89d381e71055) C:\Windows\system32\DRIVERS\SiSRaid2.sys
2010/12/19 16:18:55.0645 SiSRaid4 (3727097b55738e2f554972c3be5bc1aa) C:\Windows\system32\DRIVERS\sisraid4.sys
2010/12/19 16:18:55.0666 Smb (3e21c083b8a01cb70ba1f09303010fce) C:\Windows\system32\DRIVERS\smb.sys
2010/12/19 16:18:55.0693 spldr (95cf1ae7527fb70f7816563cbc09d942) C:\Windows\system32\drivers\spldr.sys
2010/12/19 16:18:55.0748 sptd (cdddec541bc3c96f91ecb48759673505) C:\Windows\system32\Drivers\sptd.sys
2010/12/19 16:18:55.0748 Suspicious file (NoAccess): C:\Windows\system32\Drivers\sptd.sys. md5: cdddec541bc3c96f91ecb48759673505
2010/12/19 16:18:55.0752 sptd - detected Locked file (1)
2010/12/19 16:18:55.0778 srv (2dbedfb1853f06110ec2aa7f3213c89f) C:\Windows\system32\DRIVERS\srv.sys
2010/12/19 16:18:55.0804 srv2 (db37131d1027c50ea7ee21c8bb4536aa) C:\Windows\system32\DRIVERS\srv2.sys
2010/12/19 16:18:55.0831 srvnet (f5980b74124db9233b33f86fc5ebbb4f) C:\Windows\system32\DRIVERS\srvnet.sys
2010/12/19 16:18:55.0861 stexstor (db32d325c192b801df274bfd12a7e72b) C:\Windows\system32\DRIVERS\stexstor.sys
2010/12/19 16:18:55.0886 StillCam (edb05bd63148796f23ea78506404a538) C:\Windows\system32\DRIVERS\serscan.sys
2010/12/19 16:18:55.0908 storflt (957e346ca948668f2496a6ccf6ff82cc) C:\Windows\system32\DRIVERS\vmstorfl.sys
2010/12/19 16:18:55.0928 storvsc (d5751969dc3e4b88bf482ac8ec9fe019) C:\Windows\system32\DRIVERS\storvsc.sys
2010/12/19 16:18:55.0944 swenum (e58c78a848add9610a4db6d214af5224) C:\Windows\system32\DRIVERS\swenum.sys
2010/12/19 16:18:55.0995 Tcpip (bb7f39c31c4a4417fd318e7cd184e225) C:\Windows\system32\drivers\tcpip.sys
2010/12/19 16:18:56.0031 TCPIP6 (bb7f39c31c4a4417fd318e7cd184e225) C:\Windows\system32\DRIVERS\tcpip.sys
2010/12/19 16:18:56.0050 tcpipreg (e64444523add154f86567c469bc0b17f) C:\Windows\system32\drivers\tcpipreg.sys
2010/12/19 16:18:56.0063 TDPIPE (1875c1490d99e70e449e3afae9fcbadf) C:\Windows\system32\drivers\tdpipe.sys
2010/12/19 16:18:56.0078 TDTCP (7551e91ea999ee9a8e9c331d5a9c31f3) C:\Windows\system32\drivers\tdtcp.sys
2010/12/19 16:18:56.0096 tdx (cb39e896a2a83702d1737bfd402b3542) C:\Windows\system32\DRIVERS\tdx.sys
2010/12/19 16:18:56.0116 TermDD (c36f41ee20e6999dbf4b0425963268a5) C:\Windows\system32\DRIVERS\termdd.sys
2010/12/19 16:18:56.0155 tssecsrv (98ae6fa07d12cb4ec5cf4a9bfa5f4242) C:\Windows\system32\DRIVERS\tssecsrv.sys
2010/12/19 16:18:56.0170 tunnel (3e461d890a97f9d4c168f5fda36e1d00) C:\Windows\system32\DRIVERS\tunnel.sys
2010/12/19 16:18:56.0180 uagp35 (750fbcb269f4d7dd2e420c56b795db6d) C:\Windows\system32\DRIVERS\uagp35.sys
2010/12/19 16:18:56.0197 udfs (09cc3e16f8e5ee7168e01cf8fcbe061a) C:\Windows\system32\DRIVERS\udfs.sys
2010/12/19 16:18:56.0222 uliagpkx (44e8048ace47befbfdc2e9be4cbc8880) C:\Windows\system32\DRIVERS\uliagpkx.sys
2010/12/19 16:18:56.0237 umbus (049b3a50b3d646baeeee9eec9b0668dc) C:\Windows\system32\DRIVERS\umbus.sys
2010/12/19 16:18:56.0250 UmPass (7550ad0c6998ba1cb4843e920ee0feac) C:\Windows\system32\DRIVERS\umpass.sys
2010/12/19 16:18:56.0278 usbaudio (2436a42aab4ad48a9b714e5b0f344627) C:\Windows\system32\drivers\usbaudio.sys
2010/12/19 16:18:56.0297 usbccgp (8455c4ed038efd09e99327f9d2d48ffa) C:\Windows\system32\DRIVERS\usbccgp.sys
2010/12/19 16:18:56.0308 usbcir (04ec7cec62ec3b6d9354eee93327fc82) C:\Windows\system32\DRIVERS\usbcir.sys
2010/12/19 16:18:56.0333 usbehci (ff32d4f3ec3c68b2ca61782c7964f54e) C:\Windows\system32\DRIVERS\usbehci.sys
2010/12/19 16:18:56.0348 usbhub (b0dfc7b484e0ca0c27bda5433b82d94a) C:\Windows\system32\DRIVERS\usbhub.sys
2010/12/19 16:18:56.0361 usbohci (a6fb7957ea7afb1165991e54ce934b74) C:\Windows\system32\DRIVERS\usbohci.sys
2010/12/19 16:18:56.0380 usbprint (797d862fe0875e75c7cc4c1ad7b30252) C:\Windows\system32\DRIVERS\usbprint.sys
2010/12/19 16:18:56.0395 USBSTOR (d8889d56e0d27e57ed4591837fe71d27) C:\Windows\system32\DRIVERS\USBSTOR.SYS
2010/12/19 16:18:56.0411 usbuhci (78780c3ebce17405b1ccd07a3a8a7d72) C:\Windows\system32\DRIVERS\usbuhci.sys
2010/12/19 16:18:56.0433 vdrvroot (a059c4c3edb09e07d21a8e5c0aabd3cb) C:\Windows\system32\DRIVERS\vdrvroot.sys
2010/12/19 16:18:56.0450 vga (17c408214ea61696cec9c66e388b14f3) C:\Windows\system32\DRIVERS\vgapnp.sys
2010/12/19 16:18:56.0464 VgaSave (8e38096ad5c8570a6f1570a61e251561) C:\Windows\System32\drivers\vga.sys
2010/12/19 16:18:56.0475 vhdmp (3be6e1f3a4f1afec8cee0d7883f93583) C:\Windows\system32\DRIVERS\vhdmp.sys
2010/12/19 16:18:56.0497 viaagp (c829317a37b4bea8f39735d4b076e923) C:\Windows\system32\DRIVERS\viaagp.sys
2010/12/19 16:18:56.0512 ViaC7 (e02f079a6aa107f06b16549c6e5c7b74) C:\Windows\system32\DRIVERS\viac7.sys
2010/12/19 16:18:56.0529 viaide (e43574f6a56a0ee11809b48c09e4fd3c) C:\Windows\system32\DRIVERS\viaide.sys
2010/12/19 16:18:56.0554 vmbus (379b349f65f453d2a6e75ea6b7448e49) C:\Windows\system32\DRIVERS\vmbus.sys
2010/12/19 16:18:56.0569 VMBusHID (ec2bbab4b84d0738c6c83d2234dc36fe) C:\Windows\system32\DRIVERS\VMBusHID.sys
2010/12/19 16:18:56.0586 volmgr (384e5a2aa49934295171e499f86ba6f3) C:\Windows\system32\DRIVERS\volmgr.sys
2010/12/19 16:18:56.0605 volmgrx (b5bb72067ddddbbfb04b2f89ff8c3c87) C:\Windows\system32\drivers\volmgrx.sys
2010/12/19 16:18:56.0622 volsnap (58df9d2481a56edde167e51b334d44fd) C:\Windows\system32\DRIVERS\volsnap.sys
2010/12/19 16:18:56.0642 vsmraid (9dfa0cc2f8855a04816729651175b631) C:\Windows\system32\DRIVERS\vsmraid.sys
2010/12/19 16:18:56.0660 vwifibus (90567b1e658001e79d7c8bbd3dde5aa6) C:\Windows\System32\drivers\vwifibus.sys
2010/12/19 16:18:56.0709 VX3000 (e26744e5dd71a16e80d4dd5a286b8423) C:\Windows\system32\DRIVERS\VX3000.sys
2010/12/19 16:18:56.0761 WacomPen (de3721e89c653aa281428c8a69745d90) C:\Windows\system32\DRIVERS\wacompen.sys
2010/12/19 16:18:56.0784 WANARP (692a712062146e96d28ba0b7d75de31b) C:\Windows\system32\DRIVERS\wanarp.sys
2010/12/19 16:18:56.0792 Wanarpv6 (692a712062146e96d28ba0b7d75de31b) C:\Windows\system32\DRIVERS\wanarp.sys
2010/12/19 16:18:56.0818 Wd (1112a9badacb47b7c0bb0392e3158dff) C:\Windows\system32\DRIVERS\wd.sys
2010/12/19 16:18:56.0839 Wdf01000 (9950e3d0f08141c7e89e64456ae7dc73) C:\Windows\system32\drivers\Wdf01000.sys
2010/12/19 16:18:56.0881 WfpLwf (8b9a943f3b53861f2bfaf6c186168f79) C:\Windows\system32\DRIVERS\wfplwf.sys
2010/12/19 16:18:56.0890 WIMMount (5cf95b35e59e2a38023836fff31be64c) C:\Windows\system32\drivers\wimmount.sys
2010/12/19 16:18:56.0951 WinUsb (30fc6e5448d0cbaaa95280eeef7fedae) C:\Windows\system32\DRIVERS\WinUsb.sys
2010/12/19 16:18:56.0973 WmiAcpi (0217679b8fca58714c3bf2726d2ca84e) C:\Windows\system32\DRIVERS\wmiacpi.sys
2010/12/19 16:18:56.0997 ws2ifsl (6db3276587b853bf886b69528fdb048c) C:\Windows\system32\drivers\ws2ifsl.sys
2010/12/19 16:18:57.0027 WudfPf (6f9b6c0c93232cff47d0f72d6db1d21e) C:\Windows\system32\drivers\WudfPf.sys
2010/12/19 16:18:57.0040 WUDFRd (f91ff1e51fca30b3c3981db7d5924252) C:\Windows\system32\DRIVERS\WUDFRd.sys
2010/12/19 16:18:57.0103 ================================================================================
2010/12/19 16:18:57.0103 Scan finished
2010/12/19 16:18:57.0110 Detected object count: 1
2010/12/19 16:19:08.0788 Locked file(sptd) - User select action: Skip
Twist154
Posts Posts : 39
OS OS : 7 Ultimate
Post by Belahzur on 20th December 2010, 10:55 pm
Okay it's fine.
Run ESET Online Scan
Please do an online scan with [You must be registered and logged in to see this link.]. Please use Internet Explorer as it uses ActiveX.
  • Click on Scan.
Post by Twist154 on 22nd December 2010, 1:03 am
[You must be registered and logged in to see this link.] wrote:Okay it's fine.
  • Click on Scan.
all ok
# version=7
# OnlineScanner.ocx=1.0.0.6419
# api_version=3.0.2
# EOSSerial=b23edbbae5689842a60a93397499a553
# end=finished
# remove_checked=true
# archives_checked=false
# unwanted_checked=true
# unsafe_checked=false
# antistealth_checked=true
# utc_time=2010-12-21 01:35:29
# local_time=2010-12-21 08:35:29 (-0500, Eastern Standard Time)
# country="United States"
# lang=1033
# osver=6.1.7600 NT
# compatibility_mode=5893 16776574 100 94 218610 44479736 0 0
# scanned=175427
# found=0
# cleaned=0
# scan_time=3584
Twist154
Posts Posts : 39
OS OS : 7 Ultimate
Post by Belahzur on 22nd December 2010, 1:18 am
Looks good, how is the machine running?
Post by Twist154 on 22nd December 2010, 11:59 pm
[You must be registered and logged in to see this link.] wrote:Looks good, how is the machine running?
I still cannot run my program. I have uninstalled it, reinstalled it and it still goes away when I hoover over the icon in the lower right hand corner.
Twist154
Posts Posts : 39
OS OS : 7 Ultimate
