Critical Error: Hard drive missing, hard drive not found. Hard drive error.
Post by nathdaig90 on 12th December 2010, 11:57 pm
When I start my computer HDD request starts automatically, telling me there 11 errors with my hard drive. After i perform the deframentation, it fixes 6 and 5 remains. I can use my computer for about 10 to 15 minutes before it makes me restart it. I was just wondering if there's any way of fixing this?
nathdaig90
Posts Posts : 27
Joined Joined : 2010-01-10
OS OS : Windows Vista
Points Points : 25548
Re: Critical Error: Hard drive missing, hard drive not found. Hard drive error.
Post by Nazzgull on 13th December 2010, 4:07 pm
If you're using Windows Vista, do you have that DVD ? I'll perform few repairs.
Points Points : 40465
Post by nathdaig90 on 13th December 2010, 5:16 pm
no i dont have the DVD.
nathdaig90
Posts Posts : 27
Post by Nazzgull on 13th December 2010, 5:24 pm
Can you borrow copy of Windows Vista from your friends ? It doesn't need to be original.
Pleas follow next instructions.
  • Go to Start > My Computer.
  • Right click on your C: partition and go to Properties.
  • Go to Tools tab and choose Error Checking.
  • Mark both options inside and press Start.
  • After checking, please restart your computer.
Let me know results.
Post by nathdaig90 on 13th December 2010, 5:29 pm
I've done this, numerous times.. always the same 11 errors, and it fixed 6 and leaves 5...
Read time of hard drive clusters less than 500ms- failed to fix
333% of HDD space is unreadable - failed to fix
Hard drive doesn't respond to system commands - failed to fix
Bad sectors on hard drive or damaged file allocation table - failed to fix
Boot sector of the hard drive disk is damaged - dailure to fix.
nathdaig90
Posts Posts : 27
Post by Nazzgull on 13th December 2010, 6:38 pm
Okay, please follow next instructions.
  • Go to Start > All Programs > Accessories > Right click on Command Prompt and go Run as Administrator.
  • In Command Prompt type command bellow, and after each one, press Enter to run it.
bootrec.exe
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
bootrec.exe /scanos
Please restart your computer after this step, and run Error Checking again. Tell me results.
Post by nathdaig90 on 13th December 2010, 7:33 pm
after everyone i type it it says :
'bootrec.exe' is not recognized as an internal or external command, operable program or batch files.
nathdaig90
Posts Posts : 27
Post by Nazzgull on 13th December 2010, 7:41 pm
You really need to find Windows Vista installation disc. I can not perform any action without the disc.
