Thank you for the help....and a question
Post by CBinSD on 12th December 2010, 8:24 pm
New member here. I ended up at GeekPolice via a Google search on my System Tool virus problem. After following your advice it appears the virus has been given the boot. I decided I should support your site so I purchased the full version of Anti-Malware and also got the back-up disk. And here is my question.....can I use this disk to run the full version on my second home computer? Thanks again for the help.
CBinSD
Posts Posts : 8
Joined Joined : 2010-12-12
OS OS : XP Pro
Points Points : 21889
Re: Thank you for the help....and a question
Post by Doctor Inferno on 13th December 2010, 10:02 am
If you bought a single license for Malwarebytes Anti-Malware then it can only be used on one computer.
Points Points : 104610
Post by Buttons on 13th December 2010, 9:34 pm
I also note GeekPolice isn't affiliated with Malwarebytes Corporation.
Buttons
Posts Posts : 869
Joined Joined : 2010-06-11
OS OS : 7 Ultimate x64
Points Points : 26296
