Replacement power supply for a Toshbia Laptop P305-S8996E
Post by reba76 on Thu Dec 09, 2010 10:48 am
Can you tell me if I need to buy the specific power supply for this model laptop? I know it needs to be a toshiba cord, but is it necessary to buy the power supply to this exact model?
Thanks!
reba76
Posts Posts : 5
Joined Joined : 2009-11-22
OS OS : vista
Points Points : 25738
Re: Replacement power supply for a Toshbia Laptop P305-S8996E
Post by Nazzgull on Fri Dec 10, 2010 9:35 am
It's not necessary. You can use any model of power supply which can be used by your laptop. It practically don't even need to be toshiba's. Just check your PC Shop for more information, they'll advice you what is best for your laptop.
Points Points : 40475
Post by reba76 on Fri Dec 10, 2010 9:41 am
Wonderful. Thanks for your help!
reba76
Posts Posts : 5
OS OS : vista
Post by Nazzgull on Sat Dec 11, 2010 5:13 am
No problem, have a nice day Smile
