No audio device installed
Re: No audio device installed
Post by houndmom on 6th December 2010, 5:36 pm
I did not think about trying to go back to XP pro.. My daughter can't afford 7 yet, so I will try that!
I'm with you I hate Vista, I never had anything but problems before I got 7!!!
Thanks, 2 heads are better than 1!!!
If we have helped you, Please consider helping us,  make a donation.
Helping fight malware.
houndmom
Posts Posts : 1053
Joined Joined : 2010-04-27
OS OS : Windows 7 ultimate
Protection Protection : Bitdefender Total Security 2010
Points Points : 29797
Post by Nazzgull on 6th December 2010, 6:20 pm
I just never have problem with XP sound or 7, i never used Vista because i saw what peoples talking about that 'OS' on internet, it's just too much buggy.
Try to reinstall Windows Vista and check Sound again, it might helps. If problem still appearing, just choose new OS.
Posts Posts : 2330
Points Points : 40485
Post by houndmom on 9th December 2010, 7:17 pm
Sorry I haven't brought you up to date this week yet. I tried to replace Vista OS with XP pro and got a stop error (I didn't write it down) also a message to check BIOS version.
So I reinstalled the Vista OS in order for the computer to reboot correctly, still no sound and the CD/DVD coming in and out of being recognized . I will try XP pro again to see what happens and write the stop error down.
Would it be a possibility to create another partition to try and see if the sound works on Xp that way??
This is beginning to be a pain!!! Let me think
houndmom
Posts Posts : 1053
Post by Nazzgull on 9th December 2010, 7:22 pm
Oh my god, too many errors Goofy Maybe you really have to update your BIOS, is that some really old computer or what ?
Naa, let's not try dual OS, have to many errors for now. Pain, yeah.. Try to catch up that message XP gives you, maybe it's related to some of hardware components.
Posts Posts : 2330
Post by houndmom on 9th December 2010, 7:30 pm
The computer is only 4 years old (HP DV6500 series laptop).... Just crapping out I guess.
It should have let me downgrade to Xp pro but would not, It did not even get to installing anything before the stop error and check BIOS message. When I reinstalled Vista OS According to updates the BIOS was up to date (for Vista).
Thanks Nazzgull!!
houndmom
Posts Posts : 1053
Post by Nazzgull on 9th December 2010, 7:39 pm
Posts Posts : 2330
Post by houndmom on 11th December 2010, 3:58 pm
Want to bring you up to date.
I went ahead and installed Vista SP 2 and so far the CD/DVD is being recognized. The sound still does not work, but the SoundBlaster X-FI pro installed and she has sound with earphones. I haven't figured out if it is set up that way or if I can get it to use the laptops speakers. She may have to use external Speakers, but it is working for now!! Hooray!
I will let you know If I am able to set it up to use the internal speakers.
Thanks for all your help
houndmom
Posts Posts : 1053
Post by Nazzgull on 11th December 2010, 4:23 pm
Nice information Smile Try audio from HP i give you in post above, I found on HP website for that model of laptops, maybe it helps.
No problem, I'm still here Smile
Posts Posts : 2330
Post by houndmom on 11th December 2010, 5:23 pm
Yeah I tried the link but it did not work either. It was one that I had already installed earlier.
Thanks!!
houndmom
Posts Posts : 1053
