System Tools removal
Post by keljampa on 27th November 2010, 11:15 pm
Hello
my pc is infected with System Tool and I can not even open the OTL.
Before I tried Rkill 6 diferent extensions, yep can someone help me to remove the program for free?
I have uninstaled the Sistem Tools, and deleted the only Sistem Tool.exe file found in a search.
Unfortunately it allows no previledge to restore the system.
:sad:
keljampa
Joined Joined : 2010-11-27
Points Points : 22038
Re: System Tools removal
Post by Belahzur on 28th November 2010, 12:56 am
Points Points : 245079
Post by keljampa on 29th November 2010, 2:38 pm
I managed to restore my pc to a day before discovering System Tool.
Did it by restarting in safe mode with networking.
Had to uninstall the anti virus, wouldn't repair (Avast) and installed Microsoft Security Essentials and Win Patrol these are both free. :smile2:
keljampa
