External HDD problem
Post by Biglowz on 26th November 2010, 11:23 am
Could someone help me please? I've used this External HDD as my main storage device and now it requires me to format it to use it again.. however if i were to format it, all my files and info would be deleted.. please help me.. Thank You!
Points Points : 32085
Re: External HDD problem
Post by Nazzgull on 26th November 2010, 1:48 pm
Please plug in your External HDD and go to My Computer.
  • Right click on it and go to Properties.
  • Click on Tools tab and you'll see Error-Checking.
  • Click on Check now button.
  • Mark both checkbox inside and click Start
Posts Posts : 2330
Points Points : 40495
Post by Biglowz on 27th November 2010, 1:45 am
I'ts ok until the part where i click check now, then it requires me to format again.. >.<
Post by Biglowz on 29th November 2010, 10:16 am
Bump Bump.. It still isnt solved.. T.T
Post by Nazzgull on 30th November 2010, 7:47 pm
Posts Posts : 2330
Post by Biglowz on 8th December 2010, 1:42 pm
It can't even format.. it says Windows was unable to complete the format.. =X
Post by Nazzgull on 8th December 2010, 3:27 pm
Try go to Disc Management. Go to Start > Run > type diskmgmt.msc and press Enter.
Now, do not touch your real partition, just go down and you'll see your external HDD, right click on in and set Format > Accept with Yes any prompt you got.
Posts Posts : 2330
