Wireless connection trouble
Post by dcspectre on 26th November 2010, 11:04 am
I'm currently using a Billion myGuard 7202G. I've noticed that recently the wireless has stopped working, despite showing as connected in the router settings.
Currently running 4 pc's hardwired to the router, and had been using 2 laptops and a ps3 wirelessly.
Not sure what step to take now in getting these devices back up on the network.
Regards,
dcspectre
Posts Posts : 12
Joined Joined : 2009-01-11
Points Points : 28901
Re: Wireless connection trouble
Post by Nazzgull on 29th November 2010, 2:55 pm
try to Reset your router settings to defaults.
Points Points : 40465
Post by dcspectre on 30th November 2010, 11:22 am
Router settings reset to defaults, still unable to find our network on any of the wireless devices. (Can see our neighbors networks however).
dcspectre
Posts Posts : 12
Post by Nazzgull on 30th November 2010, 7:02 pm
This is what i found on myGuard PDF file :
After the myGuard router is powered on, press this recessed button using the end of paper clip or other small pointed object to reset the router or to restore it to factory default settings.
1. Recovery procedures for non-working routers (e.g. after a failed firmware upgrade flash):
Hold the Emergency/Failure Recovery Button on the back of the modem in. Keep this button held in and turn on the modem. Once the lights on the modem have stopped flashing, release the Emergency/Failure Recovery Button. The modem's emergency-reflash web interface will then be accessible via http://192.168.1.254/ where you can upload a firmware image to restore the modem to a functional state. Please note that the modem will only respond via its web interface at this address, and will not respond to ping requests from your PC or to telnet connections.
Check user manual at link here :
http://www.billion.com/_Internet/usermanual/myGuard7202_UM_04182005.pdf
And you can maybe try to update firmware, it might helps. You have all explained inside User Manual.
