thinkpoint problems
thinkpoint problems
Post by rigginsw3 on Mon 22 Nov - 7:58
I am not a programer.
I have read most everything online about getting rid of thinkpoint.
I tried microsoft essential and the malware...
It just got worse.
The only screen on my computer is the "thinkpoint" logo
nothing else works. When I try to do any thing with the mouse it just sits there. I had to borrow my wifes laptop to contact you. She is a web developer so I am on borrowed time.
Any simple solutions?
rigginsw3
Joined Joined : 2010-11-22
Points Points : 22063
Re: thinkpoint problems
Post by Dr Jay on Mon 22 Nov - 16:37
Hi. I'm guessing, according to you sarcastic comment, you are not smart at computers? I love such comments. Ahahaha
This may be a bit complicating, so please ask questions. What we are going to do is so much easier than trying to disinfect the system with the ThinkPoint issue at hand.
  • Place a blank CD-R disc in to your CD burning drive.
  • Download [You must be registered and logged in to see this link.] and double-click on it to burn to a CD using ISO Burner.
    Note : If you do not know how to set your computer to boot from CD follow the steps [You must be registered and logged in to see this link.]
Posts Posts : 13714
Joined Joined : 2009-09-07
Points Points : 302072
