Icon problem
Solved Icon problem
Post by Lance(HAOH) on 21st November 2010, 12:24 am
Hi. My .docx format file was previously associated with wordpad. I have recently installed Microsoft Office 2007 and I set .docx format files to open with Microsoft Word by default. Although the file now opens with Microsoft Word, the icon of the file does not change to that of Microsoft Word. I am also experiencing problems for other types of Microsoft Office files. Please advise me.
Lance(HAOH)
Posts Posts : 138
Joined Joined : 2008-12-12
OS OS : Windows XP Professional, Windows 7 Enterprise, Windows 8 Professional WMC, Ubuntu Linux
Protection Protection : Avast 8
Points Points : 30210
Solved Re: Icon problem
Post by Nazzgull on 22nd November 2010, 3:00 pm
Try go right click on .docx file and go to Properties. In Opens With line click on Change button, now choose Microsoft Word and click OK.
Try to restart your computer after that, and let me know if your icons work now.
If they don't, go to Tools > Folder Options. Click on View tab and click on Advanced Settings box > Display File Icons on Thumbnails have to be checked. Just uncheck, than click Apply > check it again and click Apply. After that, you can click on Default, your choice ;)
Posts Posts : 2330
Points Points : 40485
Post by Lance(HAOH) on 24th November 2010, 3:44 am
Hi. The solution is not working. Please advise me.
Lance(HAOH)
Posts Posts : 138
Post by Nazzgull on 24th November 2010, 7:26 pm
Okay, please go to Start > Run > type CMD to start Command Prompt.
In Command Prompt, type next command :
CD /d %userprofile%\AppData\Local
DEL IconCache.db /a
EXIT
Posts Posts : 2330
Post by Lance(HAOH) on 27th November 2010, 12:28 am
It does not seem to have any effect. Please advise.
Lance(HAOH)
Posts Posts : 138
Post by Nazzgull on 29th November 2010, 2:43 pm
Check this link :
http://social.technet.microsoft.com/Forums/en-US/w7itproui/thread/06ca40c3-84e6-4189-98e0-31512ba97f87
Did you tried to reinstall MS Office ? It might helps.
Posts Posts : 2330
Post by Lance(HAOH) on 2nd December 2010, 9:28 am
I solved this problem using a utility called filetypesman. I edited the default icon path for .docx files and that worked perfectly! Thank you for taking time to help me. Thank You!
Lance(HAOH)
Posts Posts : 138
