Hill Billy needs Help with Banker Fox A and Win32.nuquel please
Post by Hill Billy on Sat 20 Nov 2010, 2:47 pm
I am very much a novice with this type of stuff. It appears the above two things have completely taken over my Dell Vista Home Premium because I am unable to do anything with the computer. I would very much appreciate a mentor to help!
Hill Billy
Operating System : Windows Vista Home Premium
Re: Hill Billy needs Help with Banker Fox A and Win32.nuquel please
Post by DragonMaster Jay on Sat 20 Nov 2010, 5:05 pm
Hello, and welcome to GeekPolice.
Please note the following information about the malware forum:
  • Only Tech Officers, Global Moderators, Administrators, and Malware Advisors are allowed to give advice on removing malware from your computer.
  • From this point on, please do not make any more changes to your computer; such as install/uninstall programs, use special fix tools, delete files, edit the registry, etc. - unless advised by the staff I noted above.
  • Please do not ask for help elsewhere (in this site or other sites). Doing so can result in system changes, which may not show up in the logs you post.
  • If you have already asked for help somewhere, please post the link to the topic you were helped.
  • We try our best to reply quickly, but for any reason we do not reply in two days, do one of two things:
    Reply to this topic with the word BUMP, or
    see [You must be registered and logged in to see this link.].
  • Lastly, keep in mind that we are volunteers, so you do not have to pay for malware removal. Persist in this topic until its close, and your computer is declared clean.
We are going to be using a Windows Recovery Environment to help disinfect the system.
  • Place a blank CD-R disc in to your CD burning drive.
  • Download OTLPEStd.exe and double-click on it to burn to a CD using ISO Burner.
GeekPolice Academy Manager
DragonMaster Jay
Manager | Tech Officer
View user profile http://www.twitter.com/jaypfoutz
