Think Point has taken over!!!! Help!
Post by JonesL17 on Sat 20 Nov 2010, 1:05 am
Hi Guys,
First post here so be kind!
I am in no way a techie so please, layman terms if possible!
Basically I have the Think Point virus. I followed the online instructions on how to get rid, booting in safe mode, downloading malwarebytes, scanning removing etc etc. I thought it had worked but apparently not!
While I was using my laptop it shut down on its own and when I tried to turn it back on, it boots (I can hear it, the light comes on etc.) but the screen is just black
I can get into the BIOS Utility Setup screen and from there I can get into the menu to choose start up with safe mode but it won't start with safe mode. In fact I've tried ALL of the options and none of them will boot up. Most options I select result in the black screen.
When I select the safe mode option it starts to boot but then hangs after a few seconds, the last filepath it hangs on is:
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS\system32\DRIVERS\isapnp.sys
I'm not sure what else to tell you.
The laptop is an Asus Eee PC
OS is XP Home Edition.
Just thought it might be relevant to mention that this laptop does not have a disc drive.
Any help at all would be much appreciated
Last edited by JonesL17 on Sat 20 Nov 2010, 1:18 am; edited 1 time in total (Reason for editing : adding further info)
JonesL17
Operating System : Windows XP Home Edition
Re: Think Point has taken over!!!! Help!
Post by Belahzur on Sat 20 Nov 2010, 11:38 am
Download OTL by OldTimer to your Desktop.
Manager | Tech Officer
Post by JonesL17 on Sat 20 Nov 2010, 3:16 pm
Thanks for the reply!
This is where the "layman terms" part comes in though :/
I can't get the laptop to boot up into ANY mode whatsoever so how do I run the above program?
I can download it on a clean computer and put it on a USB but the only screen I have access to on the infected one is the BIOS Utility Setup (?)
Confused!
Thanks again!
JonesL17
Post by Belahzur on Sun 21 Nov 2010, 11:09 am
  • Place a blank CD-R disc in to your CD burning drive.
  • Download OTLPEStd.exe and double-click on it to burn to a CD using ISO Burner.
Post by JonesL17 on Sun 21 Nov 2010, 11:24 am
Thanks, but as mentioned in my original post the laptop doesn't have a disc drive. Can I download it to a USB and boot from that?
Thanks.
JonesL17
Post by JonesL17 on Mon 22 Nov 2010, 2:58 pm
Soooooo, any ideas?
JonesL17
Post by Belahzur on Tue 23 Nov 2010, 12:08 pm
OTLPE on a Flash Drive:
IMPORTANT:
You will need a flash drive with a size of 512 Mb or bigger. Make sure that you do not leave anything important on the flash drive, as all data on it will be deleted during the following steps.
    • Download OTLPEStd.exe from one of the following links and save it to your Desktop: mirror1 or mirror2
    • Download eeepcfr.zip from the following link and save it to your Desktop: the mirror
    • Finally, if you do not have a file archiver like 7-zip or Winrar installed, please download 7-zip from the following link and install it: the mirror
  • Once you have 7-zip installed, decompress OTLPEStd.exe by rightclicking on the folder and choosing the options shown in the picture below. Please use a dedicated folder, for example OTLPE, on your Desktop
  • Open the folder OTLPEStd which will be created in the same location as OTLPEStd.exe and right-click OTLPE_New_Std.iso. Select 7-Zip and from the submenu select Extract files... and extract the content onto your Desktop in a OTLPE folder:
  • Please also decompress eeepcfr to your systemroot (usually C:\).
  • Empty the flash drive you want to install OTLPE on.
  • Go to C:\eeecpfr and double-click usb_prep8.cmd to launch it.
  • Press any key when asked to in the black window that opens.
  • As indicated in the image, make sure you have selected the correct flash drive, before proceeding.
    For Drive Label: type in OTLPE.
    Under Source Path to built BartPE/WinPE Files click ... and select the folder OTLPE that you created on your Desktop.
    Finally check Enable File Copy.
  • Click on Start, accept the disclaimers and wait for the program to finish.
  • Your bootable flash drive should now be ready!
    Post by JonesL17 on Wed 24 Nov 2010, 2:18 am
    Done all of the above but the system won't boot from the USB. It recognises the usb in the boot menu in BIOS i select it, it starts to boot, then hangs on a screen saying ' remove media or other device, press any key to restart'
    JonesL17
    Post by Belahzur on Wed 24 Nov 2010, 9:33 am
    Do you have your XP disc?
    Post by JonesL17 on Wed 24 Nov 2010, 11:39 am
    No it's a work laptop that's been passed on a few times,so I don't have any original software.
    JonesL17
    Post by Belahzur on Thu 25 Nov 2010, 9:46 am
    Afraid not much I can do then, if it's a work laptop, just give them it back and ask for a better one, lol.
    Post by Sponsored content Today at 4:09 am
