BSOD problem
BSOD problem
Post by chris0990 on Mon 15 Nov 2010, 12:57 am
i have been getting a lot of bsod this week and my computer is becoming very unreliable
below is the link to download the minidump folder.
i want to know what is the problem and how to fix it.
thank you in advance
https://cid-4adb6c0536805a16.skydrive.live.com/redir.aspx?resid=4ADB6C0536805A16!102&authkey=jhQF9wF3MhA%24
chris0990
Unborn
Unborn
Operating System : windows 7 professional
Re: BSOD problem
Post by Capt.Jack Sparrow on Wed 17 Nov 2010, 7:24 am
Hello and Welcome !
The Bugcheck 0x124 is pointing to some Hardware component. I would recommend to start with Hardware Diagnostic follow this link http://captaindebugger.wordpress.com/hardware-diagnostic/ and run all the Diagnostic. If your Overclocking please reset everything to default. Check the temperatures use Speedfan make sure there is no heating issues.
Report us back.
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8005034028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b2000040, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000800, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR:  0x124_GenuineIntel
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
PROCESS_NAME:  System
CURRENT_IRQL:  f
STACK_TEXT:
fffff880`02fdba58 fffff800`02c22903 : 00000000`00000124 00000000`00000000 fffffa80`05034028 00000000`b2000040 : nt!KeBugCheckEx
fffff880`02fdba60 fffff800`02ddf593 : 00000000`00000001 fffffa80`03c69e00 00000000`00000000 fffffa80`03c69e50 : hal!HalBugCheckSystem+0x1e3
fffff880`02fdbaa0 fffff800`02c225c8 : 00000000`00000728 fffffa80`03c69e00 fffff880`02fdbe30 fffff880`02fdbe00 : nt!WheaReportHwError+0x263
fffff880`02fdbb00 fffff800`02c21f1a : fffffa80`03c69e00 fffff880`02fdbe30 fffffa80`03c69e00 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`02fdbc50 fffff800`02c21dd5 : 00000000`00000004 00000000`00000001 fffff880`02fdbeb0 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`02fdbc90 fffff800`02c15e88 : 00000000`00000000 fffff880`02fd3180 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0x55
fffff880`02fdbcc0 fffff800`02cc7fec : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
fffff880`02fdbcf0 fffff800`02cc7e53 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`02fdbe30 fffff880`040bb9c2 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
fffff880`02ffbc98 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : intelppm+0x39c2
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  X64_0x124_GenuineIntel_PROCESSOR_BUS
Followup: MachineOwner
Hope this helps,
Captain
Regards,
Captain MVP
Tech Advisor - GP
It is considered
courteous to post a reply if you have been able to resolve your
problem, or received an answer to your question.
Capt.Jack Sparrow
Tech Advisor
Tech Advisor
Operating System : Windows 7 Ultimate, Ubuntu 10.04
View user profile http://twitter.com/CaptainDebugger
