Sound Issues: it won't record
Post by Omoo on Sat Nov 13, 2010 2:25 am
My speakers play sound perfectly fine, but when I try to record an audio, it picks up nothing, even though I can hear it. Neither SoundBlaster nor Audacity record anything. To me, it seems like there's a missing link somewhere along the way, but since I know next to nothing about sound, I have no clue what it is, although I doubt it is external hardware. So far, I have not found any helpful info on the web...
If you have any ideas, please tell me,
Thanks!
Omoo
Posts Posts : 25
Joined Joined : 2009-11-26
Protection Protection : Spybot, Outpost Firewall 2009
Points Points : 25939
Re: Sound Issues: it won't record
Post by Nazzgull on Sat Nov 13, 2010 10:23 am
Hi, do you have microphone ? Speaker can't record audio, for that, you have to use microphone.
Points Points : 40435
Post by Omoo on Sat Nov 13, 2010 9:55 pm
Thanks for your response. I am not recording my voice but I'll try to explain my question better:
Let's say you want to record a couple words of a song in iTunes for a project. You open Microsoft's default Sound Recorder (or I often use Audacity), play the song, and press the "record" button as it is playing. The volume is on and you can hear the song, but the Sound Recorder does not record it.
Any idea why this is or how to fix it?
(PS this worked fine on my other computer)
Omoo
Posts Posts : 25
Post by Nazzgull on Sun Nov 14, 2010 3:23 pm
Hm.. I also use Audacity for cutting some songs, but i don't use Record button. Just selection tool and Cut - Paste.
Check this link :
http://www.youtube.com/watch?v=RPhaKfWWF6Q
And you can read steps from here :
http://forum.audacityteam.org/viewtopic.php?f=36&t=4826
http://www.wikihow.com/Record-a-Song-With-Audacity
Post by Omoo on Thu Nov 18, 2010 3:24 am
Thanks for your help, again. I changed a couple more settings and seeing the youtube video (and some others like it) I was able to toggle the correct setting. I needed to have "Stereo Mix" checked instead of "Line-in"
Thanks much~
Omoo
Posts Posts : 25
