Red X (cross) icon by C: drive
Solved Re: Red X (cross) icon by C: drive
Post by Belahzur on Sat Nov 20, 2010 1:22 am
Hold tight, talking to a colleague and we'll see if we change the icon back.
Post by lcander on Sat Nov 20, 2010 1:49 am
Ok, not come across this one before???
lcander
OS : Xp, Vista
Solved possible fix??
Post by lcander on Sat Nov 20, 2010 2:01 am
I came across this while researching the problem, but wasn't sure if it would work and didn't want to try it if there was really still a problem with the machine.
3- Launch RegEdit from the Start menu's Run dialog and navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\
CurrenTVersion\Explorer. If a subkey named driveicons is present, open it; You will find a subkey named C ,, Delete this subkey , this will return the C drive default Icon so the red icon will be gone.
Could this be a way to get the icon back??
lcander
OS : Xp, Vista
Post by Belahzur on Sun Nov 21, 2010 12:21 am
It may, but the articles I read on that says to put the normal value back rather than delete it, that's why I'm asking some of the other helpers that work here. Smile
Solved Normal values
Post by lcander on Sun Nov 21, 2010 1:14 am
Is knowing how to get the normal values back the issue??
lcander
OS : Xp, Vista
Solved In Safe mode
Post by lcander on Sun Nov 21, 2010 1:56 am
Don't know if this will help, but the normal Icon shows when in safe mode for both Administrator and the Owner.
When looking for more answers to this, I came across a post that suggested the the default icon file (IconCache.db) may be corrupted. They suggest deleting that file and restarting the computer. They thought this should cause the default HDD icon to return.
lcander
OS : Xp, Vista
Solved Still there
Post by lcander on Tue Nov 23, 2010 4:19 pm
I tried the suggestion of deleting the IconCache.db file and the red X is still there. So that fix doesn't apply to this machine's problem.
lcander
OS : Xp, Vista
Post by Belahzur on Tue Nov 23, 2010 10:35 pm
Lets try this, we'll make a backup of the registry first.
  • Please use the following link to download [You must be registered and logged in to see this link.]
  • Use the setup program to install ERUNT on your computer
Click Erunt.exe to backup your registry to the folder of your choice.
Note:to restore your registry, go to the folder and start ERDNT.exe
Please run OTL.exe.
    :reg
    [-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\DriveIcons\c]
  • Close OTL.exe
Solved Fix log
Post by lcander on Tue Nov 23, 2010 11:26 pm
:reg
lcander
OS : Xp, Vista
Solved Fixed
Post by lcander on Tue Nov 23, 2010 11:35 pm
You're brilliant!!!
That seemed to fix it. When I restarted the computer, the default icon is back.
Thanks so much.
lcander
OS : Xp, Vista
