I have a problem with my ip adress.
Post by latrobe on Sun Nov 07, 2010 6:35 pm
Hi, I had a virus on my computer which i was told to remove by reinstalling my operating system. I have done this and I think that the virus is gone but now my internet won't connect, it says that there is something wrong with my ip adress. My keyboard keys are also all muddled. Can you please help?
latrobe
Posts Posts : 14
Joined Joined : 2010-10-14
Points Points : 22606
Re: I have a problem with my ip adress.
Post by Dr Jay on Mon Nov 08, 2010 9:49 am
Please download RenewMyDNS by DragonMaster Jay.
  • Double-click RenewMyDNS.exe to start the program.
  • Follow the prompts, and when finished it will launch a log.
  • Post that log in your next reply.
  • After posting the log, delete RenewMyDNS.exe
Posts Posts : 13717
Points Points : 302127
Post by latrobe on Mon Nov 08, 2010 6:50 pm
DNS Diagnostics and refresher
Version 0.3.2
``````````Network and DNS Information``````````
Windows IP Configuration
Host Name . . . . . . . . . . . . : your-ad3e76b51b
Node Type . . . . . . . . . . . . : Unknown
Description . . . . . . . . . . . : Generic Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller
Physical Address. . . . . . . . . : 00-13-77-AD-67-3E
Ethernet adapter Wireless Network Connection:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-21-63-8D-53-E1
Successfully flushed the DNS Resolver Cache.
``````````Speed-test - Ping``````````
Ping request could not find host yahoo.com. Please check the name and try again.
Ping request could not find host GeekPolice.net. Please check the name and try again.
Ping request could not find host facebook.com. Please check the name and try again.
Ping request could not find host google.com. Please check the name and try again.
EOF
latrobe
Posts Posts : 14
Post by Dr Jay on Tue Nov 09, 2010 10:51 am
Are you currently connected with a wireless networking router, or have been in the past?
Posts Posts : 13717
Post by latrobe on Tue Nov 09, 2010 4:39 pm
Yes
latrobe
Posts Posts : 14
Post by Dr Jay on Wed Nov 10, 2010 6:25 am
Information about the router
Please supply more info about your router.
  • Manufacturer (Linksys, Belkin, etc.)
  • Year bought
  • Current setup of Internet connection (see below)
To figure out the current setup of your Internet connection, go to Internet Explorer web browser, type in 192.168.1.1 or 192.168.2.1 and see if this pulls up the router settings page. You should get a password prompt beforehand. If you have not changed the password yourself, it will probably be admin (no username).
I need to know the following:
  • Connection type (PPPoe, Direct, etc.)
  • Static/Primary DNS addresses 1 and 2 and 3 (if available)
Posts Posts : 13717
Post by latrobe on Mon Nov 15, 2010 6:10 pm
On the netgear router it says 'Wireless ADSL Modem Router'
But I cannot find my current set up of the internet because when i click enter it says that internet explorer could not open the search page.
latrobe
Posts Posts : 14
Post by Dr Jay on Mon Nov 15, 2010 7:06 pm
Enter in http:// before that and see if it helps...
Posts Posts : 13717
Post by latrobe on Tue Nov 16, 2010 8:05 pm
It still doesn't work. when i press enter the page just stays excatly the same.
latrobe
Posts Posts : 14
Post by Dr Jay on Wed Nov 17, 2010 6:21 am
I had no idea you were not connected to the router.
If your router is not installed, please install it and try again.
Posts Posts : 13717
Post by latrobe on Thu Nov 18, 2010 5:13 pm
The internet is working for all of the other computers in my house so the router is installed.
latrobe
Posts Posts : 14
Post by Dr Jay on Sat Nov 20, 2010 4:21 am
Oh ok. Would you consider the issue solved or do you still need help?
Posts Posts : 13717
Post by Nazzgull on Sat Nov 20, 2010 11:00 am
I think his computer is still damaged from infection. Should use Recovery Console to check all Windows files. It might be a problem.
Points Points : 40455
Post by latrobe on Mon Nov 22, 2010 4:57 pm
How do I do this?
latrobe
Posts Posts : 14
Post by Nazzgull on Mon Nov 22, 2010 5:00 pm
Go to Start > Run > type next command and press Enter :
sfc /scannow
Info : If Windows ask you for installation cd, use it.
