Thinkpoint HELP!!!
Thinkpoint HELP!!!
Post by ryan76 on Sun 07 Nov 2010, 2:10 am
Hi guys I'm having trouble with the Thinkpoint Malware too. I canNOT access my desktop what so ever. A message pops up for their bogus anti virus scan so there isn't even a way to download malware protection. would appreciate help starting with gaining access to my desktop to begin.
Thanks.
ryan76
Unborn
Unborn
Operating System : vista
Re: Thinkpoint HELP!!!
Post by Sneakyone on Sun 07 Nov 2010, 2:17 am
Please download OTL to your Desktop. (If you already have it downloaded, then just follow the instructions below).
    %systemroot%\*. /mp /s
    %systemroot%\system32\*.sys
    %SYSTEMDRIVE%\*.*
    %PROGRAMFILES%\*.
    %appdata%\*.*
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    ahcix86.sys
    KR10N.sys
    disk.sys
    nvstor32.sys
    ahcix86s.sys
    nvrd32.sys
    symmpi.sys
    adp3132.sys
    mv61xx.sys
    usbstor.sys
    /md5stop
    CREATERESTOREPOINT
Sneakyone
Tech Officer
Tech Officer
Post by ryan76 on Sun 07 Nov 2010, 2:29 am
Do you meen save otl onto a flash drive? then do all this on my computer that isnt working?
ryan76
Unborn
Unborn
Post by Sneakyone on Sun 07 Nov 2010, 2:32 am
Yes that would work.
Sneakyone
Tech Officer
Tech Officer
Post by ryan76 on Sun 07 Nov 2010, 2:43 am
Everytime I put the flash in there is no reaction just the thinkpoint scan box with black background. I'm in safemode but how do I move past this in order to do the malware scan?
ryan76
Unborn
Unborn
Post by Sneakyone on Sun 07 Nov 2010, 10:21 am
Have you tried ending the task using task manager?
Sneakyone
Tech Officer
Tech Officer
Post by Sponsored content Today at 11:30 am
