i need help
Page 2 of 2 Previous  1, 2
Re: i need help
Post by eggers2010 on Thu Nov 04, 2010 6:39 pm
i am trying to run it i use the link you gave me and then i press yess then start it loaded up a page its blank and baby blue it said at the bottom of the page that the page was done but with errors what do i do from here
eggers2010
Posts Posts : 53
Joined Joined : 2010-11-01
Points Points : 23026
Re: i need help
Post by Sneakyone on Thu Nov 04, 2010 9:01 pm
Please do a scan with [You must be registered and logged in to see this link.]
Click on the Accept button and install any components it needs.
  • The program will install and then begin downloading the latest definition files.
  • After the files have been downloaded on the left side of the page in the Scan section select My Computer.
  • This will start the program and scan your system.
  • The scan will take a while, so be patient and let it run.
  • Once the scan is complete, click on View scan report
  • Now, click on the Save Report as button.
  • Save the file to your desktop.
  • Copy and paste that information in your next post.
Sneakyone
Posts Posts : 2707
Joined Joined : 2010-01-10
Points Points : 56084
Re: i need help
Post by eggers2010 on Fri Nov 05, 2010 10:47 pm
Friday, November 5, 2010
Operating system: Microsoft Windows XP Home Edition Service Pack 3 (build 2600)
Kaspersky Online Scanner version: 7.0.26.13
Last database update: Thursday, November 04, 2010 14:55:09
Records in database: 4212653
Scan settings
scan using the following database extended
Scan archives yes
Scan e-mail databases yes
Scan area My Computer
C:\
D:\
E:\
F:\
G:\
H:\
I:\
Scan statistics
Objects scanned 129933
Threats found 0
Infected objects found 0
Suspicious objects found 0
Scan duration 12:14:28
No threats found. Scanned area is clean.
Selected area has been scanned.
eggers2010
Posts Posts : 53
Re: i need help
Post by Sneakyone on Fri Nov 05, 2010 11:02 pm
How is your computer running now?
Sneakyone
Posts Posts : 2707
Re: i need help
Post by eggers2010 on Fri Nov 05, 2010 11:04 pm
none of the stuff is poping up its running a little slow but you did fix the problem can you help me speed it up or do i need to post another ad in another post
eggers2010
Posts Posts : 53
Re: i need help
Post by Sneakyone on Sat Nov 06, 2010 3:03 pm
This should speed it up a little.
Your computer is now clean. Now, time to remove the tools used, and update your computer to prevent vulnerability.
Updating System Restore
  • Click NEXT
  • Enter a name e.g. Clean
  • Click CREATE.
You now have a clean restore point.
To get rid of the bad ones:
  • Click OK
  • The System will do a calculation of temporary/old files, and then display a dialogue box.
  • At the bottom will be a System Restore box with a CLEANUP button click this
  • Accept the Warning and select OK again, the program will close and you are done.
Removing the tools
Now, to remove all of the tools we used and the files and folders they created, please do the following:
Download [You must be registered and logged in to see this link.] by OldTimer:
  • Double click OTC.exe.
  • Click the CleanUp! button.
Service Pack upgrade
Please consider upgrading to Windows XP SP3, because it includes all previously released updates. It also includes a small number of new functionalities. Some of the updates that Service Pack 3 provides, you may not have. It is now available via Windows Update.
More info about SP3: [You must be registered and logged in to see this link.]
Update Programs
Search in the list for all previous installed versions of Java (J2SE Runtime Environment). Please uninstall/remove each of them.
Staying Protected
If you don't have a Anti-Virus I recommend to download these free Anti-Virus programs:
1. [You must be registered and logged in to see this link.]
2. [You must be registered and logged in to see this link.]
3. [You must be registered and logged in to see this link.]
If you don't have a good firewall I recommend these free firewalls:
I recommend using [You must be registered and logged in to see this link.] for a anti-malware program.
If you don't have a anti-spyware I recommend to download these free programs to help keep you spyware free:
Please don't download more than one Anti-virus, firewall, or anti-spyware because they will conflict with each other making your computer slow, data loss, and false results so please just don't do it.
Here are some prevention tips:
1. Torrents are a conduit of malware; this is why we highly recommend not using them as chances are extremely high that you will be infected from them.
2. Cracks/warez/keygens are another conduit of malware and are illegal so don't use them.
3. Disable auto-run to prevent auto-run worms from infecting your machine through USB drives.[You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]
4. Always make sure you have the latest [You must be registered and logged in to see this link.].
5. Use a Site Advisor so you don't go to sites that will infect you. [You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]
6. Also there are many holes and flaws in Internet Explorer I recommend using [You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.] to keep you more safe.
7. Always keep your [You must be registered and logged in to see this link.] and Adobe Reader updated and all older versions removed to keep clear from exploits.
8. Don't fall for Scareware. What is Scareware? A rogue anti-virus on your system that will scare you into buying their fake software due to false detections.
9. Be sure to always have a firewall and anti-virus installed at all times.
Thanks for choosing GeekPolice, see [You must be registered and logged in to see this link.] if you would like to leave feedback or contribute to our site. Do you have any more questions?
For more information on keeping yourself safe please visit [You must be registered and logged in to see this link.]
Sneakyone
Posts Posts : 2707
Re: i need help
Post by eggers2010 on Sat Nov 06, 2010 6:47 pm
i downloaded the new virson of java but the on adobe reader would not let me download the 9.4 only 9.1 is that ok and i downloaded firefox do i need to delete ie or leave it in my computer
eggers2010
Posts Posts : 53
Re: i need help
Post by Sneakyone on Sat Nov 06, 2010 11:36 pm
You can leave IE on your computer.
Sneakyone
Posts Posts : 2707
Re: i need help
Post by eggers2010 on Sun Nov 07, 2010 1:12 pm
ok my problems solved thank you so much could'nt of done it with out you
eggers2010
Posts Posts : 53
Re: i need help
Post by Sneakyone on Sun Nov 07, 2010 5:30 pm
You're welcome, glad to help. Smile
Sneakyone
Posts Posts : 2707
