i need help
Page 2 of 3 Previous  1, 2, 3  Next
i need help
Post by eggers2010 on Wed 03 Nov 2010, 3:00 am
the virus that is in my computer is blocking me from posting the scan what do i need help the virus is antivius 8 and the message that pops up is from malwarefolist.com can any one help please
Last edited by eggers2010 on Wed 03 Nov 2010, 3:02 am; edited 1 time in total (Reason for editing : mispelled)
eggers2010
Rookie Surfer
Rookie Surfer
Operating System : xp
Re: i need help
Post by eggers2010 on Wed 03 Nov 2010, 4:07 am
Computer Name: YOUR-D0F670B45A | User Name: Compaq_Owner | Logged in as Administrator.
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<extension>]
[HKEY_CURRENT_USER\SOFTWARE\Classes\<extension>]
.exe [@ = exefile] -- Reg Error: Key error. File not found
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
Post by eggers2010 on Wed 03 Nov 2010, 4:08 am
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<key>\shell\[command]\command]
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
comfile [open] -- "%1" %*
exefile [open] -- "%1" %*
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
Post by eggers2010 on Wed 03 Nov 2010, 4:09 am
"FirstRunDisabled" = 1
"AntiVirusOverride" = 0
"FirewallOverride" = 1
"AntiVirusDisableNotify" = 0
"FirewallDisableNotify" = 0
"UpdatesDisableNotify" = 0
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
"DisableMonitoring" = 1
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
Post by eggers2010 on Wed 03 Nov 2010, 4:10 am
"DisableSR" = 0
"Start" = 0
"Start" = 2
"EnableFirewall" = 0
"139:TCP" = 139:TCP:*:Enabled:@xpsp2res.dll,-22004
"445:TCP" = 445:TCP:*:Enabled:@xpsp2res.dll,-22005
"137:UDP" = 137:UDP:*:Enabled:@xpsp2res.dll,-22001
"138:UDP" = 138:UDP:*:Enabled:@xpsp2res.dll,-22002
"DoNotAllowExceptions" = 0
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
Post by eggers2010 on Wed 03 Nov 2010, 4:11 am
"139:TCP" = 139:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22004
"445:TCP" = 445:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22005
"137:UDP" = 137:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22001
"138:UDP" = 138:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22002
"C:\Program Files\Compaq Connections\5577497\Program\Compaq Connections.exe" = C:\Program Files\Compaq Connections\5577497\Program\Compaq Connections.exe:*:Enabled:Compaq Connections -- (Hewlett-Packard)
"C:\Program Files\Common Files\AOL\ACS\AOLDial.exe" = C:\Program Files\Common Files\AOL\ACS\AOLDial.exe:*:Enabled:AOL -- File not found
"C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe" = C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe:*:Enabled:AOL -- File not found
"C:\Program Files\America Online 9.0\waol.exe" = C:\Program Files\America Online 9.0\waol.exe:*:Enabled:America Online 9.0 -- (America Online, Inc.)
"C:\Program Files\EarthLink TotalAccess\TaskPanl.exe" = C:\Program Files\EarthLink TotalAccess\TaskPanl.exe:*:Enabled:Earthlink -- File not found
"C:\Program Files\Kodak\Kodak EasyShare software\bin\EasyShare.exe" = C:\Program Files\Kodak\Kodak EasyShare software\bin\EasyShare.exe:*:Enabled:EasyShare -- ()
"C:\Program Files\LimeWire\LimeWire.exe" = C:\Program Files\LimeWire\LimeWire.exe:*:Enabled:LimeWire -- (Lime Wire, LLC)
"C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe" = C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe:*:Enabled:Yahoo! Messenger -- File not found
"C:\Program Files\FrostWire\FrostWire.exe" = C:\Program Files\FrostWire\FrostWire.exe:*:Enabled:FrostWire -- File not found
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
"{0840B4D6-7DD1-4187-8523-E6FC0007EFB7}" = Windows Live ID Sign-in Assistant
"{287ECFA4-719A-2143-A09B-D6A12DE54E40}" = Acrobat.com
"{2CE5A2E7-3437-4CE7-BCF4-85ED6EEFF9E4}" = iTunes
"{3248F0A8-6813-11D6-A77B-00B0D0150060}" = J2SE Runtime Environment 5.0 Update 6
"{388887F6-0661-4C80-B272-A6A23EFC7A31}" = MY CAMERA
"{39930321-4C58-4B8B-BCBF-342698C9801D}" = Max Payne
"{45D707E9-F3C4-11D9-A373-0050BAE317E1}" = HP DVD Play 2.1
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
"{A2BCA9F1-566C-4805-97D1-7FDC93386723}" = Adobe AIR
"{A67BB21E-D419-45BB-AB86-7D87D14BBCE2}" = Safari
"{AC76BA86-7AD7-1033-7B44-A92000000001}" = Adobe Reader 9.2
"{AEB9948B-4FF2-47C9-990E-47014492A0FE}" = MSXML 6.0 Parser
"{C41300B9-185D-475E-BFEC-39EF732F19B1}" = Apple Software Update
"{CCA1EEA3-555E-4D05-AC46-4B49C6C5D887}" = Apple Mobile Device Support
"{CEF7211D-CE3A-44C4-B321-D84A2099AE94}" = Comcast Desktop Software (v1.2.0.9)
"{D24DB8B9-BB6C-4334-9619-BA1C650E13D3}" = Microsoft Primary Interoperability Assemblies 2005
"{D2FCC1AE-6311-47C5-8130-C6C66D77DD71}" = Nikon Message Center
"{D45E8C45-B601-4A80-AFD8-E16338744DE1}" = ArcSoft Panorama Maker 4
"{DAEAFD68-BB4A-4507-A241-C8804D2EA66D}" = Apple Application Support
"{E7004147-2CCA-431C-AA05-2AB166B9785D}" = QuickTime
"{E9757890-7EC5-46C8-99AB-B00F07B6525C}" = Nikon Transfer
"{ECA1A3B6-898F-4DCE-9F04-714CF3BA126B}" = Adobe Flash Player 10 Plugin
"{FF1C31AE-0CDC-40CE-AB85-406F8B70D643}" = Bonjour
"Adobe AIR" = Adobe AIR
"Adobe Flash Player Plugin" = Adobe Flash Player Plugin
"Adobe Shockwave Player" = Adobe Shockwave Player 11
"LimeWire" = LimeWire 5.2.8
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
Post by eggers2010 on Wed 03 Nov 2010, 4:12 am
"N360" = Norton Security Suite
"PC-Doctor 5 for Windows" = PC-Doctor 5 for Windows
"xfinitytb" = Xfinity.com Toolbar 3.5
"Yahoo! Companion" = Yahoo! Toolbar
"Yahoo! Software Update" = Yahoo! Software Update
"abso&amp;#406;ute Poker" = abso&amp;#406;ute Poker
[ Application Events ]
Error - 11/1/2010 8:06:04 PM | Computer Name = YOUR-D0F670B45A | Source = ESENT | ID = 439
Description = wuauclt (1588) Unable to write a shadowed header for file C:\WINDOWS\SoftwareDistribution\DataStore\Logs\tmp.edb.
Error -1022.
Error - 11/1/2010 8:06:07 PM | Computer Name = YOUR-D0F670B45A | Source = ESENT | ID = 485
Description = wuauclt (1892) An attempt to delete the file "C:\WINDOWS\SoftwareDistribution\DataStore\Logs\tmp.edb"
failed with system error 1392 (0x00000570): "The file or directory is corrupted
and unreadable. ". The delete file operation will fail with error -1022 (0xfffffc02).
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
Error - 11/1/2010 8:06:07 PM | Computer Name = YOUR-D0F670B45A | Source = ESENT | ID = 490
Description = wuauclt (1892) An attempt to open the file "C:\WINDOWS\SoftwareDistribution\DataStore\Logs\tmp.edb"
for read / write access failed with system error 1392 (0x00000570): "The file or
directory is corrupted and unreadable. ". The open file operation will fail with
Error - 11/1/2010 8:06:07 PM | Computer Name = YOUR-D0F670B45A | Source = ESENT | ID = 439
Description = wuauclt (1892) Unable to write a shadowed header for file C:\WINDOWS\SoftwareDistribution\DataStore\Logs\tmp.edb.
Error -1022.
Error - 11/1/2010 8:06:10 PM | Computer Name = YOUR-D0F670B45A | Source = ESENT | ID = 485
Description = wuauclt (2756) An attempt to delete the file "C:\WINDOWS\SoftwareDistribution\DataStore\Logs\tmp.edb"
Error - 11/1/2010 8:06:10 PM | Computer Name = YOUR-D0F670B45A | Source = ESENT | ID = 490
Description = wuauclt (2756) An attempt to open the file "C:\WINDOWS\SoftwareDistribution\DataStore\Logs\tmp.edb"
Error - 11/1/2010 8:06:10 PM | Computer Name = YOUR-D0F670B45A | Source = ESENT | ID = 439
Description = wuauclt (2756) Unable to write a shadowed header for file C:\WINDOWS\SoftwareDistribution\DataStore\Logs\tmp.edb.
Error -1022.
Error - 11/1/2010 8:06:13 PM | Computer Name = YOUR-D0F670B45A | Source = ESENT | ID = 485
Description = wuauclt (1816) An attempt to delete the file "C:\WINDOWS\SoftwareDistribution\DataStore\Logs\tmp.edb"
Error - 11/1/2010 8:06:13 PM | Computer Name = YOUR-D0F670B45A | Source = ESENT | ID = 490
Description = wuauclt (1816) An attempt to open the file "C:\WINDOWS\SoftwareDistribution\DataStore\Logs\tmp.edb"
Error - 11/1/2010 8:06:13 PM | Computer Name = YOUR-D0F670B45A | Source = ESENT | ID = 439
Description = wuauclt (1816) Unable to write a shadowed header for file C:\WINDOWS\SoftwareDistribution\DataStore\Logs\tmp.edb.
Error -1022.
[ System Events ]
Error - 11/1/2010 6:28:30 PM | Computer Name = YOUR-D0F670B45A | Source = Service Control Manager | ID = 7000
Description = The McAfee Services service failed to start due to the following error:
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
Post by eggers2010 on Wed 03 Nov 2010, 4:13 am
%%3
Description = The McAfee Network Agent service failed to start due to the following
error: %%3
Description = The McAfee Proxy Service service failed to start due to the following
error: %%3
Description = The McAfee Real-time Scanner service failed to start due to the following
error: %%3
Description = The McAfee Personal Firewall Service service failed to start due to
the following error: %%3
Description = The SupportSoft Sprocket Service (ddoctorv2) service failed to start
due to the following error: %%3
Error - 11/1/2010 6:30:10 PM | Computer Name = YOUR-D0F670B45A | Source = Service Control Manager | ID = 7026
ftsata2
Error - 11/1/2010 6:30:44 PM | Computer Name = YOUR-D0F670B45A | Source = Service Control Manager | ID = 7009
Description = Timeout (30000 milliseconds) waiting for the WMI Performance Adapter
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
service to connect.
Error - 11/1/2010 6:30:44 PM | Computer Name = YOUR-D0F670B45A | Source = Service Control Manager | ID = 7000
Description = The WMI Performance Adapter service failed to start due to the following
error: %%1053
Error - 11/1/2010 6:30:45 PM | Computer Name = YOUR-D0F670B45A | Source = Service Control Manager | ID = 7011
Description = Timeout (30000 milliseconds) waiting for a transaction response from
the N360 service.
eggers2010
Rookie Surfer
Rookie Surfer
it would not let me send one file to u
Post by eggers2010 on Wed 03 Nov 2010, 4:21 am
it is out of otl it was about the updates last susful time
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
Post by Sneakyone on Wed 03 Nov 2010, 7:42 am
Please download ComboFix from BleepingComputer.com
Alternate link: GeeksToGo.com
Alternate link: Forospyware.com
Sneakyone
Tech Officer
Tech Officer
Re: i need help
Post by eggers2010 on Wed 03 Nov 2010, 8:01 am
ok it say that macfee scanner is running but i dont have that no more what should i do i dont have an icon for it or its not in my programs
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
Post by eggers2010 on Wed 03 Nov 2010, 8:28 am
a blue blank screen came up is this normal
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
Post by Sneakyone on Wed 03 Nov 2010, 8:29 am
Please reboot and go into Safe Mode with Networking by tapping F8 as it is rebooted and run ComboFix.
Sneakyone
Tech Officer
Tech Officer
log
Post by eggers2010 on Wed 03 Nov 2010, 9:50 am
ComboFix 10-11-02.01 - Compaq_Owner 11/02/2010 17:02:31.1.1 - x86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.446.163 [GMT -5:00]
Running from: c:\documents and settings\Compaq_Owner\desktop\commy.exe
AV: McAfee VirusScan *On-access scanning enabled* (Updated) {84B5EE75-6421-4CDE-A33A-DD43BA9FAD83}
AV: Norton Security Suite *On-access scanning disabled* (Updated) {E10A9785-9598-4754-B552-92431C1C35F8}
FW: McAfee Personal Firewall *enabled* {94894B63-8C7F-4050-BDA4-813CA00DA3E8}
FW: Norton Security Suite *enabled* {7C21A4C9-F61F-4AC4-B722-A6E19C16F220}
c:\documents and settings\Compaq_Owner\Application Data\FunWebProducts
c:\documents and settings\Compaq_Owner\Application Data\FunWebProducts\Data\Compaq_Owner\avatar.dat
c:\documents and settings\Compaq_Owner\Application Data\FunWebProducts\Data\Compaq_Owner\outfit.dat
c:\documents and settings\Compaq_Owner\Application Data\FunWebProducts\Data\Compaq_Owner\register.dat
c:\documents and settings\Compaq_Owner\Application Data\FunWebProducts\Data\Compaq_Owner\zbucks.dat
c:\documents and settings\Compaq_Owner\Application Data\FunWebProducts\Data\Compaq_Owner\zevents.dat
c:\program files\AV8
c:\program files\MyWebSearch
c:\program files\MyWebSearch\bar\History\search3
c:\program files\MyWebSearch\bar\Settings\s_pid.dat
C:\Redemption.ECF
c:\windows\system32\arp.exe
c:\windows\system32\drivers\RKHit.sys
c:\windows\system32\Thumbs.db
D:\Autorun.inf
-------\Legacy_BOONTY_GAMES
-------\Service_Boonty Games
((((((((((((((((((((((((( Files Created from 2010-10-02 to 2010-11-02 )))))))))))))))))))))))))))))))
2010-11-02 20:57 . 2010-11-02 21:27 -------- d-----r- C:\32788R22FWJFW
2010-11-02 19:26 . 2010-11-02 19:26 -------- d-----w- c:\documents and settings\NetworkService\Local Settings\Application Data\Apple Computer
2010-11-02 19:00 . 2010-11-02 19:00 -------- d-----w- c:\documents and settings\All Users\Application Data\Aol
2010-11-01 20:23 . 2010-11-01 22:26 -------- dc----w- c:\program files\PC Tools Security
2010-10-30 21:01 . 2010-10-30 21:02 -------- dc----w- c:\program files\PC-Doctor 5 for Windows
2010-10-29 01:14 . 2006-11-09 20:07 49265 ----a-w- c:\windows\system32\jpicpl32.cpl
2010-10-28 19:33 . 2010-10-28 19:33 -------- d-----w- c:\program files\Common Files\scanner
2010-10-27 19:28 . 2010-10-28 00:01 -------- d-----w- c:\documents and settings\All Users\Application Data\SecTaskMan
2010-10-26 23:07 . 2010-05-06 04:01 361904 ----a-w- c:\windows\system32\drivers\symtdi.sys
2010-10-26 23:07 . 2010-04-22 03:02 173104 ----a-w- c:\windows\system32\drivers\symefa.sys
2010-10-26 23:07 . 2010-04-22 02:29 43696 ----a-w- c:\windows\system32\drivers\srtspx.sys
2010-10-26 23:07 . 2009-10-15 03:50 328752 ----a-r- c:\windows\system32\drivers\symds.sys
2010-10-26 23:07 . 2010-04-29 05:03 116784 ----a-w- c:\windows\system32\drivers\ironx86.sys
2010-10-26 23:07 . 2010-02-26 00:22 501888 ----a-w- c:\windows\system32\drivers\cchpx86.sys
2010-10-25 19:50 . 2010-10-25 19:50 -------- d-----w- c:\documents and settings\Compaq_Owner\Application Data\com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
2010-10-25 17:55 . 2010-10-25 17:55 -------- d-----w- c:\documents and settings\NetworkService\Local Settings\Application Data\Adobe
2010-10-25 15:56 . 2010-11-01 22:26 -------- d-----w- c:\program files\Common Files\PC Tools
2010-10-25 15:51 . 2010-10-25 15:55 -------- d-----w- c:\documents and settings\Compaq_Owner\Application Data\GetRightToGo
2010-10-24 21:28 . 2010-10-25 01:46 -------- d-----w- c:\documents and settings\Compaq_Owner\Application Data\xfinitytb
2010-10-23 21:44 . 2010-10-23 21:44 -------- d-sh--w- c:\documents and settings\NetworkService\IETldCache
2010-10-23 20:18 . 2010-11-01 22:21 -------- d-----w- c:\documents and settings\All Users\Application Data\PC Tools
2010-10-23 17:23 . 2010-10-23 17:23 -------- d-----w- c:\documents and settings\Compaq_Owner\Application Data\MSNInstaller
2010-10-23 17:08 . 2010-10-23 17:26 -------- d-----w- c:\documents and settings\All Users\Application Data\Yahoo! Companion
2010-10-23 15:57 . 2010-10-23 15:57 -------- d-----w- c:\documents and settings\Compaq_Owner\Application Data\BigFishv1002
2010-10-23 14:41 . 2010-10-23 14:41 -------- d-----w- c:\documents and settings\Compaq_Owner\Application Data\SpinTop Games
2010-10-23 14:11 . 2010-10-23 17:01 -------- d-----w- c:\documents and settings\Compaq_Owner\Application Data\Error Fix
2010-10-23 14:07 . 2010-10-23 17:22 -------- dc----w- c:\program files\Error Fix
2010-10-23 12:48 . 2010-11-02 21:31 -------- d-----w- c:\documents and settings\Compaq_Owner\Application Data\CallingID
2010-10-23 12:48 . 2010-10-23 12:48 -------- dc----w- c:\program files\comcasttb
2010-10-23 12:47 . 2010-10-28 16:38 -------- dc----w- c:\program files\CA
2010-10-23 12:46 . 2010-10-24 21:30 -------- dc----w- c:\program files\xfinitytb
2010-10-23 12:35 . 2010-10-25 17:20 -------- dc----w- c:\program files\Microsoft
2010-10-23 12:35 . 2010-10-25 16:32 -------- dc----w- c:\program files\Microsoft Silverlight
2010-10-23 12:23 . 2010-10-25 17:41 -------- dc----w- c:\program files\VideoLAN
2010-10-23 12:21 . 2010-10-25 17:32 -------- dc----w- c:\program files\Online_Gaming
2010-10-22 20:46 . 2010-10-22 20:46 -------- dc----w- c:\program files\iPod
2010-10-22 20:45 . 2010-10-22 20:47 -------- dc----w- c:\program files\iTunes
2010-10-22 20:45 . 2010-10-22 20:47 -------- d-----w- c:\documents and settings\All Users\Application Data\{429CAD59-35B1-4DBC-BB6D-1DB246563521}
2010-10-22 20:42 . 2010-10-22 20:41 159744 ----a-w- c:\program files\Internet Explorer\PLUGINS\npqtplugin7.dll
2010-10-22 20:42 . 2010-10-22 20:41 159744 ----a-w- c:\program files\Internet Explorer\PLUGINS\npqtplugin6.dll
2010-10-22 20:42 . 2010-10-22 20:41 159744 ----a-w- c:\program files\Internet Explorer\PLUGINS\npqtplugin5.dll
2010-10-22 20:42 . 2010-10-22 20:41 159744 ----a-w- c:\program files\Internet Explorer\PLUGINS\npqtplugin4.dll
2010-10-22 20:42 . 2010-10-22 20:41 159744 ----a-w- c:\program files\Internet Explorer\PLUGINS\npqtplugin3.dll
2010-10-22 20:42 . 2010-10-22 20:41 159744 ----a-w- c:\program files\Internet Explorer\PLUGINS\npqtplugin2.dll
2010-10-22 20:42 . 2010-10-22 20:41 159744 ----a-w- c:\program files\Internet Explorer\PLUGINS\npqtplugin.dll
2010-10-22 20:39 . 2010-10-22 20:41 -------- dc----w- c:\program files\QuickTime
2010-10-22 20:39 . 2010-10-22 20:39 -------- dc----w- c:\program files\Apple Software Update
2010-10-22 17:17 . 2010-09-15 09:50 472808 ----a-w- c:\windows\system32\deployJava1.dll
2010-10-22 12:38 . 2010-10-22 12:38 -------- d-----w- C:\fbb24ff914e3336c9450c8b6
2010-10-22 12:33 . 2010-09-18 06:53 953856 ------w- c:\windows\system32\dllcache\mfc40u.dll
2010-10-22 12:33 . 2010-09-18 06:53 974848 ------w- c:\windows\system32\dllcache\mfc42.dll
2010-10-22 12:32 . 2010-08-23 16:12 617472 ------w- c:\windows\system32\dllcache\comctl32.dll
2010-10-22 12:30 . 2010-06-14 14:31 744448 ------w- c:\windows\system32\dllcache\helpsvc.exe
2010-10-22 12:24 . 2010-09-10 05:58 743424 ------w- c:\windows\system32\dllcache\iedvtool.dll
2010-10-22 02:39 . 2010-10-22 02:39 60808 ----a-w- c:\windows\system32\S32EVNT1.DLL
2010-10-22 02:39 . 2010-10-22 02:39 -------- dc----w- c:\program files\Symantec
2010-10-22 02:39 . 2010-10-22 02:39 124976 ----a-w- c:\windows\system32\drivers\SYMEVENT.SYS
2010-10-22 02:38 . 2010-10-27 14:17 -------- d-----w- c:\windows\system32\drivers\N360
2010-10-22 02:38 . 2010-10-22 02:38 -------- dc----w- c:\program files\Norton Security Suite
2010-10-22 02:38 . 2010-10-22 02:38 -------- dc----w- c:\program files\Windows Sidebar
2010-10-22 02:38 . 2010-10-22 02:38 -------- dc----w- c:\program files\NortonInstaller
2010-10-22 02:22 . 2010-10-22 02:38 -------- d-----w- c:\documents and settings\All Users\Application Data\Norton
2010-10-21 23:45 . 2010-10-21 23:45 -------- dc----w- c:\program files\ComcastUI
2010-09-18 17:23 . 2004-08-04 11:00 974848 ----a-w- c:\windows\system32\mfc42u.dll
2010-09-18 06:53 . 2004-08-04 11:00 974848 ----a-w- c:\windows\system32\mfc42.dll
2010-09-18 06:53 . 2004-08-04 11:00 954368 ----a-w- c:\windows\system32\mfc40.dll
2010-09-18 06:53 . 2004-08-04 11:00 953856 ----a-w- c:\windows\system32\mfc40u.dll
2010-09-10 05:58 . 2004-08-04 11:00 916480 ----a-w- c:\windows\system32\wininet.dll
2010-09-10 05:58 . 2004-08-04 11:00 43520 ----a-w- c:\windows\system32\licmgr10.dll
2010-09-10 05:58 . 2004-08-04 11:00 1469440 ----a-w- c:\windows\system32\inetcpl.cpl
2010-09-08 16:17 . 2010-09-08 16:17 94208 ----a-w- c:\windows\system32\QuickTimeVR.qtx
2010-09-08 16:17 . 2010-09-08 16:17 69632 ----a-w- c:\windows\system32\QuickTime.qts
2010-09-01 11:51 . 2004-08-04 11:00 285824 ----a-w- c:\windows\system32\atmfd.dll
2010-08-31 13:42 . 2004-08-04 11:00 1852800 ----a-w- c:\windows\system32\win32k.sys
2010-08-27 08:02 . 2004-08-04 11:00 119808 ----a-w- c:\windows\system32\t2embed.dll
2010-08-27 05:57 . 2004-08-04 11:00 99840 ----a-w- c:\windows\system32\srvsvc.dll
2010-08-26 13:39 . 2004-08-04 11:00 357248 ----a-w- c:\windows\system32\drivers\srv.sys
2010-08-26 12:52 . 2009-04-14 17:23 5120 ----a-w- c:\windows\system32\xpsp4res.dll
2010-08-23 16:12 . 2004-08-04 11:00 617472 ----a-w- c:\windows\system32\comctl32.dll
2010-08-17 13:17 . 2004-08-04 11:00 58880 ----a-w- c:\windows\system32\spoolsv.exe
2010-08-16 08:45 . 2004-08-04 11:00 590848 ----a-w- c:\windows\system32\rpcrt4.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{DB35C569-5624-4CFC-8043-E5139F55A073}]
2009-12-16 06:25 802256 -c--a-w- c:\progra~1\Crawler\Shared\CShared.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{dcc70a83-e184-40a3-906b-779af5e941c4}]
2010-07-30 17:33 87512 -c--a-w- c:\program files\xfinitytb\xfinitydx.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{e6d0b79e-ecac-411b-8bf6-7a574981af30}]
2010-07-30 17:34 259584 -c--a-w- c:\program files\xfinitytb\auxi\xfinityAu.dll
"{dcc70a83-e184-40a3-906b-779af5e941c4}"= "c:\program files\xfinitytb\xfinitydx.dll" [2010-07-30 87512]
[HKEY_CLASSES_ROOT\clsid\{dcc70a83-e184-40a3-906b-779af5e941c4}]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2010-09-21 932288]
"HPBootOp"="c:\program files\Hewlett-Packard\HP Boot Optimizer\HPBootOp.exe" [2006-02-16 249856]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2006-05-09 7311360]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2010-09-08 421888]
"PCDrProfiler"="c:\program files\PC-Doctor 5 for Windows\RunProfiler.exe" [2006-04-06 53248]
"SunJavaUpdateSched"="c:\program files\Java\jre1.5.0_10\bin\jusched.exe" [2006-11-09 49263]
c:\documents and settings\Administrator\Start Menu\Programs\Startup\
Pin.lnk - c:\hp\bin\CLOAKER.EXE [2006-9-4 27136]
Compaq Connections.lnk - c:\program files\Compaq Connections\5577497\Program\Compaq Connections.exe [2006-9-4 36903]
c:\documents and settings\Default User\Start Menu\Programs\Startup\
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^AOL Companion.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\AOL Companion.lnk
backup=c:\windows\pss\AOL Companion.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Kodak EasyShare software.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Kodak EasyShare software.lnk
backup=c:\windows\pss\Kodak EasyShare software.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Nikon Monitor.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Nikon Monitor.lnk
backup=c:\windows\pss\Nikon Monitor.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^Compaq_Owner^Start Menu^Programs^Startup^FrostWire On Startup.lnk]
path=c:\documents and settings\Compaq_Owner\Start Menu\Programs\Startup\FrostWire On Startup.lnk
backup=c:\windows\pss\FrostWire On Startup.lnkStartup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe Reader Speed Launcher]
2009-10-03 09:08 35696 -c--a-w- c:\program files\Adobe\Reader 9.0\Reader\reader_sl.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ComcastAntispyClient]
2009-08-19 17:25 1589208 -c--a-w- c:\program files\comcasttb\ComcastSpywareScan\ComcastAntiSpy.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ftutil2]
2004-06-07 21:05 106496 ----a-w- c:\windows\system32\ftutil2.dll
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HP Software Update]
2007-05-08 21:24 54840 -c--a-w- c:\program files\HP\HP Software Update\hpwuSchd2.exe
2010-09-24 07:10 421160 -c--a-w- c:\program files\iTunes\iTunesHelper.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NvCplDaemon]
2006-05-09 22:50 7311360 ----a-w- c:\windows\system32\nvcpl.dll
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\nwiz]
2006-05-09 22:50 1519616 ----a-w- c:\windows\system32\nwiz.exe
2010-09-08 16:17 421888 -c--a-w- c:\program files\QuickTime\QTTask.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\RealTray]
2007-10-21 02:14 26112 ----a-w- c:\program files\Real\RealPlayer\realplay.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Recguard]
2005-07-23 05:14 237568 -c--a-w- c:\windows\SMINST\Recguard.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\RTHDCPL]
2006-06-14 03:05 16239616 ----a-w- c:\windows\RTHDCPL.EXE
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SunJavaUpdateSched]
2010-05-14 16:44 248552 ----a-w- c:\program files\Common Files\Java\Java Update\jusched.exe
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\Compaq Connections\\5577497\\Program\\Compaq Connections.exe"=
"c:\\Program Files\\Kodak\\Kodak EasyShare software\\bin\\EasyShare.exe"=
"c:\\Program Files\\America Online 9.0\\waol.exe"=
R0 SymDS;Symantec Data Store;c:\windows\system32\drivers\N360\0403000.005\symds.sys [10/26/2010 6:07 PM 328752]
R0 SymEFA;Symantec Extended File Attributes;c:\windows\system32\drivers\N360\0403000.005\symefa.sys [10/26/2010 6:07 PM 173104]
R1 BHDrvx86;BHDrvx86;c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_4.0.0.127\Definitions\BASHDefs\20101029.001\BHDrvx86.sys [11/1/2010 7:33 PM 692272]
R1 ccHP;Symantec Hash Provider;c:\windows\system32\drivers\N360\0403000.005\cchpx86.sys [10/26/2010 6:07 PM 501888]
R1 SymIRON;Symantec Iron Driver;c:\windows\system32\drivers\N360\0403000.005\ironx86.sys [10/26/2010 6:07 PM 116784]
R2 AntiSpywareService;Comcast AntiSpyware;c:\program files\comcasttb\ComcastSpywareScan\ComcastAntiSpyService.exe [6/17/2009 12:49 PM 616408]
R2 N360;Norton Security Suite;c:\program files\Norton Security Suite\Engine\4.3.0.5\ccsvchst.exe [10/26/2010 6:07 PM 126392]
R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys [10/21/2010 9:57 PM 102448]
R3 IDSxpx86;IDSxpx86;c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_4.0.0.127\Definitions\IPSDefs\20101029.001\IDSXpx86.sys [10/19/2010 3:36 PM 341880]
S2 0224961221529749mcinstcleanup;McAfee Application Installer Cleanup (0224961221529749); [x]
S3 mr97310c;CIF Dual-Mode Camera;c:\windows\system32\drivers\mr97310c.sys [12/30/2008 3:05 PM 107904]
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{A509B1FF-37FF-4bFF-8CFF-4F3A747040FF}]
2009-03-08 09:32 128512 ----a-w- c:\windows\system32\advpack.dll
2010-10-22 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2009-10-22 16:50]
2010-11-02 c:\windows\Tasks\User_Feed_Synchronization-{A0133B74-079A-4103-AC51-B27BF80A343E}.job
- c:\windows\system32\msfeedssync.exe [2006-10-17 09:31]
mWindow Title = Windows Internet Explorer provided by Comcast
IE: &AOL Toolbar search - c:\program files\AOL Toolbar\toolbar.dll/SEARCH.HTML
IE: Add to Windows &Live Favorites - [You must be registered and logged in to see this link.]
IE: {{CDAFD956-97BE-443D-8EF7-F4F094EB5766} - c:\program files\Crawler\SSaver\CSSaver.exe
IE: {{d9288080-1baa-4bc4-9cf8-a92d743db949} - c:\documents and settings\Compaq_Owner\Start Menu\Programs\IMVU\Run IMVU.lnk
Trusted Zone: internet
Trusted Zone: mcafee.com
Trusted Zone: motive.com\patttbc.att
DPF: {9C23D886-43CB-43DE-B2DB-112A68D7E10A} - [You must be registered and logged in to see this link.]
BHO-{474597C5-AB09-49d6-A4D5-2E8D7341384E} - (no file)
WebBrowser-{D0523BB4-21E7-11DD-9AB7-415B56D89593} - (no file)
HKCU-Run-RegistryBooster - c:\program files\Uniblue\RegistryBooster\launcher.exe
MSConfigStartUp-AOL Spyware Protection - c:\progra~1\COMMON~1\AOL\AOLSPY~1\AOLSP Scheduler.exe
MSConfigStartUp-AOLDialer - c:\program files\Common Files\AOL\ACS\AOLDial.exe
MSConfigStartUp-ATT-SST_McciTrayApp - c:\program files\ATT-SST\McciTrayApp.exe
MSConfigStartUp-DW6 - c:\program files\The Weather Channel FW\Desktop\DesktopWeather.exe
MSConfigStartUp-ErrorRepairTool - c:\program files\ErrorRepairTool\ErrorRepairTool.exe
MSConfigStartUp-Gamevance - c:\program files\Gamevance\gamevance32.exe
MSConfigStartUp-Messenger (Yahoo!) - c:\program files\Yahoo!\Messenger\YahooMessenger.exe
MSConfigStartUp-My Web Search Bar Search Scope Monitor - c:\progra~1\MYWEBS~1\bar\2.bin\m3SrchMn.exe
MSConfigStartUp-MyWebSearch Email Plugin - c:\progra~1\MYWEBS~1\bar\2.bin\mwsoemon.exe
MSConfigStartUp-MyWebSearch Plugin - c:\progra~1\MYWEBS~1\bar\2.bin\M3PLUGIN.DLL
MSConfigStartUp-Pure Networks Port Magic - c:\progra~1\PURENE~1\PORTMA~1\PortAOL.exe
MSConfigStartUp-Search Protection - c:\program files\Yahoo!\Search Protection\SearchProtection.exe
MSConfigStartUp-SearchSettings - c:\program files\Search Settings\SearchSettings.exe
MSConfigStartUp-YSearchProtection - c:\program files\Yahoo!\Search Protection\SearchProtection.exe
Rootkit scan 2010-11-02 17:30
Stealth MBR rootkit/Mebroot/Sinowal/TDL4 detector 0.4.1 by Gmer, [You must be registered and logged in to see this link.]
Windows 5.1.2600 Disk: ST3120213AS rev.3.AHH -> \Device\Ide\IdePort0
device: opened successfully
user: MBR read successfully
called modules: ntkrnlpa.exe CLASSPNP.SYS disk.sys ACPI.sys hal.dll >>UNKNOWN [0x84F41566]<<
_asm { PUSH EBP; MOV EBP, ESP; PUSH ECX; MOV EAX, [EBP+0x8]; CMP EAX, [0x84f47624]; MOV EAX, [0x84f476a0]; PUSH EBX; PUSH ESI; MOV ESI, [EBP+0xc]; MOV EBX, [ESI+0x60]; PUSH EDI; JNZ 0x20; MOV [EBP+0x8], EAX; }
1 ntkrnlpa!IofCallDriver[0x804EE130] -> \Device\Harddisk0\DR0[0x84E39470]
3 CLASSPNP[0xF74D1FD7] -> ntkrnlpa!IofCallDriver[0x804EE130] -> \Device\00000078[0x84F83F18]
5 ACPI[0xF7368620] -> ntkrnlpa!IofCallDriver[0x804EE130] -> [0x84FCD368]
\Driver\atapi[0x84E4C368] -> IRP_MJ_CREATE -> 0x84F41566
error: Read The system cannot find the file specified.
kernel: MBR read successfully
_asm { XOR DI, DI; MOV SI, 0x200; MOV SS, DI; MOV SP, 0x7a00; MOV BX, 0x7a0; MOV CX, SI; MOV DS, BX; MOV ES, BX; REP MOVSB ; JMP FAR 0x7a0:0x5c; }
detected hooks:
\Device\Ide\IdeDeviceP2T0L0-5 -> \??\IDE#DiskST3120213AS_____________________________3.AHH___#5&8b35f09&0&0.0.0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} device not found
\Driver\atapi DriverStartIo -> 0x84F413B2
user & kernel MBR OK
Warning: possible TDL3 rootkit infection !
Filesystem trace:
called modules: ntkrnlpa.exe hal.dll fltmgr.sys BHDrvx86.sys eeCtrl.sys SYMEFA.SYS sr.sys Ntfs.sys
1 ntkrnlpa!IofCallDriver[0x804EE130] -> [0x84F1CDE0]
3 fltmgr[0xF72FDE95] -> ntkrnlpa!IofCallDriver[0x804EE130] -> [0x84F1C698]
5 sr[0xF7297870] -> ntkrnlpa!IofCallDriver[0x804EE130] -> [0x84F1C560]
7 fltmgr[0xF730A6BD] -> ntkrnlpa!IofCallDriver[0x804EE130] -> [0x84EE9658]
9 ntkrnlpa[0x80574DCB] -> ntkrnlpa!IofCallDriver[0x804EE130] -> [0x84F1CDE0]
11 fltmgr[0xF72FE098] -> ntkrnlpa!IofCallDriver[0x804EE130] -> [0x84F1C698]
13 sr[0xF7292453] -> ntkrnlpa!IofCallDriver[0x804EE130] -> [0x84F1C560]
15 fltmgr[0xF72FE098] -> ntkrnlpa!IofCallDriver[0x804EE130] -> [0x84EE9658]
Registry trace:
[HKEY_LOCAL_MACHINE\System\ControlSet004\Services\N360]
"ImagePath"=""c:\program files\Norton Security Suite\Engine\4.3.0.5\ccSvcHst.exe" /s "N360" /m "c:\program files\Norton Security Suite\Engine\4.3.0.5\diMaster.dll" /prefetch:1"
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10k_ActiveX.exe,-101"
"Enabled"=dword:00000001
@="c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10k_ActiveX.exe"
@="IFlashBroker4"
"Version"="1.0"
- - - - - - - > 'winlogon.exe'(716)
- - - - - - - > 'lsass.exe'(776)
- - - - - - - > 'explorer.exe'(3940)
c:\docume~1\COMPAQ~1\LOCALS~1\Temp\IadHide5.dll
c:\program files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
c:\program files\Common Files\Motive\McciCMService.exe
c:\program files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE
c:\program files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe
Completion time: 2010-11-02 17:45:14 - machine was rebooted
ComboFix-quarantined-files.txt 2010-11-02 22:45
Pre-Run: 65,969,778,688 bytes free
Post-Run: 66,761,216,000 bytes free
- - End Of File - - 9B2C5EF2D96EE2C6169C1924910EA517
eggers2010
Rookie Surfer
Rookie Surfer
Re: i need help
Post by Sneakyone on Wed 03 Nov 2010, 12:00 pm
Please download TDSSKiller from here and save it to your Desktop.
  • Doubleclick TDSSKiller.exe to run the tool
  • Click the Start Scan button
  • After the scan has finished, click the Close button
Note:It will also create a log in the C:\ directory.
Sneakyone
Tech Officer
Tech Officer
Re: i need help
Post by eggers2010 on Wed 03 Nov 2010, 12:07 pm
2010/11/02 20:04:29.0953 TDSS rootkit removing tool 2.4.5.1 Oct 26 2010 11:28:49
2010/11/02 20:04:29.0953 ================================================================================
2010/11/02 20:04:29.0953 SystemInfo:
2010/11/02 20:04:29.0953 OS Version: 5.1.2600 ServicePack: 3.0
2010/11/02 20:04:29.0953 Product type: Workstation
2010/11/02 20:04:29.0953 ComputerName: YOUR-D0F670B45A
2010/11/02 20:04:29.0953 UserName: Compaq_Owner
2010/11/02 20:04:29.0953 Windows directory: C:\WINDOWS
2010/11/02 20:04:29.0953 System windows directory: C:\WINDOWS
2010/11/02 20:04:29.0953 Processor architecture: Intel x86
2010/11/02 20:04:29.0953 Number of processors: 1
2010/11/02 20:04:29.0953 Page size: 0x1000
2010/11/02 20:04:29.0953 Boot type: Normal boot
2010/11/02 20:04:31.0296 Initialize success
2010/11/02 20:04:35.0796 ================================================================================
2010/11/02 20:04:35.0796 Scan started
2010/11/02 20:04:35.0796 Mode: Manual;
2010/11/02 20:04:40.0234 ACPI (8fd99680a539792a30e97944fdaecf17) C:\WINDOWS\system32\DRIVERS\ACPI.sys
2010/11/02 20:04:40.0812 ACPIEC (9859c0f6936e723e4892d7141b1327d5) C:\WINDOWS\system32\drivers\ACPIEC.sys
2010/11/02 20:04:41.0765 aec (8bed39e3c35d6a489438b8141717a557) C:\WINDOWS\system32\drivers\aec.sys
2010/11/02 20:04:42.0296 AFD (7e775010ef291da96ad17ca4b17137d7) C:\WINDOWS\System32\drivers\afd.sys
2010/11/02 20:04:44.0890 AmdK8 (59301936898ae62245a6f09c0aba9475) C:\WINDOWS\system32\DRIVERS\AmdK8.sys
2010/11/02 20:04:46.0968 ASCTRM (d880831279ed91f9a4190a2db9539ea9) C:\WINDOWS\system32\drivers\ASCTRM.sys
2010/11/02 20:04:47.0437 AsyncMac (b153affac761e7f5fcfa822b9c4e97bc) C:\WINDOWS\system32\DRIVERS\asyncmac.sys
2010/11/02 20:04:48.0234 atapi (9f3a2f5aa6875c72bf062c712cfa2674) C:\WINDOWS\system32\DRIVERS\atapi.sys
2010/11/02 20:04:49.0343 Atmarpc (9916c1225104ba14794209cfa8012159) C:\WINDOWS\system32\DRIVERS\atmarpc.sys
2010/11/02 20:04:49.0796 audstub (d9f724aa26c010a217c97606b160ed68) C:\WINDOWS\system32\DRIVERS\audstub.sys
2010/11/02 20:04:50.0890 Beep (da1f27d85e0d1525f6621372e7b685e9) C:\WINDOWS\system32\drivers\Beep.sys
2010/11/02 20:04:51.0234 BHDrvx86 (5138da8715da5f9823b753b6cb36a9a9) C:\Documents and Settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_4.0.0.127\Definitions\BASHDefs\20101029.001\BHDrvx86.sys
2010/11/02 20:04:52.0078 cbidf2k (90a673fc8e12a79afbed2576f6a7aaf9) C:\WINDOWS\system32\drivers\cbidf2k.sys
2010/11/02 20:04:52.0625 CCDECODE (0be5aef125be881c4f854c554f2b025c) C:\WINDOWS\system32\DRIVERS\CCDECODE.sys
2010/11/02 20:04:53.0203 ccHP (e941e709847fa00e0dd6d58d2b8fb5e1) C:\WINDOWS\system32\drivers\N360\0403000.005\ccHPx86.sys
2010/11/02 20:04:54.0453 Cdaudio (c1b486a7658353d33a10cc15211a873b) C:\WINDOWS\system32\drivers\Cdaudio.sys
2010/11/02 20:04:55.0015 Cdfs (c885b02847f5d2fd45a24e219ed93b32) C:\WINDOWS\system32\drivers\Cdfs.sys
2010/11/02 20:04:55.0515 Cdrom (1f4260cc5b42272d71f79e570a27a4fe) C:\WINDOWS\system32\DRIVERS\cdrom.sys
2010/11/02 20:04:57.0578 Disk (044452051f3e02e7963599fc8f4f3e25) C:\WINDOWS\system32\DRIVERS\disk.sys
2010/11/02 20:04:58.0062 dmboot (d992fe1274bde0f84ad826acae022a41) C:\WINDOWS\system32\drivers\dmboot.sys
2010/11/02 20:04:58.0625 dmio (7c824cf7bbde77d95c08005717a95f6f) C:\WINDOWS\system32\drivers\dmio.sys
2010/11/02 20:04:58.0875 dmload (e9317282a63ca4d188c0df5e09c6ac5f) C:\WINDOWS\system32\drivers\dmload.sys
2010/11/02 20:04:59.0281 DMusic (8a208dfcf89792a484e76c40e5f50b45) C:\WINDOWS\system32\drivers\DMusic.sys
2010/11/02 20:05:00.0171 drmkaud (8f5fcff8e8848afac920905fbd9d33c8) C:\WINDOWS\system32\drivers\drmkaud.sys
2010/11/02 20:05:00.0703 eeCtrl (089296aedb9b72b4916ac959752bdc89) C:\Program Files\Common Files\Symantec Shared\EENGINE\eeCtrl.sys
2010/11/02 20:05:01.0984 EraserUtilRebootDrv (850259334652d392e33ee3412562e583) C:\Program Files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys
2010/11/02 20:05:02.0781 Fastfat (38d332a6d56af32635675f132548343e) C:\WINDOWS\system32\drivers\Fastfat.sys
2010/11/02 20:05:03.0390 Fdc (92cdd60b6730b9f50f6a1a0c1f8cdc81) C:\WINDOWS\system32\drivers\Fdc.sys
2010/11/02 20:05:04.0046 Fips (d45926117eb9fa946a6af572fbe1caa3) C:\WINDOWS\system32\drivers\Fips.sys
2010/11/02 20:05:04.0859 Flpydisk (9d27e7b80bfcdf1cdd9b555862d5e7f0) C:\WINDOWS\system32\drivers\Flpydisk.sys
2010/11/02 20:05:05.0968 FltMgr (b2cf4b0786f8212cb92ed2b50c6db6b0) C:\WINDOWS\system32\drivers\fltmgr.sys
2010/11/02 20:05:06.0750 Fs_Rec (3e1e2bd4f39b0e2b7dc4f4d2bcc2779a) C:\WINDOWS\system32\drivers\Fs_Rec.sys
2010/11/02 20:05:07.0843 Ftdisk (6ac26732762483366c3969c9e4d2259d) C:\WINDOWS\system32\DRIVERS\ftdisk.sys
2010/11/02 20:05:09.0546 GEARAspiWDM (8182ff89c65e4d38b2de4bb0fb18564e) C:\WINDOWS\system32\Drivers\GEARAspiWDM.sys
2010/11/02 20:05:10.0406 Gpc (0a02c63c8b144bd8c86b103dee7c86a2) C:\WINDOWS\system32\DRIVERS\msgpc.sys
2010/11/02 20:05:10.0890 HDAudBus (573c7d0a32852b48f3058cfd8026f511) C:\WINDOWS\system32\DRIVERS\HDAudBus.sys
2010/11/02 20:05:11.0218 HidUsb (ccf82c5ec8a7326c3066de870c06daf1) C:\WINDOWS\system32\DRIVERS\hidusb.sys
2010/11/02 20:05:11.0609 HSXHWBS2 (1f5c64b0c6b2e2f48735a77ae714ccb8) C:\WINDOWS\system32\DRIVERS\HSXHWBS2.sys
2010/11/02 20:05:11.0875 HSX_DP (a7f8c9228898a1e871d2ae7082f50ac3) C:\WINDOWS\system32\DRIVERS\HSX_DP.sys
2010/11/02 20:05:12.0187 HTTP (f80a415ef82cd06ffaf0d971528ead38) C:\WINDOWS\system32\Drivers\HTTP.sys
2010/11/02 20:05:12.0843 i8042prt (4a0b06aa8943c1e332520f7440c0aa30) C:\WINDOWS\system32\DRIVERS\i8042prt.sys
2010/11/02 20:05:13.0203 IDSxpx86 (74e8463447101ecf0165ddc7e5168b7e) C:\Documents and Settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_4.0.0.127\Definitions\IPSDefs\20101029.001\IDSxpx86.sys
2010/11/02 20:05:13.0718 Imapi (083a052659f5310dd8b6a6cb05edcf8e) C:\WINDOWS\system32\DRIVERS\imapi.sys
2010/11/02 20:05:14.0390 IntcAzAudAddService (ab2fe0faa519880bd16e4a0792d633d2) C:\WINDOWS\system32\drivers\RtkHDAud.sys
2010/11/02 20:05:14.0843 IntelIde (b5466a9250342a7aa0cd1fba13420678) C:\WINDOWS\system32\DRIVERS\intelide.sys
2010/11/02 20:05:15.0062 intelppm (8c953733d8f36eb2133f5bb58808b66b) C:\WINDOWS\system32\DRIVERS\intelppm.sys
2010/11/02 20:05:15.0265 Ip6Fw (3bb22519a194418d5fec05d800a19ad0) C:\WINDOWS\system32\drivers\ip6fw.sys
2010/11/02 20:05:15.0484 IpFilterDriver (731f22ba402ee4b62748adaf6363c182) C:\WINDOWS\system32\DRIVERS\ipfltdrv.sys
2010/11/02 20:05:15.0718 IpInIp (b87ab476dcf76e72010632b5550955f5) C:\WINDOWS\system32\DRIVERS\ipinip.sys
2010/11/02 20:05:15.0953 IpNat (cc748ea12c6effde940ee98098bf96bb) C:\WINDOWS\system32\DRIVERS\ipnat.sys
2010/11/02 20:05:16.0234 IPSec (23c74d75e36e7158768dd63d92789a91) C:\WINDOWS\system32\DRIVERS\ipsec.sys
2010/11/02 20:05:16.0515 IRENUM (c93c9ff7b04d772627a3646d89f7bf89) C:\WINDOWS\system32\DRIVERS\irenum.sys
2010/11/02 20:05:16.0781 isapnp (05a299ec56e52649b1cf2fc52d20f2d7) C:\WINDOWS\system32\DRIVERS\isapnp.sys
2010/11/02 20:05:17.0000 Kbdclass (463c1ec80cd17420a542b7f36a36f128) C:\WINDOWS\system32\DRIVERS\kbdclass.sys
2010/11/02 20:05:17.0265 kmixer (692bcf44383d056aed41b045a323d378) C:\WINDOWS\system32\drivers\kmixer.sys
2010/11/02 20:05:17.0546 KSecDD (b467646c54cc746128904e1654c750c1) C:\WINDOWS\system32\drivers\KSecDD.sys
2010/11/02 20:05:18.0093 MCSTRM (5bb01b9f582259d1fb7653c5c1da3653) C:\WINDOWS\system32\drivers\MCSTRM.sys
2010/11/02 20:05:18.0328 mdmxsdk (e246a32c445056996074a397da56e815) C:\WINDOWS\system32\DRIVERS\mdmxsdk.sys
2010/11/02 20:05:18.0578 mfeavfk (c97cbfd71c1c215150a3b3e55f77a7a3) C:\WINDOWS\system32\drivers\mfeavfk.sys
2010/11/02 20:05:18.0812 mfebopk (5447338b83a1a2354fb2fea7604387fd) C:\WINDOWS\system32\drivers\mfebopk.sys
2010/11/02 20:05:19.0125 mfehidk (6c9a6ed60b8fc3baf72fe1b1d096445b) C:\WINDOWS\system32\drivers\mfehidk.sys
2010/11/02 20:05:19.0406 mferkdk (a551154b51d6a93fccf70fc4e8eaf4bd) C:\WINDOWS\system32\drivers\mferkdk.sys
2010/11/02 20:05:19.0625 mfesmfk (299a86b780c9627aaa24e74292363ed2) C:\WINDOWS\system32\drivers\mfesmfk.sys
2010/11/02 20:05:19.0843 mnmdd (4ae068242760a1fb6e1a44bf4e16afa6) C:\WINDOWS\system32\drivers\mnmdd.sys
2010/11/02 20:05:20.0078 Modem (dfcbad3cec1c5f964962ae10e0bcc8e1) C:\WINDOWS\system32\drivers\Modem.sys
2010/11/02 20:05:20.0437 Mouclass (35c9e97194c8cfb8430125f8dbc34d04) C:\WINDOWS\system32\DRIVERS\mouclass.sys
2010/11/02 20:05:20.0656 mouhid (b1c303e17fb9d46e87a98e4ba6769685) C:\WINDOWS\system32\DRIVERS\mouhid.sys
2010/11/02 20:05:20.0906 MountMgr (a80b9a0bad1b73637dbcbba7df72d3fd) C:\WINDOWS\system32\drivers\MountMgr.sys
2010/11/02 20:05:21.0203 MPFP (e454f42ae5524d695d76eab5d363b8ac) C:\WINDOWS\system32\Drivers\Mpfp.sys
2010/11/02 20:05:21.0421 mr97310c (721a2b4d1a23d078db95702d47e7ac6d) C:\WINDOWS\system32\DRIVERS\mr97310c.sys
2010/11/02 20:05:21.0781 MREMP50 (9bd4dcb5412921864a7aacdedfbd1923) C:\PROGRA~1\COMMON~1\Motive\MREMP50.SYS
2010/11/02 20:05:22.0625 MRESP50 (07c02c892e8e1a72d6bf35004f0e9c5e) C:\PROGRA~1\COMMON~1\Motive\MRESP50.SYS
2010/11/02 20:05:23.0031 MRxDAV (11d42bb6206f33fbb3ba0288d3ef81bd) C:\WINDOWS\system32\DRIVERS\mrxdav.sys
2010/11/02 20:05:23.0406 MRxSmb (f3aefb11abc521122b67095044169e98) C:\WINDOWS\system32\DRIVERS\mrxsmb.sys
2010/11/02 20:05:23.0687 Msfs (c941ea2454ba8350021d774daf0f1027) C:\WINDOWS\system32\drivers\Msfs.sys
2010/11/02 20:05:23.0921 MSKSSRV (d1575e71568f4d9e14ca56b7b0453bf1) C:\WINDOWS\system32\drivers\MSKSSRV.sys
2010/11/02 20:05:24.0109 MSPCLOCK (325bb26842fc7ccc1fcce2c457317f3e) C:\WINDOWS\system32\drivers\MSPCLOCK.sys
2010/11/02 20:05:24.0328 MSPQM (bad59648ba099da4a17680b39730cb3d) C:\WINDOWS\system32\drivers\MSPQM.sys
2010/11/02 20:05:24.0562 mssmbios (af5f4f3f14a8ea2c26de30f7a1e17136) C:\WINDOWS\system32\DRIVERS\mssmbios.sys
2010/11/02 20:05:24.0781 MSTEE (e53736a9e30c45fa9e7b5eac55056d1d) C:\WINDOWS\system32\drivers\MSTEE.sys
2010/11/02 20:05:25.0015 Mup (2f625d11385b1a94360bfc70aaefdee1) C:\WINDOWS\system32\drivers\Mup.sys
2010/11/02 20:05:25.0250 NABTSFEC (5b50f1b2a2ed47d560577b221da734db) C:\WINDOWS\system32\DRIVERS\NABTSFEC.sys
2010/11/02 20:05:25.0500 NAVENG (49d802531e5984cf1fe028c6c129b9d8) C:\Documents and Settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_4.0.0.127\Definitions\VirusDefs\20101101.054\NAVENG.SYS
2010/11/02 20:05:25.0781 NAVEX15 (158676a5758c1fa519563b3e72fbf256) C:\Documents and Settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\N360_4.0.0.127\Definitions\VirusDefs\20101101.054\NAVEX15.SYS
2010/11/02 20:05:26.0093 NDIS (1df7f42665c94b825322fae71721130d) C:\WINDOWS\system32\drivers\NDIS.sys
2010/11/02 20:05:26.0421 NdisIP (7ff1f1fd8609c149aa432f95a8163d97) C:\WINDOWS\system32\DRIVERS\NdisIP.sys
2010/11/02 20:05:26.0640 NdisTapi (1ab3d00c991ab086e69db84b6c0ed78f) C:\WINDOWS\system32\DRIVERS\ndistapi.sys
2010/11/02 20:05:26.0859 Ndisuio (f927a4434c5028758a842943ef1a3849) C:\WINDOWS\system32\DRIVERS\ndisuio.sys
2010/11/02 20:05:27.0093 NdisWan (edc1531a49c80614b2cfda43ca8659ab) C:\WINDOWS\system32\DRIVERS\ndiswan.sys
2010/11/02 20:05:27.0343 NDProxy (6215023940cfd3702b46abc304e1d45a) C:\WINDOWS\system32\drivers\NDProxy.sys
2010/11/02 20:05:27.0625 NetBIOS (5d81cf9a2f1a3a756b66cf684911cdf0) C:\WINDOWS\system32\DRIVERS\netbios.sys
2010/11/02 20:05:27.0875 NetBT (74b2b2f5bea5e9a3dc021d685551bd3d) C:\WINDOWS\system32\DRIVERS\netbt.sys
2010/11/02 20:05:28.0203 Npfs (3182d64ae053d6fb034f44b6def8034a) C:\WINDOWS\system32\drivers\Npfs.sys
2010/11/02 20:05:28.0546 Ntfs (78a08dd6a8d65e697c18e1db01c5cdca) C:\WINDOWS\system32\drivers\Ntfs.sys
2010/11/02 20:05:28.0843 Null (73c1e1f395918bc2c6dd67af7591a3ad) C:\WINDOWS\system32\drivers\Null.sys
2010/11/02 20:05:29.0328 nv (642a87877f83313eb5302749cd479024) C:\WINDOWS\system32\DRIVERS\nv4_mini.sys
2010/11/02 20:05:29.0703 NVENETFD (22eedb34c4d7613a25b10c347c6c4c21) C:\WINDOWS\system32\DRIVERS\NVENETFD.sys
2010/11/02 20:05:29.0953 nvnetbus (5e3f6ad5cad0f12d3cccd06fd964087a) C:\WINDOWS\system32\DRIVERS\nvnetbus.sys
2010/11/02 20:05:30.0218 NwlnkFlt (b305f3fad35083837ef46a0bbce2fc57) C:\WINDOWS\system32\DRIVERS\nwlnkflt.sys
2010/11/02 20:05:30.0468 NwlnkFwd (c99b3415198d1aab7227f2c88fd664b9) C:\WINDOWS\system32\DRIVERS\nwlnkfwd.sys
2010/11/02 20:05:30.0671 Parport (5575faf8f97ce5e713d108c2a58d7c7c) C:\WINDOWS\system32\DRIVERS\parport.sys
2010/11/02 20:05:30.0906 PartMgr (beb3ba25197665d82ec7065b724171c6) C:\WINDOWS\system32\drivers\PartMgr.sys
2010/11/02 20:05:31.0109 ParVdm (70e98b3fd8e963a6a46a2e6247e0bea1) C:\WINDOWS\system32\drivers\ParVdm.sys
2010/11/02 20:05:31.0421 PCI (a219903ccf74233761d92bef471a07b1) C:\WINDOWS\system32\DRIVERS\pci.sys
2010/11/02 20:05:31.0859 PCIIde (ccf5f451bb1a5a2a522a76e670000ff0) C:\WINDOWS\system32\DRIVERS\pciide.sys
2010/11/02 20:05:32.0062 Pcmcia (9e89ef60e9ee05e3f2eef2da7397f1c1) C:\WINDOWS\system32\drivers\Pcmcia.sys
2010/11/02 20:05:33.0718 PptpMiniport (efeec01b1d3cf84f16ddd24d9d9d8f99) C:\WINDOWS\system32\DRIVERS\raspptp.sys
2010/11/02 20:05:34.0421 Processor (a32bebaf723557681bfc6bd93e98bd26) C:\WINDOWS\system32\DRIVERS\processr.sys
2010/11/02 20:05:35.0265 PSched (09298ec810b07e5d582cb3a3f9255424) C:\WINDOWS\system32\DRIVERS\psched.sys
2010/11/02 20:05:36.0156 Ptilink (80d317bd1c3dbc5d4fe7b1678c60cadd) C:\WINDOWS\system32\DRIVERS\ptilink.sys
2010/11/02 20:05:36.0750 PxHelp20 (d86b4a68565e444d76457f14172c875a) C:\WINDOWS\system32\Drivers\PxHelp20.sys
2010/11/02 20:05:39.0062 RasAcd (fe0d99d6f31e4fad8159f690d68ded9c) C:\WINDOWS\system32\DRIVERS\rasacd.sys
2010/11/02 20:05:39.0906 Rasl2tp (11b4a627bc9614b885c4969bfa5ff8a6) C:\WINDOWS\system32\DRIVERS\rasl2tp.sys
2010/11/02 20:05:40.0187 RasPppoe (5bc962f2654137c9909c3d4603587dee) C:\WINDOWS\system32\DRIVERS\raspppoe.sys
2010/11/02 20:05:40.0609 Raspti (fdbb1d60066fcfbb7452fd8f9829b242) C:\WINDOWS\system32\DRIVERS\raspti.sys
2010/11/02 20:05:41.0093 Rdbss (7ad224ad1a1437fe28d89cf22b17780a) C:\WINDOWS\system32\DRIVERS\rdbss.sys
2010/11/02 20:05:41.0593 RDPCDD (4912d5b403614ce99c28420f75353332) C:\WINDOWS\system32\DRIVERS\RDPCDD.sys
2010/11/02 20:05:42.0046 RDPWD (6728e45b66f93c08f11de2e316fc70dd) C:\WINDOWS\system32\drivers\RDPWD.sys
2010/11/02 20:05:42.0328 redbook (f828dd7e1419b6653894a8f97a0094c5) C:\WINDOWS\system32\DRIVERS\redbook.sys
2010/11/02 20:05:42.0921 rtl8139 (d507c1400284176573224903819ffda3) C:\WINDOWS\system32\DRIVERS\RTL8139.SYS
2010/11/02 20:05:43.0218 Secdrv (90a3935d05b494a5a39d37e71f09a677) C:\WINDOWS\system32\DRIVERS\secdrv.sys
2010/11/02 20:05:43.0546 Serial (cca207a8896d4c6a0c9ce29a4ae411a7) C:\WINDOWS\system32\drivers\Serial.sys
2010/11/02 20:05:43.0859 Sfloppy (8e6b8c671615d126fdc553d1e2de5562) C:\WINDOWS\system32\drivers\Sfloppy.sys
2010/11/02 20:05:44.0296 SLIP (866d538ebe33709a5c9f5c62b73b7d14) C:\WINDOWS\system32\DRIVERS\SLIP.sys
2010/11/02 20:05:44.0734 splitter (ab8b92451ecb048a4d1de7c3ffcb4a9f) C:\WINDOWS\system32\drivers\splitter.sys
2010/11/02 20:05:45.0281 sr (76bb022c2fb6902fd5bdd4f78fc13a5d) C:\WINDOWS\system32\DRIVERS\sr.sys
2010/11/02 20:05:45.0828 SRTSP (ec5c3c6260f4019b03dfaa03ec8cbf6a) C:\WINDOWS\System32\Drivers\N360\0403000.005\SRTSP.SYS
2010/11/02 20:05:46.0296 SRTSPX (55d5c37ed41231e3ac2063d16df50840) C:\WINDOWS\system32\drivers\N360\0403000.005\SRTSPX.SYS
2010/11/02 20:05:46.0953 Srv (0f6aefad3641a657e18081f52d0c15af) C:\WINDOWS\system32\DRIVERS\srv.sys
2010/11/02 20:05:47.0703 StillCam (a9573045baa16eab9b1085205b82f1ed) C:\WINDOWS\system32\DRIVERS\serscan.sys
2010/11/02 20:05:48.0234 streamip (77813007ba6265c4b6098187e6ed79d2) C:\WINDOWS\system32\DRIVERS\StreamIP.sys
2010/11/02 20:05:48.0703 swenum (3941d127aef12e93addf6fe6ee027e0f) C:\WINDOWS\system32\DRIVERS\swenum.sys
2010/11/02 20:05:49.0375 swmidi (8ce882bcc6cf8a62f2b2323d95cb3d01) C:\WINDOWS\system32\drivers\swmidi.sys
2010/11/02 20:05:50.0796 SymDS (56890bf9d9204b93042089d4b45ae671) C:\WINDOWS\system32\drivers\N360\0403000.005\SYMDS.SYS
2010/11/02 20:05:51.0578 SymEFA (1c91df5188150510a6f0cf78f7d94b69) C:\WINDOWS\system32\drivers\N360\0403000.005\SYMEFA.SYS
2010/11/02 20:05:52.0015 SymEvent (961b48b86f94d4cc8ceb483f8aa89374) C:\WINDOWS\system32\Drivers\SYMEVENT.SYS
2010/11/02 20:05:52.0593 SymIRON (dc80fbf0a348e54853ef82eed4e11e35) C:\WINDOWS\system32\drivers\N360\0403000.005\Ironx86.SYS
2010/11/02 20:05:52.0937 SYMTDI (41aad61f87ca8e3b5d0f7fe7fba0797d) C:\WINDOWS\System32\Drivers\N360\0403000.005\SYMTDI.SYS
2010/11/02 20:05:54.0078 sysaudio (8b83f3ed0f1688b4958f77cd6d2bf290) C:\WINDOWS\system32\drivers\sysaudio.sys
2010/11/02 20:05:54.0953 Tcpip (9aefa14bd6b182d61e3119fa5f436d3d) C:\WINDOWS\system32\DRIVERS\tcpip.sys
2010/11/02 20:05:55.0875 TDPIPE (6471a66807f5e104e4885f5b67349397) C:\WINDOWS\system32\drivers\TDPIPE.sys
2010/11/02 20:05:56.0625 TDTCP (c56b6d0402371cf3700eb322ef3aaf61) C:\WINDOWS\system32\drivers\TDTCP.sys
2010/11/02 20:05:57.0328 TermDD (88155247177638048422893737429d9e) C:\WINDOWS\system32\DRIVERS\termdd.sys
2010/11/02 20:05:58.0531 Udfs (5787b80c2e3c5e2f56c2a233d91fa2c9) C:\WINDOWS\system32\drivers\Udfs.sys
2010/11/02 20:06:00.0421 Update (402ddc88356b1bac0ee3dd1580c76a31) C:\WINDOWS\system32\DRIVERS\update.sys
2010/11/02 20:06:01.0218 usbehci (65dcf09d0e37d4c6b11b5b0b76d470a7) C:\WINDOWS\system32\DRIVERS\usbehci.sys
2010/11/02 20:06:01.0843 usbhub (1ab3cdde553b6e064d2e754efe20285c) C:\WINDOWS\system32\DRIVERS\usbhub.sys
2010/11/02 20:06:02.0359 usbohci (0daecce65366ea32b162f85f07c6753b) C:\WINDOWS\system32\DRIVERS\usbohci.sys
2010/11/02 20:06:02.0812 usbscan (a0b8cf9deb1184fbdd20784a58fa75d4) C:\WINDOWS\system32\DRIVERS\usbscan.sys
2010/11/02 20:06:03.0265 usbstor (a32426d9b14a089eaa1d922e0c5801a9) C:\WINDOWS\system32\DRIVERS\USBSTOR.SYS
2010/11/02 20:06:03.0750 usbuhci (26496f9dee2d787fc3e61ad54821ffe6) C:\WINDOWS\system32\DRIVERS\usbuhci.sys
2010/11/02 20:06:04.0281 VgaSave (0d3a8fafceacd8b7625cd549757a7df1) C:\WINDOWS\System32\drivers\vga.sys
2010/11/02 20:06:04.0843 ViaIde (3b3efcda263b8ac14fdf9cbdd0791b2e) C:\WINDOWS\system32\DRIVERS\viaide.sys
2010/11/02 20:06:05.0359 VolSnap (4c8fcb5cc53aab716d810740fe59d025) C:\WINDOWS\system32\drivers\VolSnap.sys
2010/11/02 20:06:05.0906 Wanarp (e20b95baedb550f32dd489265c1da1f6) C:\WINDOWS\system32\DRIVERS\wanarp.sys
2010/11/02 20:06:07.0156 wdmaud (6768acf64b18196494413695f0c3a00f) C:\WINDOWS\system32\drivers\wdmaud.sys
2010/11/02 20:06:07.0734 winachsx (11ec1afceb5c917ce73d3c301ff4291e) C:\WINDOWS\system32\DRIVERS\HSX_CNXT.sys
2010/11/02 20:06:08.0500 WS2IFSL (6abe6e225adb5a751622a9cc3bc19ce8) C:\WINDOWS\System32\drivers\ws2ifsl.sys
2010/11/02 20:06:08.0984 WSTCODEC (c98b39829c2bbd34e454150633c62c78) C:\WINDOWS\system32\DRIVERS\WSTCODEC.SYS
2010/11/02 20:06:09.0515 WudfPf (f15feafffbb3644ccc80c5da584e6311) C:\WINDOWS\system32\DRIVERS\WudfPf.sys
2010/11/02 20:06:10.0046 WudfRd (28b524262bce6de1f7ef9f510ba3985b) C:\WINDOWS\system32\DRIVERS\wudfrd.sys
2010/11/02 20:06:10.0234 \HardDisk0\MBR - detected Rootkit.Win32.TDSS.tdl4 (0)
2010/11/02 20:06:10.0234 ================================================================================
2010/11/02 20:06:10.0234 Scan finished
2010/11/02 20:06:10.0265 Detected object count: 1
2010/11/02 20:06:51.0015 \HardDisk0\MBR - will be cured after reboot
2010/11/02 20:06:51.0015 Rootkit.Win32.TDSS.tdl4(\HardDisk0\MBR) - User select action: Cure
eggers2010
Rookie Surfer
Rookie Surfer
Operating System : xp
Re: i need help
Post by Sneakyone on Thu 04 Nov 2010, 4:16 am
Please download Malwarebytes Anti-Malware from Here.
  • Make sure a checkmark is placed next to Update Malwarebytes Anti-Malware and Launch Malwarebytes Anti-Malware, then click Finish.
  • When disinfection is completed, a log will open in Notepad and you may be prompted to Restart.(See Extra Note)
  • Copy&Paste the entire report in your next reply.
If MBAM encounters a file that is difficult to remove,you will be presented with 1 of 2 prompts,click OK to either and let MBAM proceed with the disinfection process. If asked to restart the computer, please do so immediatly.
Sneakyone
Tech Officer
Tech Officer
mbam-log-2009-03-18(20-19-51)
Post by eggers2010 on Thu 04 Nov 2010, 11:32 am
Malwarebytes' Anti-Malware 1.34
Database version: 1866
3/18/2009 8:19:51 PM
mbam-log-2009-03-18 (20-19-51).txt
Objects scanned: 76236
Time elapsed: 12 minute(s), 23 second(s)
Memory Processes Infected: 2
Memory Modules Infected: 13
Registry Keys Infected: 191
Registry Values Infected: 18
Registry Data Items Infected: 4
Folders Infected: 23
Files Infected: 139
C:\Program Files\MyWebSearch\bar\5.bin\M3SRCHMN.EXE (Adware.MyWebSearch) -> Unloaded process successfully.
C:\Program Files\Intelinet\Intelinet.exe (Rogue.Intelinet) -> Unloaded process successfully.
C:\Program Files\MyWebSearch\bar\5.bin\MWSBAR.DLL (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\Internet Explorer\msimg32.dll (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\MyWebSearch\SrchAstt\5.bin\MWSSRCAS.DLL (Adware.MyWeb) -> Delete on reboot.
C:\WINDOWS\system32\winconfig.dll (Trojan.BHO) -> Delete on reboot.
C:\Program Files\Intelinet\BCKManager.dll (Rogue.Intelinet) -> Delete on reboot.
C:\Program Files\Intelinet\CheckRegistry.dll (Rogue.Intelinet) -> Delete on reboot.
C:\Program Files\Intelinet\ListLogs.dll (Rogue.Intelinet) -> Delete on reboot.
C:\Program Files\Intelinet\ManageRegistry.dll (Rogue.Intelinet) -> Delete on reboot.
C:\Program Files\Intelinet\MFC71.dll (Rogue.Intelinet) -> Delete on reboot.
C:\Program Files\Intelinet\msvcp71.dll (Rogue.Intelinet) -> Delete on reboot.
C:\Program Files\Intelinet\msvcr71.dll (Rogue.Intelinet) -> Delete on reboot.
C:\Program Files\Intelinet\SpywareGuard.dll (Rogue.Intelinet) -> Delete on reboot.
C:\Program Files\Intelinet\Spywarehandler.dll (Rogue.Intelinet) -> Delete on reboot.
HKEY_CLASSES_ROOT\TypeLib\{07b18ea0-a523-4961-b6bb-170de4475cca} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{07b18eaa-a523-4961-b6bb-170de4475cca} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{07b18eac-a523-4961-b6bb-170de4475cca} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{f87d7fb5-9dc5-4c8c-b998-d8dfe02e2978} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{53ced2d0-5e9a-4761-9005-648404e6f7e5} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{00a6faf6-072e-44cf-8957-5838f569a31d} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.browseroverlaybarbutton (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{98635087-3f5d-418f-990c-b1efe0797a3b} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{38a7c9da-8db7-4d0f-a7b1-c4b1a305bddb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{8d292ec0-6792-4a38-82ed-73a087e41ba6} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{a6573479-9075-4a65-98a6-19fd29cf7374} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{a6573479-9075-4a65-98a6-19fd29cf7374} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{d778513b-1c40-4819-b0c5-49e40b39afd0} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.browseroverlaybarbutton.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.browseroverlayembed (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.browseroverlayembed.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.datacontrol (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{c8cecde3-1ae1-4c4a-ad82-6d5b00212144} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{17de5e5e-bfe3-4e83-8e1f-8755795359ec} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{1f52a5fa-a705-4415-b975-88503b291728} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{a626cdbd-3d13-4f78-b819-440a28d7e8fc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.datacontrol.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historykillerscheduler (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{8ca01f0e-987c-49c3-b852-2f1ac4a7094c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{1093995a-ba37-41d2-836e-091067c4ad17} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{120927bf-1700-43bc-810f-fab92549b390} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{247a115f-06c2-4fb3-967d-2d62d3cf4f0a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e53e2cb-86db-4a4a-8bd9-ffeb7a64df82} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{90449521-d834-4703-bb4e-d3aa44042ff8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{991aac62-b100-47ce-8b75-253965244f69} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{bbabdc90-f3d5-4801-863a-ee6ae529862d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{d6ff3684-ad3b-48eb-bbb4-b9e6c5a355c1} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{eb9e5c1c-b1f9-4c2b-be8a-27d6446fdaf8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{0f8ecf4f-3646-4c3a-8881-8e138ffcaf70} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{b813095c-81c0-4e40-aa14-67520372b987} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{c9d7be3e-141a-4c85-8cd6-32461f3df2c7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{cff4ce82-3aa2-451f-9b77-7165605fb835} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historykillerscheduler.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historyswattercontrolbar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historyswattercontrolbar.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{e47caee0-deea-464a-9326-3f2801535a4d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e1656ed-f60e-4597-b6aa-b6a58e171495} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{741de825-a6f0-4497-9aa6-8023cf9b0fff} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{98d9753d-d73b-42d5-8c85-4469cda897ab} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{98d9753d-d73b-42d5-8c85-4469cda897ab} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu.2 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.iecookiesmanager (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.iecookiesmanager.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.killerobjmanager (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.killerobjmanager.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswatterbarbutton (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{8e6f1830-9607-4440-8530-13be7c4b1d14} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{63d0ed2b-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{63d0ed2d-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{63d0ed2c-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{63d0ed2c-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{8e6f1832-9607-4440-8530-13be7c4b1d14} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{a9571378-68a1-443d-b082-284f960c6d17} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswatterbarbutton.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswattersettingscontrol (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswattersettingscontrol.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.shellviewcontrol (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{621feacd-8857-43a6-ae26-451d670d5370} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{2763e333-b168-41a0-a112-d35f96f410c0} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{2eff3cf7-99c1-4c29-bc2b-68e057e22340} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{2eff3cf7-99c1-4c29-bc2b-68e057e22340} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.shellviewcontrol.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\imeshmediabar.stockbar (Adware.SoftMate) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\imeshmediabar.stockbar.1 (Adware.SoftMate) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.chatsessionplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.chatsessionplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.htmlpanel (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{3e720450-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e720451-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e720453-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{3e720452-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{3e720452-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.htmlpanel.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.outlookaddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{adb01e81-3c79-4272-a0f1-7b2be7a782dc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.outlookaddin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.pseudotransparentplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{7473d290-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d291-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d293-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d295-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d297-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d292-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d294-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{7473d294-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d296-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.pseudotransparentplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.settingsplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.settingsplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.toolbarplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.toolbarplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\sbsrv.coreservices (Adware.Hotbar) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\sbsrv.coreservices.1 (Adware.Hotbar) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\screensavercontrol.screensaverinstaller (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{29d67d3c-509a-4544-903f-c8c1b8236554} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{2e3537fc-cf2f-4f56-af54-5a6a3dd375cc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{2e9937fc-cf2f-4f56-af54-5a6a3dd375cc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{938aa51a-996c-4884-98ce-80dd16a5c9da} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{9ff05104-b030-46fc-94b8-81276e4e27df} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{9ff05104-b030-46fc-94b8-81276e4e27df} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{9ff05104-b030-46fc-94b8-81276e4e27df} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\screensavercontrol.screensaverinstaller.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{6e74766c-4d93-4cc0-96d1-47b8e07ff9ca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{72ee7f04-15bd-4845-a005-d6711144d86a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{de38c398-b328-4f4c-a3ad-1b5e4ed93477} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e342af55-b78a-4cd0-a2bb-da7f52d9d25e} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e342af55-b78a-4cd0-a2bb-da7f52d9d25f} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e79dfbc9-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e79dfbcb-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{0656a137-b161-cadd-9777-e37a75727e78} (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{0b682cc1-fb40-4006-a5dd-99edd3c9095d} (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{0e1230f8-ea50-42a9-983c-d22abc2eeb4c} (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{9dd4258a-7138-49c4-8d34-587879a5c7a4} (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{b8c0220d-763d-49a4-95f4-61dfdec66ee6} (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{c3bcc488-1ae7-11d4-ab82-0010a4ec2338} (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{147a976f-eee1-4377-8ea7-4716e4cdd239} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{1E0DE227-5CE4-4ea3-AB0C-8B03E1AA76BC} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{84da4fdf-a1cf-4195-8688-3e961f505983} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{a4730ebe-43a6-443e-9776-36915d323ad3} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{d9fffb27-d62a-4d64-8cec-1ff006528805} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{0d26bc71-a633-4e71-ad31-eadc3a1b6a3a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{d263fa6d-84cc-48a8-9af6-c664362b7a5b} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{d263fa6d-84cc-48a8-9af6-c664362b7a5b} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{d263fa6d-84cc-48a8-9af6-c664362b7a5b} (Trojan.BHO) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{e79dfbc0-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{f42228fb-e84e-479e-b922-fbbd096e792c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{9522b3fb-7a2b-4646-8af6-36e7f593073c} (Adware.Coupons) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{b7d3e479-cc68-42b5-a338-938ece35f419} (Adware.SoftMate) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{4b18dd50-c996-44fc-ac52-0fecff82ed58} (Spyware.Hotbar) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{e596df5f-4239-4d40-8367-ebadf0165917} (Rogue.Installer) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{90b5a95a-afd5-4d11-b9bd-a69d53d22226} (Adware.Hotbar) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{ed8525ea-2bfc-4440-bd8a-20efb9d5e541} (Adware.Hotbar) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{100eb1fd-d03e-47fd-81f3-ee91287f9465} (Adware.Shopping.Report) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{c5428486-50a0-4a02-9d20-520b59a9f9b2} (Adware.Shopping.Report) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{c5428486-50a0-4a02-9d20-520b59a9f9b3} (Adware.Shopping.Report) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{b64f4a7c-97c9-11da-8bde-f66bad1e3f3a} (Rogue.WinAntivirus) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{2d2bee6e-3c9a-4d58-b9ec-458edb28d0f6} (Rogue.DriveCleaner) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1e5b2693-d348-4ca7-8364-4f5e51bf9c6d} (Adware.Zango) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{54a3f8b7-228e-4ed8-895b-de832b2c3959} (Adware.Zango) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1d4db7d2-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{4e7bd74f-2b8d-469e-86bd-fd60bb9aae3a} (Adware.OneToolBar) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{6fd31ed6-7c94-4bbc-8e95-f927f4d3a949} (Adware.180Solutions) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{56256a51-b582-467e-b8d4-7786eda79ae0} (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{90b5a95a-afd5-4d11-b9bd-a69d53d22226} (Adware.Hotbar) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{8109fd3d-d891-4f80-8339-50a4913ace6f} (Adware.Zango) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{e79dfbca-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\RkHit (Rogue.SpywareCease) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\SpyClean (Rogue.NetCom3) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Intelinet_is1 (Rogue.Intelinet) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Intelinet (Rogue.Intelinet) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Classes\hol5_vxiewer.full.1 (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Classes\applications\accessdiver.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Trymedia Systems (Adware.Trymedia) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\SpamBlockerUtility (Adware.Hotbar) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\SBTV (Adware.Hotbar) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\MyWebSearch (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/x-f3embed (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins\MyWebSearch.OutlookAddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Word\Addins\MyWebSearch.OutlookAddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\FunWebProducts (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Fun Web Products (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\MyWebSearch (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\FocusInteractive (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Fun Web Products (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\spyshredder (Rogue.SpyShredder) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks\{00a6faf6-072e-44cf-8957-5838f569a31d} (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\my web search bar search scope monitor (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\mywebsearch email plugin (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\mywebsearch email plugin (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\my web search community tools (Adware.MyWeb) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Toolbar\{b7d3e479-cc68-42b5-a338-938ece35f419} (Adware.SoftMate) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser\{b7d3e479-cc68-42b5-a338-938ece35f419} (Adware.SoftMate) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser\{07aa283a-43d7-4cbe-a064-32a21112d94d} (Adware.Zango) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser\{4e7bd74f-2b8d-469e-86bd-fd60bb9aae3a} (Adware.OneToolBar) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\intelinet (Rogue.Intelinet) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\6ddc456981296f2d9ebf2279f13563f4 (Rogue.A360Antivirus) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\IEPR (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\iOmem (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\ADP (Rogue.Multiple) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\MenuExt\&Search\ (Adware.Hotbar) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Media\WMSDK\Sources\f3PopularScreensavers (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\User Agent\Post Platform\FunWebProducts (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\ForceActiveDesktopOn (Hijack.Desktop) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\MyWebSearch\bar (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\MyWebSearch\bar\5.bin (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\MyWebSearch\bar\Avatar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Avatar\COMMON (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\History (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Message (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Message\COMMON (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\SrchAstt (Adware.MyWebSearch) -> Delete on reboot.
C:\Program Files\MyWebSearch\SrchAstt\5.bin (Adware.MyWebSearch) -> Delete on reboot.
C:\Documents and Settings\Compaq_Owner\Application Data\FunWebProducts (Adware.MyWay) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\FunWebProducts\Data (Adware.MyWay) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\FunWebProducts\Data\Compaq_Owner (Adware.MyWay) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\Intelinet (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\Backup (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\Database (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\Logs (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\MWSBAR.DLL (Adware.MyWeb) -> Delete on reboot.
C:\Program Files\MyWebSearch\bar\5.bin\M3SRCHMN.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\MWSOEMON.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\M3IMPIPE.EXE (Adware.MyWeb) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3BROVLY.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3DTACTL.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3HISTSW.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3HTMLMU.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3POPSWT.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3SHLLVW.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\M3HTML.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\M3OUTLCN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\M3SKIN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3SCRCTR.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3CJPEG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3HTTPCT.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\MWSOEPLG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\f3PSSavr.scr (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\xfljulnv.exe (Adware.Hotbar) -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-923993542-2026946710-3953759661-1008\Dc382.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Program Files\Mozilla Firefox\plugins\NPMyWebS.dll (Adware.MyWeb) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3IMSTUB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3PSSAVR.SCR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3REPROX.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3RESTUB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3SCHMON.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3WPHOOK.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\M3FFXTBR.MANIFEST (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\M3IDLE.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\M3NTSTBR.MANIFEST (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\M3PLUGIN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\M3SKPLAY.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\M3SLSRCH.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\MWSOESTB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\NPMYWEBS.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Avatar\COMMON\window.ico (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\files.ini (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\History\search2 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\CM.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\MFC.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\PSS.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\SMILEY.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\WB.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\ZWINKY.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings\setting2.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings\setting2.htm.bak (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings\settings.dat (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings\settings.dat.bak (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings\s_pid.dat (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\FunWebProducts\Data\Compaq_Owner\avatar.dat (Adware.MyWay) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\FunWebProducts\Data\Compaq_Owner\register.dat (Adware.MyWay) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\FunWebProducts\Data\Compaq_Owner\zbucks.dat (Adware.MyWay) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\Intelinet\Intelinet.lnk (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\Intelinet\Uninstall Intelinet.lnk (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\BCKManager.dll (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\CheckRegistry.dll (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\hashes.md5 (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\intelin2.exe (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\Intelinet.exe (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\ListLogs.dll (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\ManageRegistry.dll (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\MFC71.dll (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\msvcp71.dll (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\msvcr71.dll (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\SpywareGuard.dll (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\Spywarehandler.dll (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\unins000.dat (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\unins000.exe (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\Database\Immunizer.db (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\Database\Spyware.db (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Program Files\Intelinet\Logs\2009_03_18.log (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Desktop\Intelinet.lnk (Rogue.Intelinet) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Local Settings\TempImages\ISPR108.exe (Trojan.Agent) -> Delete on reboot.
C:\WINDOWS\default.htm (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Desktopblackbird.jpg (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
C:\WINDOWS\base64.tmp (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
C:\WINDOWS\System32hxiwlgpm.dat (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
C:\WINDOWS\System32taack.dat (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
C:\WINDOWS\zip1.tmp (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
C:\WINDOWS\zip2.tmp (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
C:\WINDOWS\zip3.tmp (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
C:\WINDOWS\zipped.tmp (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
C:\WINDOWS\rs.txt (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\Web\def.htm (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\stfv.bin (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Favorites\Online Security Test.url (Rogue.Link) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Favorites\Error Cleaner.url (Rogue.Link) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Favorites\Privacy Protector.url (Rogue.Link) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\blank.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\box_2.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\button_buynow.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\button_freescan.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\cell_bg.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\cell_footer.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\cell_header_block.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\cell_header_remove.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\cell_header_scan.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\detect.htm (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\download_btn.jpg (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\download_now_btn.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\footer_back.jpg (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\header_1.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\header_2.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\header_3.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\header_4.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\header_red_bg.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\header_red_free_scan.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\header_red_free_scan_bg.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\header_red_protect_your_pc.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\infected.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\main_back.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\product_2_header.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\product_2_name_small.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\product_features.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\pt.htm (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\rating.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\s_detect.htm (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\screenshot.jpg (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\sep_hor.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\sep_vert.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\shadow.jpg (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\shadow_bg.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\spacer.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\star.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\star_gray.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\star_gray_small.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\star_small.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\style.css (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\v.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\warning_icon.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\win_logo.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\x.gif (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\aconti.log (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
C:\WINDOWS\acontidialer.txt (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\sznf.ascii (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\dpqaqlqx.bin (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
eggers2010
Rookie Surfer
Rookie Surfer
mbam-log-2009-03-22(04-06-06)
Post by eggers2010 on Thu 04 Nov 2010, 11:33 am
3/22/2009 4:06:06 AM
mbam-log-2009-03-22 (04-06-06).txt
Objects scanned: 88055
Time elapsed: 17 minute(s), 19 second(s)
eggers2010
Rookie Surfer
Rookie Surfer
mbam-log-2010-11-03(19-19-47)
Post by eggers2010 on Thu 04 Nov 2010, 11:35 am
Database version: 5039
11/3/2010 7:19:47 PM
mbam-log-2010-11-03 (19-19-47).txt
Scan type: Quick scan
Objects scanned: 150262
Time elapsed: 11 minute(s), 51 second(s)
Registry Keys Infected: 12
Folders Infected: 14
Files Infected: 251
HKEY_CLASSES_ROOT\Interface\{cf54be1c-9359-4395-8533-1657cf209cfe} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{d518921a-4a03-425e-9873-b9a71756821e} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{b7d3e479-cc68-42b5-a338-938ece35f419} (Adware.Softomate) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\.pox (Rogue.FixTool) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\pofile (Rogue.FixTool) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\RegTool (Rogue.RegTool) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\ErrorFix (Rogue.ErrorFix) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\RunDll32Policy\f3ScrCtr.dll (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\RegTool (Rogue.RegTool) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Results (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\KwinzySearch (Adware.Kwinzy) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\RegTool (Rogue.RegTool) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\RegTool\Logs (Rogue.RegTool) -> Quarantined and deleted successfully.
C:\Program Files\Error Fix (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Program Files\Error Fix\PW (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\Logs (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\PCOBackups (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590 (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\Results (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\spy_ignore.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-03-19 21-10-580.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-01 16-46-110.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-02 09-41-280.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-02 12-00-040.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-02 12-00-140.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-02 17-39-000.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-02 18-12-240.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-03 09-47-040.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-03 12-00-000.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-03 12-00-040.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-04 09-41-030.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-04 12-00-020.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-04 12-00-050.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-05 12-00-020.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-05 12-00-050.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-06 12-00-030.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-06 12-00-060.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-07 12-00-090.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-07 12-00-160.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-08 12-00-020.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-08 12-00-030.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-09 12-00-030.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-09 12-00-060.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-10 12-00-010.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-10 12-00-030.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-11 12-00-020.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-11 12-00-040.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-12 12-00-040.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-12 12-00-080.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-13 12-00-090.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Logs\2009-05-13 12-00-170.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Results\Evidence.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Results\Junk.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Results\Registry.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\ErrorFix\Results\Update.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\RegTool\resultsw.db (Rogue.RegTool) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\RegTool\Logs\2009-03-20 21-08-130.log (Rogue.RegTool) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\RegTool\Logs\2009-03-21 12-00-050.log (Rogue.RegTool) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\RegTool\Logs\2009-03-21 12-00-060.log (Rogue.RegTool) -> Quarantined and deleted successfully.
C:\Program Files\Error Fix\PW\general.html (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Program Files\Error Fix\PW\optimizations.html (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Program Files\Error Fix\PW\privacy.html (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Program Files\Error Fix\PW\scheduler.html (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Program Files\Error Fix\PW\startup.html (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Program Files\Error Fix\PW\wizard.css (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\spy_ignore.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\Logs\2010-10-23 09-11-140.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\Logs\2010-10-23 12-01-470.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\Logs\2010-10-23 12-01-540.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\Logs\2010-10-23 12-18-180.log (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\filelist.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-0.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-1.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-10.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-100.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-101.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-102.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-103.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-104.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-105.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-106.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-107.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-108.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-109.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-11.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-110.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-111.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-112.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-113.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-114.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-115.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-116.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-117.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-118.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-119.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-12.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-120.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-121.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-122.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-123.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-124.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-125.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-126.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-127.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-128.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-129.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-13.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-130.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-131.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-132.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-133.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-134.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-135.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-136.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-137.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-138.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-139.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-14.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-140.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-141.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-142.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-143.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-144.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-145.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-146.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-147.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-148.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-149.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-15.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-150.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-151.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-152.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-153.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-154.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-155.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-156.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-157.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-158.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-159.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-16.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-160.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-161.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-162.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-163.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-164.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-165.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-166.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-167.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-168.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-169.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-17.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-170.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-171.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-172.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-173.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-174.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-175.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-176.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-177.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-178.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-179.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-18.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-180.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-181.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-182.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-183.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-184.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-185.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-186.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-187.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-188.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-189.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-19.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-190.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-191.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-192.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-193.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-194.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-2.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-20.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-21.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-22.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-23.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-24.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-25.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-26.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-27.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-28.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-29.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-3.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-30.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-31.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-32.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-33.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-34.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-35.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-36.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-37.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-38.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-39.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-4.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-40.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-41.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-42.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-43.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-44.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-45.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-46.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-47.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-48.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-49.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-5.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-50.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-51.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-52.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-53.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-54.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-55.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-56.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-57.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-58.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-59.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-6.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-60.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-61.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-62.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-63.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-64.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-65.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-66.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-67.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-68.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-69.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-7.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-70.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-71.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-72.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-73.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-74.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-75.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-76.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-77.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-78.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-79.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-8.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-80.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-81.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-82.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-83.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-84.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-85.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-86.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-87.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-88.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-89.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-9.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-90.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-91.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-92.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-93.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-94.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-95.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-96.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-97.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-98.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\QuarantineW\2010-10-23 09-17-590\regb-99.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\Results\Evidence.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\Results\Junk.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\Results\Registry.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
C:\Documents and Settings\Compaq_Owner\Application Data\Error Fix\Results\Update.db (Rogue.ErrorFix) -> Quarantined and deleted successfully.
eggers2010
Rookie Surfer
Rookie Surfer
Operating System : xp
Re: i need help
Post by Sneakyone on Thu 04 Nov 2010, 2:37 pm
Please run a free online scan with the ESET Online Scanner
  • Click Start
  • Click Start
Sneakyone
Tech Officer
Tech Officer
Re: i need help
Post by Sponsored content Today at 9:44 am
Page 2 of 3 Previous  1, 2, 3  Next
