Serious Help Needed in regards to Think Point Virus Removal!
Page 1 of 2 1, 2  Next
Post by JulieMomster on Sat 30 Oct 2010, 5:03 am
My computer was infected with the thinkpoint virus. I went through all of the steps (ending the hotfix.exe process, enabling explorer.exe), and starting running malwarebytes to remove it. I got partially through the malwarebytes scan, when my computer showed a blue screen message. It stated that I needed to reboot, uninstall affected programs (?), and if it happened again to run my computer in safe mode.
The only problem is that now I cannot run my computer at all. At first, when I went to start it in safe mode, my screen was straight black, with no actions. After that, I ran an image burn of the Dr. Web program to clear my system. Ran the program twice, for both hard drives, and eventually they came back clean. But when I went back to start up in safe mode to do a full system clean, instead of a black screen, I'm getting script back.... and that's it.
What am I supposed to do now?
JulieMomster
Operating System : windows XP
Re: Serious Help Needed in regards to Think Point Virus Removal!
Post by Sneakyone on Sat 30 Oct 2010, 8:08 am
Step 1: you need to get the appropriate burning software for this task.
Download ISOBurner
  • This will allow you to burn OTLPE ISO to a cd and make it bootable. Just install the program, from there on in it is fairly automatic.
  • See the instructions page for more info.
Step 2: download the OTLPE REATOGO Windows Recovery Environment.
  • Download OTLPE.iso and burn to a CD using ISO Burner. NOTE: This file is 292Mb in size so it may take some time to download.
  • When downloaded double click and this will then open ISOBurner to burn the file to CD
Sneakyone
Tech Officer
Tech Officer
Post by JulieMomster on Sat 30 Oct 2010, 9:12 am
Alright, I have the ISO burner downloaded and installed, but the link for the OTLPE.iso file says it is broken.
Is there another place to download the file from?
JulieMomster
Post by Sneakyone on Sat 30 Oct 2010, 10:19 am
Are you able to boot into Windows at all? If not try Last Known Good Configuration.
Sneakyone
Tech Officer
Tech Officer
Post by JulieMomster on Mon 01 Nov 2010, 3:17 am
I tried the Last Known Configuration, but it takes me back to the blank screen again. Is there any other place to download the OTLPE.iso file?
JulieMomster
Post by Sneakyone on Mon 01 Nov 2010, 3:47 am
Please use [You must be registered and logged in to see this link.]
Sneakyone
Tech Officer
Tech Officer
Post by JulieMomster on Mon 01 Nov 2010, 4:17 am
Will that still work to boot the computer since it's the .exe file? Or would I need to .iso to boot?
JulieMomster
Post by Sneakyone on Mon 01 Nov 2010, 10:18 am
You should be able to boot with that.
Sneakyone
Tech Officer
Tech Officer
Post by JulieMomster on Wed 03 Nov 2010, 8:39 am
My computer won't let me boot up with the .exe file. Is ther any other way I can get that up and running?
JulieMomster
Post by Sneakyone on Wed 03 Nov 2010, 12:11 pm
Do you have your XP disk?
Sneakyone
Tech Officer
Tech Officer
Post by JulieMomster on Thu 04 Nov 2010, 9:49 am
Alright, I re-burned the img of the OTLPE file, and ran it on my main hard drive. It wouldn't run on my secondary drive, either on it's own (it does not have a windows file on it), or running as a slave to the CD-ROM drive.
But here is the OTL.txt file from the main hard drive:
OTL logfile created on: 11/3/2010 6:57:31 PM - Run
OTLPE by OldTimer - Version 3.1.43.0 Folder = X:\Programs\OTLPE
Microsoft Windows XP Service Pack 3 (Version = 5.1.2600) - Type = SYSTEM
Internet Explorer (Version = 6.0.2900.5512)
254.00 Mb Total Physical Memory | 93.00 Mb Available Physical Memory | 37.00% Memory free
222.00 Mb Paging File | 107.00 Mb Available in Paging File | 48.00% Paging File free
Paging file location(s): [Binary data over 100 bytes]
Drive C: | 34.44 Gb Total Space | 11.31 Gb Free Space | 32.85% Space Free | Partition Type: NTFS
Drive X: | 434.99 Mb Total Space | 0.00 Mb Free Space | 0.00% Space Free | Partition Type: CDFS
Computer Name: REATOGO | User Name: SYSTEM
Boot Mode: Normal | Scan Mode: All users
Using ControlSet: ControlSet001
SRV - File not found [Disabled] -- C:\WINDOWS\System32\hidserv.dll -- (HidServ)
SRV - File not found [On_Demand] -- C:\WINDOWS\System32\appmgmts.dll -- (AppMgmt)
SRV - [2010/10/27 14:08:44 | 000,307,200 | ---- | M] (CJSC Computing Forces) [Auto] -- C:\WINDOWS\SYSTEM32\sshnas21.dll -- (SSHNAS)
DRV - File not found [Kernel | On_Demand] -- -- (WDICA)
DRV - File not found [Kernel | On_Demand] -- C:\WINDOWS\System32\DRIVERS\wanatw4.sys -- (wanatw) WAN Miniport (ATW)
DRV - File not found [Kernel | On_Demand] -- -- (PDRFRAME)
DRV - File not found [Kernel | On_Demand] -- -- (PDRELI)
DRV - File not found [Kernel | On_Demand] -- -- (PDFRAME)
DRV - File not found [Kernel | On_Demand] -- -- (PDCOMP)
DRV - File not found [Kernel | System] -- -- (PCIDump)
DRV - File not found [Kernel | System] -- -- (lbrtfdc)
DRV - File not found [Kernel | System] -- -- (Changer)
DRV - [2010/10/27 18:27:55 | 000,000,000 | ---- | M] () [Kernel | Boot] -- C:\WINDOWS\System32\drivers\myiqtsc.sys -- (myiqtsc)
DRV - [2010/09/27 19:21:58 | 000,691,696 | ---- | M] (Duplex Secure Ltd.) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\sptd.sys -- (sptd)
DRV - [2008/04/13 14:36:39 | 000,043,008 | ---- | M] (Advanced Micro Devices, Inc.) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\amdagp.sys -- (amdagp)
DRV - [2008/04/13 14:36:39 | 000,040,960 | ---- | M] (Silicon Integrated Systems Corporation) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\sisagp.sys -- (sisagp)
DRV - [2004/08/04 00:29:56 | 001,897,408 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand] -- C:\WINDOWS\SYSTEM32\DRIVERS\NV4_MINI.SYS -- (nv)
DRV - [2004/06/16 00:52:40 | 000,061,157 | ---- | M] (Intel Corporation) [Kernel | On_Demand] -- C:\WINDOWS\SYSTEM32\DRIVERS\IntelC53.sys -- (IntelC53)
DRV - [2004/04/26 11:49:56 | 000,381,056 | ---- | M] (Sensaura) [Kernel | On_Demand] -- C:\WINDOWS\SYSTEM32\DRIVERS\senfilt.sys -- (senfilt)
DRV - [2004/03/06 00:15:34 | 000,647,929 | ---- | M] (Intel Corporation) [Kernel | On_Demand] -- C:\WINDOWS\SYSTEM32\DRIVERS\IntelC52.sys -- (IntelC52)
DRV - [2004/03/06 00:14:42 | 001,233,525 | ---- | M] (Intel Corporation) [Kernel | On_Demand] -- C:\WINDOWS\SYSTEM32\DRIVERS\IntelC51.sys -- (IntelC51)
DRV - [2004/03/06 00:13:38 | 000,037,048 | ---- | M] (Intel Corporation) [Kernel | On_Demand] -- C:\WINDOWS\SYSTEM32\DRIVERS\mohfilt.sys -- (mohfilt)
DRV - [2003/05/23 14:58:30 | 000,043,136 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand] -- C:\WINDOWS\SYSTEM32\DRIVERS\bcm4sbxp.sys -- (bcm4sbxp)
DRV - [2002/11/08 15:45:06 | 000,017,217 | ---- | M] (Dell Computer Corporation) [Kernel | System] -- C:\WINDOWS\SYSTEM32\DRIVERS\omci.sys -- (omci)
DRV - [2001/08/17 16:07:44 | 000,019,072 | ---- | M] (Adaptec, Inc.) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\SPARROW.SYS -- (Sparrow)
DRV - [2001/08/17 16:07:42 | 000,030,688 | ---- | M] (LSI Logic) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\SYM_U3.SYS -- (sym_u3)
DRV - [2001/08/17 16:07:40 | 000,028,384 | ---- | M] (LSI Logic) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\SYM_HI.SYS -- (sym_hi)
DRV - [2001/08/17 16:07:36 | 000,032,640 | ---- | M] (LSI Logic) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\SYMC8XX.SYS -- (symc8xx)
DRV - [2001/08/17 16:07:34 | 000,016,256 | ---- | M] (Symbios Logic Inc.) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\SYMC810.SYS -- (symc810)
DRV - [2001/08/17 15:52:22 | 000,036,736 | ---- | M] (Promise Technology, Inc.) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\ULTRA.SYS -- (ultra)
DRV - [2001/08/17 15:52:20 | 000,045,312 | ---- | M] (QLogic Corporation) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\QL12160.SYS -- (ql12160)
DRV - [2001/08/17 15:52:20 | 000,040,320 | ---- | M] (QLogic Corporation) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\QL1080.SYS -- (ql1080)
DRV - [2001/08/17 15:52:18 | 000,049,024 | ---- | M] (QLogic Corporation) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\QL1280.SYS -- (ql1280)
DRV - [2001/08/17 15:52:16 | 000,179,584 | ---- | M] (Mylex Corporation) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\DAC2W2K.SYS -- (dac2w2k)
DRV - [2001/08/17 15:52:12 | 000,017,280 | ---- | M] (American Megatrends Inc.) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\MRAID35X.SYS -- (mraid35x)
DRV - [2001/08/17 15:52:00 | 000,026,496 | ---- | M] (Advanced System Products, Inc.) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\ASC.SYS -- (asc)
DRV - [2001/08/17 15:51:58 | 000,014,848 | ---- | M] (Advanced System Products, Inc.) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\ASC3550.SYS -- (asc3550)
DRV - [2001/08/17 15:51:56 | 000,005,248 | ---- | M] (Acer Laboratories Inc.) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\ALIIDE.SYS -- (AliIde)
DRV - [2001/08/17 15:51:54 | 000,006,656 | ---- | M] (CMD Technology, Inc.) [Kernel | Boot] -- C:\WINDOWS\SYSTEM32\DRIVERS\CMDIDE.SYS -- (CmdIde)
IE - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = [You must be registered and logged in to see this link.]
IE - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = %SystemRoot%\system32\blank.htm
IE - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = [You must be registered and logged in to see this link.]
IE - HKU\.DEFAULT\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = [You must be registered and logged in to see this link.]
IE - HKU\.DEFAULT\Software\Microsoft\Internet Explorer\Main,First Home Page = [You must be registered and logged in to see this link.]
IE - HKU\.DEFAULT\Software\Microsoft\Internet Explorer\Main,Start Page = [You must be registered and logged in to see this link.]
IE - HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
IE - HKU\Jules_ON_C\Software\Microsoft\Internet Explorer\Main,Start Page = [You must be registered and logged in to see this link.]
IE - HKU\Jules_ON_C\..\URLSearchHook: {44F9B173-041C-4825-A9B9-D914BD9DCBB3} - Reg Error: Key error. File not found
IE - HKU\Jules_ON_C\..\URLSearchHook: ~4D25F926-B9FE-4682-BF72-8AB8210D6D75} - Reg Error: Key error. File not found
IE - HKU\Jules_ON_C\..\URLSearchHook: ~CFBFAE00-17A6-11D0-99CB-00C04FD64497} - Reg Error: Key error. File not found
IE - HKU\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
IE - HKU\Mikey_ON_C\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = [You must be registered and logged in to see this link.]
IE - HKU\Mikey_ON_C\Software\Microsoft\Internet Explorer\Main,Start Page = [You must be registered and logged in to see this link.]
IE - HKU\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
========== FireFox ==========
FF - prefs.js..browser.search.order.1: "Google"
FF - prefs.js..browser.search.selectedEngine: "Google"
FF - prefs.js..browser.startup.homepage: "http://www.facebook.com/"
FF - prefs.js..extensions.enabledItems: {22BCE474-26A4-41D6-BC8F-CD0F4ECAC1E2}:1.9.1
FF - prefs.js..extensions.enabledItems: {FD57B90C-AEA6-44E8-A343-C6A2E427491D}:1.9.1
FF - prefs.js..keyword.URL: "http://search.fast-find.net/?sid=10101067100&s="
FF - prefs.js..network.proxy.type: 0
FF - user.js..browser.search.selectedEngine: "Google"
FF - user.js..browser.search.order.1: "Google"
FF - user.js..keyword.URL: "http://search.fast-find.net/?sid=10101067100&s="
FF - HKLM\software\mozilla\Firefox\Extensions\\{22BCE474-26A4-41D6-BC8F-CD0F4ECAC1E2}: C:\Documents and Settings\Mikey\Local Settings\Application Data\{22BCE474-26A4-41D6-BC8F-CD0F4ECAC1E2} [2010/10/27 14:12:28 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\{FD57B90C-AEA6-44E8-A343-C6A2E427491D}: C:\Documents and Settings\Jules\Local Settings\Application Data\{FD57B90C-AEA6-44E8-A343-C6A2E427491D}\ [2010/10/27 14:50:57 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.11\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/10/20 22:48:34 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.11\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/10/22 18:02:58 | 000,000,000 | ---D | M]
[2010/08/07 22:34:42 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jules\Application Data\Mozilla\Extensions
[2010/09/06 12:30:55 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jules\Application Data\Mozilla\Firefox\Profiles\06yof9ee.default\extensions
[2010/08/07 22:32:54 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
[2010/10/24 07:52:18 | 000,002,074 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\google_search.xml
O1 HOSTS File: ([2004/08/04 07:00:00 | 000,000,734 | ---- | M]) - C:\WINDOWS\SYSTEM32\DRIVERS\ETC\HOSTS
O2 - BHO: (no name) - {81EA3F36-357A-435A-8741-52C27CCC9F21} - C:\WINDOWS\System32\ssqPGwwX.dll File not found
O2 - BHO: (C:\WINDOWS\system32\xeetnkw8sg.dll) - {B6BA40C1-A501-59BD-F413-03B03A2C8952} - C:\WINDOWS\System32\xeetnkw8sg.dll File not found
O3 - HKLM\..\Toolbar: (no name) - {BA52B914-B692-46c4-B683-905236F6F655} - No CLSID value found.
O3 - HKU\Jules_ON_C\..\Toolbar\WebBrowser: (AIM Search) - {40D41A8B-D79B-43D7-99A7-9EE0F344C385} - C:\Program Files\AIM Toolbar\AIMBar.dll File not found
O4 - HKLM..\Run: [HNUhcIXn0Z] C:\DOCUME~1\Mikey\LOCALS~1\Temp\system.exe File not found
O4 - HKLM..\Run: [HNUhcIXnb] C:\DOCUME~1\Mikey\LOCALS~1\Temp\mdm.exe File not found
O4 - HKLM..\Run: [HNUhcIXnd] C:\DOCUME~1\Mikey\LOCALS~1\Temp\avp.exe File not found
O4 - HKLM..\Run: [HNUhcIXneP] C:\DOCUME~1\Mikey\LOCALS~1\Temp\avp32.exe File not found
O4 - HKLM..\Run: [HNUhcIXnf] C:\DOCUME~1\Mikey\LOCALS~1\Temp\win.exe File not found
O4 - HKLM..\Run: [HNUhcIXnfQ] C:\DOCUME~1\Mikey\LOCALS~1\Temp\win16.exe File not found
O4 - HKLM..\Run: [HNUhcIXngP] C:\DOCUME~1\Mikey\LOCALS~1\Temp\win32.exe File not found
O4 - HKLM..\Run: [HNUhcIXnoc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\debug.exe File not found
O4 - HKLM..\Run: [HNUhcIXnqe] C:\DOCUME~1\Mikey\LOCALS~1\Temp\login.exe File not found
O4 - HKLM..\Run: [HNUhcIXnqg] C:\DOCUME~1\Mikey\LOCALS~1\Temp\hexdump.exe File not found
O4 - HKLM..\Run: [HNUhcIXnrc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\winamp.exe File not found
O4 - HKLM..\Run: [HNUhcIXnsb] C:\DOCUME~1\Mikey\LOCALS~1\Temp\drweb.exe File not found
O4 - HKLM..\Run: [HNUhcIXnsd] C:\DOCUME~1\Mikey\LOCALS~1\Temp\taskmgr.exe File not found
O4 - HKLM..\Run: [HNUhcIXnsf] C:\DOCUME~1\Mikey\LOCALS~1\Temp\lsass.exe File not found
O4 - HKLM..\Run: [HNUhcIXntg] C:\DOCUME~1\Mikey\LOCALS~1\Temp\wininst.exe File not found
O4 - HKLM..\Run: [HNUhcIXnth] C:\DOCUME~1\Mikey\LOCALS~1\Temp\svchost.exe File not found
O4 - HKLM..\Run: [HNUhcIXnUf] C:\DOCUME~1\Mikey\LOCALS~1\Temp\z77hqz.exe File not found
O4 - HKLM..\Run: [HNUhcIXnusc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\winlogon.exe File not found
O4 - HKLM..\Run: [HNUhcIXnvc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\user.exe File not found
O4 - HKLM..\Run: [HNUhcIXnvZ] C:\DOCUME~1\Mikey\LOCALS~1\Temp\install.exe File not found
O4 - HKLM..\Run: [HNUhcIXnwe] C:\DOCUME~1\Mikey\LOCALS~1\Temp\setup.exe File not found
O4 - HKLM..\Run: [HNUhcIXnwg] C:\DOCUME~1\Mikey\LOCALS~1\Temp\spoolsv.exe File not found
O4 - HKLM..\Run: [HNUhcIXnwpc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\services.exe File not found
O4 - HKLM..\Run: [HNUhcIXnxb] C:\DOCUME~1\Mikey\LOCALS~1\Temp\sysedit.exe File not found
O4 - HKLM..\Run: [HNUhcIXnxc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\smss.exe File not found
O4 - HKLM..\Run: [HNUhcIXnY] C:\DOCUME~1\Mikey\LOCALS~1\Temp\cmd.exe File not found
O4 - HKLM..\Run: [HNUhcIXnz9] C:\DOCUME~1\Mikey\LOCALS~1\Temp\nvsvc32.exe File not found
O4 - HKLM..\Run: [HNUkaIXnd] C:\DOCUME~1\Jules\LOCALS~1\Temp\avp.exe File not found
O4 - HKLM..\Run: [HNUkaIXneP] C:\DOCUME~1\Jules\LOCALS~1\Temp\avp32.exe File not found
O4 - HKLM..\Run: [HNUkaIXnfQ] C:\DOCUME~1\Jules\LOCALS~1\Temp\win16.exe File not found
O4 - HKLM..\Run: [HNUkaIXnsd] C:\DOCUME~1\Jules\LOCALS~1\Temp\taskmgr.exe File not found
O4 - HKLM..\Run: [HNUkaIXntg] C:\DOCUME~1\Jules\LOCALS~1\Temp\wininst.exe File not found
O4 - HKLM..\Run: [HNUkaIXnvZ] C:\DOCUME~1\Jules\LOCALS~1\Temp\install.exe File not found
O4 - HKLM..\Run: [HNUkaIXnwg] C:\DOCUME~1\Jules\LOCALS~1\Temp\spoolsv.exe File not found
O4 - HKLM..\Run: [HNUkaIXnxb] C:\DOCUME~1\Jules\LOCALS~1\Temp\sysedit.exe File not found
O4 - HKLM..\Run: [HNUkaIXnz9] C:\DOCUME~1\Jules\LOCALS~1\Temp\nvsvc32.exe File not found
O4 - HKLM..\Run: [HNUkaIXnZP] C:\DOCUME~1\Jules\LOCALS~1\Temp\gdi32.exe File not found
O4 - HKLM..\Run: [KernelFaultCheck] File not found
O4 - HKLM..\Run: [MKaoc] C:\WINDOWS\debug.exe File not found
O4 - HKLM..\Run: [MKasc] C:\WINDOWS\drweb.exe File not found
O4 - HKLM..\Run: [MKayc] C:\WINDOWS\csrss.exe File not found
O4 - HKLM..\Run: [MKaZ] C:\WINDOWS\cmd.exe File not found
O4 - HKLM..\Run: [MKbMc] C:\WINDOWS\gdi32.exe File not found
O4 - HKLM..\Run: [MKbta] C:\WINDOWS\install.exe File not found
O4 - HKLM..\Run: [MKbtc] C:\WINDOWS\hexdump.exe File not found
O4 - HKLM..\Run: [MKbuqc] C:\WINDOWS\iexplarer.exe File not found
O4 - HKLM..\Run: [MKcZ] C:\WINDOWS\mdm.exe File not found
O4 - HKLM..\Run: [MKee] C:\WINDOWS\user.exe File not found
O4 - HKLM..\Run: [MKeg] C:\WINDOWS\smss.exe File not found
O4 - HKLM..\Run: [MKeta] C:\WINDOWS\services.exe File not found
O4 - HKLM..\Run: [MKetc] C:\WINDOWS\sysedit.exe File not found
O4 - HKLM..\Run: [MKeuf] C:\WINDOWS\spoolsv.exe File not found
O4 - HKLM..\Run: [MKeufdtop.info&p=R0lGODlhyAA8APcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/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==] C:\WINDOWS\spoolsv.exe File not found
O4 - HKLM..\Run: [MKevc] C:\WINDOWS\setup.exe File not found
O4 - HKLM..\Run: [MKexe] C:\WINDOWS\system.exe File not found
O4 - HKLM..\Run: [MKfa] C:\WINDOWS\win.exe File not found
O4 - HKLM..\Run: [MKfPc] C:\WINDOWS\win32.exe File not found
O4 - HKLM..\Run: [MKfre] C:\WINDOWS\wininst.exe File not found
O4 - HKLM..\Run: [MKfsc] C:\WINDOWS\winlogon.exe File not found
O4 - HKLM..\Run: [MKWPtg] C:\WINDOWS\TEMP\wininst.exe File not found
O4 - HKLM..\Run: [MKZe] C:\WINDOWS\avp.exe File not found
O4 - HKLM..\Run: [MKZSc] C:\WINDOWS\avp32.exe File not found
O4 - HKLM..\Run: [OSCD_Creator] C:\DELL\PREODM.EXE ()
O4 - HKLM..\Run: [Recordpad] C:\Program Files\NCH Swift Sound\Recordpad\recordpad.exe (NCH Software)
O4 - HKLM..\Run: [SunJavaUpdateSched] C:\Program Files\Java\j2re1.4.2_03\bin\jusched.exe ()
O4 - HKLM..\Run: [Tpinudepiguyoru] C:\WINDOWS\ogudenenor.DLL ()
O4 - HKLM..\Run: [uPc+MV0NbtaGuo] C:\WINDOWS\System32\zh0ycwd.DLL ()
O4 - HKU\Jules_ON_C..\Run: [E6TaskPanel] C:\Program Files\EarthLink TotalAccess\TaskPanl.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXn0Z] C:\DOCUME~1\Mikey\LOCALS~1\Temp\system.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnb] C:\DOCUME~1\Mikey\LOCALS~1\Temp\mdm.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXneP] C:\DOCUME~1\Mikey\LOCALS~1\Temp\avp32.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnfQ] C:\DOCUME~1\Mikey\LOCALS~1\Temp\win16.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXngP] C:\DOCUME~1\Mikey\LOCALS~1\Temp\win32.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnqe] C:\DOCUME~1\Mikey\LOCALS~1\Temp\login.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnqg] C:\DOCUME~1\Mikey\LOCALS~1\Temp\hexdump.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnrc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\winamp.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnsb] C:\DOCUME~1\Mikey\LOCALS~1\Temp\drweb.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnsf] C:\DOCUME~1\Mikey\LOCALS~1\Temp\lsass.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXntg] C:\DOCUME~1\Mikey\LOCALS~1\Temp\wininst.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnUf] C:\DOCUME~1\Mikey\LOCALS~1\Temp\z77hqz.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnusc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\winlogon.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnvc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\user.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnvZ] C:\DOCUME~1\Mikey\LOCALS~1\Temp\install.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnwe] C:\DOCUME~1\Mikey\LOCALS~1\Temp\setup.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnwg] C:\DOCUME~1\Mikey\LOCALS~1\Temp\spoolsv.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnxc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\smss.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUhcIXnz9] C:\DOCUME~1\Mikey\LOCALS~1\Temp\nvsvc32.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUkaIXnd] C:\DOCUME~1\Jules\LOCALS~1\Temp\avp.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUkaIXneP] C:\DOCUME~1\Jules\LOCALS~1\Temp\avp32.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUkaIXnfQ] C:\DOCUME~1\Jules\LOCALS~1\Temp\win16.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUkaIXnsd] C:\DOCUME~1\Jules\LOCALS~1\Temp\taskmgr.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUkaIXntg] C:\DOCUME~1\Jules\LOCALS~1\Temp\wininst.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUkaIXnvZ] C:\DOCUME~1\Jules\LOCALS~1\Temp\install.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUkaIXnwg] C:\DOCUME~1\Jules\LOCALS~1\Temp\spoolsv.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUkaIXnxb] C:\DOCUME~1\Jules\LOCALS~1\Temp\sysedit.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUkaIXnz9] C:\DOCUME~1\Jules\LOCALS~1\Temp\nvsvc32.exe File not found
O4 - HKU\Jules_ON_C..\Run: [HNUkaIXnZP] C:\DOCUME~1\Jules\LOCALS~1\Temp\gdi32.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKaoc] C:\WINDOWS\debug.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKasc] C:\WINDOWS\drweb.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKayc] C:\WINDOWS\csrss.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKbMc] C:\WINDOWS\gdi32.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKbta] C:\WINDOWS\install.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKbtc] C:\WINDOWS\hexdump.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKcZ] C:\WINDOWS\mdm.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKee] C:\WINDOWS\user.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKeg] C:\WINDOWS\smss.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKeta] C:\WINDOWS\services.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKetc] C:\WINDOWS\sysedit.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKeuf] C:\WINDOWS\spoolsv.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKevc] C:\WINDOWS\setup.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKexe] C:\WINDOWS\system.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKfPc] C:\WINDOWS\win32.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKfre] C:\WINDOWS\wininst.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKfsc] C:\WINDOWS\winlogon.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKWPtg] C:\WINDOWS\TEMP\wininst.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKZe] C:\WINDOWS\avp.exe File not found
O4 - HKU\Jules_ON_C..\Run: [MKZSc] C:\WINDOWS\avp32.exe File not found
O4 - HKU\Jules_ON_C..\Run: [SpySweeper] File not found
O4 - HKU\Jules_ON_C..\Run: [uPc+MV0NbtaGuo] C:\WINDOWS\System32\zh0ycwd.DLL ()
O4 - HKU\Jules_ON_C..\Run: [uTorrent] C:\Program Files\uTorrent\uTorrent.exe (BitTorrent, Inc.)
O4 - HKU\Mikey_ON_C..\Run: [DAEMON Tools Lite] C:\Program Files\DAEMON Tools Lite\DTLite.exe (DT Soft Ltd)
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXn0Z] C:\DOCUME~1\Mikey\LOCALS~1\Temp\system.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnb] C:\DOCUME~1\Mikey\LOCALS~1\Temp\mdm.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnd] C:\DOCUME~1\Mikey\LOCALS~1\Temp\avp.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXneP] C:\DOCUME~1\Mikey\LOCALS~1\Temp\avp32.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnf] C:\DOCUME~1\Mikey\LOCALS~1\Temp\win.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnfQ] C:\DOCUME~1\Mikey\LOCALS~1\Temp\win16.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXngP] C:\DOCUME~1\Mikey\LOCALS~1\Temp\win32.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnqe] C:\DOCUME~1\Mikey\LOCALS~1\Temp\login.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnqg] C:\DOCUME~1\Mikey\LOCALS~1\Temp\hexdump.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnrc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\winamp.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnsb] C:\DOCUME~1\Mikey\LOCALS~1\Temp\drweb.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnsf] C:\DOCUME~1\Mikey\LOCALS~1\Temp\lsass.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXntg] C:\DOCUME~1\Mikey\LOCALS~1\Temp\wininst.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnth] C:\DOCUME~1\Mikey\LOCALS~1\Temp\svchost.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnUf] C:\DOCUME~1\Mikey\LOCALS~1\Temp\z77hqz.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnusc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\winlogon.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnvc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\user.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnvZ] C:\DOCUME~1\Mikey\LOCALS~1\Temp\install.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnwe] C:\DOCUME~1\Mikey\LOCALS~1\Temp\setup.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnwg] C:\DOCUME~1\Mikey\LOCALS~1\Temp\spoolsv.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnwpc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\services.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnxc] C:\DOCUME~1\Mikey\LOCALS~1\Temp\smss.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUhcIXnz9] C:\DOCUME~1\Mikey\LOCALS~1\Temp\nvsvc32.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUkaIXnd] C:\DOCUME~1\Jules\LOCALS~1\Temp\avp.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUkaIXneP] C:\DOCUME~1\Jules\LOCALS~1\Temp\avp32.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUkaIXnfQ] C:\DOCUME~1\Jules\LOCALS~1\Temp\win16.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUkaIXnsd] C:\DOCUME~1\Jules\LOCALS~1\Temp\taskmgr.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUkaIXntg] C:\DOCUME~1\Jules\LOCALS~1\Temp\wininst.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUkaIXnvZ] C:\DOCUME~1\Jules\LOCALS~1\Temp\install.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUkaIXnwg] C:\DOCUME~1\Jules\LOCALS~1\Temp\spoolsv.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUkaIXnxb] C:\DOCUME~1\Jules\LOCALS~1\Temp\sysedit.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUkaIXnz9] C:\DOCUME~1\Jules\LOCALS~1\Temp\nvsvc32.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [HNUkaIXnZP] C:\DOCUME~1\Jules\LOCALS~1\Temp\gdi32.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKaoc] C:\WINDOWS\debug.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKasc] C:\WINDOWS\drweb.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKayc] C:\WINDOWS\csrss.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKbMc] C:\WINDOWS\gdi32.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKbta] C:\WINDOWS\install.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKbtc] C:\WINDOWS\hexdump.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKcZ] C:\WINDOWS\mdm.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKee] C:\WINDOWS\user.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKeg] C:\WINDOWS\smss.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKeta] C:\WINDOWS\services.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKetc] C:\WINDOWS\sysedit.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKeuf] C:\WINDOWS\spoolsv.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKevc] C:\WINDOWS\setup.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKexe] C:\WINDOWS\system.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKfPc] C:\WINDOWS\win32.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKfre] C:\WINDOWS\wininst.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKfsc] C:\WINDOWS\winlogon.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKWPtg] C:\WINDOWS\TEMP\wininst.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKZe] C:\WINDOWS\avp.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [MKZSc] C:\WINDOWS\avp32.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [Snosesicogoto] C:\WINDOWS\werowp.DLL ()
O4 - HKU\Mikey_ON_C..\Run: [U36VRSFLG6] C:\DOCUME~1\Mikey\LOCALS~1\Temp\Uwl.exe File not found
O4 - HKU\Mikey_ON_C..\Run: [uPc+MV0NbtaGuo] C:\WINDOWS\System32\zh0ycwd.DLL ()
O4 - HKLM..\RunOnce: [OSCD_Creator] C:\Dell\PreODM.EXE ()
O4 - Startup: C:\Documents and Settings\Mikey\Start Menu\Programs\Startup\Adobe Gamma.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe (Adobe Systems, Inc.)
O4 - Startup: C:\Documents and Settings\Mikey\Start Menu\Programs\Startup\Stardock ObjectDock.lnk = C:\Program Files\Stardock\ObjectDock\ObjectDock.exe (Stardock)
O7 - HKU\.DEFAULT\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O7 - HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
O7 - HKU\Jules_ON_C\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O7 - HKU\Jules_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
O7 - HKU\Jules_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoFolderOptions = 1
O7 - HKU\Jules_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: DisableRegistryTools = 1
O7 - HKU\LocalService_ON_C\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O7 - HKU\LocalService_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
O7 - HKU\Mikey_ON_C\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O7 - HKU\Mikey_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
O7 - HKU\Mikey_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoFolderOptions = 1
O7 - HKU\Mikey_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: DisableRegistryTools = 1
O7 - HKU\NetworkService_ON_C\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O7 - HKU\NetworkService_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
O7 - HKU\systemprofile_ON_C\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O8 - Extra context menu item: Add to Google Photos Screensa&ver - C:\WINDOWS\System32\GPhotos.scr (Google Inc.)
O9 - Extra 'Tools' menuitem : Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - Reg Error: Key error. File not found
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.4.2_03)
O16 - DPF: {CAFEEFAC-0014-0002-0003-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.4.2_03)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 24.247.15.53 24.247.24.53 68.115.71.53
O20 - HKLM Winlogon: UIHost - (%windir%\XP ARENA.exe) - C:\WINDOWS\XP ARENA.EXE (Microsoft Corporation)
O20 - HKU\Mikey_ON_C Winlogon: Shell - (C:\Documents and Settings\Mikey\Application Data\hotfix.exe) - C:\Documents and Settings\Mikey\Application Data\hotfix.exe ()
O20 - Winlogon\Notify\igfxcui: DllName - igfxsrvc.dll - C:\WINDOWS\System32\igfxsrvc.dll (Intel Corporation)
O20 - Winlogon\Notify\ssqPGwwX: DllName - ssqPGwwX.dll - File not found
O22 - SharedTaskScheduler: {B6BA40C1-A501-59BD-F413-03B03A2C8952} - dfskea98e4iagjiufhg87df87u - C:\WINDOWS\System32\xeetnkw8sg.dll File not found
O24 - Desktop WallPaper: B:\Documents and Settings\Default User\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O24 - Desktop BackupWallPaper: B:\Documents and Settings\Default User\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O28 - HKLM ShellExecuteHooks: {81EA3F36-357A-435A-8741-52C27CCC9F21} - C:\WINDOWS\System32\ssqPGwwX.dll File not found
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2004/08/10 15:04:08 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O32 - AutoRun File - [2006/03/24 07:06:41 | 000,000,053 | R--- | M] () - X:\AUTORUN.INF -- [ CDFS ]
O36 - AppCertDlls: FSUTonui - (C:\WINDOWS\system32\magnyi64.dll) - C:\WINDOWS\SYSTEM32\magnyi64.dll ()
[2010/10/27 17:47:10 | 000,016,736 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\mucltui.dll.mui
[2010/10/27 17:47:09 | 000,274,288 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\mucltui.dll
[2010/10/27 15:33:04 | 000,000,000 | ---D | C] -- C:\WINDOWS\Minidump
[2010/10/27 15:31:44 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Application Data\Malwarebytes
[2010/10/27 15:31:24 | 000,038,224 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbamswissarmy.sys
[2010/10/27 15:31:21 | 000,020,952 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbam.sys
[2010/10/27 15:31:20 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Desktop\Malwarebytes' Anti-Malware
[2010/10/27 14:50:57 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jules\Local Settings\Application Data\{FD57B90C-AEA6-44E8-A343-C6A2E427491D}
[2010/10/27 14:50:39 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jules\My Documents\Recordpad
[2010/10/27 14:50:37 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jules\Application Data\Recordpad
[2010/10/27 14:50:15 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jules\Application Data\NCH Swift Sound
[2010/10/27 14:17:22 | 000,000,000 | ---D | C] -- C:\Documents and Settings\LocalService\Application Data\Adobe
[2010/10/27 14:16:58 | 000,000,000 | R--D | C] -- C:\Documents and Settings\LocalService\Favorites
[2010/10/27 14:12:28 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Local Settings\Application Data\{22BCE474-26A4-41D6-BC8F-CD0F4ECAC1E2}
[2010/10/27 14:08:43 | 000,307,200 | ---- | C] (CJSC Computing Forces) -- C:\WINDOWS\System32\sshnas21.dll
[2010/10/27 13:06:51 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\My Documents\Gygan Downloads
[2010/10/27 13:06:12 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Application Data\Gygan
[2010/10/27 13:06:00 | 000,000,000 | ---D | C] -- C:\Program Files\Xenocode
[2010/10/27 13:06:00 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Local Settings\Application Data\Xenocode
[2010/10/27 12:57:22 | 000,014,640 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\spmsg.dll
[2010/10/26 23:31:09 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Apple
[2010/10/24 19:42:13 | 000,000,000 | ---D | C] -- C:\Program Files\Veetle
[2010/10/24 02:05:19 | 000,000,000 | RH-D | C] -- C:\Documents and Settings\Mikey\Recent
[2010/10/24 00:38:27 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Local Settings\Application Data\Unity
[2010/10/23 17:15:47 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Local Settings\Application Data\Temp
[2010/10/23 17:15:40 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Local Settings\Application Data\Google
[2010/10/23 17:08:37 | 000,000,000 | --SD | C] -- C:\Documents and Settings\Mikey\UserData
[2010/10/22 22:45:23 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Application Data\Opera
[2010/10/22 18:25:22 | 000,000,000 | ---D | C] -- C:\Program Files\GoldWave
[2010/10/22 18:01:18 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Apple
[2010/10/22 18:01:11 | 000,000,000 | ---D | C] -- C:\Program Files\QuickTime
[2010/10/22 18:00:24 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Local Settings\Application Data\Apple
[2010/10/22 18:00:11 | 000,000,000 | ---D | C] -- C:\Program Files\Apple Software Update
[2010/10/22 17:59:59 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Local Settings\Application Data\Apple Computer
[2010/10/22 17:59:04 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\DigiDesign
[2010/10/22 17:59:03 | 000,000,000 | ---D | C] -- C:\Program Files\Steinberg
[2010/10/22 17:59:02 | 000,000,000 | ---D | C] -- C:\Program Files\IK Multimedia
[2010/10/22 17:58:36 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Application Data\InstallShield
[2010/10/20 23:58:47 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\My Documents\Recordpad
[2010/10/20 23:58:45 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Application Data\Recordpad
[2010/10/20 23:33:03 | 007,034,880 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\XP ARENA.EXE
[2010/10/20 19:35:36 | 000,000,000 | ---D | C] -- C:\Program Files\War2Combat
[2010/10/19 13:38:51 | 000,000,000 | ---D | C] -- C:\Program Files\NCH Software
[2010/10/19 13:37:55 | 000,000,000 | ---D | C] -- C:\Program Files\NCH Swift Sound
[2010/10/19 13:37:51 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Application Data\NCH Swift Sound
[2010/10/19 02:49:59 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Application Data\IObit
[2010/10/19 02:49:58 | 000,000,000 | ---D | C] -- C:\Program Files\IObit
[2010/10/19 02:14:48 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\Local Settings\Application Data\FriendBlasterPro
[2010/10/19 02:11:30 | 000,241,664 | ---- | C] (Namtuk.com) -- C:\WINDOWS\System32\MyFramePanel.ocx
[2010/10/19 02:11:27 | 000,609,824 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\ComCtl32.ocx
[2010/10/19 02:11:25 | 000,245,760 | ---- | C] (LansSoft Studio) -- C:\WINDOWS\System32\aUpdateNow.ocx
[2010/10/19 02:11:25 | 000,140,488 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\COMDLG32.OCX
[2010/10/19 02:11:25 | 000,132,880 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\msinet.ocx
[2010/10/19 02:11:24 | 001,081,616 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\MSCOMCTL.OCX
[2010/10/19 02:11:22 | 000,101,888 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\VB6STKIT.DLL
[2010/10/19 02:11:18 | 000,000,000 | ---D | C] -- C:\Program Files\FriendBlasterPro
[2010/10/17 14:42:07 | 000,000,000 | -HSD | C] -- C:\WINDOWS\ftpcache
[2010/10/17 11:28:17 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Sandlot Shared
[2010/10/14 05:18:33 | 000,000,000 | ---D | C] -- C:\Program Files\LucasArts
[2010/10/13 20:23:58 | 000,000,000 | ---D | C] -- C:\Program Files\Infogrames
[2010/10/13 20:13:54 | 000,000,000 | ---D | C] -- C:\Program Files\Infogrames Interactive
[2010/10/13 20:08:25 | 000,000,000 | ---D | C] -- C:\Program Files\GameHouse Games Collection
[2010/10/13 00:48:09 | 000,000,000 | ---D | C] -- C:\Program Files\Postal2
[2010/10/13 00:38:08 | 000,000,000 | ---D | C] -- C:\Program Files\Core Design
[2010/10/11 20:44:27 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Mikey\My Documents\EMULATORS
[2010/10/10 20:31:02 | 000,000,000 | ---D | C] -- C:\Program Files\Bethesda Softworks
[2010/10/07 18:40:29 | 000,000,000 | ---D | C] -- C:\Program Files\ElcomSoft
[7 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
[2 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
[1 C:\WINDOWS\System32\drivers\*.tmp files -> C:\WINDOWS\System32\drivers\*.tmp -> ]
[1 C:\*.tmp files -> C:\*.tmp -> ]
[2010/11/02 12:53:37 | 517,783,552 | ---- | M] () -- C:\REMOVE_THIS_FILE.livecd.swap
[2010/10/27 18:27:55 | 000,000,000 | ---- | M] () -- C:\WINDOWS\System32\drivers\myiqtsc.sys
[2010/10/27 18:27:44 | 000,000,282 | -H-- | M] () -- C:\WINDOWS\tasks\{22116563-108C-42c0-A7CE-60161B75E508}.job
[2010/10/27 18:27:28 | 000,000,282 | -H-- | M] () -- C:\WINDOWS\tasks\{BBAEAEAF-1275-40e2-BD6C-BC8F88BD114A}.job
[2010/10/27 18:27:25 | 000,000,246 | -H-- | M] () -- C:\WINDOWS\tasks\{35DC3473-A719-4d14-B7C1-FD326CA84A0C}.job
[2010/10/27 18:26:24 | 000,002,048 | --S- | M] () -- C:\WINDOWS\BOOTSTAT.DAT
[2010/10/27 18:26:21 | 266,407,936 | -HS- | M] () -- C:\hiberfil.sys
[2010/10/27 18:24:46 | 000,000,782 | ---- | M] () -- C:\Documents and Settings\Jules\Desktop\Windows Media Player.lnk
[2010/10/27 18:24:33 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At18.job
[2010/10/27 17:24:12 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At17.job
[2010/10/27 17:20:26 | 000,000,978 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-2069859330-2289683646-104145182-1008UA.job
[2010/10/27 17:20:25 | 000,000,926 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-2069859330-2289683646-104145182-1008Core.job
[2010/10/27 16:24:10 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At16.job
[2010/10/27 15:24:10 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At15.job
[2010/10/27 15:23:50 | 000,000,228 | ---- | M] () -- C:\Documents and Settings\Mikey\Desktop\shell.reg
[2010/10/27 14:24:11 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At14.job
[2010/10/27 14:21:39 | 000,000,006 | ---- | M] () -- C:\Documents and Settings\Mikey\Application Data\start
[2010/10/27 14:21:21 | 000,000,006 | ---- | M] () -- C:\Documents and Settings\Mikey\Application Data\completescan
[2010/10/27 14:13:12 | 000,000,013 | ---- | M] () -- C:\WINDOWS\popcinfo.dat
[2010/10/27 14:12:42 | 000,000,000 | ---- | M] () -- C:\WINDOWS\Ubobecahexofi.bin
[2010/10/27 14:12:40 | 000,000,120 | ---- | M] () -- C:\WINDOWS\Wwehikicilucipi.dat
[2010/10/27 14:12:39 | 000,000,849 | ---- | M] () -- C:\Documents and Settings\Mikey\Desktop\ThinkPoint.lnk
[2010/10/27 14:12:25 | 000,000,010 | ---- | M] () -- C:\Documents and Settings\Mikey\Application Data\install
[2010/10/27 14:11:36 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At23.job
[2010/10/27 14:11:36 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At22.job
[2010/10/27 14:11:36 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At21.job
[2010/10/27 14:11:36 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At20.job
[2010/10/27 14:11:28 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At19.job
[2010/10/27 14:10:39 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At9.job
[2010/10/27 14:10:39 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At8.job
[2010/10/27 14:10:39 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At13.job
[2010/10/27 14:10:39 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At12.job
[2010/10/27 14:10:39 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At11.job
[2010/10/27 14:10:39 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At10.job
[2010/10/27 14:10:30 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At7.job
[2010/10/27 14:10:30 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At6.job
[2010/10/27 14:10:30 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At5.job
[2010/10/27 14:10:30 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At4.job
[2010/10/27 14:10:08 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At3.job
[2010/10/27 14:10:00 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At2.job
[2010/10/27 14:10:00 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\At1.job
[2010/10/27 14:09:32 | 000,525,824 | ---- | M] () -- C:\Documents and Settings\Mikey\Application Data\hotfix.exe
[2010/10/27 14:09:03 | 000,030,000 | ---- | M] () -- C:\WINDOWS\System32\zh0ycwd.dll
[2010/10/27 14:08:44 | 000,307,200 | ---- | M] (CJSC Computing Forces) -- C:\WINDOWS\System32\sshnas21.dll
[2010/10/27 14:08:43 | 000,053,248 | -H-- | M] () -- C:\WINDOWS\System32\magnyi64.dll
[2010/10/27 13:04:16 | 000,000,800 | ---- | M] () -- C:\Documents and Settings\Mikey\Application Data\Microsoft\Internet Explorer\Quick Launch\Windows Media Player.lnk
[2010/10/27 13:04:16 | 000,000,782 | ---- | M] () -- C:\Documents and Settings\Mikey\Desktop\Windows Media Player.lnk
[2010/10/27 12:57:08 | 000,001,393 | ---- | M] () -- C:\WINDOWS\imsins.BAK
[2010/10/27 12:56:51 | 000,023,392 | ---- | M] () -- C:\WINDOWS\System32\nscompat.tlb
[2010/10/27 12:56:51 | 000,016,832 | ---- | M] () -- C:\WINDOWS\System32\amcompat.tlb
[2010/10/27 12:52:34 | 000,002,206 | ---- | M] () -- C:\WINDOWS\System32\WPA.DBL
[2010/10/26 23:31:12 | 000,000,284 | ---- | M] () -- C:\WINDOWS\tasks\AppleSoftwareUpdate.job
[2010/10/26 22:29:40 | 000,053,454 | ---- | M] () -- C:\Documents and Settings\Mikey\Application Data\Game Setup.exe
[2010/10/25 22:39:36 | 000,235,960 | ---- | M] () -- C:\WINDOWS\System32\FNTCACHE.DAT
[2010/10/25 17:55:05 | 000,000,282 | ---- | M] () -- C:\WINDOWS\tasks\wavepadShakeIcon.job
[2010/10/23 17:19:37 | 000,002,284 | ---- | M] () -- C:\Documents and Settings\Mikey\Desktop\Google Chrome.lnk
[2010/10/23 17:19:37 | 000,002,262 | ---- | M] () -- C:\Documents and Settings\Mikey\Application Data\Microsoft\Internet Explorer\Quick Launch\Google Chrome.lnk
[2010/10/22 23:59:58 | 000,014,336 | ---- | M] () -- C:\Documents and Settings\Mikey\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2010/10/22 18:05:35 | 000,000,016 | ---- | M] () -- C:\WINDOWS\System32\w3data.vss
[2010/10/22 18:05:35 | 000,000,016 | ---- | M] () -- C:\WINDOWS\System32\msvcsv60.dll
[2010/10/22 18:05:35 | 000,000,016 | ---- | M] () -- C:\WINDOWS\msocreg32.dat
[2010/10/22 18:02:24 | 000,001,802 | ---- | M] () -- C:\Documents and Settings\Mikey\Application Data\Microsoft\Internet Explorer\Quick Launch\QuickTime Player.lnk
[2010/10/22 16:41:07 | 000,054,156 | -H-- | M] () -- C:\WINDOWS\QTFont.qfn
[2010/10/22 15:01:00 | 000,000,278 | ---- | M] () -- C:\WINDOWS\tasks\switchShakeIcon.job
[2010/10/20 19:35:41 | 000,001,668 | ---- | M] () -- C:\Documents and Settings\Mikey\Desktop\War2Combat.lnk
[2010/10/19 02:50:02 | 000,000,755 | ---- | M] () -- C:\Documents and Settings\Mikey\Application Data\Microsoft\Internet Explorer\Quick Launch\Game Booster.lnk
[2010/10/19 02:50:02 | 000,000,146 | ---- | M] () -- C:\Documents and Settings\Mikey\Desktop\IObit Freeware.url
[2010/10/19 02:23:34 | 000,402,406 | ---- | M] () -- C:\WINDOWS\System32\PERFH009.DAT
[2010/10/19 02:23:34 | 000,063,016 | ---- | M] () -- C:\WINDOWS\System32\PERFC009.DAT
[2010/10/15 06:12:39 | 000,001,409 | ---- | M] () -- C:\WINDOWS\QTFont.for
[2010/10/13 20:19:48 | 000,000,792 | ---- | M] () -- C:\Documents and Settings\Mikey\My Documents\Games Collection.lnk
[2010/10/13 20:14:59 | 000,000,000 | ---- | M] () -- C:\WINDOWS\PowerReg.dat
[2010/10/11 20:50:02 | 000,000,407 | ---- | M] () -- C:\Documents and Settings\Mikey\My Documents\EMULATORS.lnk
[2010/10/09 20:22:27 | 000,000,025 | ---- | M] () -- C:\WINDOWS\popcinfot.dat
[2010/10/27 19:13:48 | 517,783,552 | ---- | C] () -- C:\REMOVE_THIS_FILE.livecd.swap
[2010/10/27 15:23:49 | 000,000,228 | ---- | C] () -- C:\Documents and Settings\Mikey\Desktop\shell.reg
[2010/10/27 14:21:39 | 000,000,006 | ---- | C] () -- C:\Documents and Settings\Mikey\Application Data\start
[2010/10/27 14:17:02 | 000,000,006 | ---- | C] () -- C:\Documents and Settings\Mikey\Application Data\completescan
[2010/10/27 14:12:42 | 000,000,000 | ---- | C] () -- C:\WINDOWS\Ubobecahexofi.bin
[2010/10/27 14:12:40 | 000,000,120 | ---- | C] () -- C:\WINDOWS\Wwehikicilucipi.dat
[2010/10/27 14:12:33 | 000,000,849 | ---- | C] () -- C:\Documents and Settings\Mikey\Desktop\ThinkPoint.lnk
[2010/10/27 14:12:25 | 000,000,010 | ---- | C] () -- C:\Documents and Settings\Mikey\Application Data\install
[2010/10/27 14:11:31 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At23.job
[2010/10/27 14:11:30 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At22.job
[2010/10/27 14:11:30 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At21.job
[2010/10/27 14:11:26 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At20.job
[2010/10/27 14:11:23 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At19.job
[2010/10/27 14:11:08 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At18.job
[2010/10/27 14:11:04 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At17.job
[2010/10/27 14:10:49 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At16.job
[2010/10/27 14:10:48 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At15.job
[2010/10/27 14:10:44 | 000,000,000 | ---- | C] () -- C:\WINDOWS\System32\drivers\myiqtsc.sys
[2010/10/27 14:10:42 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At14.job
[2010/10/27 14:10:37 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At13.job
[2010/10/27 14:10:35 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At12.job
[2010/10/27 14:10:35 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At11.job
[2010/10/27 14:10:34 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At10.job
[2010/10/27 14:10:32 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At9.job
[2010/10/27 14:10:28 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At8.job
[2010/10/27 14:10:27 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At7.job
[2010/10/27 14:10:25 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At6.job
[2010/10/27 14:10:12 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At5.job
[2010/10/27 14:10:08 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At4.job
[2010/10/27 14:10:01 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At3.job
[2010/10/27 14:09:58 | 000,000,282 | -H-- | C] () -- C:\WINDOWS\tasks\{BBAEAEAF-1275-40e2-BD6C-BC8F88BD114A}.job
[2010/10/27 14:09:55 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At2.job
[2010/10/27 14:09:53 | 000,000,404 | ---- | C] () -- C:\WINDOWS\tasks\At1.job
[2010/10/27 14:09:47 | 000,000,282 | -H-- | C] () -- C:\WINDOWS\tasks\{22116563-108C-42c0-A7CE-60161B75E508}.job
[2010/10/27 14:09:41 | 000,000,246 | -H-- | C] () -- C:\WINDOWS\tasks\{35DC3473-A719-4d14-B7C1-FD326CA84A0C}.job
[2010/10/27 14:09:31 | 000,525,824 | ---- | C] () -- C:\Documents and Settings\Mikey\Application Data\hotfix.exe
[2010/10/27 14:09:03 | 000,030,000 | ---- | C] () -- C:\WINDOWS\System32\zh0ycwd.dll
[2010/10/27 14:08:43 | 000,053,248 | -H-- | C] () -- C:\WINDOWS\System32\magnyi64.dll
[2010/10/27 13:04:16 | 000,000,800 | ---- | C] () -- C:\Documents and Settings\Mikey\Application Data\Microsoft\Internet Explorer\Quick Launch\Windows Media Player.lnk
[2010/10/27 12:55:56 | 000,023,392 | ---- | C] () -- C:\WINDOWS\System32\nscompat.tlb
[2010/10/27 12:55:56 | 000,016,832 | ---- | C] () -- C:\WINDOWS\System32\amcompat.tlb
[2010/10/27 12:51:23 | 000,000,782 | ---- | C] () -- C:\Documents and Settings\Mikey\Desktop\Windows Media Player.lnk
[2010/10/26 22:29:40 | 000,053,454 | ---- | C] () -- C:\Documents and Settings\Mikey\Application Data\Game Setup.exe
[2010/10/23 17:19:37 | 000,002,284 | ---- | C] () -- C:\Documents and Settings\Mikey\Desktop\Google Chrome.lnk
[2010/10/23 17:19:37 | 000,002,262 | ---- | C] () -- C:\Documents and Settings\Mikey\Application Data\Microsoft\Internet Explorer\Quick Launch\Google Chrome.lnk
[2010/10/23 17:15:45 | 000,000,978 | ---- | C] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-2069859330-2289683646-104145182-1008UA.job
[2010/10/23 17:15:43 | 000,000,926 | ---- | C] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-2069859330-2289683646-104145182-1008Core.job
[2010/10/22 18:05:32 | 000,000,016 | ---- | C] () -- C:\WINDOWS\System32\w3data.vss
[2010/10/22 18:05:32 | 000,000,016 | ---- | C] () -- C:\WINDOWS\System32\msvcsv60.dll
[2010/10/22 18:05:32 | 000,000,016 | ---- | C] () -- C:\WINDOWS\msocreg32.dat
[2010/10/22 18:02:24 | 000,001,802 | ---- | C] () -- C:\Documents and Settings\Mikey\Application Data\Microsoft\Internet Explorer\Quick Launch\QuickTime Player.lnk
[2010/10/22 18:00:25 | 000,000,284 | ---- | C] () -- C:\WINDOWS\tasks\AppleSoftwareUpdate.job
[2010/10/22 17:55:53 | 000,000,282 | ---- | C] () -- C:\WINDOWS\tasks\wavepadShakeIcon.job
[2010/10/20 19:35:41 | 000,001,668 | ---- | C] () -- C:\Documents and Settings\Mikey\Desktop\War2Combat.lnk
[2010/10/19 15:01:58 | 000,000,278 | ---- | C] () -- C:\WINDOWS\tasks\switchShakeIcon.job
[2010/10/19 02:50:02 | 000,000,755 | ---- | C] () -- C:\Documents and Settings\Mikey\Application Data\Microsoft\Internet Explorer\Quick Launch\Game Booster.lnk
[2010/10/19 02:50:02 | 000,000,146 | ---- | C] () -- C:\Documents and Settings\Mikey\Desktop\IObit Freeware.url
[2010/10/15 06:12:39 | 000,054,156 | -H-- | C] () -- C:\WINDOWS\QTFont.qfn
[2010/10/15 06:12:39 | 000,001,409 | ---- | C] () -- C:\WINDOWS\QTFont.for
[2010/10/13 20:19:48 | 000,000,792 | ---- | C] () -- C:\Documents and Settings\Mikey\My Documents\Games Collection.lnk
[2010/10/13 20:14:59 | 000,000,000 | ---- | C] () -- C:\WINDOWS\PowerReg.dat
[2010/10/12 22:22:58 | 000,000,013 | ---- | C] () -- C:\WINDOWS\popcinfo.dat
[2010/10/11 20:50:02 | 000,000,407 | ---- | C] () -- C:\Documents and Settings\Mikey\My Documents\EMULATORS.lnk
[2010/09/28 02:57:12 | 000,000,751 | ---- | C] () -- C:\WINDOWS\Rtcwplat.INI
[2010/09/28 00:16:16 | 000,000,561 | ---- | C] () -- C:\Documents and Settings\Mikey\BnetLog.txt
[2010/09/21 22:05:02 | 000,000,002 | ---- | C] () -- C:\WINDOWS\msoffice.ini
[2010/09/21 13:38:24 | 000,014,336 | ---- | C] () -- C:\Documents and Settings\Mikey\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2005/04/30 16:36:27 | 000,061,678 | ---- | C] () -- C:\Documents and Settings\Jules\Application Data\PFP120JPR.{PB
[2005/04/30 16:36:27 | 000,012,358 | ---- | C] () -- C:\Documents and Settings\Jules\Application Data\PFP120JCM.{PB
[2005/04/17 18:53:39 | 000,035,328 | ---- | C] () -- C:\Documents and Settings\Jules\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2005/04/13 17:30:19 | 000,000,034 | ---- | C] () -- C:\WINDOWS\AuthMgr.INI
[2004/12/20 01:42:22 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
[2004/12/20 00:56:12 | 000,000,520 | ---- | C] () -- C:\WINDOWS\System32\OEMINFO.INI
[2004/08/10 15:13:12 | 000,000,780 | ---- | C] () -- C:\WINDOWS\ORUN32.INI
[2004/08/10 15:03:52 | 000,004,161 | ---- | C] () -- C:\WINDOWS\ODBCINST.INI
[2004/08/04 07:00:00 | 000,206,848 | ---- | C] () -- C:\WINDOWS\ogudenenor.dll
[2004/08/04 07:00:00 | 000,081,408 | ---- | C] () -- C:\WINDOWS\werowp.dll
[2004/08/04 07:00:00 | 000,001,793 | ---- | C] () -- C:\WINDOWS\System32\FXSPERF.INI
[2002/03/13 16:46:46 | 000,053,248 | R--- | C] () -- C:\WINDOWS\System32\zlib.dll
JulieMomster
Post by JulieMomster on Thu 04 Nov 2010, 9:50 am
CON'T:
[2005/04/13 19:26:26 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jules\Application Data\Aim
[2005/04/12 18:11:53 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jules\Application Data\Earthlink
[2005/04/13 17:35:43 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jules\Application Data\EarthLink Toolbar
[2010/10/27 14:50:15 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jules\Application Data\NCH Swift Sound
[2010/10/27 14:50:37 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jules\Application Data\Recordpad
[2010/10/27 15:11:38 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jules\Application Data\uTorrent
[2010/09/27 20:34:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mikey\Application Data\DAEMON Tools Lite
[2010/09/13 12:55:26 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mikey\Application Data\EarthLink Toolbar
[2010/10/27 14:30:03 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mikey\Application Data\Gygan
[2010/09/28 19:27:49 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mikey\Application Data\HD Tune Pro
[2010/10/19 02:49:59 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mikey\Application Data\IObit
[2010/10/22 17:42:05 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mikey\Application Data\NCH Swift Sound
[2010/10/22 22:45:23 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mikey\Application Data\Opera
[2010/10/20 23:58:45 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mikey\Application Data\Recordpad
[2010/10/27 14:11:02 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Mikey\Application Data\uTorrent
[2010/10/27 14:10:00 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At1.job
[2010/10/27 14:10:39 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At10.job
[2010/10/27 14:10:39 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At11.job
[2010/10/27 14:10:39 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At12.job
[2010/10/27 14:10:39 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At13.job
[2010/10/27 14:24:11 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At14.job
[2010/10/27 15:24:10 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At15.job
[2010/10/27 16:24:10 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At16.job
[2010/10/27 17:24:12 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At17.job
[2010/10/27 18:24:33 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At18.job
[2010/10/27 14:11:28 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At19.job
[2010/10/27 14:10:00 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At2.job
[2010/10/27 14:11:36 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At20.job
[2010/10/27 14:11:36 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At21.job
[2010/10/27 14:11:36 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At22.job
[2010/10/27 14:11:36 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At23.job
[2010/10/27 14:10:08 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At3.job
[2010/10/27 14:10:30 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At4.job
[2010/10/27 14:10:30 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At5.job
[2010/10/27 14:10:30 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At6.job
[2010/10/27 14:10:30 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At7.job
[2010/10/27 14:10:39 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At8.job
[2010/10/27 14:10:39 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\At9.job
[2010/10/22 15:01:00 | 000,000,278 | ---- | M] () -- C:\WINDOWS\Tasks\switchShakeIcon.job
[2010/10/25 17:55:05 | 000,000,282 | ---- | M] () -- C:\WINDOWS\Tasks\wavepadShakeIcon.job
[2010/10/27 18:27:44 | 000,000,282 | -H-- | M] () -- C:\WINDOWS\Tasks\{22116563-108C-42c0-A7CE-60161B75E508}.job
[2010/10/27 18:27:25 | 000,000,246 | -H-- | M] () -- C:\WINDOWS\Tasks\{35DC3473-A719-4d14-B7C1-FD326CA84A0C}.job
[2010/10/27 18:27:28 | 000,000,282 | -H-- | M] () -- C:\WINDOWS\Tasks\{BBAEAEAF-1275-40e2-BD6C-BC8F88BD114A}.job
JulieMomster
Operating System : windows XP
Re: Serious Help Needed in regards to Think Point Virus Removal!
Post by JulieMomster on Thu 04 Nov 2010, 12:10 pm
What do I do now? I tried running my hard drive in safe mode, but it still went to the blank screen.
JulieMomster
Post by Sneakyone on Thu 04 Nov 2010, 2:52 pm
This machine is severely infected chances of cleaning it are slim if OTL freezes.
Please run OTL.exe.
    :OTL
    :Files
    C:\WINDOWS\tasks\At*.job
    :commands
    [emptytemp]
    [resethosts]
    [purity]
  • Close OTL.exe
If a file or folder cannot be moved immediately you may be asked to reboot the machine to finish the move process. If you are asked to reboot the machine choose Yes.=
Please download ComboFix from BleepingComputer.com
Alternate link: GeeksToGo.com
Alternate link: Forospyware.com
Sneakyone
Tech Officer
Tech Officer
Post by JulieMomster on Fri 05 Nov 2010, 10:08 am
OTL Report:
========== OTL ==========
Registry key HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\SSHNAS deleted successfully.
C:\WINDOWS\SYSTEM32\sshnas21.dll moved successfully.
Registry key HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\myiqtsc deleted successfully.
C:\WINDOWS\SYSTEM32\DRIVERS\myiqtsc.sys moved successfully.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{81EA3F36-357A-435A-8741-52C27CCC9F21}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{81EA3F36-357A-435A-8741-52C27CCC9F21}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{B6BA40C1-A501-59BD-F413-03B03A2C8952}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{B6BA40C1-A501-59BD-F413-03B03A2C8952}\ deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\{BA52B914-B692-46c4-B683-905236F6F655} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{BA52B914-B692-46c4-B683-905236F6F655}\ not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXn0Z deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnb deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnd deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXneP deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnf deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnfQ deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXngP deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnoc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnqe deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnqg deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnrc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnsb deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnsd deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnsf deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXntg deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnth deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnUf deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnusc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnvc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnvZ deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnwe deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnwg deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnwpc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnxb deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnxc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnY deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnz9 deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnd deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXneP deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnfQ deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnsd deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXntg deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnvZ deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnwg deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnxb deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnz9 deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnZP deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\KernelFaultCheck deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKaoc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKasc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKayc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKaZ deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKbMc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKbta deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKbtc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKbuqc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKcZ deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKee deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKeg deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKeta deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKetc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKeuf deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\ not found.
File MKeufdtop.info&p=R0lGODlhyAA8APcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/ not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKevc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKexe deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKfa deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKfPc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKfre deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKfsc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKWPtg deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKZe deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MKZSc deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\Tpinudepiguyoru deleted successfully.
C:\WINDOWS\ogudenenor.dll moved successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\uPc+MV0NbtaGuo deleted successfully.
C:\WINDOWS\SYSTEM32\zh0ycwd.dll moved successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXn0Z deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnb deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXneP deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnfQ deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXngP deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnqe deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnqg deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnrc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnsb deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnsf deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXntg deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnUf deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnusc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnvc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnvZ deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnwe deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnwg deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnxc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnz9 deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnd deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXneP deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnfQ deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnsd deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXntg deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnvZ deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnwg deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnxb deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnz9 deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnZP deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKaoc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKasc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKayc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKbMc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKbta deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKbtc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKcZ deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKee deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKeg deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKeta deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKetc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKeuf deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKevc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKexe deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKfPc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKfre deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKfsc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKWPtg deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKZe deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKZSc deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\uPc+MV0NbtaGuo deleted successfully.
File C:\WINDOWS\System32\zh0ycwd.DLL not found.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXn0Z deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnb deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnd deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXneP deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnf deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnfQ deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXngP deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnqe deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnqg deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnrc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnsb deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnsf deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXntg deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnth deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnUf deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnusc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnvc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnvZ deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnwe deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnwg deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnwpc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnxc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUhcIXnz9 deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnd deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXneP deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnfQ deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnsd deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXntg deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnvZ deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnwg deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnxb deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnz9 deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\HNUkaIXnZP deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKaoc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKasc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKayc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKbMc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKbta deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKbtc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKcZ deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKee deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKeg deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKeta deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKetc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKeuf deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKevc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKexe deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKfPc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKfre deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKfsc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKWPtg deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKZe deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\MKZSc deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\Snosesicogoto deleted successfully.
C:\WINDOWS\werowp.dll moved successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\U36VRSFLG6 deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\uPc+MV0NbtaGuo deleted successfully.
Registry key HKEY_USERS\.DEFAULT\Software\Policies\Microsoft\Internet Explorer\Control Panel\ not found.
Registry key HKEY_USERS\Jules_ON_C\Software\Policies\Microsoft\Internet Explorer\Control Panel\ deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\\NoFolderOptions deleted successfully.
Registry value HKEY_USERS\Jules_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\\DisableRegistryTools deleted successfully.
Registry key HKEY_USERS\LocalService_ON_C\Software\Policies\Microsoft\Internet Explorer\Control Panel\ not found.
Registry key HKEY_USERS\Mikey_ON_C\Software\Policies\Microsoft\Internet Explorer\Control Panel\ not found.
Registry value HKEY_USERS\Mikey_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\\NoFolderOptions deleted successfully.
Registry value HKEY_USERS\Mikey_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System\\DisableRegistryTools deleted successfully.
Registry key HKEY_USERS\NetworkService_ON_C\Software\Policies\Microsoft\Internet Explorer\Control Panel\ not found.
Registry key HKEY_USERS\systemprofile_ON_C\Software\Policies\Microsoft\Internet Explorer\Control Panel\ not found.
HKEY_LOCAL_MACHINE\System\ControlSet001\Services\Tcpip\Parameters\\DhcpNameServer| /E : value set successfully!
Registry value HKEY_USERS\Mikey_ON_C\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\\Shell:C:\Documents and Settings\Mikey\Application Data\hotfix.exe deleted successfully.
C:\Documents and Settings\Mikey\Application Data\hotfix.exe moved successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\ssqPGwwX\ deleted successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler\\{B6BA40C1-A501-59BD-F413-03B03A2C8952} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{B6BA40C1-A501-59BD-F413-03B03A2C8952}\ not found.
Registry value HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Session Manager\AppCertDlls\\FSUTonui:C:\WINDOWS\system32\magnyi64.dll deleted successfully.
C:\WINDOWS\SYSTEM32\magnyi64.dll moved successfully.
C:\WINDOWS\tasks\{22116563-108C-42c0-A7CE-60161B75E508}.job moved successfully.
C:\WINDOWS\tasks\{BBAEAEAF-1275-40e2-BD6C-BC8F88BD114A}.job moved successfully.
C:\WINDOWS\tasks\{35DC3473-A719-4d14-B7C1-FD326CA84A0C}.job moved successfully.
C:\Documents and Settings\Mikey\Desktop\shell.reg moved successfully.
C:\Documents and Settings\Mikey\Application Data\start moved successfully.
C:\Documents and Settings\Mikey\Application Data\completescan moved successfully.
C:\WINDOWS\popcinfo.dat moved successfully.
C:\WINDOWS\Ubobecahexofi.bin moved successfully.
C:\WINDOWS\Wwehikicilucipi.dat moved successfully.
C:\Documents and Settings\Mikey\Desktop\ThinkPoint.lnk moved successfully.
C:\Documents and Settings\Mikey\Application Data\install moved successfully.
File C:\Documents and Settings\Mikey\Application Data\hotfix.exe not found.
File C:\WINDOWS\System32\zh0ycwd.dll not found.
File C:\WINDOWS\System32\sshnas21.dll not found.
File C:\WINDOWS\System32\magnyi64.dll not found.
========== FILES ==========
C:\WINDOWS\tasks\At1.job moved successfully.
C:\WINDOWS\tasks\At10.job moved successfully.
C:\WINDOWS\tasks\At11.job moved successfully.
C:\WINDOWS\tasks\At12.job moved successfully.
C:\WINDOWS\tasks\At13.job moved successfully.
C:\WINDOWS\tasks\At14.job moved successfully.
C:\WINDOWS\tasks\At15.job moved successfully.
C:\WINDOWS\tasks\At16.job moved successfully.
C:\WINDOWS\tasks\At17.job moved successfully.
C:\WINDOWS\tasks\At18.job moved successfully.
C:\WINDOWS\tasks\At19.job moved successfully.
C:\WINDOWS\tasks\At2.job moved successfully.
C:\WINDOWS\tasks\At20.job moved successfully.
C:\WINDOWS\tasks\At21.job moved successfully.
C:\WINDOWS\tasks\At22.job moved successfully.
C:\WINDOWS\tasks\At23.job moved successfully.
C:\WINDOWS\tasks\At3.job moved successfully.
C:\WINDOWS\tasks\At4.job moved successfully.
C:\WINDOWS\tasks\At5.job moved successfully.
C:\WINDOWS\tasks\At6.job moved successfully.
C:\WINDOWS\tasks\At7.job moved successfully.
C:\WINDOWS\tasks\At8.job moved successfully.
C:\WINDOWS\tasks\At9.job moved successfully.
[EMPTYTEMP]
User: All Users
User: Default User
->Temporary Internet Files folder emptied: 32768 bytes
User: Jules
->Temp folder emptied: 614986831 bytes
->Temporary Internet Files folder emptied: 2431511 bytes
->FireFox cache emptied: 93617972 bytes
->Flash cache emptied: 47235 bytes
User: LocalService
->Temp folder emptied: 65984 bytes
->Temporary Internet Files folder emptied: 180162 bytes
User: Mikey
->Temp folder emptied: 182500386 bytes
->Temporary Internet Files folder emptied: 49713342 bytes
->FireFox cache emptied: 43919867 bytes
->Google Chrome cache emptied: 56915911 bytes
->Flash cache emptied: 8359 bytes
User: NetworkService
->Temporary Internet Files folder emptied: 554332 bytes
%systemdrive% .tmp files removed: 6597 bytes
%systemroot% .tmp files removed: 19569 bytes
%systemroot%\System32 .tmp files removed: 1940497 bytes
Windows Temp folder emptied: 2612102 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 0 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 34318 bytes
Total Files Cleaned = 1,001.00 mb
C:\WINDOWS\System32\drivers\etc\Hosts moved successfully.
HOSTS file reset successfully
OTLPE by OldTimer - Version 3.1.43.0 log created on 11042010_214353
JulieMomster
Post by JulieMomster on Fri 05 Nov 2010, 10:09 am
ComboFix Report:
ComboFix 10-11-03.04 - Jules 11/04/2010 22:14:44.1.1 - x86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.254.98 [GMT -4:00]
Running from: c:\documents and settings\Mikey\My Documents\Downloads\ComboFix.exe
( Other Deletions )
c:\documents and settings\All Users\Application Data\Update\seupd.exe
c:\documents and settings\Jules\Local Settings\Application Data\{FD57B90C-AEA6-44E8-A343-C6A2E427491D}
c:\documents and settings\Jules\Local Settings\Application Data\{FD57B90C-AEA6-44E8-A343-C6A2E427491D}\chrome.manifest
c:\documents and settings\Jules\Local Settings\Application Data\{FD57B90C-AEA6-44E8-A343-C6A2E427491D}\chrome\content\_cfg.js
c:\documents and settings\Jules\Local Settings\Application Data\{FD57B90C-AEA6-44E8-A343-C6A2E427491D}\chrome\content\overlay.xul
c:\documents and settings\Jules\Local Settings\Application Data\{FD57B90C-AEA6-44E8-A343-C6A2E427491D}\install.rdf
c:\documents and settings\Mikey\Application Data\Game Setup.exe
c:\documents and settings\Mikey\Local Settings\Application Data\{22BCE474-26A4-41D6-BC8F-CD0F4ECAC1E2}
c:\documents and settings\Mikey\Local Settings\Application Data\{22BCE474-26A4-41D6-BC8F-CD0F4ECAC1E2}\chrome.manifest
c:\documents and settings\Mikey\Local Settings\Application Data\{22BCE474-26A4-41D6-BC8F-CD0F4ECAC1E2}\chrome\content\_cfg.js
c:\documents and settings\Mikey\Local Settings\Application Data\{22BCE474-26A4-41D6-BC8F-CD0F4ECAC1E2}\chrome\content\overlay.xul
c:\documents and settings\Mikey\Local Settings\Application Data\{22BCE474-26A4-41D6-BC8F-CD0F4ECAC1E2}\install.rdf
c:\program files\Mozilla Firefox\searchplugins\google_search.xml
c:\windows\system32\msvcsv60.dll
((((((((((((((((((((((((( Files Created from 2010-10-05 to 2010-11-05 )))))))))))))))))))))))))))))))
2010-11-05 01:56 . 2010-11-05 01:56 -------- d-----w- c:\windows\LastGood
2010-11-05 01:44 . 2010-10-23 17:55 553984 ----a-r- C:\OTLPE.exe
2010-11-05 01:43 . 2010-11-05 01:43 -------- d-----w- C:\_OTL
2010-10-27 21:47 . 2009-08-06 23:23 215920 ----a-w- c:\windows\system32\muweb.dll
2010-10-27 21:47 . 2009-08-06 23:23 274288 ----a-w- c:\windows\system32\mucltui.dll
2010-10-27 19:31 . 2010-10-27 19:31 -------- d-----w- c:\documents and settings\Mikey\Application Data\Malwarebytes
2010-10-27 19:31 . 2010-04-29 19:39 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2010-10-27 19:31 . 2010-10-27 19:31 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2010-10-27 19:31 . 2010-04-29 19:39 20952 ----a-w- c:\windows\system32\drivers\mbam.sys
2010-10-27 18:50 . 2010-10-27 18:50 -------- d-----w- c:\documents and settings\Jules\Application Data\Recordpad
2010-10-27 18:50 . 2010-10-27 18:50 -------- d-----w- c:\documents and settings\Jules\Application Data\NCH Swift Sound
2010-10-27 18:08 . 2010-11-05 02:22 -------- d-----w- c:\documents and settings\All Users\Application Data\Update
2010-10-27 17:06 . 2010-10-27 18:30 -------- d-----w- c:\documents and settings\Mikey\Application Data\Gygan
2010-10-27 17:06 . 2010-10-27 17:06 -------- d-----w- c:\program files\Xenocode
2010-10-27 17:06 . 2010-10-27 17:06 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\Xenocode
2010-10-27 03:31 . 2010-10-27 03:31 -------- d-----w- c:\documents and settings\NetworkService\Local Settings\Application Data\Apple
2010-10-24 23:42 . 2010-10-24 23:42 -------- d-----w- c:\program files\Veetle
2010-10-24 04:38 . 2010-10-24 04:38 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\Unity
2010-10-23 21:15 . 2010-10-23 21:16 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\Temp
2010-10-23 21:15 . 2010-10-23 21:18 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\Google
2010-10-23 21:08 . 2010-10-23 21:08 -------- d-s---w- c:\documents and settings\Mikey\UserData
2010-10-22 22:32 . 2010-10-22 22:32 -------- d-----w- c:\documents and settings\All Users\Application Data\GoldWave
2010-10-22 22:25 . 2010-10-22 22:25 -------- d-----w- c:\program files\GoldWave
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Internet Explorer\PLUGINS\npqtplugin7.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin7.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin6.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin5.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin4.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin3.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin2.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin.dll
2010-10-22 22:01 . 2010-10-22 22:01 -------- d-----w- c:\program files\Common Files\Apple
2010-10-22 22:01 . 2010-10-22 22:02 -------- d-----w- c:\program files\QuickTime
2010-10-22 22:01 . 2010-10-22 22:01 -------- d-----w- c:\documents and settings\All Users\Application Data\Apple Computer
2010-10-22 22:00 . 2010-10-22 22:00 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\Apple
2010-10-22 22:00 . 2010-10-22 22:00 -------- d-----w- c:\program files\Apple Software Update
2010-10-22 22:00 . 2010-10-22 22:00 -------- d-----w- c:\documents and settings\All Users\Application Data\Apple
2010-10-22 21:59 . 2010-10-22 21:59 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\Apple Computer
2010-10-22 21:59 . 2010-10-22 21:59 -------- d-----w- c:\program files\Common Files\DigiDesign
2010-10-22 21:59 . 2010-10-22 21:59 -------- d-----w- c:\program files\Steinberg
2010-10-22 21:59 . 2010-10-22 21:59 -------- d-----w- c:\program files\IK Multimedia
2010-10-22 21:58 . 2010-10-22 21:58 -------- d-----w- c:\documents and settings\Mikey\Application Data\InstallShield
2010-10-21 03:58 . 2010-10-21 03:58 -------- d-----w- c:\documents and settings\Mikey\Application Data\Recordpad
2010-10-21 03:33 . 2010-02-16 17:04 7034880 ----a-w- c:\windows\XP ARENA.EXE
2010-10-20 23:35 . 2010-10-22 19:53 -------- d-----w- c:\program files\War2Combat
2010-10-19 17:38 . 2010-10-19 17:38 -------- d-----w- c:\program files\NCH Software
2010-10-19 17:38 . 2010-10-22 21:42 -------- d-----w- c:\documents and settings\All Users\Application Data\NCH Swift Sound
2010-10-19 17:37 . 2010-10-19 17:38 -------- d-----w- c:\program files\NCH Swift Sound
2010-10-19 17:37 . 2010-10-22 21:42 -------- d-----w- c:\documents and settings\Mikey\Application Data\NCH Swift Sound
2010-10-19 06:49 . 2010-10-19 06:49 -------- d-----w- c:\documents and settings\Mikey\Application Data\IObit
2010-10-19 06:49 . 2010-10-19 06:49 -------- d-----w- c:\program files\IObit
2010-10-19 06:14 . 2010-10-19 06:15 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\FriendBlasterPro
2010-10-19 06:11 . 2005-10-11 17:25 241664 ----a-w- c:\windows\system32\MyFramePanel.ocx
2010-10-19 06:11 . 2004-03-09 00:30 609824 ----a-w- c:\windows\system32\ComCtl32.ocx
2010-10-19 06:11 . 2005-07-15 16:49 245760 ----a-w- c:\windows\system32\aUpdateNow.ocx
2010-10-19 06:11 . 2004-03-08 22:00 132880 ----a-w- c:\windows\system32\msinet.ocx
2010-10-19 06:11 . 2000-05-22 04:00 140488 ----a-w- c:\windows\system32\COMDLG32.OCX
2010-10-19 06:11 . 2004-03-08 22:00 1081616 ----a-w- c:\windows\system32\MSCOMCTL.OCX
2010-10-19 06:11 . 2000-07-15 04:00 101888 ----a-w- c:\windows\system32\VB6STKIT.DLL
2010-10-19 06:11 . 2010-10-19 06:18 -------- d-----w- c:\program files\FriendBlasterPro
2010-10-17 18:42 . 2010-10-17 18:42 -------- d-sh--w- c:\windows\ftpcache
2010-10-17 15:28 . 2010-10-28 11:28 -------- d-----w- c:\program files\Common Files\Sandlot Shared
2010-10-17 15:28 . 2010-10-17 15:28 -------- d-----w- c:\documents and settings\All Users\Application Data\Sandlot Games
2010-10-15 10:12 . 2010-10-15 10:12 1409 ----a-w- c:\windows\QTFont.for
2010-10-14 09:18 . 2010-10-14 09:18 -------- d-----w- c:\program files\LucasArts
2010-10-14 00:23 . 2010-10-14 00:23 -------- d-----w- c:\program files\Infogrames
2010-10-14 00:13 . 2010-10-14 00:13 -------- d-----w- c:\program files\Infogrames Interactive
2010-10-14 00:08 . 2010-10-14 00:13 -------- d-----w- c:\program files\GameHouse Games Collection
2010-10-13 04:48 . 2010-10-13 04:54 -------- d-----w- c:\program files\Postal2
2010-10-13 04:38 . 2010-10-13 04:38 -------- d-----w- c:\program files\Core Design
2010-10-11 00:31 . 2010-10-11 00:31 -------- d-----w- c:\program files\Bethesda Softworks
2010-10-11 00:28 . 2001-09-05 10:18 225280 ------w- c:\program files\Common Files\InstallShield\IScript\iscript.dll
2010-10-11 00:28 . 2001-09-05 10:14 176128 ------w- c:\program files\Common Files\InstallShield\Engine\6\Intel 32\iuser.dll
2010-10-11 00:28 . 2001-09-05 10:13 32768 ------w- c:\program files\Common Files\InstallShield\Engine\6\Intel 32\objectps.dll
2010-10-11 00:28 . 2001-09-05 10:18 77824 ----a-w- c:\program files\Common Files\InstallShield\Engine\6\Intel 32\ctor.dll
2010-10-11 00:27 . 2001-09-05 10:24 610436 ----a-w- c:\program files\Common Files\InstallShield\Engine\6\Intel 32\IKernel.exe
2010-10-07 22:40 . 2010-10-19 06:41 -------- d-----w- c:\program files\ElcomSoft
2010-09-28 22:08 . 2010-09-28 22:08 74 ----a-w- C:\start.vbs
2010-09-27 23:21 . 2010-09-27 23:21 691696 ----a-w- c:\windows\system32\drivers\sptd.sys
2010-08-12 18:29 . 2010-08-12 18:29 2772992 ----a-w- c:\windows\system32\GPhotos.scr
------- Sigcheck -------
[-] 2008-04-13 . 9F3A2F5AA6875C72BF062C712CFA2674 . 96512 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\atapi.sys
[-] 2008-04-13 . 9F3A2F5AA6875C72BF062C712CFA2674 . 96512 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\DRIVERS\atapi.sys
[-] 2004-08-04 . CDFE4411A69C224BD1D11B2DA92DAC51 . 95360 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\atapi.sys
[-] 2004-08-04 . CDFE4411A69C224BD1D11B2DA92DAC51 . 95360 . . [5.1.2600.2180] . . c:\windows\SYSTEM32\ReinstallBackups\0003\DriverFiles\i386\atapi.sys
[-] 2008-04-13 . B153AFFAC761E7F5FCFA822B9C4E97BC . 14336 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\asyncmac.sys
[-] 2008-04-13 . B153AFFAC761E7F5FCFA822B9C4E97BC . 14336 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\DRIVERS\asyncmac.sys
[-] 2004-08-04 . 02000ABF34AF4C218C35D257024807D6 . 14336 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\asyncmac.sys
[-] 2004-08-04 . DA1F27D85E0D1525F6621372E7B685E9 . 4224 . . [5.1.2600.0] . . c:\windows\SYSTEM32\DRIVERS\BEEP.SYS
[-] 2008-04-13 . 463C1EC80CD17420A542B7F36A36F128 . 24576 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\kbdclass.sys
[-] 2008-04-13 . 463C1EC80CD17420A542B7F36A36F128 . 24576 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\DRIVERS\kbdclass.sys
[-] 2004-08-04 . EBDEE8A2EE5393890A1ACEE971C4C246 . 24576 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\kbdclass.sys
[-] 2008-04-13 . 1DF7F42665C94B825322FAE71721130D . 182656 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ndis.sys
[-] 2008-04-13 . 1DF7F42665C94B825322FAE71721130D . 182656 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\DRIVERS\ndis.sys
[-] 2004-08-04 . 558635D3AF1C7546D26067D5D9B6959E . 182912 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\ndis.sys
[-] 2008-04-13 . 78A08DD6A8D65E697C18E1DB01C5CDCA . 574976 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ntfs.sys
[-] 2008-04-13 . 78A08DD6A8D65E697C18E1DB01C5CDCA . 574976 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\DRIVERS\ntfs.sys
[-] 2004-08-04 . B78BE402C3F63DD55521F73876951CDD . 574592 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\ntfs.sys
[-] 2004-08-04 . 73C1E1F395918BC2C6DD67AF7591A3AD . 2944 . . [5.1.2600.0] . . c:\windows\SYSTEM32\DRIVERS\NULL.SYS
[-] 2008-06-20 . AD978A1B783B5719720CFF204B666C8E . 361600 . . [5.1.2600.5625] . . c:\windows\$hf_mig$\KB951748\SP3QFE\tcpip.sys
[-] 2008-06-20 . 9AEFA14BD6B182D61E3119FA5F436D3D . 361600 . . [5.1.2600.5625] . . c:\windows\$hf_mig$\KB951748\SP3GDR\tcpip.sys
[-] 2008-06-20 . 9AEFA14BD6B182D61E3119FA5F436D3D . 361600 . . [5.1.2600.5625] . . c:\windows\SYSTEM32\DLLCACHE\tcpip.sys
[-] 2008-06-20 . 9AEFA14BD6B182D61E3119FA5F436D3D . 361600 . . [5.1.2600.5625] . . c:\windows\SYSTEM32\DRIVERS\tcpip.sys
[-] 2008-06-20 . 2A5554FC5B1E04E131230E3CE035C3F9 . 360320 . . [5.1.2600.3394] . . c:\windows\$NtServicePackUninstall$\tcpip.sys
[-] 2008-06-20 . 744E57C99232201AE98C49168B918F48 . 360960 . . [5.1.2600.3394] . . c:\windows\$hf_mig$\KB951748\SP2QFE\tcpip.sys
[-] 2008-04-13 . 93EA8D04EC73A85DB02EB8805988F733 . 361344 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB951748$\tcpip.sys
[-] 2008-04-13 . 93EA8D04EC73A85DB02EB8805988F733 . 361344 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\tcpip.sys
[-] 2005-03-14 . 6129E70F3D2F1E60860C930EBEAF92C2 . 359936 . . [5.1.2600.2631] . . c:\windows\$hf_mig$\KB893066\SP2QFE\tcpip.sys
[-] 2005-03-14 . 0E66B538096A6529D1AC66E78EB0D5C8 . 359808 . . [5.1.2600.2631] . . c:\windows\$NtUninstallKB951748_0$\tcpip.sys
[-] 2004-08-04 . 9F4B36614A0FC234525BA224957DE55C . 359040 . . [5.1.2600.2180] . . c:\windows\$NtUninstallKB893066$\tcpip.sys
[-] 2008-04-14 . A06CE3399D16DB864F55FAEB1F1927A9 . 77824 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\browser.dll
[-] 2008-04-14 . A06CE3399D16DB864F55FAEB1F1927A9 . 77824 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\browser.dll
[-] 2004-08-04 . E3CFCCDDA4EDD1D0DC9168B2E18F27B8 . 77312 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\browser.dll
[-] 2008-04-14 . BF2466B3E18E970D8A976FB95FC1CA85 . 13312 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\lsass.exe
[-] 2008-04-14 . BF2466B3E18E970D8A976FB95FC1CA85 . 13312 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\lsass.exe
[-] 2004-08-04 . 84885F9B82F4D55C6146EBF6065D75D2 . 13312 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\lsass.exe
[-] 2008-04-14 . 13E67B55B3ABD7BF3FE7AAE5A0F9A9DE . 198144 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\netman.dll
[-] 2008-04-14 . 13E67B55B3ABD7BF3FE7AAE5A0F9A9DE . 198144 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\netman.dll
[-] 2004-08-04 . DAB9E6C7105D2EF49876FE92C524F565 . 198144 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\netman.dll
[-] 2008-04-14 . 574738F61FCA2935F5265DC4E5691314 . 409088 . . [6.7.2600.5512] . . c:\windows\ServicePackFiles\i386\qmgr.dll
[-] 2008-04-14 . 574738F61FCA2935F5265DC4E5691314 . 409088 . . [6.7.2600.5512] . . c:\windows\SYSTEM32\qmgr.dll
[-] 2008-04-14 . 574738F61FCA2935F5265DC4E5691314 . 409088 . . [6.7.2600.5512] . . c:\windows\SYSTEM32\bits\qmgr.dll
[-] 2004-08-04 . 2C69EC7E5A311334D10DD95F338FCCEA . 382464 . . [6.6.2600.2180] . . c:\windows\$NtServicePackUninstall$\qmgr.dll
[-] 2009-02-09 . 6B27A5C03DFB94B4245739065431322C . 401408 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3GDR\rpcss.dll
[-] 2009-02-09 . 6B27A5C03DFB94B4245739065431322C . 401408 . . [5.1.2600.5755] . . c:\windows\SYSTEM32\rpcss.dll
[-] 2009-02-09 . 6B27A5C03DFB94B4245739065431322C . 401408 . . [5.1.2600.5755] . . c:\windows\SYSTEM32\DLLCACHE\rpcss.dll
[-] 2009-02-09 . 9222562D44021B988B9F9F62207FB6F2 . 401408 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3QFE\rpcss.dll
[-] 2009-02-09 . 01095FEBF33BEEA00C2A0730B9B3EC28 . 399360 . . [5.1.2600.3520] . . c:\windows\$NtServicePackUninstall$\rpcss.dll
[-] 2009-02-09 . 24B5D53B9ACCC1E2EDCF0A878D6659D4 . 401408 . . [5.1.2600.3520] . . c:\windows\$hf_mig$\KB956572\SP2QFE\rpcss.dll
[-] 2008-04-14 . 2589FE6015A316C0F5D5112B4DA7B509 . 399360 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB956572$\rpcss.dll
[-] 2008-04-14 . 2589FE6015A316C0F5D5112B4DA7B509 . 399360 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\rpcss.dll
[-] 2005-01-14 . 419899803CA479B73B02390318C787C0 . 395776 . . [5.1.2600.2595] . . c:\windows\$NtUninstallKB956572_0$\rpcss.dll
[-] 2005-01-14 . 94456045BEB4545B5EBE1DCC85951AFA . 395776 . . [5.1.2600.2595] . . c:\windows\$hf_mig$\KB873333\SP2QFE\rpcss.dll
[-] 2004-08-04 . 5C83A4408604F737717AB96371201680 . 395776 . . [5.1.2600.2180] . . c:\windows\$NtUninstallKB873333$\rpcss.dll
[-] 2009-02-06 . 37561F8D4160D62DA86D24AE41FAE8DE . 110592 . . [5.1.2600.3520] . . c:\windows\$NtServicePackUninstall$\services.exe
[-] 2009-02-06 . 65DF52F5B8B6E9BBD183505225C37315 . 110592 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3GDR\services.exe
[-] 2009-02-06 . 65DF52F5B8B6E9BBD183505225C37315 . 110592 . . [5.1.2600.5755] . . c:\windows\SYSTEM32\services.exe
[-] 2009-02-06 . 65DF52F5B8B6E9BBD183505225C37315 . 110592 . . [5.1.2600.5755] . . c:\windows\SYSTEM32\DLLCACHE\services.exe
[-] 2009-02-06 . 020CEAAEDC8EB655B6506B8C70D53BB6 . 110592 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3QFE\services.exe
[-] 2009-02-06 . 4712531AB7A01B7EE059853CA17D39BD . 110592 . . [5.1.2600.3520] . . c:\windows\$hf_mig$\KB956572\SP2QFE\services.exe
[-] 2008-04-14 . 0E776ED5F7CC9F94299E70461B7B8185 . 108544 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB956572$\services.exe
[-] 2008-04-14 . 0E776ED5F7CC9F94299E70461B7B8185 . 108544 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\services.exe
[-] 2004-08-04 . C6CE6EEC82F187615D1002BB3BB50ED4 . 108032 . . [5.1.2600.2180] . . c:\windows\$NtUninstallKB956572_0$\services.exe
[-] 2010-08-17 . 258DD5D4283FD9F9A7166BE9AE45CE73 . 58880 . . [5.1.2600.6024] . . c:\windows\SoftwareDistribution\Download\9460002f6d8231358fc1eb590f9b1dce\sp3qfe\spoolsv.exe
[-] 2010-08-17 . 60784F891563FB1B767F70117FC2428F . 58880 . . [5.1.2600.6024] . . c:\windows\SoftwareDistribution\Download\9460002f6d8231358fc1eb590f9b1dce\sp3gdr\spoolsv.exe
[-] 2008-04-14 . D8E14A61ACC1D4A6CD0D38AEBAC7FA3B . 57856 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\spoolsv.exe
[-] 2008-04-14 . D8E14A61ACC1D4A6CD0D38AEBAC7FA3B . 57856 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\spoolsv.exe
[-] 2004-08-04 . 7435B108B935E42EA92CA94F59C8E717 . 57856 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\spoolsv.exe
[-] 2008-04-14 . ED0EF0A136DEC83DF69F04118870003E . 507904 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\winlogon.exe
[-] 2008-04-14 . ED0EF0A136DEC83DF69F04118870003E . 507904 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\winlogon.exe
[-] 2004-08-04 . 01C3346C241652F43AED8E2149881BFE . 502272 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\winlogon.exe
[-] 2010-08-23 . 93AFB83FBC1F9443CAC722FCA63D73BF . 617472 . . [5.82] . . c:\windows\SoftwareDistribution\Download\21cbd3f70584651805685eba1753505f\SP3QFE\comctl32.dll
[-] 2010-08-23 . 736B12B725AEB2B07F0241A9F680CB10 . 1054208 . . [6.0] . . c:\windows\SoftwareDistribution\Download\21cbd3f70584651805685eba1753505f\asms\60\msft\windows\common\controls\comctl32.dll
[-] 2010-08-23 . 736B12B725AEB2B07F0241A9F680CB10 . 1054208 . . [6.0] . . c:\windows\SoftwareDistribution\Download\21cbd3f70584651805685eba1753505f\SP3QFE\asms\60\msft\windows\common\controls\comctl32.dll
[-] 2008-04-14 . BD38D1EBE24A46BD3EDA059560AFBA12 . 1054208 . . [6.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
[-] 2008-04-14 . 06F247492BC786CE5C24A23E178C711A . 617472 . . [5.82] . . c:\windows\ServicePackFiles\i386\comctl32.dll
[-] 2008-04-14 . 06F247492BC786CE5C24A23E178C711A . 617472 . . [5.82] . . c:\windows\SYSTEM32\comctl32.dll
[-] 2004-08-04 . A77DFB85FAEE49D66C74DA6024EBC69B . 611328 . . [5.82] . . c:\windows\$NtServicePackUninstall$\comctl32.dll
[-] 2004-08-04 . AEF3D788DBF40C7C4D204EA45EB0C505 . 921088 . . [6.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.0.0_x-ww_1382d70a\COMCTL32.DLL
[-] 2004-08-04 . 5AF68A5E44734A082442668E9C787743 . 1050624 . . [6.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2180_x-ww_a84f1ff9\COMCTL32.DLL
[-] 2008-04-14 . 3D4E199942E29207970E04315D02AD3B . 62464 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\cryptsvc.dll
[-] 2008-04-14 . 3D4E199942E29207970E04315D02AD3B . 62464 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\cryptsvc.dll
[-] 2004-08-04 . 10654F9DDCEA9C46CFB77554231BE73B . 60416 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\cryptsvc.dll
[-] 2008-07-07 20:32 . 60D1A6342238378BFB7545C81EE3606C . 253952 . . [2001.12.4414.320] . . c:\windows\$NtServicePackUninstall$\es.dll
[-] 2008-07-07 20:26 . D4991D98F2DB73C60D042F1AEF79EFAE . 253952 . . [2001.12.4414.706] . . c:\windows\$hf_mig$\KB950974\SP3GDR\es.dll
[-] 2008-07-07 20:26 . D4991D98F2DB73C60D042F1AEF79EFAE . 253952 . . [2001.12.4414.706] . . c:\windows\SYSTEM32\es.dll
[-] 2008-07-07 20:26 . D4991D98F2DB73C60D042F1AEF79EFAE . 253952 . . [2001.12.4414.706] . . c:\windows\SYSTEM32\DLLCACHE\es.dll
[-] 2008-07-07 20:23 . F17F6226BDC0CD5F0BEF0DAF84D29BEC . 253952 . . [2001.12.4414.706] . . c:\windows\$hf_mig$\KB950974\SP3QFE\es.dll
[-] 2008-07-07 20:06 . A4AB3DCA4A383F0DF4988ABDEB84F9A4 . 253952 . . [2001.12.4414.320] . . c:\windows\$hf_mig$\KB950974\SP2QFE\es.dll
[-] 2008-04-14 00:11 . 19A799805B24990867B00C120D300C3A . 246272 . . [2001.12.4414.701] . . c:\windows\$NtUninstallKB950974$\es.dll
[-] 2008-04-14 00:11 . 19A799805B24990867B00C120D300C3A . 246272 . . [2001.12.4414.701] . . c:\windows\ServicePackFiles\i386\es.dll
[-] 2004-08-04 11:00 . ACD36A2DD7D1E9D8A060AA651DC07E63 . 243200 . . [2001.12.4414.258] . . c:\windows\$NtUninstallKB950974_0$\es.dll
[-] 2008-04-14 . 0DA85218E92526972A821587E6A8BF8F . 110080 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\imm32.dll
[-] 2008-04-14 . 0DA85218E92526972A821587E6A8BF8F . 110080 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\imm32.dll
[-] 2004-08-04 . 87CA7CE6469577F059297B9D6556D66D . 110080 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\imm32.dll
[-] 2009-03-21 . B6ACAED7588295129791E0E6A2B0FADE . 986112 . . [5.1.2600.3541] . . c:\windows\$NtServicePackUninstall$\kernel32.dll
[-] 2009-03-21 . B921FB870C9AC0D509B2CCABBBBE95F3 . 989696 . . [5.1.2600.5781] . . c:\windows\$hf_mig$\KB959426\SP3GDR\kernel32.dll
[-] 2009-03-21 . B921FB870C9AC0D509B2CCABBBBE95F3 . 989696 . . [5.1.2600.5781] . . c:\windows\SYSTEM32\kernel32.dll
[-] 2009-03-21 . B921FB870C9AC0D509B2CCABBBBE95F3 . 989696 . . [5.1.2600.5781] . . c:\windows\SYSTEM32\DLLCACHE\kernel32.dll
[-] 2009-03-21 . DA11D9D6ECBDF0F93436A4B7C13F7BEC . 991744 . . [5.1.2600.5781] . . c:\windows\$hf_mig$\KB959426\SP3QFE\kernel32.dll
[-] 2009-03-21 . 80202858D245FF07DAA1739C57A3E19B . 989184 . . [5.1.2600.3541] . . c:\windows\$hf_mig$\KB959426\SP2QFE\kernel32.dll
[-] 2008-04-14 . C24B983D211C34DA8FCC1AC38477971D . 989696 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB959426$\kernel32.dll
[-] 2008-04-14 . C24B983D211C34DA8FCC1AC38477971D . 989696 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\kernel32.dll
[-] 2004-08-04 . 888190E31455FAD793312F8D087146EB . 983552 . . [5.1.2600.2180] . . c:\windows\$NtUninstallKB959426_0$\kernel32.dll
[-] 2008-04-14 . 2DC5A8019E2387987905F77C664E4BE2 . 19968 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\linkinfo.dll
[-] 2008-04-14 . 2DC5A8019E2387987905F77C664E4BE2 . 19968 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\linkinfo.dll
[-] 2004-08-04 . C2BBD044C741EA4292016C36F718D2E4 . 18944 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\linkinfo.dll
[-] 2008-04-14 . 012DF358CEBAA23ACB26D82077820817 . 22016 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\lpk.dll
[-] 2008-04-14 . 012DF358CEBAA23ACB26D82077820817 . 22016 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\lpk.dll
[-] 2004-08-04 . 74D66B3DE265E8789153414E75175F26 . 22016 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\lpk.dll
[-] 2010-09-09 . 575FBCB3E2C6E848F0386F38AAF0E4ED . 3074560 . . [6.00.2900.6036] . . c:\windows\SoftwareDistribution\Download\3fcddeb58b831e5d95534882e96f16af\sp3qfe\mshtml.dll
[-] 2010-09-09 . 565EA6D4DF8638CE9143A20DE5B229F6 . 3073536 . . [6.00.2900.6036] . . c:\windows\SoftwareDistribution\Download\3fcddeb58b831e5d95534882e96f16af\sp3gdr\mshtml.dll
[-] 2010-06-24 . E833C8A9918DA80DBE80ABD2917B9292 . 3073536 . . [6.00.2900.6003] . . c:\windows\$hf_mig$\KB2183461\SP3QFE\mshtml.dll
[-] 2010-06-24 . 2CA3A0836EF47AEE5D471B43B7639B6C . 3073024 . . [6.00.2900.6003] . . c:\windows\SYSTEM32\mshtml.dll
[-] 2010-06-24 . 2CA3A0836EF47AEE5D471B43B7639B6C . 3073024 . . [6.00.2900.6003] . . c:\windows\SYSTEM32\DLLCACHE\mshtml.dll
[-] 2010-04-16 . 6B930309A4A246D133A49EADE11E5773 . 3073024 . . [6.00.2900.5969] . . c:\windows\$hf_mig$\KB982381\SP3GDR\mshtml.dll
[-] 2010-04-16 . 6B930309A4A246D133A49EADE11E5773 . 3073024 . . [6.00.2900.5969] . . c:\windows\$NtUninstallKB2183461$\mshtml.dll
[-] 2010-04-16 . 9574D5B0C784DA0FD8F6A9BB37936A52 . 3073536 . . [6.00.2900.5969] . . c:\windows\$hf_mig$\KB982381\SP3QFE\mshtml.dll
[-] 2010-04-16 . 44A6BB3DE8FF814209A1CDFEC4BB51BD . 3065344 . . [6.00.2900.3698] . . c:\windows\$NtServicePackUninstall$\mshtml.dll
[-] 2010-04-16 . 149F37C9702F24A50741E56FBC7AE56B . 3073024 . . [6.00.2900.3698] . . c:\windows\$hf_mig$\KB982381\SP2QFE\mshtml.dll
[-] 2008-04-14 . A706E122B398FE1AB85CB9B75D044223 . 3066880 . . [6.00.2900.5512] . . c:\windows\$NtUninstallKB982381$\mshtml.dll
[-] 2008-04-14 . A706E122B398FE1AB85CB9B75D044223 . 3066880 . . [6.00.2900.5512] . . c:\windows\ServicePackFiles\i386\mshtml.dll
[-] 2005-03-10 . 84A1B9B0C362051E68BB131F14C6DAAD . 3010560 . . [6.00.2900.2627] . . c:\windows\$NtUninstallKB982381_0$\mshtml.dll
[-] 2005-03-10 . 255C2CE965543ABDC3E0A25A5DA1874A . 3011072 . . [6.00.2900.2627] . . c:\windows\$hf_mig$\KB890923\SP2QFE\mshtml.dll
[-] 2004-09-29 . D94E6405E420373161467ACD3DA65640 . 3004928 . . [6.00.2900.2523] . . c:\windows\$NtUninstallKB890923$\mshtml.dll
[-] 2004-09-29 . 087FF7C54E7EBE4A59BD4DFC1D0EE9B8 . 3004928 . . [6.00.2900.2524] . . c:\windows\$hf_mig$\KB834707\SP2QFE\mshtml.dll
[-] 2004-08-04 . 376E0843B2356CA91CEC8D9837A56FF7 . 3003392 . . [6.00.2900.2180] . . c:\windows\$NtUninstallKB834707$\mshtml.dll
[-] 2008-04-14 . D7075E95AA599EE77B7A89D39296BD3D . 343040 . . [7.0.2600.5512] . . c:\windows\WinSxS\x86_Microsoft.Windows.CPlusPlusRuntime_6595b64144ccf1df_7.0.2600.5512_x-ww_3fd60d63\msvcrt.dll
[-] 2008-04-14 . 355EDBB4D412B01F1740C17E3F50FA00 . 343040 . . [7.0.2600.5512] . . c:\windows\ServicePackFiles\i386\msvcrt.dll
[-] 2008-04-14 . 355EDBB4D412B01F1740C17E3F50FA00 . 343040 . . [7.0.2600.5512] . . c:\windows\SYSTEM32\msvcrt.dll
[-] 2004-08-04 . B0FEFA816D61EC66AA765DDF534EAB5E . 343040 . . [7.0.2600.2180] . . c:\windows\$NtServicePackUninstall$\msvcrt.dll
[-] 2004-08-04 . 4200BE3808F6406DBE45A7B88DAE5035 . 322560 . . [7.0.2600.0] . . c:\windows\WinSxS\x86_Microsoft.Windows.CPlusPlusRuntime_6595b64144ccf1df_7.0.0.0_x-ww_2726e76a\MSVCRT.DLL
[-] 2004-08-04 . 98EC447E00229AFD88D5161A25D065DA . 343040 . . [7.0.2600.2180] . . c:\windows\WinSxS\x86_Microsoft.Windows.CPlusPlusRuntime_6595b64144ccf1df_7.0.2600.2180_x-ww_b2505ed9\MSVCRT.DLL
[-] 2008-06-20 . 832E4DD8964AB7ACC880B2837CB1ED20 . 245248 . . [5.1.2600.5625] . . c:\windows\$hf_mig$\KB951748\SP3GDR\mswsock.dll
[-] 2008-06-20 . 832E4DD8964AB7ACC880B2837CB1ED20 . 245248 . . [5.1.2600.5625] . . c:\windows\SYSTEM32\mswsock.dll
[-] 2008-06-20 . 832E4DD8964AB7ACC880B2837CB1ED20 . 245248 . . [5.1.2600.5625] . . c:\windows\SYSTEM32\DLLCACHE\mswsock.dll
[-] 2008-06-20 . FCEE5FCB99F7C724593365C706D28388 . 245248 . . [5.1.2600.5625] . . c:\windows\$hf_mig$\KB951748\SP3QFE\mswsock.dll
[-] 2008-06-20 . 097722F235A1FB698BF9234E01B52637 . 245248 . . [5.1.2600.3394] . . c:\windows\$NtServicePackUninstall$\mswsock.dll
[-] 2008-06-20 . 1DFCA7713EA5A70D5D93B436AEA0317A . 245248 . . [5.1.2600.3394] . . c:\windows\$hf_mig$\KB951748\SP2QFE\mswsock.dll
[-] 2008-04-14 . B4138E99236F0F57D4CF49BAE98A0746 . 245248 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB951748$\mswsock.dll
[-] 2008-04-14 . B4138E99236F0F57D4CF49BAE98A0746 . 245248 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\mswsock.dll
[-] 2004-08-04 . 4E74AF063C3271FBEA20DD940CFD1184 . 245248 . . [5.1.2600.2180] . . c:\windows\$NtUninstallKB951748_0$\mswsock.dll
[-] 2009-02-06 . 6C476D33D82F1054849790181E8F7772 . 408064 . . [5.1.2600.3520] . . c:\windows\$hf_mig$\KB968389\SP2QFE\netlogon.dll
[-] 2009-02-06 . 6C476D33D82F1054849790181E8F7772 . 408064 . . [5.1.2600.3520] . . c:\windows\$hf_mig$\KB975467\SP2QFE\netlogon.dll
[-] 2008-04-14 . 1B7F071C51B77C272875C3A23E1E4550 . 407040 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\netlogon.dll
[-] 2008-04-14 . 1B7F071C51B77C272875C3A23E1E4550 . 407040 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\netlogon.dll
[-] 2004-08-04 . 96353FCECBA774BB8DA74A1C6507015A . 407040 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\netlogon.dll
[-] 2010-04-28 . 472059774023F80EB7227EAF9A7ACDA1 . 2189952 . . [5.1.2600.5973] . . c:\windows\Driver Cache\I386\ntoskrnl.exe
[-] 2010-04-28 . 472059774023F80EB7227EAF9A7ACDA1 . 2189952 . . [5.1.2600.5973] . . c:\windows\SYSTEM32\ntoskrnl.exe
[-] 2010-04-28 . 472059774023F80EB7227EAF9A7ACDA1 . 2189952 . . [5.1.2600.5973] . . c:\windows\SYSTEM32\DLLCACHE\ntoskrnl.exe
[-] 2010-04-27 . A2ABBEC40CDB57454645D06B7EBD22F5 . 2190080 . . [5.1.2600.5973] . . c:\windows\$hf_mig$\KB981852\SP3QFE\ntoskrnl.exe
[-] 2010-02-17 . D41C3CBAD0E1C0728D1CDFD541F60CFA . 2189952 . . [5.1.2600.5938] . . c:\windows\$hf_mig$\KB979683\SP3GDR\ntoskrnl.exe
[-] 2010-02-17 . D41C3CBAD0E1C0728D1CDFD541F60CFA . 2189952 . . [5.1.2600.5938] . . c:\windows\$NtUninstallKB981852$\ntoskrnl.exe
[-] 2010-02-16 . 97E2BF68857818A4D142B872404DC41B . 2186880 . . [5.1.2600.3670] . . c:\windows\$hf_mig$\KB979683\SP2QFE\ntoskrnl.exe
[-] 2010-02-16 . EBB75B113E74E90074382347B74D652B . 2181376 . . [5.1.2600.3670] . . c:\windows\$NtServicePackUninstall$\ntoskrnl.exe
[-] 2010-02-16 . E1F653A542449D54FA2D27463D99B6B6 . 2190080 . . [5.1.2600.5938] . . c:\windows\$hf_mig$\KB979683\SP3QFE\ntoskrnl.exe
[-] 2009-02-07 . EFE8EACE83EAAD5849A7A548FB75B584 . 2189184 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3QFE\ntoskrnl.exe
[-] 2009-02-06 . FACEBB0CA3154F77009CDFEE78A00BBB . 2180480 . . [5.1.2600.3520] . . c:\windows\$NtUninstallKB979683_0$\ntoskrnl.exe
[-] 2009-02-06 . 7A95B10A73737EBF24139AAA63F5212B . 2189056 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3GDR\ntoskrnl.exe
[-] 2009-02-06 . 7A95B10A73737EBF24139AAA63F5212B . 2189056 . . [5.1.2600.5755] . . c:\windows\$NtUninstallKB979683$\ntoskrnl.exe
[-] 2009-02-06 . 6A936E9D7BADAF3CAAEED1E1966EC1B0 . 2186112 . . [5.1.2600.3520] . . c:\windows\$hf_mig$\KB956572\SP2QFE\ntoskrnl.exe
[-] 2008-04-13 . 0C89243C7C3EE199B96FCC16990E0679 . 2188928 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB956572$\ntoskrnl.exe
[-] 2008-04-13 . 0C89243C7C3EE199B96FCC16990E0679 . 2188928 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ntoskrnl.exe
[-] 2005-03-02 . 28187802B7C368C0D3AEF7D4C382AABB . 2179456 . . [5.1.2600.2622] . . c:\windows\$hf_mig$\KB890859\SP2QFE\ntoskrnl.exe
[-] 2005-03-02 . 4D4CF2C14550A4B7718E94A6E581856E . 2179328 . . [5.1.2600.2622] . . c:\windows\$NtUninstallKB956572_0$\ntoskrnl.exe
[-] 2004-08-04 . CE218BC7088681FAA06633E218596CA7 . 2180992 . . [5.1.2600.2180] . . c:\windows\$NtUninstallKB890859$\ntoskrnl.exe
[-] 2008-04-14 . 50A166237A0FA771261275A405646CC0 . 17408 . . [6.00.2900.5512] . . c:\windows\ServicePackFiles\i386\powrprof.dll
[-] 2008-04-14 . 50A166237A0FA771261275A405646CC0 . 17408 . . [6.00.2900.5512] . . c:\windows\SYSTEM32\powrprof.dll
[-] 2004-08-04 . 1B5F6923ABB450692E9FE0672C897AED . 17408 . . [6.00.2900.2180] . . c:\windows\$NtServicePackUninstall$\powrprof.dll
[-] 2008-04-14 . A86BB5E61BF3E39B62AB4C7E7085A084 . 181248 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\scecli.dll
[-] 2008-04-14 . A86BB5E61BF3E39B62AB4C7E7085A084 . 181248 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\scecli.dll
[-] 2004-08-04 . 0F78E27F563F2AAF74B91A49E2ABF19A . 180224 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\scecli.dll
[-] 2008-04-14 . 96E1C926F22EE1BFBAE82901A35F6BF3 . 5120 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\sfc.dll
[-] 2008-04-14 . 96E1C926F22EE1BFBAE82901A35F6BF3 . 5120 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\sfc.dll
[-] 2004-08-04 . E8A12A12EA9088B4327D49EDCA3ADD3E . 5120 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\sfc.dll
[-] 2008-04-14 . 27C6D03BCDB8CFEB96B716F3D8BE3E18 . 14336 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\svchost.exe
[-] 2008-04-14 . 27C6D03BCDB8CFEB96B716F3D8BE3E18 . 14336 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\svchost.exe
[-] 2004-08-04 . 8F078AE4ED187AAABC0A305146DE6716 . 14336 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\svchost.exe
[-] 2008-04-14 . 3CB78C17BB664637787C9A1C98F79C38 . 249856 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\tapisrv.dll
[-] 2008-04-14 . 3CB78C17BB664637787C9A1C98F79C38 . 249856 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\tapisrv.dll
[-] 2004-08-04 . EB4A4187D74A8EFDCBEA3EA2CB1BDFBD . 246272 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\tapisrv.dll
[-] 2008-04-14 . B26B135FF1B9F60C9388B4A7D16F600B . 578560 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\user32.dll
[-] 2008-04-14 . B26B135FF1B9F60C9388B4A7D16F600B . 578560 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\user32.dll
[-] 2005-03-02 . 1800F293BCCC8EDE8A70E12B88D80036 . 577024 . . [5.1.2600.2622] . . c:\windows\$hf_mig$\KB890859\SP2QFE\user32.dll
[-] 2005-03-02 . DE2DB164BBB35DB061AF0997E4499054 . 577024 . . [5.1.2600.2622] . . c:\windows\$NtServicePackUninstall$\user32.dll
[-] 2004-08-04 . C72661F8552ACE7C5C85E16A3CF505C4 . 577024 . . [5.1.2600.2180] . . c:\windows\$NtUninstallKB890859$\user32.dll
[-] 2008-04-14 . A93AEE1928A9D7CE3E16D24EC7380F89 . 26112 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\userinit.exe
[-] 2008-04-14 . A93AEE1928A9D7CE3E16D24EC7380F89 . 26112 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\userinit.exe
[-] 2004-08-04 . 39B1FFB03C2296323832ACBAE50D2AFF . 24576 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\userinit.exe
[-] 2010-09-09 . D7275E6DA8D1A8BEB36468548899522C . 668672 . . [6.00.2900.6036] . . c:\windows\SoftwareDistribution\Download\3fcddeb58b831e5d95534882e96f16af\sp3qfe\wininet.dll
[-] 2010-09-09 . 118767E386CBAE1AD67D934BC9402E08 . 667136 . . [6.00.2900.6036] . . c:\windows\SoftwareDistribution\Download\3fcddeb58b831e5d95534882e96f16af\sp3gdr\wininet.dll
[-] 2010-06-24 . 7F489AED93B4AA2B170025DF0670E17F . 668672 . . [6.00.2900.6003] . . c:\windows\$hf_mig$\KB2183461\SP3QFE\wininet.dll
[-] 2010-06-24 . CD8CAE4012D9A5E6B6C6A46D80460527 . 667136 . . [6.00.2900.6003] . . c:\windows\SYSTEM32\wininet.dll
[-] 2010-06-24 . CD8CAE4012D9A5E6B6C6A46D80460527 . 667136 . . [6.00.2900.6003] . . c:\windows\SYSTEM32\DLLCACHE\wininet.dll
[-] 2010-04-16 . B43B18FB0EB577856883E5A0708AB9EF . 667136 . . [6.00.2900.5969] . . c:\windows\$hf_mig$\KB982381\SP3GDR\wininet.dll
[-] 2010-04-16 . B43B18FB0EB577856883E5A0708AB9EF . 667136 . . [6.00.2900.5969] . . c:\windows\$NtUninstallKB2183461$\wininet.dll
[-] 2010-04-16 . C3052A99A24F462B418632A05328BB38 . 668672 . . [6.00.2900.5969] . . c:\windows\$hf_mig$\KB982381\SP3QFE\wininet.dll
[-] 2010-04-16 . 602BB82E56758BC6E50B17741CD5F081 . 662016 . . [6.00.2900.3698] . . c:\windows\$NtServicePackUninstall$\wininet.dll
[-] 2010-04-16 . 9CE5DEF97E55E52C23201098DB755280 . 668672 . . [6.00.2900.3698] . . c:\windows\$hf_mig$\KB982381\SP2QFE\wininet.dll
[-] 2008-04-14 . 7A4F775ABB2F1C97DEF3E73AFA2FAEDD . 666112 . . [6.00.2900.5512] . . c:\windows\$NtUninstallKB982381$\wininet.dll
[-] 2008-04-14 . 7A4F775ABB2F1C97DEF3E73AFA2FAEDD . 666112 . . [6.00.2900.5512] . . c:\windows\ServicePackFiles\i386\wininet.dll
[-] 2005-03-10 . 6F018D6319BE4F96426EA829B79E05D5 . 656896 . . [6.00.2900.2627] . . c:\windows\$NtUninstallKB982381_0$\wininet.dll
[-] 2005-03-10 . C8663B488996E89A84C3D17C1D12B79E . 657920 . . [6.00.2900.2627] . . c:\windows\$hf_mig$\KB890923\SP2QFE\wininet.dll
[-] 2004-09-29 . CBA65B573C66FE23F647FF96E3A10994 . 656896 . . [6.00.2900.2518] . . c:\windows\$NtUninstallKB890923$\wininet.dll
[-] 2004-09-29 . 2C07195588D69A067C2AFDAA31759295 . 656896 . . [6.00.2900.2518] . . c:\windows\$hf_mig$\KB834707\SP2QFE\wininet.dll
[-] 2004-08-04 . C0823FC5469663BA63E7DB88F9919D70 . 656384 . . [6.00.2900.2180] . . c:\windows\$NtUninstallKB834707$\wininet.dll
[-] 2008-04-14 . 2CCC474EB85CEAA3E1FA1726580A3E5A . 82432 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ws2_32.dll
[-] 2008-04-14 . 2CCC474EB85CEAA3E1FA1726580A3E5A . 82432 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\ws2_32.dll
[-] 2004-08-04 . 2ED0B7F12A60F90092081C50FA0EC2B2 . 82944 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\ws2_32.dll
[-] 2008-04-14 . 9789E95E1D88EEB4B922BF3EA7779C28 . 19968 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ws2help.dll
[-] 2008-04-14 . 9789E95E1D88EEB4B922BF3EA7779C28 . 19968 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\ws2help.dll
[-] 2004-08-04 . 9BEACB911CA61E5881102188AB7FB431 . 19968 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\ws2help.dll
[-] 2008-04-14 . 12896823FB95BFB3DC9B46BCAEDC9923 . 1033728 . . [6.00.2900.5512] . . c:\windows\explorer.exe
[-] 2008-04-14 . 12896823FB95BFB3DC9B46BCAEDC9923 . 1033728 . . [6.00.2900.5512] . . c:\windows\ServicePackFiles\i386\explorer.exe
[-] 2004-08-04 . A0732187050030AE399B241436565E64 . 1032192 . . [6.00.2900.2180] . . c:\windows\$NtServicePackUninstall$\explorer.exe
[-] 2010-07-16 . 7A6A7900B5E322763430BA6FD9A31224 . 1288192 . . [5.1.2600.6010] . . c:\windows\SoftwareDistribution\Download\e104dcd29adf1c6c473a5efad2d509be\sp3gdr\ole32.dll
[-] 2010-07-16 . 8D51FB47062F2A1A9EFECCEF338A4C46 . 1289216 . . [5.1.2600.6010] . . c:\windows\SoftwareDistribution\Download\e104dcd29adf1c6c473a5efad2d509be\sp3qfe\ole32.dll
[-] 2008-04-14 . ECCE74BC6168375016450A86A164D976 . 1287168 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ole32.dll
[-] 2008-04-14 . ECCE74BC6168375016450A86A164D976 . 1287168 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\ole32.dll
[-] 2005-01-14 . ABDEF60CED7C04AB35A415EFB6B96D81 . 1285120 . . [5.1.2600.2595] . . c:\windows\$NtServicePackUninstall$\ole32.dll
[-] 2005-01-14 . 2E752611C9A9AE1B6BFD0DA03CF7F17E . 1284608 . . [5.1.2600.2595] . . c:\windows\$hf_mig$\KB873333\SP2QFE\ole32.dll
[-] 2004-08-04 . 4FE9D9FA62D020E35E0AC6D1AEEB96F0 . 1281536 . . [5.1.2600.2180] . . c:\windows\$NtUninstallKB873333$\ole32.dll
[-] 2008-04-14 . 3805DF0AC4296A34BA4BF93B346CC378 . 171008 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\srsvc.dll
[-] 2008-04-14 . 3805DF0AC4296A34BA4BF93B346CC378 . 171008 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\srsvc.dll
[-] 2004-08-04 . 92BDF74F12D6CBEC43C94D4B7F804838 . 170496 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\srsvc.dll
[-] 2008-04-14 . F92E1076C42FCD6DB3D72D8CFE9816D5 . 13824 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\wscntfy.exe
[-] 2008-04-14 . F92E1076C42FCD6DB3D72D8CFE9816D5 . 13824 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\wscntfy.exe
[-] 2004-08-04 . 49911DD39E023BB6C45E4E436CFBD297 . 13824 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\wscntfy.exe
[-] 2008-04-14 . 295D21F14C335B53CB8154E5B1F892B9 . 129024 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\xmlprov.dll
[-] 2008-04-14 . 295D21F14C335B53CB8154E5B1F892B9 . 129024 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\xmlprov.dll
[-] 2004-08-04 . EEF46DAB68229A14DA3D8E73C99E2959 . 129536 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\xmlprov.dll
[-] 2008-04-14 . 6D4FEB43EE538FC5428CC7F0565AA656 . 56320 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\eventlog.dll
[-] 2008-04-14 . 6D4FEB43EE538FC5428CC7F0565AA656 . 56320 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\eventlog.dll
[-] 2004-08-04 . 82B24CB70E5944E6E34662205A2A5B78 . 55808 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\eventlog.dll
[-] 2008-04-14 . 9DD07AF82244867CA36681EA2D29CE79 . 1614848 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\sfcfiles.dll
[-] 2008-04-14 . 9DD07AF82244867CA36681EA2D29CE79 . 1614848 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\sfcfiles.dll
[-] 2004-08-04 . 30A609E00BD1D4FFC49D6B5A432BE7F2 . 1580544 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\sfcfiles.dll
[-] 2008-04-14 . 5F1D5F88303D4A4DBC8E5F97BA967CC3 . 15360 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ctfmon.exe
[-] 2008-04-14 . 5F1D5F88303D4A4DBC8E5F97BA967CC3 . 15360 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\ctfmon.exe
[-] 2004-08-04 . 24232996A38C0B0CF151C2140AE29FC8 . 15360 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\ctfmon.exe
[-] 2008-04-14 . 1926899BF9FFE2602B63074971700412 . 135168 . . [6.00.2900.5512] . . c:\windows\ServicePackFiles\i386\shsvcs.dll
[-] 2008-04-14 . 1926899BF9FFE2602B63074971700412 . 135168 . . [6.00.2900.5512] . . c:\windows\SYSTEM32\shsvcs.dll
[-] 2004-08-04 . E7518DC542D3EBDCB80EDD98462C7821 . 134656 . . [6.00.2900.2180] . . c:\windows\$NtServicePackUninstall$\shsvcs.dll
[-] 2008-04-14 . 5B19B557B0C188210A56A6B699D90B8F . 59904 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\regsvc.dll
[-] 2008-04-14 . 5B19B557B0C188210A56A6B699D90B8F . 59904 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\regsvc.dll
[-] 2004-08-04 . 3151427DB7D87107D1C5BE58FAC53960 . 59904 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\regsvc.dll
[-] 2008-04-14 . 0A9A7365A1CA4319AA7C1D6CD8E4EAFA . 192512 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\schedsvc.dll
[-] 2008-04-14 . 0A9A7365A1CA4319AA7C1D6CD8E4EAFA . 192512 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\schedsvc.dll
[-] 2004-08-04 . 92360854316611F6CC471612213C3D92 . 190976 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\schedsvc.dll
[-] 2008-04-14 . 0A5679B3714EDAB99E357057EE88FCA6 . 71680 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ssdpsrv.dll
[-] 2008-04-14 . 0A5679B3714EDAB99E357057EE88FCA6 . 71680 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\ssdpsrv.dll
[-] 2004-08-04 . 4B8D61792F7175BED48859CC18CE4E38 . 71680 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\ssdpsrv.dll
[-] 2008-04-14 . FF3477C03BE7201C294C35F684B3479F . 295424 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\termsrv.dll
[-] 2008-04-14 . FF3477C03BE7201C294C35F684B3479F . 295424 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\termsrv.dll
[-] 2004-08-04 . B60C877D16D9C880B952FDA04ADF16E6 . 295424 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\termsrv.dll
[-] 2004-08-04 . 9859C0F6936E723E4892D7141B1327D5 . 11648 . . [5.1.2600.0] . . c:\windows\SYSTEM32\DRIVERS\ACPIEC.SYS
[-] 2008-04-13 16:39 . 8BED39E3C35D6A489438B8141717A557 . 142592 . . [5.1.2601.3142] . . c:\windows\SYSTEM32\DLLCACHE\aec.sys
[-] 2008-04-13 16:39 . 8BED39E3C35D6A489438B8141717A557 . 142592 . . [5.1.2601.3142] . . c:\windows\SYSTEM32\DRIVERS\aec.sys
[-] 2008-04-13 16:39 . 8BED39E3C35D6A489438B8141717A557 . 142592 . . [5.1.2601.3142] . . c:\windows\ServicePackFiles\i386\aec.sys
[-] 2004-08-04 04:39 . 841F385C6CFAF66B58FBD898722BB4F0 . 142464 . . [5.1.2601.2078] . . c:\windows\$NtServicePackUninstall$\aec.sys
[-] 2008-04-13 . 08FD04AA961BDC77FB983F328334E3D7 . 42368 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\agp440.sys
[-] 2008-04-13 . 08FD04AA961BDC77FB983F328334E3D7 . 42368 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\DRIVERS\agp440.sys
[-] 2004-08-04 . 2C428FA0C3E3A01ED93C9B2A27D8D4BB . 42368 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\agp440.sys
[-] 2008-04-13 . 3BB22519A194418D5FEC05D800A19AD0 . 36608 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ip6fw.sys
[-] 2008-04-13 . 3BB22519A194418D5FEC05D800A19AD0 . 36608 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\DRIVERS\ip6fw.sys
[-] 2004-08-04 . 4448006B6BC60E6C027932CFC38D6855 . 29056 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\ip6fw.sys
[-] 2010-09-18 07:18 . 842900DEDBC8E3E8DBCCCB298FD88F65 . 953856 . . [4.1.6151] . . c:\windows\SoftwareDistribution\Download\b91377d1d56820d9d699c0c2dc7c8e80\SP3QFE\mfc40u.dll
[-] 2010-09-18 06:53 . E76A5C202E68AF5A322D16B5A78F48B9 . 953856 . . [4.1.6151] . . c:\windows\SoftwareDistribution\Download\b91377d1d56820d9d699c0c2dc7c8e80\SP3GDR\mfc40u.dll
[-] 2008-04-14 00:11 . CDDD4416B2B4C7295FE3FDB6DDE57E4E . 927504 . . [4.1.0.61] . . c:\windows\ServicePackFiles\i386\mfc40u.dll
[-] 2008-04-14 00:11 . CDDD4416B2B4C7295FE3FDB6DDE57E4E . 927504 . . [4.1.0.61] . . c:\windows\SYSTEM32\mfc40u.dll
[-] 2004-08-04 11:00 . DDF8D47ACF8FC3FE5F7F2B95C4D4D136 . 924432 . . [4.1.6140] . . c:\windows\$NtServicePackUninstall$\mfc40u.dll
[-] 2008-04-14 . 986B1FF5814366D71E0AC5755C88F2D3 . 33792 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\msgsvc.dll
[-] 2008-04-14 . 986B1FF5814366D71E0AC5755C88F2D3 . 33792 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\msgsvc.dll
[-] 2004-08-04 . 95FD808E4AC22ABA025A7B3EAC0375D2 . 33792 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\msgsvc.dll
[-] 2009-01-31 00:33 . 051B1BDECD6DEE18C771B5D5EC7F044D . 27136 . . [11.0.5721.5262] . . c:\windows\SYSTEM32\mspmsnsv.dll
[-] 2009-01-31 00:33 . 051B1BDECD6DEE18C771B5D5EC7F044D . 27136 . . [11.0.5721.5262] . . c:\windows\SYSTEM32\DLLCACHE\mspmsnsv.dll
[-] 2004-09-15 18:27 . A477391B7A8B0A0DAABADB17CF533A4B . 25088 . . [10.0.3790.3646] . . c:\windows\$NtUninstallWMFDist11$\mspmsnsv.dll
[-] 2004-09-15 18:27 . A477391B7A8B0A0DAABADB17CF533A4B . 25088 . . [10.0.3790.3646] . . c:\windows\RegisteredPackages\{30C7234B-6482-4A55-A11D-ECD9030313F2}\MsPMSNSv.dll
[-] 2004-08-04 11:00 . C086483E3DBA8C1C0A687EC8D5B3D4C1 . 52224 . . [9.0.1.56] . . c:\windows\RegisteredPackages\{30C7234B-6482-4A55-A11D-ECD9030313F2}$BACKUP$\System\MsPMSNSv.dll
[-] 2010-04-28 . 756362706DE8BC92F11E197C98A73844 . 2066944 . . [5.1.2600.5973] . . c:\windows\$hf_mig$\KB981852\SP3QFE\ntkrnlpa.exe
[-] 2010-04-27 . DC57ABED7BDE1487E658968B4423BED7 . 2066816 . . [5.1.2600.5973] . . c:\windows\Driver Cache\I386\ntkrnlpa.exe
[-] 2010-04-27 . DC57ABED7BDE1487E658968B4423BED7 . 2066816 . . [5.1.2600.5973] . . c:\windows\SYSTEM32\ntkrnlpa.exe
[-] 2010-04-27 . DC57ABED7BDE1487E658968B4423BED7 . 2066816 . . [5.1.2600.5973] . . c:\windows\SYSTEM32\DLLCACHE\ntkrnlpa.exe
[-] 2010-02-17 . 1811AFC2FADB60B88947E3D08E250860 . 2063744 . . [5.1.2600.3670] . . c:\windows\$hf_mig$\KB979683\SP2QFE\ntkrnlpa.exe
[-] 2010-02-16 . A046C627EC20456E2959B7BD628E1FD0 . 2066816 . . [5.1.2600.5938] . . c:\windows\$hf_mig$\KB979683\SP3GDR\ntkrnlpa.exe
[-] 2010-02-16 . A046C627EC20456E2959B7BD628E1FD0 . 2066816 . . [5.1.2600.5938] . . c:\windows\$NtUninstallKB981852$\ntkrnlpa.exe
[-] 2010-02-16 . 1EE6B94ACA7BE115A1813BBCA65099A8 . 2058368 . . [5.1.2600.3670] . . c:\windows\$NtServicePackUninstall$\ntkrnlpa.exe
[-] 2010-02-16 . DED8B5A89B085284634502E9D75AC78C . 2066944 . . [5.1.2600.5938] . . c:\windows\$hf_mig$\KB979683\SP3QFE\ntkrnlpa.exe
[-] 2009-02-07 . 5BA7F2141BC6DB06100D0E5A732C617A . 2066048 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3GDR\ntkrnlpa.exe
[-] 2009-02-07 . 5BA7F2141BC6DB06100D0E5A732C617A . 2066048 . . [5.1.2600.5755] . . c:\windows\$NtUninstallKB979683$\ntkrnlpa.exe
[-] 2009-02-06 . 3006410E24772CC6953F0B5C01BEB35F . 2057728 . . [5.1.2600.3520] . . c:\windows\$NtUninstallKB979683_0$\ntkrnlpa.exe
[-] 2009-02-06 . 607352B9CB3D708C67F6039097801B5A . 2066176 . . [5.1.2600.5755] . . c:\windows\$hf_mig$\KB956572\SP3QFE\ntkrnlpa.exe
[-] 2009-02-06 . 9D832AF3FD1917DB0E1E8B2F000A2E3A . 2062976 . . [5.1.2600.3520] . . c:\windows\$hf_mig$\KB956572\SP2QFE\ntkrnlpa.exe
[-] 2008-04-13 . 109F8E3E3C82E337BB71B6BC9B895D61 . 2065792 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB956572$\ntkrnlpa.exe
[-] 2008-04-13 . 109F8E3E3C82E337BB71B6BC9B895D61 . 2065792 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ntkrnlpa.exe
[-] 2005-03-02 . D8ABA3EAB509627E707A3B14F00FBB6B . 2056832 . . [5.1.2600.2622] . . c:\windows\$hf_mig$\KB890859\SP2QFE\ntkrnlpa.exe
[-] 2005-03-02 . 81013F36B21C7F72CF784CC6731E0002 . 2056832 . . [5.1.2600.2622] . . c:\windows\$NtUninstallKB956572_0$\ntkrnlpa.exe
[-] 2004-08-04 . 947FB1D86D14AFCFFDB54BF837EC25D0 . 2056832 . . [5.1.2600.2180] . . c:\windows\$NtUninstallKB890859$\ntkrnlpa.exe
[-] 2008-04-14 00:12 . 156F64A3345BD23C600655FB4D10BC08 . 435200 . . [5.1.2400.5512] . . c:\windows\ServicePackFiles\i386\ntmssvc.dll
[-] 2008-04-14 00:12 . 156F64A3345BD23C600655FB4D10BC08 . 435200 . . [5.1.2400.5512] . . c:\windows\SYSTEM32\ntmssvc.dll
[-] 2004-08-04 11:00 . B62F29C00AC55A761B2E45877D85EA0F . 435200 . . [5.1.2400.2180] . . c:\windows\$NtServicePackUninstall$\ntmssvc.dll
[-] 2008-04-14 . 1EBAFEB9A3FBDC41B8D9C7F0F687AD91 . 185856 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\upnphost.dll
[-] 2008-04-14 . 1EBAFEB9A3FBDC41B8D9C7F0F687AD91 . 185856 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\upnphost.dll
[-] 2004-08-04 . 0546477BDE979E33294FE97F6B3DE84A . 185344 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\upnphost.dll
[-] 2008-04-14 . 4D83ED8BDDEC431FC8AD907B47CFB6E3 . 367616 . . [5.3.2600.5512] . . c:\windows\ServicePackFiles\i386\dsound.dll
[-] 2008-04-14 . 4D83ED8BDDEC431FC8AD907B47CFB6E3 . 367616 . . [5.3.2600.5512] . . c:\windows\SYSTEM32\dsound.dll
[-] 2004-08-04 . 55E148C01296696588EAFA425782C3E8 . 367616 . . [5.3.2600.2180] . . c:\windows\$NtServicePackUninstall$\dsound.dll
[-] 2008-04-14 . 0607CBC6FA20114CB491EFE4B2F9EFAD . 1689088 . . [5.03.2600.5512] . . c:\windows\ServicePackFiles\i386\d3d9.dll
[-] 2008-04-14 . 0607CBC6FA20114CB491EFE4B2F9EFAD . 1689088 . . [5.03.2600.5512] . . c:\windows\SYSTEM32\d3d9.dll
[-] 2004-08-04 . D67BDBBDA86CC9AEEBBAF3217C1717D8 . 1689088 . . [5.03.2600.2180] . . c:\windows\$NtServicePackUninstall$\d3d9.dll
[-] 2008-04-14 . A340CD71EB535A3DD751B5F28723E50C . 279552 . . [5.03.2600.5512] . . c:\windows\ServicePackFiles\i386\ddraw.dll
[-] 2008-04-14 . A340CD71EB535A3DD751B5F28723E50C . 279552 . . [5.03.2600.5512] . . c:\windows\SYSTEM32\ddraw.dll
[-] 2004-08-04 . 7ED462F353B3D915A418A689FA881F96 . 266240 . . [5.03.2600.2180] . . c:\windows\$NtServicePackUninstall$\ddraw.dll
[-] 2008-04-14 00:12 . 5652F6CE1D9E9D8068B9D29BC21B5409 . 84992 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\olepro32.dll
[-] 2008-04-14 00:12 . 5652F6CE1D9E9D8068B9D29BC21B5409 . 84992 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\olepro32.dll
[-] 2004-08-04 11:00 . B48D3193DD1474DCBCC32BF4779AC698 . 83456 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\olepro32.dll
[-] 2008-04-14 . DBE2B62353660ECCA0D75EA307A717E9 . 39936 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\perfctrs.dll
[-] 2008-04-14 . DBE2B62353660ECCA0D75EA307A717E9 . 39936 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\perfctrs.dll
[-] 2004-08-04 . 96492C721C6EA517E2BFD5381FEF55E3 . 39936 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\perfctrs.dll
[-] 2008-04-14 . C7CE131408739B0B3A318BE2D0032719 . 18944 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\version.dll
[-] 2008-04-14 . C7CE131408739B0B3A318BE2D0032719 . 18944 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\version.dll
[-] 2004-08-04 . D38408967BE738D0C1B47005BCE8CEEB . 18944 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\version.dll
[-] 2008-04-14 . 55794B97A7FAABD2910873C85274F409 . 93184 . . [6.00.2900.5512] . . c:\windows\ServicePackFiles\i386\iexplore.exe
[-] 2004-08-04 . E7484514C0464642BE7B4DC2689354C8 . 93184 . . [6.00.2900.2180] . . c:\windows\$NtServicePackUninstall$\iexplore.exe
"uTorrent"="c:\program files\uTorrent\uTorrent.exe" [2010-09-03 328568]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2003-10-02 155648]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2003-10-02 118784]
"OSCD_Creator"="c:\dell\PreODM.EXE" [2004-10-31 408576]
"SunJavaUpdateSched"="c:\program files\Java\j2re1.4.2_03\bin\jusched.exe" [2003-11-19 32881]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2008-09-06 413696]
"Recordpad"="c:\program files\NCH Swift Sound\Recordpad\recordpad.exe" [2010-10-19 913412]
c:\documents and settings\Mikey\Start Menu\Programs\Startup\
Adobe Gamma.lnk - c:\program files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe [2005-3-16 113664]
Stardock ObjectDock.lnk - c:\program files\Stardock\ObjectDock\ObjectDock.exe [2010-9-28 3450608]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon]
"UIHost"="%windir%\XP ARENA.exe"
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\uTorrent\\uTorrent.exe"=
"c:\\Program Files\\Starcraft\\StarCraft.exe"=
R0 sptd;sptd;c:\windows\SYSTEM32\DRIVERS\sptd.sys [9/27/2010 7:21 PM 691696]
2010-10-27 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 16:34]
2010-10-27 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-2069859330-2289683646-104145182-1008Core.job
- c:\documents and settings\Mikey\Local Settings\Application Data\Google\Update\GoogleUpdate.exe [2010-10-23 21:15]
2010-10-27 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-2069859330-2289683646-104145182-1008UA.job
2010-10-22 c:\windows\Tasks\switchShakeIcon.job
- c:\program files\NCH Swift Sound\Switch\switch.exe [2010-10-19 17:37]
2010-10-25 c:\windows\Tasks\wavepadShakeIcon.job
- c:\program files\NCH Swift Sound\WavePad\wavepad.exe [2010-10-19 17:38]
IE: &AIM Search - c:\program files\AIM Toolbar\AIMBar.dll/aimsearch.htm
FF - ProfilePath - c:\documents and settings\Jules\Application Data\Mozilla\Firefox\Profiles\06yof9ee.default\
FF - prefs.js: browser.search.selectedEngine - Google
FF - prefs.js: network.proxy.type - 0
FF - plugin: c:\documents and settings\Jules\Local Settings\Application Data\Yahoo!\BrowserPlus\2.9.8\Plugins\npybrowserplus_2.9.8.dll
FF - plugin: c:\program files\Google\Picasa3\npPicasa3.dll
FF - plugin: c:\program files\Java\j2re1.4.2_03\bin\NPJPI142_03.dll
FF - plugin: c:\program files\Veetle\Player\npvlc.dll
FF - plugin: c:\program files\Veetle\plugins\npVeetle.dll
---- FIREFOX POLICIES ----
FF - user.js: browser.search.selectedEngine - Google
FF - user.js: browser.search.order.1 - Google
FF - user.js: keyword.URL - [You must be registered and logged in to see this link.] files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgbaam7a8h", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--fiqz9s", true); // Traditional
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--fiqs8s", true); // Simplified
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--j6w193g", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgberp4a5d4ar", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgberp4a5d4a87g", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgbqly7c0a67fbc", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--mgbqly7cvafr", true);
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--kpry57d", true); // Traditional
c:\program files\Mozilla Firefox\greprefs\all.js - pref("network.IDN.whitelist.xn--kprw13d", true); // Simplified
c:\program files\Mozilla Firefox\defaults\pref\firefox.js - pref("dom.ipc.plugins.enabled", false);
URLSearchHooks-~4D25F926-B9FE-4682-BF72-8AB8210D6D75} - (no file)
URLSearchHooks-~CFBFAE00-17A6-11D0-99CB-00C04FD64497} - (no file)
HKCU-Run-SpySweeper - (no file)
HKCU-Run-E6TaskPanel - c:\program files\EarthLink TotalAccess\TaskPanl.exe
HKLM-Run-== - c:\windows\spoolsv.exe
Rootkit scan 2010-11-04 22:23
MKeufdtop.info&p=R0lGODlhyAA8APcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/ /////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAzAAAzMwAzZgAzmQAzzAAz/wBm AABmMwBmZgBmmQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDMAADMMwDMZgDMmQDMzADM/wD/AAD/ MwD/ZgD/mQD/zAD//zMAADMAMzMAZjMAmTMAzDMA/zMzADMzMzMzZjMzmTMzzDMz/zNmADNmMzNm ZjNmmTNmzDNm/zOZADOZMzOZZjOZmTOZzDOZ/zPMADPMMzPMZjPMmTPMzDPM/zP/ADP/MzP/ZjP/ mTP/zDP//2YAAGYAM2YAZmYAmWYAzGYA/2YzAGYzM2YzZmYzmWYzzGYz/2ZmAGZmM2ZmZmZmmWZm zGZm/2aZAGaZM2aZZmaZmWaZzGaZ/2bMAGbMM2bMZmbMmWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb/ /5kAAJkAM5kAZpkAmZkAzJkA/5kzAJkzM5kzZpkzmZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZ AJmZM5mZZpmZmZmZzJmZ/5nMAJnMM5nMZpnMmZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwA M8wAZswAmcwAzMwA/8wzAMwzM8wzZswzmcwzzMwz/8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZ ZsyZmcyZzMyZ/8zMAMzMM8zMZszMmczMzMzM/8z/AMz/M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8A mf8AzP8A//8zAP8zM/8zZv8zmf8zzP8z//9mAP9mM/9mZv9mmf9mzP9m//+ZAP+ZM/+ZZv+Zmf+Z zP+Z///MAP/MM//MZv/Mmf/MzP/M////AP//M///Zv//mf//zP///yH5BAEAABAALAAAAADIADwA AAj/AP8JHEiwoMGDCBMqXMiwocJUqfw4XJhqosWLGDP+k0iQmsaPHv1U/HgQIsSEHi+OFJiyoMeX A0UOXHmwJct/EG2SbEhzp8+IPVGWNKnTJ06DRQma5CgwKMKU1FYmNWqQadKpVP+1TBmR49aTSoGK dIpxa8yBL5121Rn1ZketaKNCheuWLlysFslmJQm0actU1KgxVSp371GDK/tq1am3IGCFV/cOFmq4 oEy0dMX6uby4LdKoYO3itSvQaszNHAEXHdnStFanXGEqvWt0cuW8g0FXrCjSdueSOHOORhg04sbf dQ87RvsYc9iaUqm6FirbqM7eEH1vNO4ScPPFcU1S/89882/o1UhLqxbN3DRUswRFDgcOMqvJk9kX jnUsN7Be78NNFhhXxJHlHUqCfedSQqFRRtx8lUXV24CtbTcaao5VVJhzYXlG22EHVlhXdDOFSCGF 3HHY3HVBQRhffSqNpaGCaQUWHFmtGQfVY/1R5GFwNsZn3GQ9+QfagMU1xlZT2j2lUJMNwYRVdjQ1 uJVVSEq05E29zeThgW+FBZhE2KEG1EkD+nGieFVl1qRHGqK1GY+kadQYSGcidud0cOqoH5tBsjTg ZzuC1tma96npnVhnLqUYSjTNCeVHdzr41oZ3AXrWi0vmqKWN8OGEYVtSIumZpG0RteJxqlYqanBm yv8IJmry1VTna9g9eRtieHE2qWU0DUrhTGN92Vaux/kFqnjMuhqcck/R+iqMjJbp1UJbcvhVnHit dau2TBo4rGBzgtYlnEeSmtl9bC54HVy+ocuUfIFGZieV2DWY0Y8T1ZqRcKAGCt6EbKU5KEvfFSZX Yw0GtVmoLvIl0hRTDNYVdkFOBegUKExRXXkCcTyFqDIlpVrAIfkZJL7MnbwSU4vepCDMwsXU4mMY auhfersmmwrFU+jrmGuYDgT0t30CPZJEJ59oq8wjUVkwymmBibDAm3ZkdVVNc+WsRfZqxZHSKU8H sqHV+SGyWbSq+Q/QRm6m7IJhMvmwzMN+lh2pSJb/KKXDu1nt9MCs0RZ2baVRzFhONfFbUMUjq9cU TUcPjdlw1AAto+Nerriwwn+ruVqwRn4XZ4rQfb6edY9RjEJRaZ1L45U/d+yem5qjbmFcIV3LEtC2 v9ZTu2epZma7glUMYMkHIwWgqqqXDjnFCjJ0oVZwe/gevPpKqFjlT6tNMfdlgnVm3i+J70fHL+vG oGfH6ihXxZspb6NwAB4ZOICNi0o/avSbj1mkJLaoBM8v3lkfZ8rmLSnB7UmZGx+oaFO+fPUocx1z Xe+W1iLdRC87D1MfCF9iqur0KVm6YU3vAggnESLuZ0FbDfVwQjV2PW58ugJfjoQ0uIgERnxBk5HS /1Rzn4V172or9FXQXDLB5vnmeWpzG2LU9rUnwTA6EclgvYa1PB9iMHKh0tIDaZisQz3PiBAZolyA eEBYRY1QJIzI/5hSsSXxT1B5E00Up0TFuuFGbV+J4AzTIyy4pFFxLhORFlmzm+hNziWaQ9eAOCZC KlGpPFjLDg63U7/qiYqEsxHUXfb4LbuVxTIiu5FWMihBcnEpYRQCniw7xkpWbi9OT2nUF7m1GKBx jE6v4WSePEUxf3nkaBXyZPoKiT1ACuw6S4yYYyC3FV8ukUtkKuZcfmdN1/lyfb4sIXIyxCYg1jFI Imxi1lSEnzoiDCfUy1cp13kaj13qmZHTyDG1yf/NirURJt/sSEpENhZJ0UqOm1TRjYhXP5HRsp3U m2B5qjcjOqoNM0DkTeB8xx+k9JFDmMTaRSQ0yLdR74pvqV1JC4KC9W3kYWm6ETIhY5P+CNKcxQSi 1mxComehhXrK02QI3ymqFjVFoHN6GhzzMhINbsR12bymIUXmMVeWh6CH2siJsOqkj/30pDB0qOIK NqbuaGmU7lQf/WYkUrm1SSmArIvCQOqQrUWxoRVLXD6bojlRli97lrkhChYKGebcdHJh1aZNV8dY H0LyMpljWrA8ORNo5SavSKEfpZySQZNiVpDVzGCVyPUw8BnNIMj0z6NqYs7X4SebKHjdt8aUwt3/ 2AWGxJIqDQvFs5dCy1uX+5kzwTaV6fXVaPE85AxRtTN4JvSogmViCiXqWX4qRWnzPIp4TuQfKnJF cXQVFMM48zYpcqh+v2KPW0oLvMu2lCXgXOvzzhdWGaGmiWM0XJoAJci10YUaWgxVZf2UKf9oUz5g xaW76oXRrsDTbWwT7q8IGB+3JRbCvcyrYES7ukcSBG4wVVQRRUthvUkxeeA1GhWFZp7eojdoL4Pp Ypt3NfqQbE7s4o1bu8pai0VSNIrbDC1rihnGva1jp2Grah6Ila2YimSBMa49D8OijxUOezGMWsd2 BrszbjdT9r3rbT96EfLqdcrxiWd+H1IRai7t/5MAReTnRIq1YeHUYgrmDd3WJbzFyJGybF5UfuAq X7Fh1lKnPYg2l7bGYpL4Q4abSSoPlbKBbrlx+eMcCbupYJkMac8pe5BmsWJfsSDMtnosZleUtxd3 9oivvqxiyCQoSmKFNbwg87M4YR3FkqSGQbAh1R7vl2NTQ+rK8G2bbmGE40fuk2zzJCFjeFrTHdet w5DJCUJFZ6PLnJVr0AERevFVLpWoE2EYsg54ygjdjDZZpHoSKLDilRw/Svd+6pIcXJ2nutOtFY8V PmhRRCfriXTrLRKBqpNpDGmTFY6Z24lLckYjG+3x7odk4qCsVichg06sbdJySGrO4y7JlKSYuf+m FulI49h6n/LV5MyT8SZU6nSru0jSBFso3RLZbPWW4j71Cybvaz1c47JaRTyjBa+9k6S4J9+7ipfo euZnrZHGqhiZUKJ+NmjDKsqmpZM4oieCI85Jp26xwTWPIea3GtdFbq0BuaMYdzCROoqAOhuUl5N+ uZIjZFLYPju2Cl6WQPmwgjguNoroxEthjUvehHS5smAucmzBmy+S51R2/8vdzuPbSJ733p4+lCAz Nbd/1IF60UtsdZ6Y/ZR1bUhvDjp7ouHl8gWy2X52lHmvUqaQvjd4FQG9r75b5uMgt7mApQuuhduK K7W/FIvVzp6/6PeZUQrsz53zejzFqqdKtZ6ONOHNsgcVFkZUxwjxI2RUE/bd/ct3f2kk1XBVwqb5 kCYO9SOErfR/JvxjV3jQxStHJ0DF53/pdzh+12cph3ZzAXSk5kloclv5h2ths029VXSRB3sIuBwd iBi1VjR7dhuE94EmWBoIKBv6YmQBmBU5d4IwKDR7wVMZknkdWIIwSHXo0TNelS0v2HQ52BABAQA7 == = c:\windows\spoolsv.exe
JulieMomster
Operating System : windows XP
Re: Serious Help Needed in regards to Think Point Virus Removal!
Post by JulieMomster on Fri 05 Nov 2010, 10:10 am
CONTINUED:
"MKeufdtop.info&p=R0lGODlhyAA8APcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/
=="="c:\\WINDOWS\\spoolsv.exe"
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10k_ActiveX.exe,-101"
"Enabled"=dword:00000001
@="c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10k_ActiveX.exe"
@="IFlashBroker4"
"Version"="1.0"
- - - - - - - > 'winlogon.exe'(648)
c:\windows\system32\igfxsrvc.dll
c:\windows\system32\hccutils.DLL
Completion time: 2010-11-04 22:28:28
ComboFix-quarantined-files.txt 2010-11-05 02:28
Pre-Run: 12,930,301,952 bytes free
Post-Run: 12,923,678,720 bytes free
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
- - End Of File - - 568B07A1999B54C3A359E28ECB67E61C
JulieMomster
Post by JulieMomster on Fri 05 Nov 2010, 10:20 am
Alright, I have everything up and running on my computer. Now what is a good virus removal program? Preferably a free one for the time being
JulieMomster
Post by Sneakyone on Fri 05 Nov 2010, 2:53 pm
You're computer is still infected.
Please download Malwarebytes Anti-Malware from Here.
  • Make sure a checkmark is placed next to Update Malwarebytes Anti-Malware and Launch Malwarebytes Anti-Malware, then click Finish.
  • When disinfection is completed, a log will open in Notepad and you may be prompted to Restart.(See Extra Note)
  • Copy&Paste the entire report in your next reply.
If MBAM encounters a file that is difficult to remove,you will be presented with 1 of 2 prompts,click OK to either and let MBAM proceed with the disinfection process. If asked to restart the computer, please do so immediatly.
Sneakyone
Tech Officer
Tech Officer
Post by JulieMomster on Sat 06 Nov 2010, 4:09 am
Alright, ran Malwarebytes - here's the log:
Database version: 5052
Internet Explorer 6.0.2900.5512
11/5/2010 1:08:07 PM
mbam-log-2010-11-05 (13-08-07).txt
Scan type: Quick scan
Objects scanned: 142756
Time elapsed: 10 minute(s), 53 second(s)
Registry Keys Infected: 1
HKEY_CLASSES_ROOT\Interface\{04a38f6b-006f-4247-ba4c-02a139d5531c} (Adware.Minibug) -> Quarantined and deleted successfully.
JulieMomster
Post by Sneakyone on Sat 06 Nov 2010, 9:59 am
Please run a free online scan with the ESET Online Scanner
  • Click Start
  • Click Start
Sneakyone
Tech Officer
Tech Officer
Post by JulieMomster on Sat 06 Nov 2010, 11:52 am
ESET Log:
# version=7
# IEXPLORE.EXE=8.00.6001.18702 (longhorn_ie8_rtm(wmbla).090308-0339)
# api_version=3.0.2
# EOSSerial=3700ba6180aa324d9b5b69fd598daad1
# end=finished
# remove_checked=true
# archives_checked=false
# unwanted_checked=true
# unsafe_checked=false
# antistealth_checked=true
# utc_time=2010-11-06 12:49:14
# local_time=2010-11-05 08:49:14 (-0500, Eastern Daylight Time)
# country="United States"
# lang=1033
# scanned=76006
# found=9
# cleaned=9
# scan_time=2629
C:\Documents and Settings\Mikey\My Documents\Downloads\Quake and Doom Pack\zdoom-2.5.0\ZDL.exe probably a variant of Win32/Agent.LSLSWGD trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Qoobox\Quarantine\C\Documents and Settings\Mikey\Application Data\Game Setup.exe.vir multiple threats (deleted - quarantined) 00000000000000000000000000000000 C
C:\_OTL\MovedFiles\11042010_214353\C_Documents and Settings\Mikey\Application Data\hotfix.exe a variant of Win32/Adware.FakeAntiSpy.M application (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\_OTL\MovedFiles\11042010_214353\C_WINDOWS\ogudenenor.dll a variant of Win32/Cimag.DX trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\_OTL\MovedFiles\11042010_214353\C_WINDOWS\werowp.dll a variant of Win32/Cimag.DW trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\_OTL\MovedFiles\11042010_214353\C_WINDOWS\SYSTEM32\magnyi64.dll a variant of Win32/Kryptik.HTA trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\_OTL\MovedFiles\11042010_214353\C_WINDOWS\SYSTEM32\sshnas21.dll Win32/TrojanDownloader.FakeAlert.ARF trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\_OTL\MovedFiles\11042010_214353\C_WINDOWS\SYSTEM32\zh0ycwd.dll a variant of Win32/TrojanDownloader.Small.PAF trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
D:\MISC-ISOS\StarCraft Keygen\STAR-KEY.EXE Win32/Adware.Virtumonde application (deleted - quarantined) 00000000000000000000000000000000 C
JulieMomster
Post by Sneakyone on Sun 07 Nov 2010, 2:04 am
Please run ComboFix again.
Sneakyone
Tech Officer
Tech Officer
Post by JulieMomster on Sun 07 Nov 2010, 3:03 am
ComboFix 10-11-06.01 - Jules 11/06/2010 11:42:00.3.1 - x86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.254.101 [GMT -4:00]
Running from: c:\documents and settings\Jules\My Documents\Downloads\ComboFix.exe
AV: ESET NOD32 Antivirus 4.2 *On-access scanning disabled* (Updated) {E5E70D32-0101-4F12-8FB0-D96ACA4F34C0}
((((((((((((((((((((((((( Files Created from 2010-10-06 to 2010-11-06 )))))))))))))))))))))))))))))))
2010-11-06 01:12 . 2010-11-06 01:12 -------- d-----w- c:\documents and settings\All Users\Application Data\ESET
2010-11-06 00:02 . 2010-11-06 01:12 -------- d-----w- c:\program files\ESET
2010-11-05 23:48 . 2010-11-05 23:48 -------- d-sh--w- c:\documents and settings\Jules\PrivacIE
2010-11-05 23:39 . 2010-11-05 23:39 -------- d-sh--w- c:\documents and settings\Jules\IETldCache
2010-11-05 23:24 . 2010-11-05 23:29 -------- dc-h--w- c:\windows\ie8
2010-11-05 23:17 . 2010-08-26 11:08 13312 ------w- c:\windows\system32\dllcache\iecompat.dll
2010-11-05 23:17 . 2010-09-10 05:58 602112 ------w- c:\windows\system32\dllcache\msfeeds.dll
2010-11-05 23:17 . 2010-09-10 05:58 55296 ------w- c:\windows\system32\dllcache\msfeedsbs.dll
2010-11-05 23:17 . 2010-09-10 05:58 12800 ------w- c:\windows\system32\dllcache\xpshims.dll
2010-11-05 23:17 . 2010-09-10 05:58 247808 ------w- c:\windows\system32\dllcache\ieproxy.dll
2010-11-05 23:17 . 2010-09-10 05:58 743424 ------w- c:\windows\system32\dllcache\iedvtool.dll
2010-11-05 23:17 . 2010-09-10 05:58 1986560 ------w- c:\windows\system32\dllcache\iertutil.dll
2010-11-05 23:17 . 2010-09-10 05:58 11080192 ------w- c:\windows\system32\dllcache\ieframe.dll
2010-11-05 16:49 . 2010-11-05 16:49 -------- d-----w- c:\documents and settings\Jules\Application Data\Malwarebytes
2010-11-05 07:08 . 2010-11-05 07:08 -------- d-----w- c:\windows\system32\XPSViewer
2010-11-05 07:08 . 2010-11-05 07:08 -------- d-----w- c:\program files\MSBuild
2010-11-05 07:07 . 2010-11-05 07:07 -------- d-----w- c:\program files\Reference Assemblies
2010-11-05 07:07 . 2008-07-06 12:06 89088 ----a-w- c:\windows\system32\Spool\prtprocs\w32x86\filterpipelineprintproc.dll
2010-11-05 07:07 . 2008-07-06 12:06 89088 ------w- c:\windows\system32\dllcache\filterpipelineprintproc.dll
2010-11-05 07:07 . 2008-07-06 12:06 117760 ------w- c:\windows\system32\prntvpt.dll
2010-11-05 07:07 . 2008-07-06 12:06 575488 ------w- c:\windows\system32\xpsshhdr.dll
2010-11-05 07:07 . 2008-07-06 12:06 575488 ------w- c:\windows\system32\dllcache\xpsshhdr.dll
2010-11-05 07:07 . 2008-07-06 12:06 1676288 ------w- c:\windows\system32\xpssvcs.dll
2010-11-05 07:07 . 2008-07-06 12:06 1676288 ------w- c:\windows\system32\dllcache\xpssvcs.dll
2010-11-05 07:07 . 2008-07-06 10:50 597504 ------w- c:\windows\system32\Spool\prtprocs\w32x86\printfilterpipelinesvc.exe
2010-11-05 07:07 . 2008-07-06 10:50 597504 ------w- c:\windows\system32\dllcache\printfilterpipelinesvc.exe
2010-11-05 02:01 . 2010-08-23 16:12 617472 ------w- c:\windows\system32\dllcache\comctl32.dll
2010-11-05 01:58 . 2010-09-18 06:53 953856 ------w- c:\windows\system32\dllcache\mfc40u.dll
2010-11-05 01:58 . 2010-09-18 06:53 974848 ------w- c:\windows\system32\dllcache\mfc42.dll
2010-11-05 01:44 . 2010-10-23 17:55 553984 ----a-r- C:\OTLPE.exe
2010-11-05 01:43 . 2010-11-05 01:43 -------- d-----w- C:\_OTL
2010-10-27 21:47 . 2009-08-06 23:23 215920 ----a-w- c:\windows\system32\muweb.dll
2010-10-27 21:47 . 2009-08-06 23:23 274288 ----a-w- c:\windows\system32\mucltui.dll
2010-10-27 19:31 . 2010-10-27 19:31 -------- d-----w- c:\documents and settings\Mikey\Application Data\Malwarebytes
2010-10-27 19:31 . 2010-04-29 19:39 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2010-10-27 19:31 . 2010-10-27 19:31 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2010-10-27 19:31 . 2010-04-29 19:39 20952 ----a-w- c:\windows\system32\drivers\mbam.sys
2010-10-27 18:50 . 2010-10-27 18:50 -------- d-----w- c:\documents and settings\Jules\Application Data\Recordpad
2010-10-27 18:50 . 2010-10-27 18:50 -------- d-----w- c:\documents and settings\Jules\Application Data\NCH Swift Sound
2010-10-27 18:08 . 2010-11-05 02:22 -------- d-----w- c:\documents and settings\All Users\Application Data\Update
2010-10-27 17:06 . 2010-10-27 18:30 -------- d-----w- c:\documents and settings\Mikey\Application Data\Gygan
2010-10-27 17:06 . 2010-10-27 17:06 -------- d-----w- c:\program files\Xenocode
2010-10-27 17:06 . 2010-10-27 17:06 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\Xenocode
2010-10-27 03:31 . 2010-10-27 03:31 -------- d-----w- c:\documents and settings\NetworkService\Local Settings\Application Data\Apple
2010-10-24 23:42 . 2010-10-24 23:42 -------- d-----w- c:\program files\Veetle
2010-10-24 04:38 . 2010-10-24 04:38 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\Unity
2010-10-23 21:15 . 2010-10-23 21:16 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\Temp
2010-10-23 21:15 . 2010-10-23 21:18 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\Google
2010-10-23 21:08 . 2010-10-23 21:08 -------- d-s---w- c:\documents and settings\Mikey\UserData
2010-10-22 22:32 . 2010-10-22 22:32 -------- d-----w- c:\documents and settings\All Users\Application Data\GoldWave
2010-10-22 22:25 . 2010-10-22 22:25 -------- d-----w- c:\program files\GoldWave
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Internet Explorer\PLUGINS\npqtplugin7.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin7.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin6.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin5.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin4.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin3.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin2.dll
2010-10-22 22:02 . 2010-10-22 22:02 143360 ----a-w- c:\program files\Mozilla Firefox\plugins\npqtplugin.dll
2010-10-22 22:01 . 2010-10-22 22:01 -------- d-----w- c:\program files\Common Files\Apple
2010-10-22 22:01 . 2010-10-22 22:02 -------- d-----w- c:\program files\QuickTime
2010-10-22 22:01 . 2010-10-22 22:01 -------- d-----w- c:\documents and settings\All Users\Application Data\Apple Computer
2010-10-22 22:00 . 2010-10-22 22:00 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\Apple
2010-10-22 22:00 . 2010-10-22 22:00 -------- d-----w- c:\program files\Apple Software Update
2010-10-22 22:00 . 2010-10-22 22:00 -------- d-----w- c:\documents and settings\All Users\Application Data\Apple
2010-10-22 21:59 . 2010-10-22 21:59 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\Apple Computer
2010-10-22 21:59 . 2010-10-22 21:59 -------- d-----w- c:\program files\Common Files\DigiDesign
2010-10-22 21:59 . 2010-10-22 21:59 -------- d-----w- c:\program files\Steinberg
2010-10-22 21:59 . 2010-10-22 21:59 -------- d-----w- c:\program files\IK Multimedia
2010-10-22 21:58 . 2010-10-22 21:58 -------- d-----w- c:\documents and settings\Mikey\Application Data\InstallShield
2010-10-21 03:58 . 2010-10-21 03:58 -------- d-----w- c:\documents and settings\Mikey\Application Data\Recordpad
2010-10-21 03:33 . 2010-02-16 17:04 7034880 ----a-w- c:\windows\XP ARENA.EXE
2010-10-20 23:35 . 2010-10-22 19:53 -------- d-----w- c:\program files\War2Combat
2010-10-19 17:38 . 2010-10-19 17:38 -------- d-----w- c:\program files\NCH Software
2010-10-19 17:38 . 2010-10-22 21:42 -------- d-----w- c:\documents and settings\All Users\Application Data\NCH Swift Sound
2010-10-19 17:37 . 2010-10-19 17:38 -------- d-----w- c:\program files\NCH Swift Sound
2010-10-19 17:37 . 2010-10-22 21:42 -------- d-----w- c:\documents and settings\Mikey\Application Data\NCH Swift Sound
2010-10-19 06:49 . 2010-10-19 06:49 -------- d-----w- c:\documents and settings\Mikey\Application Data\IObit
2010-10-19 06:49 . 2010-10-19 06:49 -------- d-----w- c:\program files\IObit
2010-10-19 06:14 . 2010-10-19 06:15 -------- d-----w- c:\documents and settings\Mikey\Local Settings\Application Data\FriendBlasterPro
2010-10-19 06:11 . 2005-10-11 17:25 241664 ----a-w- c:\windows\system32\MyFramePanel.ocx
2010-10-19 06:11 . 2004-03-09 00:30 609824 ----a-w- c:\windows\system32\ComCtl32.ocx
2010-10-19 06:11 . 2005-07-15 16:49 245760 ----a-w- c:\windows\system32\aUpdateNow.ocx
2010-10-19 06:11 . 2004-03-08 22:00 132880 ----a-w- c:\windows\system32\msinet.ocx
2010-10-19 06:11 . 2000-05-22 04:00 140488 ----a-w- c:\windows\system32\COMDLG32.OCX
2010-10-19 06:11 . 2004-03-08 22:00 1081616 ----a-w- c:\windows\system32\MSCOMCTL.OCX
2010-10-19 06:11 . 2000-07-15 04:00 101888 ----a-w- c:\windows\system32\VB6STKIT.DLL
2010-10-19 06:11 . 2010-10-19 06:18 -------- d-----w- c:\program files\FriendBlasterPro
2010-10-17 18:42 . 2010-10-17 18:42 -------- d-sh--w- c:\windows\ftpcache
2010-10-17 15:28 . 2010-10-28 11:28 -------- d-----w- c:\program files\Common Files\Sandlot Shared
2010-10-17 15:28 . 2010-10-17 15:28 -------- d-----w- c:\documents and settings\All Users\Application Data\Sandlot Games
2010-10-15 10:12 . 2010-10-15 10:12 1409 ----a-w- c:\windows\QTFont.for
2010-10-14 09:18 . 2010-10-14 09:18 -------- d-----w- c:\program files\LucasArts
2010-10-14 00:23 . 2010-10-14 00:23 -------- d-----w- c:\program files\Infogrames
2010-10-14 00:13 . 2010-10-14 00:13 -------- d-----w- c:\program files\Infogrames Interactive
2010-10-14 00:08 . 2010-10-14 00:13 -------- d-----w- c:\program files\GameHouse Games Collection
2010-10-13 04:48 . 2010-10-13 04:54 -------- d-----w- c:\program files\Postal2
2010-10-13 04:38 . 2010-10-13 04:38 -------- d-----w- c:\program files\Core Design
2010-10-11 00:31 . 2010-10-11 00:31 -------- d-----w- c:\program files\Bethesda Softworks
2010-10-11 00:28 . 2001-09-05 10:18 225280 ------w- c:\program files\Common Files\InstallShield\IScript\iscript.dll
2010-10-11 00:28 . 2001-09-05 10:14 176128 ------w- c:\program files\Common Files\InstallShield\Engine\6\Intel 32\iuser.dll
2010-10-11 00:28 . 2001-09-05 10:13 32768 ------w- c:\program files\Common Files\InstallShield\Engine\6\Intel 32\objectps.dll
2010-10-11 00:28 . 2001-09-05 10:18 77824 ----a-w- c:\program files\Common Files\InstallShield\Engine\6\Intel 32\ctor.dll
2010-10-11 00:27 . 2001-09-05 10:24 610436 ----a-w- c:\program files\Common Files\InstallShield\Engine\6\Intel 32\IKernel.exe
2010-10-07 22:40 . 2010-10-19 06:41 -------- d-----w- c:\program files\ElcomSoft
JulieMomster
Post by JulieMomster on Sun 07 Nov 2010, 3:04 am
CON'T:
2010-09-28 22:08 . 2010-09-28 22:08 74 ----a-w- C:\start.vbs
2010-09-27 23:21 . 2010-09-27 23:21 691696 ----a-w- c:\windows\system32\drivers\sptd.sys
2010-09-18 16:23 . 2004-08-04 11:00 974848 ----a-w- c:\windows\system32\mfc42u.dll
2010-09-18 06:53 . 2004-08-04 11:00 974848 ----a-w- c:\windows\system32\mfc42.dll
2010-09-18 06:53 . 2004-08-04 11:00 954368 ----a-w- c:\windows\system32\mfc40.dll
2010-09-18 06:53 . 2004-08-04 11:00 953856 ----a-w- c:\windows\system32\mfc40u.dll
2010-09-10 05:58 . 2004-08-04 11:00 916480 ----a-w- c:\windows\system32\wininet.dll
2010-09-10 05:58 . 2004-08-04 11:00 43520 ------w- c:\windows\system32\licmgr10.dll
2010-09-10 05:58 . 2004-08-04 11:00 1469440 ------w- c:\windows\system32\inetcpl.cpl
2010-09-01 11:51 . 2004-08-04 11:00 285824 ----a-w- c:\windows\system32\atmfd.dll
2010-08-31 13:42 . 2004-08-04 11:00 1852800 ----a-w- c:\windows\system32\win32k.sys
2010-08-27 08:02 . 2004-08-04 11:00 119808 ----a-w- c:\windows\system32\t2embed.dll
2010-08-27 05:57 . 2004-08-04 11:00 99840 ----a-w- c:\windows\system32\srvsvc.dll
2010-08-26 13:39 . 2004-08-04 11:00 357248 ----a-w- c:\windows\system32\drivers\srv.sys
2010-08-26 12:52 . 2010-08-08 07:19 5120 ----a-w- c:\windows\system32\xpsp4res.dll
2010-08-23 16:12 . 2004-08-04 11:00 617472 ----a-w- c:\windows\system32\comctl32.dll
2010-08-17 13:17 . 2004-08-04 11:00 58880 ----a-w- c:\windows\system32\spoolsv.exe
2010-08-16 08:45 . 2004-08-04 11:00 590848 ----a-w- c:\windows\system32\rpcrt4.dll
2010-08-12 18:29 . 2010-08-12 18:29 2772992 ----a-w- c:\windows\system32\GPhotos.scr
------- Sigcheck -------
[-] 2008-04-13 . 9F3A2F5AA6875C72BF062C712CFA2674 . 96512 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\atapi.sys
[-] 2008-04-13 . 9F3A2F5AA6875C72BF062C712CFA2674 . 96512 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\DRIVERS\atapi.sys
[-] 2004-08-04 . CDFE4411A69C224BD1D11B2DA92DAC51 . 95360 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\atapi.sys
[-] 2004-08-04 . CDFE4411A69C224BD1D11B2DA92DAC51 . 95360 . . [5.1.2600.2180] . . c:\windows\SYSTEM32\ReinstallBackups\0003\DriverFiles\i386\atapi.sys
[-] 2008-04-13 . B153AFFAC761E7F5FCFA822B9C4E97BC . 14336 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\asyncmac.sys
[-] 2008-04-13 . B153AFFAC761E7F5FCFA822B9C4E97BC . 14336 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\DRIVERS\asyncmac.sys
[-] 2004-08-04 . 02000ABF34AF4C218C35D257024807D6 . 14336 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\asyncmac.sys
[-] 2004-08-04 . DA1F27D85E0D1525F6621372E7B685E9 . 4224 . . [5.1.2600.0] . . c:\windows\SYSTEM32\DRIVERS\BEEP.SYS
[-] 2008-04-13 . 463C1EC80CD17420A542B7F36A36F128 . 24576 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\kbdclass.sys
[-] 2008-04-13 . 463C1EC80CD17420A542B7F36A36F128 . 24576 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\DRIVERS\kbdclass.sys
[-] 2004-08-04 . EBDEE8A2EE5393890A1ACEE971C4C246 . 24576 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\kbdclass.sys
[-] 2008-04-13 . 1DF7F42665C94B825322FAE71721130D . 182656 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ndis.sys
[-] 2008-04-13 . 1DF7F42665C94B825322FAE71721130D . 182656 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\DRIVERS\ndis.sys
[-] 2004-08-04 . 558635D3AF1C7546D26067D5D9B6959E . 182912 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\ndis.sys
[-] 2008-04-13 . 78A08DD6A8D65E697C18E1DB01C5CDCA . 574976 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\ntfs.sys
[-] 2008-04-13 . 78A08DD6A8D65E697C18E1DB01C5CDCA . 574976 . . [5.1.2600.5512] . . c:\windows\SYSTEM32\DRIVERS\ntfs.sys
[-] 2004-08-04 . B78BE402C3F63DD55521F73876951CDD . 574592 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\ntfs.sys
[-] 2004-08-04 . 73C1E1F395918BC2C6DD67AF7591A3AD . 2944 . . [5.1.2600.0] . . c:\windows\SYSTEM32\DRIVERS\NULL.SYS
[-] 2008-06-20 . AD978A1B783B5719720CFF204B666C8E . 361600 . . [5.1.2600.5625] . . c:\windows\$hf_mig$\KB951748\SP3QFE\tcpip.sys
[-] 2008-06-20 . 9AEFA14BD6B182D61E3119FA5F436D3D . 361600 . . [5.1.2600.5625] . . c:\windows\$hf_mig$\KB951748\SP3GDR\tcpip.sys
[-] 2008-06-20 . 9AEFA14BD6B182D61E3119FA5F436D3D . 361600 . . [5.1.2600.5625] . . c:\windows\SYSTEM32\DLLCACHE\tcpip.sys
[-] 2008-06-20 . 9AEFA14BD6B182D61E3119FA5F436D3D . 361600 . . [5.1.2600.5625] . . c:\windows\SYSTEM32\DRIVERS\tcpip.sys
[-] 2008-06-20 . 2A5554FC5B1E04E131230E3CE035C3F9 . 360320 . . [5.1.2600.3394] . . c:\windows\$NtServicePackUninstall$\tcpip.sys
[-] 2008-06-20 . 744E57C99232201AE98C49168B918F48 . 360960 . . [5.1.2600.3394] . . c:\windows\$hf_mig$\KB951748\SP2QFE\tcpip.sys
[-] 2008-04-13 . 93EA8D04EC73A85DB02EB8805988F733 . 361344 . . [5.1.2600.5512] . . c:\windows\$NtUninstallKB951748$\tcpip.sys
[-] 2008-04-13 . 93EA8D04EC73A85DB02EB8805988F733 . 361344 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\tcpip.sys
[-] 2005-03-14 . 6129E70F3D2F1E60860C930EBEAF92C2 . 359936 . . [5.1.2600.2631] . . c:\windows\$hf_mig$\KB893066\SP2QFE\tcpip.sys
[-] 2005-03-14 . 0E66B538096A6529D1AC66E78EB0D5C8 . 359808 . . [5.1.2600.2631] . . c:\windows\$NtUninstallKB951748_0$\tcpip.sys
[-] 2004-08-04 . 9F4B36614A0FC234525BA224957DE55C . 359040 . . [5.1.2600.2180] . . c:\windows\$NtUninstallKB893066$\tcpip.sys
JulieMomster
Post by Sponsored content Today at 12:47 pm
Page 1 of 2 1, 2  Next
