Monitor Blinks But Does Not Come on
Post by Sir $wat on 26th October 2010, 10:57 pm
Hey, I was recently given a monitor (Flat Screen) from a friend. However, it does not work. When i press the power button, the light keeps blinking but the screen remains blank.
What can be the problem?
Points Points : 34201
Re: Monitor Blinks But Does Not Come on
Post by Dr Jay on 28th October 2010, 4:57 am
Hello. Glad to have you here at GeekPolice.
Please wait here, while I refer you to an excellent Tech Advisor or other staff.
Posts Posts : 14309
Points Points : 302960
Post by Capt.Jack Sparrow on 28th October 2010, 9:10 pm
Maybe the signal is not coming. Its possible it might be a bad cable.
- Captain
Regards,
Captain MVP
It is considered
courteous to  post a reply if you have been able to resolve your problem, or received  an answer to your question.
Capt.Jack Sparrow
Posts Posts : 321
Joined Joined : 2010-09-27
OS OS : Windows 7 Ultimate, Ubuntu 10.04
Protection Protection : Avast, WinPatrol, Malwarebytes, Windows Firewall
Points Points : 26968
Post by Sir $wat on 29th October 2010, 10:27 am
i tried it with two different cables...
so it's not that..
thanx
Post by Capt.Jack Sparrow on 29th October 2010, 3:49 pm
Did you test it different PC ?
Regards,
Captain MVP
It is considered
Capt.Jack Sparrow
Posts Posts : 321
Post by Sir $wat on 31st October 2010, 12:25 pm
yes, on two different pcs...
Post by Capt.Jack Sparrow on 4th November 2010, 3:26 am
Is it working in that 2 different PC's ? Not sure though because its really old behavior
Regards,
Captain MVP
It is considered
Capt.Jack Sparrow
Posts Posts : 321
Post by Nazzgull on 4th November 2010, 10:07 pm
Probably dead. Try to open monitor and check Smile
Posts Posts : 2330
Points Points : 40485
