External Harddrive problems
Post by DIADEM on 24th October 2010, 1:36 am
I'm having problems with my external harddrive, I keep getting the cylic redundacy check error and the please format harddisk. Please help.
DIADEM
Posts Posts : 73
Joined Joined : 2008-12-07
OS OS : windows xp
Points Points : 29245
Re: External Harddrive problems
Post by Dr Jay on 28th October 2010, 4:47 am
Sorry for the delay. Let us know if you still need help.
Posts Posts : 14295
Points Points : 302922
Post by Nazzgull on 5th November 2010, 11:31 pm
Hi, did you tried to Format it or you didn't ?
If you can, do it. If you don't want to lose your data, just plug your hard drive in computer, find it in My Computer -> Right click on it > Properties > Tools > Check now.. > Select both methods and press Start button.
Posts Posts : 2330
Points Points : 40475
