Connecting Samsung Blu Ray BD-C6500 to Linksys wireless WRT310N
Post by jeffco79 on Wed Oct 20, 2010 4:19 pm
I can get connected but can't get to the internet. I have a WEP key but can't figure out how to enter the WEP in the Samsung setup. Anyone done this successfully?
jeffco79
Posts Posts : 5
Joined Joined : 2010-01-11
Points Points : 25226
Re: Connecting Samsung Blu Ray BD-C6500 to Linksys wireless WRT310N
Post by Dr Jay on Fri Oct 22, 2010 9:14 pm
Sorry for the delay in getting to you...
Please wait here, while I refer you to an excellent Tech Advisor or other staff.
Posts Posts : 13713
Points Points : 302059
Post by jeffco79 on Sat Oct 23, 2010 5:42 pm
I think the problem is the Linksys WRT310N. The PBC buttone doesn't work.
There may be a download to fix the issues but Samsung support is horrible.
jeffco79
Posts Posts : 5
Post by Nazzgull on Fri Nov 05, 2010 11:29 pm
Hi, i have bad news, as i found on Google, your Samsung BD don't support WEP connection. But some other sources tells me it has, anyway, check this link:
http://forums.cnet.com/7723-6142_102-411619.html
Points Points : 40435
Post by jeffco79 on Tue Nov 09, 2010 4:33 am
Thanks much for you update -
jeffco79
Posts Posts : 5
Post by Nazzgull on Wed Nov 10, 2010 10:14 pm
I hope it helps
