Think Point - Help!
Think Point - Help!
Post by teedee on Tue Oct 19, 2010 9:16 am
Hi, Hope you can help!
Think Point has got total control of my PC. I can't start in safe or normal mode, can't get to my desktop, get on the internet, anything. Shafted, basically. I've seen the advice to download OTL (?) but as I say - no chance...
Please help!
Cheers, TeeDee Smile
teedee
OS : Vista
Re: Think Point - Help!
Post by TheAvatar on Tue Oct 19, 2010 9:21 am
Hi I take it you have access to a clean computer? Please obtain a portable USB flash drive to transfer tools from the clean computer to the infected machine.
Download the tools then do the following in Safe Mode:
1.
Please download and run the following tool to help allow other programs to run. (courtesy of BleepingComputer.com)
There are 3 different versions. If one of them won't run then download and try to run the other one.
Vista and Win7 users need to right click and choose Run as Admin
You only need to get one of them to run, not all of them.
You will likely see a message from this rogue telling you the file is infected. Ignore the message. Leave the message OPEN, do not close the message. Run rkill repeatedly until it's able to do it's job. This may take a few tries. You'll be able to tell rkill has done it's job when your desktop (explorer.exe) cycles off and then on again.
Once the tool has run, do NOT reboot the machine. Try immediately to run OTL (step 2)
2.
  • Download [You must be registered and logged in to see this link.] to your desktop.
  • When the window appears, underneath Output at the top change it to Minimal Output.
  • Check the boxes beside LOP Check and Purity Check.
    • When the scan completes, it will open two notepad windows. OTL.Txt and Extras.Txt.
      Note:These logs can be located in the OTL. folder on you C:\ drive if they fail to open automatically.
    • Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post it with your next reply. You may need two posts to fit them both in.
Please transfer logs to your USB again and back to the clean computer to post.
- The Avatar
GeekPolice.net Adviser
If I have helped you, please consider donating to [You must be registered and logged in to see this link.]
GeekPolice.net [You must be registered and logged in to see this link.] [You must be registered and logged in to see this link.]
Online: GMT 10+ 7:30pm to 8:30pm weekdays. On and off on weekends regularly.
TheAvatar
OS : Windows XP SP3
Post by teedee on Tue Oct 19, 2010 9:37 am
Thanks for helping! Smile
Is that Safe Mode with Networking?
teedee
OS : Vista
Post by teedee on Tue Oct 19, 2010 9:50 am
[You must be registered and logged in to see this link.] wrote:Thanks for helping! Smile
Well, I went for SM with Networking. But how do I get the files from the flash drive onto the infected computer. Nothing happens when I plug it in, and all I have access to is the Task Manager, other than that I have the Think Point screen asking me to start in safe mode..... Sad tearing
teedee
OS : Vista
Post by TheAvatar on Tue Oct 19, 2010 10:09 am
Please try in just plane old Safe Mode. Thanks.
- The Avatar
TheAvatar
OS : Windows XP SP3
Post by teedee on Tue Oct 19, 2010 10:23 am
Sorry, still in networking but got the logs Smile
OTL logfile created on: 19/10/2010 11:15:40 - Run 1
OTL by OldTimer - Version 3.2.15.2 Folder = C:\Users\TIM\Desktop
Windows Vista Home Premium Edition Service Pack 2 (Version = 6.0.6002) - Type = NTWorkstation
Internet Explorer (Version = 8.0.6001.18975)
Locale: 00000809 | Country: United Kingdom | Language: ENG | Date Format: dd/MM/yyyy
3.00 Gb Total Physical Memory | 3.00 Gb Available Physical Memory | 86.00% Memory free
7.00 Gb Paging File | 6.00 Gb Available in Paging File | 96.00% Paging File free
Drive C: | 450.70 Gb Total Space | 337.96 Gb Free Space | 74.99% Space Free | Partition Type: NTFS
Drive D: | 15.00 Gb Total Space | 9.74 Gb Free Space | 64.94% Space Free | Partition Type: NTFS
Drive J: | 241.96 Mb Total Space | 32.17 Mb Free Space | 13.30% Space Free | Partition Type: FAT
Computer Name: HOME-PC | User Name: TIM | Logged in as Administrator.
Boot Mode: SafeMode with Networking | Scan Mode: Current user
PRC - C:\Users\TIM\Desktop\OTL.exe (OldTimer Tools)
MOD - C:\Users\TIM\Desktop\OTL.exe (OldTimer Tools)
MOD - C:\Windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb72f2a088b0ed3\comctl32.dll (Microsoft Corporation)
MOD - C:\Windows\System32\msscript.ocx (Microsoft Corporation)
SRV - (avast! Web Scanner) -- C:\Program Files\Alwil Software\Avast5\AvastSvc.exe (AVAST Software)
SRV - (avast! Mail Scanner) -- C:\Program Files\Alwil Software\Avast5\AvastSvc.exe (AVAST Software)
SRV - (avast! Antivirus) -- C:\Program Files\Alwil Software\Avast5\AvastSvc.exe (AVAST Software)
SRV - (Apple Mobile Device) -- C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe (Apple Inc.)
SRV - (ServiceLayer) -- C:\Program Files\PC Connectivity Solution\ServiceLayer.exe (Nokia)
SRV - (WPFFontCache_v0400) -- C:\Windows\Microsoft.NET\Framework\v4.0.30319\WPF\WPFFontCache_v0400.exe (Microsoft Corporation)
SRV - (clr_optimization_v4.0.30319_32) -- C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe (Microsoft Corporation)
SRV - (FontCache) -- C:\Windows\System32\FntCache.dll (Microsoft Corporation)
SRV - (GoToAssist) -- C:\Program Files\Citrix\GoToAssist\514\g2aservice.exe (Citrix Online, a division of Citrix Systems, Inc.)
SRV - (SeaPort) -- C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe (Microsoft Corporation)
SRV - (sprtsvc_DellSupportCenter) SupportSoft Sprocket Service (DellSupportCenter) -- C:\Program Files\Dell Support Center\bin\sprtsvc.exe (SupportSoft, Inc.)
SRV - (AERTFilters) -- C:\Program Files\Realtek\Audio\HDA\AERTSrv.exe (Andrea Electronics Corporation)
SRV - (DockLoginService) -- C:\Program Files\Dell\DellDock\DockLogin.exe (Stardock Corporation)
SRV - (WinDefend) -- C:\Program Files\Windows Defender\MpSvc.dll (Microsoft Corporation)
SRV - (SCM_Service) -- C:\Windows\System32\WinService.exe ()
DRV - (NwlnkFwd) -- C:\Windows\System32\DRIVERS\nwlnkfwd.sys File not found
DRV - (NwlnkFlt) -- C:\Windows\System32\DRIVERS\nwlnkflt.sys File not found
DRV - (IpInIp) -- C:\Windows\System32\DRIVERS\ipinip.sys File not found
DRV - (aswTdi) -- C:\Windows\System32\drivers\aswTdi.sys (AVAST Software)
DRV - (aswSP) -- C:\Windows\System32\drivers\aswSP.sys (AVAST Software)
DRV - (aswRdr) -- C:\Windows\System32\drivers\aswRdr.sys (AVAST Software)
DRV - (aswMonFlt) -- C:\Windows\System32\drivers\aswMonFlt.sys (AVAST Software)
DRV - (aswFsBlk) -- C:\Windows\System32\drivers\aswFsBlk.sys (AVAST Software)
DRV - (UsbserFilt) -- C:\Windows\System32\drivers\usbser_lowerfltj.sys (Nokia)
DRV - (upperdev) -- C:\Windows\System32\drivers\usbser_lowerflt.sys (Nokia)
DRV - (nmwcdc) -- C:\Windows\System32\drivers\ccdcmbo.sys (Nokia)
DRV - (nmwcd) -- C:\Windows\System32\drivers\ccdcmb.sys (Nokia)
DRV - (iaStor) -- C:\Windows\system32\drivers\iastor.sys (Intel Corporation)
DRV - (RTL8169) -- C:\Windows\System32\drivers\Rtlh86.sys (Realtek Corporation )
DRV - (IntcAzAudAddService) Service for Realtek HD Audio (WDM) -- C:\Windows\System32\drivers\RTKVHDA.sys (Realtek Semiconductor Corp.)
DRV - (igfx) -- C:\Windows\System32\drivers\igdkmd32.sys (Intel Corporation)
DRV - (PCD5SRVC{3F6A8B78-EC003E00-05040104}) -- C:\Program Files\Dell Support Center\HWDiag\bin\pcd5srvc.pkms (PC-Doctor, Inc.)
DRV - (pccsmcfd) -- C:\Windows\System32\drivers\pccsmcfd.sys (Nokia)
DRV - (MegaSR) -- C:\Windows\system32\drivers\megasr.sys (LSI Corporation, Inc.)
DRV - (adpu320) -- C:\Windows\system32\drivers\adpu320.sys (Adaptec, Inc.)
DRV - (megasas) -- C:\Windows\system32\drivers\megasas.sys (LSI Corporation)
DRV - (adpu160m) -- C:\Windows\system32\drivers\adpu160m.sys (Adaptec, Inc.)
DRV - (SiSRaid4) -- C:\Windows\system32\drivers\sisraid4.sys (Silicon Integrated Systems)
DRV - (HpCISSs) -- C:\Windows\system32\drivers\hpcisss.sys (Hewlett-Packard Company)
DRV - (adpahci) -- C:\Windows\system32\drivers\adpahci.sys (Adaptec, Inc.)
DRV - (e1express) Intel(R) -- C:\Windows\System32\drivers\e1e6032.sys (Intel Corporation)
DRV - (LSI_SAS) -- C:\Windows\system32\drivers\lsi_sas.sys (LSI Logic)
DRV - (ql2300) -- C:\Windows\system32\drivers\ql2300.sys (QLogic Corporation)
DRV - (E1G60) Intel(R) -- C:\Windows\System32\drivers\E1G60I32.sys (Intel Corporation)
DRV - (arcsas) -- C:\Windows\system32\drivers\arcsas.sys (Adaptec, Inc.)
DRV - (iaStorV) -- C:\Windows\system32\drivers\iastorv.sys (Intel Corporation)
DRV - (vsmraid) -- C:\Windows\system32\drivers\vsmraid.sys (VIA Technologies Inc.,Ltd)
DRV - (ulsata2) -- C:\Windows\system32\drivers\ulsata2.sys (Promise Technology, Inc.)
DRV - (LSI_SCSI) -- C:\Windows\system32\drivers\lsi_scsi.sys (LSI Logic)
DRV - (LSI_FC) -- C:\Windows\system32\drivers\lsi_fc.sys (LSI Logic)
DRV - (arc) -- C:\Windows\system32\drivers\arc.sys (Adaptec, Inc.)
DRV - (elxstor) -- C:\Windows\system32\drivers\elxstor.sys (Emulex)
DRV - (adp94xx) -- C:\Windows\system32\drivers\adp94xx.sys (Adaptec, Inc.)
DRV - (nvraid) -- C:\Windows\system32\drivers\nvraid.sys (NVIDIA Corporation)
DRV - (nvstor) -- C:\Windows\system32\drivers\nvstor.sys (NVIDIA Corporation)
DRV - (uliahci) -- C:\Windows\system32\drivers\uliahci.sys (ULi Electronics Inc.)
DRV - (viaide) -- C:\Windows\system32\drivers\viaide.sys (VIA Technologies, Inc.)
DRV - (cmdide) -- C:\Windows\system32\drivers\cmdide.sys (CMD Technology, Inc.)
DRV - (aliide) -- C:\Windows\system32\drivers\aliide.sys (Acer Laboratories Inc.)
DRV - (RTL8187) -- C:\Windows\System32\drivers\wg111v2.sys (NETGEAR Inc.)
DRV - (SCMNdisP) -- C:\Windows\system32\DRIVERS\scmndisp.sys (Windows (R) Codename Longhorn DDK provider)
DRV - (ql40xx) -- C:\Windows\system32\drivers\ql40xx.sys (QLogic Corporation)
DRV - (UlSata) -- C:\Windows\system32\drivers\ulsata.sys (Promise Technology, Inc.)
DRV - (nfrd960) -- C:\Windows\system32\drivers\nfrd960.sys (IBM Corporation)
DRV - (iirsp) -- C:\Windows\system32\drivers\iirsp.sys (Intel Corp./ICP vortex GmbH)
DRV - (aic78xx) -- C:\Windows\system32\drivers\djsvs.sys (Adaptec, Inc.)
DRV - (iteraid) -- C:\Windows\system32\drivers\iteraid.sys (Integrated Technology Express, Inc.)
DRV - (iteatapi) -- C:\Windows\system32\drivers\iteatapi.sys (Integrated Technology Express, Inc.)
DRV - (Symc8xx) -- C:\Windows\system32\drivers\symc8xx.sys (LSI Logic)
DRV - (Sym_u3) -- C:\Windows\system32\drivers\sym_u3.sys (LSI Logic)
DRV - (Mraid35x) -- C:\Windows\system32\drivers\mraid35x.sys (LSI Logic Corporation)
DRV - (Sym_hi) -- C:\Windows\system32\drivers\sym_hi.sys (LSI Logic)
DRV - (Brserid) Brother MFC Serial Port Interface Driver (WDM) -- C:\Windows\system32\drivers\brserid.sys (Brother Industries Ltd.)
DRV - (BrUsbSer) -- C:\Windows\system32\drivers\brusbser.sys (Brother Industries Ltd.)
DRV - (BrFiltUp) -- C:\Windows\system32\drivers\brfiltup.sys (Brother Industries, Ltd.)
DRV - (BrFiltLo) -- C:\Windows\system32\drivers\brfiltlo.sys (Brother Industries, Ltd.)
DRV - (BrSerWdm) -- C:\Windows\system32\drivers\brserwdm.sys (Brother Industries Ltd.)
DRV - (BrUsbMdm) -- C:\Windows\system32\drivers\brusbmdm.sys (Brother Industries Ltd.)
DRV - (ntrigdigi) -- C:\Windows\system32\drivers\ntrigdigi.sys (N-trig Innovative Technologies)
DRV - (R300) -- C:\Windows\System32\drivers\atikmdag.sys (ATI Technologies Inc.)
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,StartPageCache = 1
IE - HKCU\..\URLSearchHook: {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
FF - HKLM\software\mozilla\Firefox\Extensions\\bkmrksync@nokia.com: C:\Program Files\Nokia\Nokia PC Suite 7\bkmrksync\ [2009/09/27 16:16:39 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\{A27F3FEF-1113-4cfb-A032-8E12D7D8EE70}: C:\Program Files\Nokia\Nokia Ovi Suite\Connectors\Bookmarks Connector\FirefoxExtension\ [2010/07/03 17:08:20 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Thunderbird\Extensions\\{CCB7D94B-CA92-4E3F-B79D-ADE0F07ADC74}: C:\Program Files\Nokia\Nokia Ovi Suite\Connectors\Thunderbird Connector\ThunderbirdExtension\ [2010/07/03 17:08:21 | 000,000,000 | ---D | M]
O1 HOSTS File: ([2006/09/18 22:41:30 | 000,000,761 | ---- | M]) - C:\Windows\System32\drivers\etc\hosts
O1 - Hosts: ::1 localhost
O2 - BHO: (&Yahoo! Toolbar Helper) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
O2 - BHO: (Search Helper) - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll (Microsoft Corporation)
O2 - BHO: (Easy Photo Print) - {9421DD08-935F-4701-A9CA-22DF90AC4EA6} - C:\Program Files\Epson Software\Easy Photo Print\EPTBL.dll (SEIKO EPSON CORPORATION / CyCom Technology Corp.)
O2 - BHO: (Windows Live Toolbar Helper) - {E15A8DC0-8516-42A1-81EA-DC94EC1ACF10} - C:\Program Files\Windows Live\Toolbar\wltcore.dll (Microsoft Corporation)
O3 - HKLM\..\Toolbar: (&Windows Live Toolbar) - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll (Microsoft Corporation)
O3 - HKLM\..\Toolbar: (Easy Photo Print) - {9421DD08-935F-4701-A9CA-22DF90AC4EA6} - C:\Program Files\Epson Software\Easy Photo Print\EPTBL.dll (SEIKO EPSON CORPORATION / CyCom Technology Corp.)
O3 - HKLM\..\Toolbar: (Yahoo! Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
O3 - HKCU\..\Toolbar\WebBrowser: (&Windows Live Toolbar) - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll (Microsoft Corporation)
O4 - HKLM..\Run: [] File not found
O4 - HKLM..\Run: [avast5] C:\Program Files\Alwil Software\Avast5\avastUI.exe (AVAST Software)
O4 - HKLM..\Run: [dellsupportcenter] C:\Program Files\Dell Support Center\bin\sprtcmd.exe (SupportSoft, Inc.)
O4 - HKLM..\Run: [EEventManager] C:\Program Files\Epson Software\Event Manager\EEventManager.exe (SEIKO EPSON CORPORATION)
O4 - HKLM..\Run: [NokiaMServer] C:\Program Files\Common Files\Nokia\MPlatform\NokiaMServer.exe (Nokia)
O4 - HKLM..\Run: [RtHDVCpl] C:\Program Files\Realtek\Audio\HDA\RtHDVCpl.exe (Realtek Semiconductor)
O4 - HKCU..\Run: [] File not found
O4 - HKCU..\Run: [Dzemegefimifetel] C:\Users\TIM\AppData\Local\KBDLT12.DLL ()
O4 - HKCU..\Run: [EPSON SX210 Series] C:\Windows\System32\spool\DRIVERS\W32X86\3\E_FATIFDE.EXE (SEIKO EPSON CORPORATION)
O4 - HKCU..\Run: [Izoxavasam] C:\Users\TIM\AppData\Local\ifabedidayiyuk.DLL (MPC-HC Team)
O4 - HKCU..\Run: [uzofel] C:\Users\TIM\AppData\Roaming\Microsoft\Windows\Global\uzofel.exe ()
O4 - HKCU..\Run: [wxsneacomr.exe] C:\Users\TIM\AppData\Local\Temp\wxsneacomr.exe File not found
O9 - Extra Button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll (Microsoft Corporation)
O10 - NameSpace_Catalog5\Catalog_Entries\000000000007 [] - C:\Program Files\Bonjour\mdnsNSP.dll (Apple Inc.)
O13 - gopher Prefix: missing
O15 - HKCU\..Trusted Domains: internet ([]about in Trusted sites)
O15 - HKCU\..Trusted Domains: mcafee.com ([]http in Trusted sites)
O15 - HKCU\..Trusted Domains: mcafee.com ([]https in Trusted sites)
O16 - DPF: {6678BE91-1E04-4A4A-9C32-63145EA79C2A} [You must be registered and logged in to see this link.] (EAFO3AXLauncher Control)
O16 - DPF: {80AEEC0E-A2BE-4B8D-985F-350FE869DC40} [You must be registered and logged in to see this link.] (HPDDClientExec Class)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_13)
O16 - DPF: {CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_13)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_13)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.0.1
O18 - Protocol\Handler\wlmailhtml {03C514A3-1EFB-4856-9F99-10D7BE1653C0} - C:\Program Files\Windows Live\Mail\mailcomm.dll (Microsoft Corporation)
O20 - HKLM Winlogon: Shell - (explorer.exe) - C:\Windows\explorer.exe (Microsoft Corporation)
O20 - HKCU Winlogon: Shell - (C:\Users\TIM\AppData\Roaming\hotfix.exe) - C:\Users\TIM\AppData\Roaming\hotfix.exe ()
O20 - Winlogon\Notify\GoToAssist: DllName - C:\Program Files\Citrix\GoToAssist\514\G2AWinLogon.dll - C:\Program Files\Citrix\GoToAssist\514\g2awinlogon.dll (Citrix Online, a division of Citrix Systems, Inc.)
O20 - Winlogon\Notify\igfxcui: DllName - igfxdev.dll - C:\Windows\System32\igfxdev.dll (Intel Corporation)
O24 - Desktop WallPaper: C:\Users\TIM\AppData\Roaming\Microsoft\Windows Live Photo Gallery\Windows Live Photo Gallery Wallpaper.jpg
O24 - Desktop BackupWallPaper: C:\Users\TIM\AppData\Roaming\Microsoft\Windows Live Photo Gallery\Windows Live Photo Gallery Wallpaper.jpg
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2006/09/18 22:43:36 | 000,000,024 | ---- | M] () - C:\autoexec.bat -- [ NTFS ]
[2010/10/19 11:04:55 | 000,574,464 | ---- | C] (OldTimer Tools) -- C:\Users\TIM\Desktop\OTL.exe
[2010/10/18 23:53:33 | 000,000,000 | ---D | C] -- C:\Users\TIM\AppData\Local\{F8A60C09-4CCD-47C3-8D1C-DBC23224EF78}
[2010/10/18 23:42:22 | 000,000,000 | -H-D | C] -- C:\Users\Public\Documents\Windows
[2010/10/18 23:41:45 | 000,000,000 | -H-D | C] -- C:\Users\Public\Documents\Server
[2010/10/18 23:40:50 | 000,000,000 | ---D | C] -- C:\Users\TIM\AppData\Roaming\B3B9DB4707079D52592352E3A5481C8B
[2010/10/14 14:12:16 | 000,000,000 | ---D | C] -- C:\Windows\System32\MpEngineStore
[2010/10/14 13:57:16 | 000,017,744 | ---- | C] (AVAST Software) -- C:\Windows\System32\drivers\aswFsBlk.sys
[2010/10/14 13:57:15 | 000,165,584 | ---- | C] (AVAST Software) -- C:\Windows\System32\drivers\aswSP.sys
[2010/10/14 13:57:15 | 000,023,376 | ---- | C] (AVAST Software) -- C:\Windows\System32\drivers\aswRdr.sys
[2010/10/14 13:57:14 | 000,046,672 | ---- | C] (AVAST Software) -- C:\Windows\System32\drivers\aswTdi.sys
[2010/10/14 13:57:10 | 000,050,768 | ---- | C] (AVAST Software) -- C:\Windows\System32\drivers\aswMonFlt.sys
[2010/10/14 13:56:31 | 000,038,848 | ---- | C] (AVAST Software) -- C:\Windows\avastSS.scr
[2010/10/14 13:56:29 | 000,167,592 | ---- | C] (AVAST Software) -- C:\Windows\System32\aswBoot.exe
[2010/10/14 13:56:21 | 000,000,000 | ---D | C] -- C:\ProgramData\Alwil Software
[2010/10/14 13:56:21 | 000,000,000 | ---D | C] -- C:\Program Files\Alwil Software
[2010/10/14 08:26:51 | 008,147,456 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\wmploc.DLL
[2010/10/14 08:26:32 | 000,017,920 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\netevent.dll
[2010/10/14 08:26:15 | 000,157,184 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\t2embed.dll
[2010/10/14 08:26:10 | 000,602,112 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\msfeeds.dll
[2010/10/14 08:26:10 | 000,385,024 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\html.iec
[2010/10/14 08:26:10 | 000,043,520 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\licmgr10.dll
[2010/10/14 08:26:09 | 001,469,440 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\inetcpl.cpl
[2010/10/14 08:26:09 | 000,611,840 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\mstime.dll
[2010/10/14 08:26:09 | 000,387,584 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\iedkcs32.dll
[2010/10/14 08:26:09 | 000,164,352 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\ieui.dll
[2010/10/14 08:26:08 | 001,638,912 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\mshtml.tlb
[2010/10/14 08:26:08 | 000,184,320 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\iepeers.dll
[2010/10/14 08:26:08 | 000,173,056 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\ie4uinit.exe
[2010/10/14 08:26:08 | 000,133,632 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\ieUnatt.exe
[2010/10/14 08:26:08 | 000,109,056 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\iesysprep.dll
[2010/10/14 08:26:08 | 000,071,680 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\iesetup.dll
[2010/10/14 08:26:08 | 000,055,808 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\iernonce.dll
[2010/10/14 08:26:08 | 000,055,296 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\msfeedsbs.dll
[2010/10/14 08:26:08 | 000,025,600 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\jsproxy.dll
[2010/10/14 08:26:08 | 000,013,312 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\msfeedssync.exe
[2010/10/14 08:26:05 | 000,954,752 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\mfc40.dll
[2010/10/14 08:26:05 | 000,954,288 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\mfc40u.dll
[2010/10/14 08:26:03 | 002,038,272 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\win32k.sys
[2010/10/14 08:26:01 | 000,231,424 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\msshsq.dll
[2010/10/14 08:25:59 | 000,867,328 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\wmpmde.dll
[2010/10/10 09:01:29 | 000,000,000 | ---D | C] -- C:\ProgramData\WindowsSearch
[2010/10/02 23:20:01 | 000,000,000 | ---D | C] -- C:\Users\TIM\Documents\yWriter Projects
[2010/10/02 23:19:24 | 000,000,000 | ---D | C] -- C:\Users\TIM\AppData\Roaming\Spacejock Software
[2010/10/02 23:18:57 | 000,000,000 | ---D | C] -- C:\Users\TIM\Documents\yWriter5 Sample
[2010/10/02 23:18:57 | 000,000,000 | ---D | C] -- C:\Program Files\yWriter5
[2010/10/01 20:00:40 | 000,002,048 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\tzres.dll
[2009/09/17 07:48:38 | 000,192,512 | ---- | C] (MPC-HC Team) -- C:\Users\TIM\AppData\Local\ifabedidayiyuk.dll
[2010/10/19 11:04:56 | 000,574,464 | ---- | M] (OldTimer Tools) -- C:\Users\TIM\Desktop\OTL.exe
[2010/10/19 10:42:07 | 000,602,924 | ---- | M] () -- C:\Windows\System32\perfh009.dat
[2010/10/19 10:42:07 | 000,106,602 | ---- | M] () -- C:\Windows\System32\perfc009.dat
[2010/10/19 10:36:38 | 000,067,584 | --S- | M] () -- C:\Windows\bootstat.dat
[2010/10/19 10:35:08 | 000,003,616 | -H-- | M] () -- C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-1.C7483456-A289-439d-8115-601632D005A0
[2010/10/19 10:35:08 | 000,003,616 | -H-- | M] () -- C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-0.C7483456-A289-439d-8115-601632D005A0
[2010/10/19 10:14:08 | 000,000,006 | ---- | M] () -- C:\Users\TIM\AppData\Roaming\completescan
[2010/10/19 10:08:08 | 000,000,874 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskMachineCore.job
[2010/10/19 09:40:05 | 000,000,878 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskMachineUA.job
[2010/10/19 09:40:00 | 000,000,898 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskUserS-1-5-21-136451748-926823148-2315087893-1000UA.job
[2010/10/18 23:53:35 | 000,000,120 | ---- | M] () -- C:\Users\TIM\AppData\Local\Tvusax.dat
[2010/10/18 23:53:35 | 000,000,000 | ---- | M] () -- C:\Users\TIM\AppData\Local\Aqetoqeziw.bin
[2010/10/18 23:51:44 | 000,000,006 | ---- | M] () -- C:\Users\TIM\AppData\Roaming\start
[2010/10/18 23:42:58 | 000,000,010 | ---- | M] () -- C:\Users\TIM\AppData\Roaming\install
[2010/10/18 23:42:21 | 000,000,172 | ---- | M] () -- C:\Users\TIM\AppData\Roaming\31971.bat
[2010/10/18 23:42:20 | 000,511,488 | ---- | M] () -- C:\Users\TIM\AppData\Roaming\hotfix.exe
[2010/10/18 21:41:18 | 000,000,414 | -H-- | M] () -- C:\Windows\tasks\User_Feed_Synchronization-{BBE22A44-EFEE-4C35-ADEA-2CED6CF12A00}.job
[2010/10/18 20:14:03 | 000,021,000 | ---- | M] () -- C:\Users\TIM\Desktop\Project proposal Draft.docx
[2010/10/18 20:10:54 | 000,026,967 | ---- | M] () -- C:\Users\TIM\Desktop\Project proposal Notes.docx
[2010/10/18 19:40:00 | 000,000,846 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskUserS-1-5-21-136451748-926823148-2315087893-1000Core.job
[2010/10/18 13:28:58 | 000,351,007 | ---- | M] () -- C:\Users\TIM\Desktop\What Happens in the Brain to Cause the Transformation From Healthy Aging to AD.mht
[2010/10/15 09:52:32 | 000,001,356 | ---- | M] () -- C:\Users\TIM\AppData\Local\d3d9caps.dat
[2010/10/14 19:50:37 | 000,016,921 | ---- | M] () -- C:\Users\TIM\Desktop\Gibb's 141010.docx
[2010/10/14 14:18:21 | 000,295,832 | ---- | M] () -- C:\Windows\System32\FNTCACHE.DAT
[2010/10/14 14:12:16 | 000,000,127 | ---- | M] () -- C:\Windows\System32\MRT.INI
[2010/10/14 13:57:16 | 000,001,802 | ---- | M] () -- C:\Users\Public\Desktop\avast! Free Antivirus.lnk
[2010/10/14 13:57:10 | 000,002,577 | ---- | M] () -- C:\Windows\System32\config.nt
[2010/10/13 18:28:19 | 000,213,797 | ---- | M] () -- C:\Users\TIM\Desktop\doh dementia.pdf
[2010/10/11 22:03:53 | 000,066,978 | ---- | M] () -- C:\Users\TIM\Desktop\The_guidelines_manual_2009_-_Chapter_6_Reviewing_the_evidence.pdf
[2010/10/11 20:42:18 | 001,341,968 | ---- | M] () -- C:\Users\TIM\Desktop\NICE - Dementia.pdf
[2010/10/10 18:10:17 | 000,036,196 | ---- | M] () -- C:\Users\TIM\Desktop\weekly_calendar_02.jpg
[2010/10/08 14:07:14 | 000,308,224 | ---- | M] () -- C:\Users\TIM\Documents\Handbook%202010-11%20Project%20Proposal[2].doc
[2010/10/08 14:02:19 | 000,083,968 | ---- | M] () -- C:\Users\TIM\Desktop\Handbook%20Project%202010-11[1].doc
[2010/10/08 14:00:04 | 000,090,112 | ---- | M] () -- C:\Users\TIM\Desktop\Handbook%202010-110[1].doc
[2010/10/08 12:40:36 | 000,011,297 | ---- | M] () -- C:\Users\TIM\Documents\NOTIFICATION OF PROPOSED STUDY AND METHOD[1].docx
[2010/10/06 20:17:50 | 000,174,592 | ---- | M] () -- C:\Users\TIM\Desktop\oct2010 scas.xls
[2010/10/02 23:18:58 | 000,000,766 | ---- | M] () -- C:\Users\TIM\Desktop\yWriter5.lnk
[2010/09/24 08:19:35 | 000,002,034 | ---- | M] () -- C:\Users\TIM\Desktop\Google Chrome.lnk
[2010/09/24 08:19:35 | 000,001,996 | ---- | M] () -- C:\Users\TIM\Application Data\Microsoft\Internet Explorer\Quick Launch\Google Chrome.lnk
[2010/10/18 23:53:35 | 000,000,120 | ---- | C] () -- C:\Users\TIM\AppData\Local\Tvusax.dat
[2010/10/18 23:53:35 | 000,000,000 | ---- | C] () -- C:\Users\TIM\AppData\Local\Aqetoqeziw.bin
[2010/10/18 23:51:44 | 000,000,006 | ---- | C] () -- C:\Users\TIM\AppData\Roaming\start
[2010/10/18 23:48:23 | 000,000,006 | ---- | C] () -- C:\Users\TIM\AppData\Roaming\completescan
[2010/10/18 23:42:58 | 000,000,010 | ---- | C] () -- C:\Users\TIM\AppData\Roaming\install
[2010/10/18 23:42:21 | 000,000,172 | ---- | C] () -- C:\Users\TIM\AppData\Roaming\31971.bat
[2010/10/18 23:42:20 | 000,511,488 | ---- | C] () -- C:\Users\TIM\AppData\Roaming\hotfix.exe
[2010/10/18 17:21:03 | 000,021,000 | ---- | C] () -- C:\Users\TIM\Desktop\Project proposal Draft.docx
[2010/10/18 16:25:36 | 000,026,967 | ---- | C] () -- C:\Users\TIM\Desktop\Project proposal Notes.docx
[2010/10/18 13:28:56 | 000,351,007 | ---- | C] () -- C:\Users\TIM\Desktop\What Happens in the Brain to Cause the Transformation From Healthy Aging to AD.mht
[2010/10/14 19:50:37 | 000,016,921 | ---- | C] () -- C:\Users\TIM\Desktop\Gibb's 141010.docx
[2010/10/14 14:12:16 | 000,000,127 | ---- | C] () -- C:\Windows\System32\MRT.INI
[2010/10/14 13:57:16 | 000,001,802 | ---- | C] () -- C:\Users\Public\Desktop\avast! Free Antivirus.lnk
[2010/10/13 18:28:19 | 000,213,797 | ---- | C] () -- C:\Users\TIM\Desktop\doh dementia.pdf
[2010/10/11 22:03:53 | 000,066,978 | ---- | C] () -- C:\Users\TIM\Desktop\The_guidelines_manual_2009_-_Chapter_6_Reviewing_the_evidence.pdf
[2010/10/11 20:42:18 | 001,341,968 | ---- | C] () -- C:\Users\TIM\Desktop\NICE - Dementia.pdf
[2010/10/10 18:11:41 | 000,036,196 | ---- | C] () -- C:\Users\TIM\Desktop\weekly_calendar_02.jpg
[2010/10/08 14:07:13 | 000,308,224 | ---- | C] () -- C:\Users\TIM\Documents\Handbook%202010-11%20Project%20Proposal[2].doc
[2010/10/08 14:02:18 | 000,083,968 | ---- | C] () -- C:\Users\TIM\Desktop\Handbook%20Project%202010-11[1].doc
[2010/10/08 14:00:03 | 000,090,112 | ---- | C] () -- C:\Users\TIM\Desktop\Handbook%202010-110[1].doc
[2010/10/08 12:40:36 | 000,011,297 | ---- | C] () -- C:\Users\TIM\Documents\NOTIFICATION OF PROPOSED STUDY AND METHOD[1].docx
[2010/10/05 22:29:29 | 000,174,592 | ---- | C] () -- C:\Users\TIM\Desktop\oct2010 scas.xls
[2010/10/02 23:18:58 | 000,000,766 | ---- | C] () -- C:\Users\TIM\Desktop\yWriter5.lnk
[2010/07/19 22:05:09 | 000,139,152 | ---- | C] () -- C:\Users\TIM\AppData\Roaming\PnkBstrK.sys
[2010/07/19 22:05:09 | 000,138,968 | ---- | C] () -- C:\Windows\System32\drivers\PnkBstrK.sys
[2009/12/30 19:54:29 | 000,000,097 | ---- | C] () -- C:\Windows\System32\PICSDK.ini
[2009/11/18 11:11:12 | 000,000,058 | ---- | C] () -- C:\Users\TIM\AppData\Local\DonationCoder_ScreenshotCaptor_InstallInfo.dat
[2009/10/20 11:05:55 | 000,006,902 | ---- | C] () -- C:\ProgramData\hpzinstall.log
[2009/09/17 07:48:38 | 000,117,248 | ---- | C] () -- C:\Windows\System32\EhStorAuthn.dll
[2009/09/17 07:48:38 | 000,077,312 | ---- | C] () -- C:\Users\TIM\AppData\Local\KBDLT12.dll
[2009/09/10 18:44:20 | 000,003,424 | ---- | C] () -- C:\Users\TIM\AppData\Roaming\wklnhst.dat
[2009/09/09 13:34:37 | 000,001,356 | ---- | C] () -- C:\Users\TIM\AppData\Local\d3d9caps.dat
[2009/08/31 01:07:58 | 000,050,176 | ---- | C] () -- C:\Users\TIM\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2009/08/03 15:07:42 | 000,403,816 | ---- | C] () -- C:\Windows\System32\OGACheckControl.dll
[2009/07/05 01:19:26 | 000,147,456 | ---- | C] () -- C:\Windows\System32\igfxCoIn_v1472.dll
[2006/11/02 13:35:32 | 000,005,632 | ---- | C] () -- C:\Windows\System32\sysprepMCE.dll
[2006/11/02 11:25:44 | 000,159,744 | ---- | C] () -- C:\Windows\System32\atitmmxx.dll
[2006/11/02 08:40:29 | 000,013,750 | ---- | C] () -- C:\Windows\System32\pacerprf.ini
[2010/07/25 22:34:34 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Ahug
[2010/10/18 23:40:50 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\B3B9DB4707079D52592352E3A5481C8B
[2009/11/18 11:11:12 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\DonationCoder
[2009/12/30 20:23:45 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Epson
[2010/07/22 23:33:08 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Hauzb
[2010/10/14 14:16:44 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Kuomt
[2010/07/03 18:38:28 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Nokia
[2010/02/21 17:07:04 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Osax
[2009/09/04 21:14:14 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Ovce
[2009/11/12 21:45:56 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\PC Suite
[2010/08/16 21:41:25 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Puofu
[2010/10/02 23:19:24 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Spacejock Software
[2009/09/10 18:44:21 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Template
[2010/09/19 20:17:19 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\TS3Client
[2009/09/22 04:49:22 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Watuyd
[2010/02/22 00:03:59 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Xiypxo
[2010/10/14 14:16:44 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Ykac
[2010/10/14 11:27:10 | 000,000,000 | ---D | M] -- C:\Users\TIM\AppData\Roaming\Ykeca
[2010/10/19 10:35:08 | 000,032,622 | ---- | M] () -- C:\Windows\Tasks\SCHEDLGU.TXT
[2010/10/18 21:41:18 | 000,000,414 | -H-- | M] () -- C:\Windows\Tasks\User_Feed_Synchronization-{BBE22A44-EFEE-4C35-ADEA-2CED6CF12A00}.job
teedee
OS : Vista
Post by teedee on Tue Oct 19, 2010 10:25 am
OTL Extras logfile created on: 19/10/2010 11:15:40 - Run 1
.cpl [@ = cplfile] -- C:\Windows\System32\control.exe (Microsoft Corporation)
.hlp [@ = hlpfile] -- C:\Windows\winhlp32.exe (Microsoft Corporation)
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
hlpfile [open] -- %SystemRoot%\winhlp32.exe %1 (Microsoft Corporation)
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
"cval" = 0
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc]
"AntiVirusOverride" = 0
"AntiSpywareOverride" = 0
"FirewallOverride" = 0
"VistaSp1" = Reg Error: Unknown registry data type -- File not found
"VistaSp2" = Reg Error: Unknown registry data type -- File not found
"EnableFirewall" = 1
"DisableNotifications" = 0
========== Vista Active Open Ports Exception List ==========
"{499D66F5-2559-41C5-A1E6-C2117BA3139C}" = lport=2869 | protocol=6 | dir=in | app=system |
"{AA331F89-1F94-42D8-AC0E-B82C223C86A4}" = lport=1900 | protocol=17 | dir=in | svc=ssdpsrv | app=svchost.exe |
========== Vista Active Application Exception List ==========
"{00D75F3C-D125-481E-AA3B-53BEB52812DB}" = dir=in | app=c:\program files\hp\digital imaging\bin\hpqgpc01.exe |
"{017141EC-B0E5-4B2E-9BD7-1B43E3B5F905}" = dir=in | app=c:\program files\hp\digital imaging\bin\hpiscnapp.exe |
"{06D450A3-BA7F-4F6A-BA4C-2A5CCFD98C65}" = dir=in | app=c:\program files\hp\digital imaging\bin\hpqgplgtupl.exe |
"{0C31E9FF-26AD-471F-99E7-62F36CFD7048}" = dir=in | app=c:\program files\hp\digital imaging\bin\hposid01.exe |
"{2B0ABFAA-D0AC-4BCD-B45C-C7C20108A70D}" = dir=in | app=c:\program files\hp\digital imaging\bin\hpqste08.exe |
"{4235C4A0-5198-4F1A-9DF7-912944231503}" = dir=in | app=c:\program files\hp\digital imaging\bin\hpqkygrp.exe |
"{42E87318-9CF8-44FB-889B-48B9B7156393}" = dir=in | app=c:\program files\common files\mcafee\mna\mcnasvc.exe |
"{47E08645-11BE-4D3F-83DF-FD712148A68D}" = protocol=17 | dir=in | app=c:\windows\system32\pnkbstra.exe |
"{52815F4A-9512-43E0-9B8A-2F9CF2C9F235}" = protocol=17 | dir=in | app=c:\windows\system32\pnkbstrb.exe |
"{573D75C3-00C2-450F-BDA6-5B8F9E1969E7}" = protocol=6 | dir=in | app=c:\program files\microsoft office\office12\onenote.exe |
"{67AF238B-FF66-4FC8-9D44-54DB44893085}" = protocol=6 | dir=in | app=c:\windows\system32\pnkbstrb.exe |
"{961E0CCF-907E-4722-B30D-2D48972153A4}" = protocol=17 | dir=in | app=c:\program files\bonjour\mdnsresponder.exe |
"{A16493E1-889B-462E-8DAE-70AEE0EA5FAC}" = dir=in | app=c:\program files\itunes\itunes.exe |
"{B9304FE4-37E3-48B9-AF4A-34642D8FD700}" = protocol=6 | dir=in | app=c:\windows\system32\pnkbstra.exe |
"{BAA786CC-A00C-42E2-9779-DD0B6A8AE28C}" = dir=in | app=c:\program files\windows live\sync\windowslivesync.exe |
"{BAFC5A38-7F95-442F-A77E-9403003982BC}" = dir=in | app=c:\program files\common files\hp\digital imaging\bin\hpqphotocrm.exe |
"{C2E3078F-1ED8-47C2-AC37-FCFDAEF05235}" = dir=in | app=c:\program files\windows live\messenger\msnmsgr.exe |
"{C2EB952A-CBD1-45CD-8C5B-D4836AFCC7E9}" = dir=in | app=c:\program files\hp\digital imaging\bin\hpqcopy2.exe |
"{C3961CDE-3454-497D-8A73-776DF78263D2}" = dir=in | app=c:\program files\hp\digital imaging\bin\hpqtra08.exe |
"{CCCB5371-A7E4-4593-BD66-C2BED6044788}" = dir=in | app=c:\program files\hp\digital imaging\bin\hpfccopy.exe |
"{CF32C8F4-ABD9-4009-953F-BF403AB01C44}" = dir=in | app=c:\program files\hp\digital imaging\bin\hpqsudi.exe |
"{E1670C02-AFFC-4F9E-9B92-B6EF2C2BFA7D}" = dir=in | app=c:\program files\hp\digital imaging\bin\hpqpse.exe |
"{E8F47A96-83CD-4D10-9BEF-40B06C76871C}" = protocol=17 | dir=in | app=c:\program files\microsoft office\office12\onenote.exe |
"{EB855A86-4614-480D-8E28-2F96683045F4}" = dir=in | app=c:\program files\hp\digital imaging\bin\hpqpsapp.exe |
"{F4DE317D-13F6-460F-B139-8BB5139D13D7}" = protocol=6 | dir=in | app=c:\program files\bonjour\mdnsresponder.exe |
"{F52211C8-CCA0-465C-87B5-CE51C7A9ED2B}" = dir=in | app=c:\program files\hp\digital imaging\bin\hpoews01.exe |
"TCP Query User{8ABD0731-6F52-4669-95FF-8C517766681B}C:\program files\epson software\event manager\eeventmanager.exe" = protocol=6 | dir=in | app=c:\program files\epson software\event manager\eeventmanager.exe |
"TCP Query User{C49D5C79-D19A-4A5A-B550-C6F6CB7D2227}C:\program files\epson software\event manager\eeventmanager.exe" = protocol=6 | dir=in | app=c:\program files\epson software\event manager\eeventmanager.exe |
"UDP Query User{356F28CD-21A3-4E84-915B-6F8D48E7F33A}C:\program files\epson software\event manager\eeventmanager.exe" = protocol=17 | dir=in | app=c:\program files\epson software\event manager\eeventmanager.exe |
"UDP Query User{C00C1DF0-9612-419A-874E-B6AC44655D6D}C:\program files\epson software\event manager\eeventmanager.exe" = protocol=17 | dir=in | app=c:\program files\epson software\event manager\eeventmanager.exe |
"{00203668-8170-44A0-BE44-B632FA4D780F}" = Adobe AIR
"{089DD780-DB3F-4CDB-A0C2-111360247298}" = PC Connectivity Solution
"{08E81ABD-79F7-49C2-881F-FD6CB0975693}" = Roxio Creator Data
"{09760D42-E223-42AD-8C3E-55B47D0DDAC3}" = Roxio Creator DE
"{0CB9668D-F979-4F31-B8B8-67FE90F929F8}" = Bonjour
"{0EC7C406-B592-4686-BAC1-AD29A85EAE6A}" = HP Driver Diagnostics
"{1373559F-6DC6-44EA-9079-6ABDCCE8CDAD}" = OviMPlatform
"{15BC8CD0-A65B-47D0-A2DD-90A824590FA8}" = Microsoft Works
"{171E6C1E-B5FC-11DF-B115-005056C00008}" = Google Earth Plug-in
"{178832DE-9DE0-4C87-9F82-9315A9B03985}" = Windows Live Writer
"{1B9B5B3B-28E7-4E59-A80D-D670AA984514}" = Nokia Connectivity Cable Driver
"{1F54DAFA-9261-4A62-B59D-6C9F26B48FE4}" = Roxio Creator Tools
"{212748BB-0DA5-46DE-82A1-403736DC9F27}" = MSVC80_x86
"{26A24AE4-039D-4CA4-87B4-2F83216013FF}" = Java(TM) 6 Update 13
"{2D10FC46-1D96-44C4-8855-85F21B9B011E}" = Ovi Desktop Sync Engine
"{30465B6C-B53F-49A1-9EBA-A3F187AD502E}" = Roxio Update Manager
"{3138EAD3-700B-4A10-B617-B3F8096EE30D}" = Dell Edoc Viewer
"{350FB27C-CF62-4EF3-AF9D-70FF313FE221}" = iTunes
"{3700194C-C5DD-439A-BE06-A66960CA4C70}" = MSVCSetup
"{3B4E636E-9D65-4D67-BA61-189800823F52}" = Windows Live Communications Platform
"{3C3901C5-3455-3E0A-A214-0B093A5070A6}" = Microsoft .NET Framework 4 Client Profile
"{3D39E775-DDDA-4327-B747-0BDC5F191331}" = Nokia PC Suite
"{4102037D-E8E0-48E0-B203-E521D194FB71}" = NETGEAR WG111v2 wireless USB 2.0 adapter
"{45338B07-A236-4270-9A77-EBB4115517B5}" = Windows Live Sign-in Assistant
"{47ECCB1F-2811-49C0-B6A7-26778639ABA0}" = 32 Bit HP CIO Components Installer
"{48F22622-1CC2-4A83-9C1E-644DD96F832D}" = Epson Event Manager
"{4C911A61-39EA-41CC-AB3C-FE3BFFDB5F78}" = Nokia Software Updater
"{4CBA3D4C-8F51-4D60-B27E-F6B641C571E7}" = Microsoft Search Enhancement Pack
"{6412CECE-8172-4BE5-935B-6CECACD2CA87}" = Windows Live Mail
"{6675CA7F-E51B-4F6A-99D4-F8F0124C6EAA}" = Roxio Express Labeler 3
"{6D3245B1-8DB8-4A23-9CD2-2C90F40ABAF6}" = MSVC80_x86_v2
"{6FE3B0CE-37C1-4825-908A-5A84C9B4EC2F}" = EA SPORTS(TM) FIFA Online
"{73A4F29F-31AC-4EBD-AA1B-0CC5F18C8F83}" = Roxio Creator Audio
"{77DCDCE3-2DED-62F3-8154-05E745472D07}" = Acrobat.com
"{7B01FD07-1790-4EE9-B5E0-149527D70C7D}" = Nokia Ovi Suite
"{7DB9F1E5-9ACB-410D-A7DC-7A3D023CE045}" = Dell Getting Started Guide
"{81128EE8-8EAD-4DB0-85C6-17C2CE50FF71}" = Windows Live Essentials
"{818ABC3C-635C-4651-8183-D0E9640B7DD1}" = HP Update
"{84EBDF39-4B33-49D7-A0BD-EB6E2C4E81C1}" = Windows Live Sync
"{87C2248A-C7DD-49ED-9BCD-B312A9D0819E}" = Epson Easy Photo Print 2
"{8A74E887-8F0F-4017-AF53-CBA42211AAA5}" = Microsoft Sync Framework Runtime Native v1.0 (x86)
"{90120000-0016-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0018-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001B-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_HOMESTUDENTR_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_HOMESTUDENTR_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_HOMESTUDENTR_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-00A1-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{995F1E2E-F542-4310-8E1D-9926F5A279B3}" = Windows Live Toolbar
"{A0D65C73-F2C5-432F-8788-90F8A2E99B98}" = Nokia Ovi Suite Software Updater
"{A85FD55B-891B-4314-97A5-EA96C0BD80B5}" = Windows Live Messenger
"{AC76BA86-7AD7-1033-7B44-A93000000001}" = Adobe Reader 9.3.3
"{AC76BA86-7AD7-5464-3428-900000000004}" = Spelling Dictionaries Support For Adobe Reader 9
"{ACF60000-22B9-4CE9-98D6-2CCF359BAC07}" = ABBYY FineReader 6.0 Sprint
"{AF111648-99A1-453E-81DD-80DBBF6DAD0D}" = MSVC90_x86
"{AFD9E698-03C2-4E88-80A6-1496562D4304}" = Google SketchUp 7.1
"{B2544A03-10D0-4E5E-BA69-0362FFC20D18}" = OGA Notifier 2.0.0048.0
"{B6A26DE5-F2B5-4D58-9570-4FC760E00FCD}" = Roxio Creator Copy
"{B935C985-A17F-484B-8470-09E4FC27DC26}" = Dell-eBay
"{BD64AF4A-8C80-4152-AD77-FCDDF05208AB}" = Microsoft Sync Framework Services Native v1.0 (x86)
"{CCA1EEA3-555E-4D05-AC46-4B49C6C5D887}" = Apple Mobile Device Support
"{D6C75F0B-3BC1-4FC9-B8C5-3F7E8ED059CA}" = Windows Live Photo Gallery
"{DAEAFD68-BB4A-4507-A241-C8804D2EA66D}" = Apple Application Support
"{E2DFE069-083E-4631-9B6C-43C48E991DE5}" = Junk Mail filter update
"{E3BFEE55-39E2-4BE0-B966-89FE583822C1}" = Dell Support Center (Support Software)
"{EB900AF8-CC61-4E15-871B-98D1EA3E8025}" = QuickTime
"{ED439A64-F018-4DD4-8BA5-328D85AB09AB}" = Roxio Creator DE
"{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}" = Microsoft SQL Server 2005 Compact Edition [ENU]
"{F6BD194C-4190-4D73-B1B1-C48C99921BFE}" = Windows Live Call
"{F6CB42B9-F033-4152-8813-FF11DA8E6A78}" = Dell Dock
"{FCC07EEA-FA18-4A21-9105-9666603C6885}" = McAfee Virtual Technician
"504244733D18C8F63FF584AEB290E3904E791693" = Windows Driver Package - Nokia pccsmcfd (08/22/2008 7.0.0.0)
"Adobe AIR" = Adobe AIR
"AudibleDownloadManager" = Audible Download Manager
"avast5" = avast! Free Antivirus
"E8A6D621B6D3FC5D43C68C549D959DE76EEF5D84" = Windows Driver Package - Nokia Modem (06/01/2009 4.1)
"EPSON Scanner" = EPSON Scan
"Epson Stylus SX210_SX410_TX210_TX410 User’s Guide" = Epson Stylus SX210_SX410_TX210_TX410 Manual
"EPSON SX210 Series" = EPSON SX210 Series Printer Uninstall
"F779F5541ABD99C95C03B0FD5E3C058B22DA0FF7" = Windows Driver Package - Nokia Modem (06/01/2009 7.01.0.3)
"Gadwin PrintScreen" = Gadwin PrintScreen
"GoToAssist" = GoToAssist 8.0.0.514
"Nokia Ovi Suite" = Nokia Ovi Suite
"Nokia PC Suite" = Nokia PC Suite
"PunkBusterSvc" = PunkBuster Services
"ScreenshotCaptor_is1" = Screenshot Captor 2.76.01
"ST6UNST #1" = OU eTMA File Handler
"Super Screen Capture_is1" = Super Screen Capture 4.0
"TeamSpeak 3 Client" = TeamSpeak 3 Client
"Yahoo! Companion" = Yahoo! Toolbar
"yWriter5_is1" = yWriter5
"Google Chrome" = Google Chrome
"Power Loader" = Power Challenge Game Plugin
[ Application Events ]
Error - 13/10/2010 03:20:39 | Computer Name = HOME-PC | Source = Bonjour Service | ID = 100
Description = Task Scheduling Error: m->NextScheduledSPRetry 33042011
Error - 13/10/2010 03:20:40 | Computer Name = HOME-PC | Source = Bonjour Service | ID = 100
Description = Task Scheduling Error: Continuously busy for more than a second
Description = Task Scheduling Error: m->NextScheduledEvent 33043009
Description = Task Scheduling Error: m->NextScheduledSPRetry 33043009
Error - 13/10/2010 03:20:41 | Computer Name = HOME-PC | Source = Bonjour Service | ID = 100
Description = Task Scheduling Error: m->NextScheduledEvent 33044007
Description = Task Scheduling Error: m->NextScheduledSPRetry 33044007
Error - 13/10/2010 03:20:42 | Computer Name = HOME-PC | Source = Bonjour Service | ID = 100
Description = Task Scheduling Error: m->NextScheduledEvent 33045021
Description = Task Scheduling Error: m->NextScheduledSPRetry 33045021
[ System Events ]
Error - 19/10/2010 04:18:33 | Computer Name = HOME-PC | Source = Service Control Manager | ID = 7026
Description =
Error - 19/10/2010 04:27:50 | Computer Name = HOME-PC | Source = Service Control Manager | ID = 7031
Description =
Description =
Error - 19/10/2010 04:27:50 | Computer Name = HOME-PC | Source = Service Control Manager | ID = 7032
Description =
Error - 19/10/2010 04:27:56 | Computer Name = HOME-PC | Source = Service Control Manager | ID = 7031
Description =
Error - 19/10/2010 04:27:56 | Computer Name = HOME-PC | Source = Service Control Manager | ID = 7032
Description =
Error - 19/10/2010 05:08:02 | Computer Name = HOME-PC | Source = EventLog | ID = 6008
Description = The previous system shutdown at 09:40:26 on 19/10/2010 was unexpected.
Error - 19/10/2010 05:37:58 | Computer Name = HOME-PC | Source = Service Control Manager | ID = 7001
Description =
Error - 19/10/2010 05:37:58 | Computer Name = HOME-PC | Source = Service Control Manager | ID = 7026
Description =
Error - 19/10/2010 06:13:31 | Computer Name = HOME-PC | Source = DCOM | ID = 10005
Description =
teedee
OS : Vista
Post by TheAvatar on Tue Oct 19, 2010 10:34 am
Hi teedee,
Please continue in safe mode with networking. Step 1 should allow you to boot into normal mode and continue to step 2.
Step 1:
Run OTL.exe
  • Copy/paste the following text written inside of the quote box into the Custom Scans/Fixes box located at the bottom of OTL
    :OTL
    :Commands
    [purity]
    [emptytemp]
    [emptyflash]
  • Then click the Run Fix button at the top
  • Let the program run unhindered, reboot when it is done
  • After rebooting, please post the OTL you are presented with on startup.
Step 2:
Please download [You must be registered and logged in to see this link.].
Double click mbam-setup.exe to install the application.
  • Once the program has loaded, select Perform Full Scan, then click Scan.
    The scan may take some time to finish,so please be patient.
  • When disinfection is completed, a log will open in Notepad and you may be prompted to restart. Restart if it tells you to.
Please post:
  • The log from OTL.
  • The MBAM log.
Thanks.
- The Avatar
TheAvatar
OS : Windows XP SP3
Post by teedee on Tue Oct 19, 2010 10:48 am
Ignore! Now rebooting.
teedee
OS : Vista
Post by teedee on Tue Oct 19, 2010 10:55 am
All processes killed
========== OTL ==========
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{5C255C8A-E604-49b4-9D64-90988571CECB}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{5C255C8A-E604-49b4-9D64-90988571CECB}\ not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\ not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\\ not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\\Dzemegefimifetel not found.
File C:\Users\TIM\AppData\Local\KBDLT12.DLL not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\\wxsneacomr.exe not found.
Starting removal of ActiveX control {8AD9C840-044E-11D1-B3E9-00805F499D93}
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{8AD9C840-044E-11D1-B3E9-00805F499D93}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{8AD9C840-044E-11D1-B3E9-00805F499D93}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{8AD9C840-044E-11D1-B3E9-00805F499D93}\ not found.
Starting removal of ActiveX control {CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA}
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA}\ not found.
Starting removal of ActiveX control {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}\ not found.
Registry value HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\\Shell:C:\Users\TIM\AppData\Roaming\hotfix.exe deleted successfully.
File C:\Users\TIM\AppData\Roaming\hotfix.exe not found.
File C:\Users\TIM\AppData\Roaming\31971.bat not found.
File C:\Users\TIM\AppData\Local\Tvusax.dat not found.
File C:\Users\TIM\AppData\Local\Aqetoqeziw.bin not found.
File C:\Users\TIM\AppData\Roaming\start not found.
File C:\Users\TIM\AppData\Roaming\completescan not found.
File C:\Users\TIM\AppData\Roaming\install not found.
[EMPTYTEMP]
User: All Users
User: Default
->Temporary Internet Files folder emptied: 0 bytes
User: Default User
User: Public
User: TIM
->Temp folder emptied: 521441769 bytes
->Temporary Internet Files folder emptied: 280165712 bytes
->Java cache emptied: 13650444 bytes
->Google Chrome cache emptied: 19378278 bytes
->Flash cache emptied: 57496 bytes
%systemroot% .tmp files removed: 0 bytes
Windows Temp folder emptied: 215369522 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 0 bytes
RecycleBin emptied: 856245113 bytes
Total Files Cleaned = 1,818.00 mb
[EMPTYFLASH]
User: All Users
User: Default
User: Default User
User: Public
User: TIM
Total Flash Files Cleaned = 0.00 mb
OTL by OldTimer - Version 3.2.15.2 log created on 10192010_114418
File\Folder C:\Users\TIM\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\03O0QX8C\01[1].htm not found!
File\Folder C:\Users\TIM\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\03O0QX8C\Results[1].htm not found!
File\Folder C:\Users\TIM\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\03O0QX8C\think-point-help-t24250[3].htm not found!
teedee
OS : Vista
Post by teedee on Tue Oct 19, 2010 11:32 am
So far so good Smile Currently doing full scan with MalwareBytes...
teedee
OS : Vista
Post by teedee on Tue Oct 19, 2010 12:17 pm
Database version: 4879
Windows 6.0.6002 Service Pack 2
Internet Explorer 8.0.6001.18975
19/10/2010 13:17:03
mbam-log-2010-10-19 (13-17-03).txt
Scan type: Full scan (C:\|D:\|E:\|F:\|G:\|H:\|I:\|J:\|)
Objects scanned: 268438
Time elapsed: 55 minute(s), 14 second(s)
Memory Processes Infected: 1
Registry Keys Infected: 1
Registry Values Infected: 2
Files Infected: 12
C:\Users\Public\Documents\Windows\winhelp.exe (Spyware.Passwords.XGen) -> Unloaded process successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1d4db7d2-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\uzofel (Spyware.Passwords.XGen) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\izoxavasam (Trojan.Agent.U) -> Delete on reboot.
C:\Users\Public\Documents\Windows\winhelp.exe (Spyware.Passwords.XGen) -> Delete on reboot.
C:\Users\TIM\AppData\Roaming\Microsoft\Windows\Global\uzofel.exe (Spyware.Passwords.XGen) -> Quarantined and deleted successfully.
C:\Users\TIM\AppData\Roaming\Microsoft\Windows\Templates\memory.tmp (Spyware.Passwords.XGen) -> Quarantined and deleted successfully.
C:\Users\TIM\AppData\Roaming\Osax\ocucc.exe (Trojan.Dropper.Gen) -> Quarantined and deleted successfully.
C:\Users\TIM\AppData\Roaming\Ovce\foixi.exe (Trojan.Dropper.Gen) -> Quarantined and deleted successfully.
C:\Users\TIM\AppData\Roaming\Watuyd\yqso.exe (Trojan.Dropper.Gen) -> Quarantined and deleted successfully.
C:\_OTL\MovedFiles\10192010_114005\C_Users\TIM\AppData\Local\KBDLT12.dll (Trojan.Hiloti) -> Quarantined and deleted successfully.
C:\_OTL\MovedFiles\10192010_114005\C_Users\TIM\AppData\Roaming\hotfix.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Users\Public\Documents\Server\admin.txt (Malware.Trace) -> Quarantined and deleted successfully.
C:\Users\Public\Documents\Server\server.dat (Malware.Trace) -> Delete on reboot.
C:\Users\TIM\Templates\memory.tmp (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Users\TIM\AppData\Local\ifabedidayiyuk.dll (Trojan.Agent.U) -> Delete on reboot.
teedee
OS : Vista
Post by teedee on Tue Oct 19, 2010 12:36 pm
That seems to have worked! Rejoice!
Thanks a million TheAvatar, you're a legend! Smile
One small thing, on reboot I get a RunDLL error for ifabedidayiyuk.dll
- "The specified module could not be found."
Any thoughts?
teedee
OS : Vista
Re: Think Point - Help!
Post by TheAvatar on Tue Oct 19, 2010 9:37 pm
Hi teedee,
That is great, we still have a little more work to do however Smile Please stick with me till I give you the all clean.
Step 1:
  • To get the latest version of Java please go [You must be registered and logged in to see this link.]
  • Go to Start -> Control Panel -> Programs and Features.
  • Search in the list for all previous installed versions of Java. (J2SE Runtime Environment.... )
    They should have this icon next to any that are there:
    Select any found and choose Uninstall.
  • Then install the version you downloaded earlier.
Step 2:
REMOVED
Step 3:
Using Internet Explorer or Firefox, visit [You must be registered and logged in to see this link.]
1. Click Accept, when prompted to download and install the program files and database of malware definitions.
2. To optimize scanning time and produce a more sensible report for review:
  • Close any open programs
  • Turn off the real time scanner of any existing antivirus program while performing the online scan. Click [You must be registered and logged in to see this link.] to see how to disable the most common antivirus programs.
3. Click Run at the Security prompt.
The program will then begin downloading and installing and will also update the database.
Please be patient as this can take quite a long time to download.
  • Once the update is complete, click on Settings.
  • Make sure these boxes are checked (ticked). If they are not, please tick them and click on the Save button:
    • Spyware, adware, dialers, and other riskware
    • Archives
    • E-mail databases
  • Click on My Computer under the green Scan bar to the left to start the scan.
  • Once the scan is complete, it will display if your system has been infected. It does not provide an option to clean/disinfect. We only require a report from it.
  • Do NOT be alarmed by what you see in the report. Many of the finds have likely been quarantined.
  • Click View report... at the bottom.
  • Click the Save report... button.
  • Change the Files of type dropdown box to Text file (.txt) and name the file KasReport.txt to save the file to your desktop so that you may post it in your next reply
Please post the Kaspersky log.
- The Avatar
GeekPolice.net Adviser
If I have helped you, please consider donating to [You must be registered and logged in to see this link.]
GeekPolice.net [You must be registered and logged in to see this link.] [You must be registered and logged in to see this link.]
Online: GMT 10+ 7:30pm to 8:30pm weekdays. On and off on weekends regularly.
TheAvatar
OS : Windows XP SP3
