hard drive split?
Solved hard drive split?
Post by screwdriver9uk on 9th October 2010, 10:30 am
i have a hard drive which is split 40gb on c drive and then 460gb on D drive , the problem i have is that the c drive is now full and loads of capacity on D drive but when i try to download for instance music on spotify it now says that no capacity left to download onto, why is this happening and how do i resolve this , i am not very good at geek stuff so please be simple in explaining thankyou Thank You!
screwdriver9uk
Joined Joined : 2010-10-07
OS OS : windows7
Points Points : 22553
Solved Re: hard drive split?
Post by Dr Jay on 9th October 2010, 8:12 pm
Hello. Glad to have you here at GeekPolice.
Please wait here, while I refer you to an excellent Tech Advisor or other staff.
Posts Posts : 13810
Points Points : 302437
Post by Capt.Jack Sparrow on 10th October 2010, 3:02 am
Hello and Welcome !
You have to just extend the partition. Try this software and instructions are mentioned in it http://www.partition-tool.com/easeus-partition-manager/extend-system-partition.htm
Hope this helps !
Regards,
Captain MVP
It is considered
courteous to  post a reply if you have been able to resolve your problem, or received  an answer to your question.
Capt.Jack Sparrow
Posts Posts : 321
Joined Joined : 2010-09-27
OS OS : Windows 7 Ultimate, Ubuntu 10.04
Protection Protection : Avast, WinPatrol, Malwarebytes, Windows Firewall
Points Points : 26958
Solved brilliant
Post by screwdriver9uk on 10th October 2010, 4:42 pm
[quote="Capt.Jack Sparrow"]Hello and Welcome !
Hope this helps ! [/quote
many thanks worked like a dream and so easyto do even for me Thank You!
screwdriver9uk
OS OS : windows7
Post by Dr Jay on 10th October 2010, 7:36 pm
Marked as solved. Glad we could help.
Posts Posts : 13810
