Hard Drive Replacement
Post by olyneum on 28th September 2010, 1:29 am
I had a problem after booting computer. I kept getting a message "AHCI BIOS not installed" and would stop there. Suspected a hard drive problem. Took into a tech and they confirmed a hard drive failure. I purchase a new WD 350GB SATA hard drive to replace the bad one. I removed the old one and installed the new HD. Turned on computer and got the same message. I tried to boot through Windows XP OS disk but kept getting an error message "The problem seems to be caused by the following file: setupdd.sys" When the OS installation asks whether to partition no drives show up to do so.
Not sure what I am missing??
Olyneum
olyneum
Posts Posts : 4
Joined Joined : 2009-09-24
Points Points : 26359
Re: Hard Drive Replacement
Post by Capt.Jack Sparrow on 28th September 2010, 2:44 am
Check this article http://support.microsoft.com/kb/330181it mostly happens if there is an incompatibility with hardware. I assume your using XP SP 2 or above. If the HDDs are larger than 132 GB and Your version of XP is without SP1, then install SP1 before continuing the partitioning/formating beyond the one onto which XP is installed. Older BIOS might need SATA drivers. Check this article http://cruftbox.com/blog/archives/000867.html
Hope this helps !
Regards,
Captain MVP
It is considered
courteous to  post a reply if you have been able to resolve your problem, or received  an answer to your question.
Capt.Jack Sparrow
Posts Posts : 321
Joined Joined : 2010-09-27
OS OS : Windows 7 Ultimate, Ubuntu 10.04
Protection Protection : Avast, WinPatrol, Malwarebytes, Windows Firewall
Points Points : 26978
Post by olyneum on 28th September 2010, 6:31 pm
Thanks for the advice. The microsoft article is no longer there. I will look at the Cruftbox article and give it a try.
Olyneum
olyneum
Posts Posts : 4
Post by Nazzgull on 2nd October 2010, 8:24 am
Hi, go to BIOS and find your Drives configuration. You should see somewhere HDD - AHCI, just click Enter on that and shange it to SATA. Save your changes with F10 and restart your computer ;)
Posts Posts : 2330
Points Points : 40495
