Strange CPU behavior
Post by wmbarnes on Mon Sep 20, 2010 1:54 am
This morning I woke up and logged on to my laptop only to discover when I got to my desktop, the screen was upside down. Not the login screen, or the loading screen, just my dektop view was upside down. This continued to happen throughout the day, I just kind of hoped it would dissapear on its own. I started fiddling around and tried to go into safe mode when all that happened was a dark screen showed up with safe mode in all 4 corners and my mouse cursor. There were no icons, toolbars, or pop ups on the screen. I tried to do a system restore from the bootup menu, but when I got to the desktop I was met with just a blank screen and my mouse cursor. Right now I am running diagnostic tests but am stumped on what to do? Any help would be appreciated.
wmbarnes
Posts Posts : 18
Joined Joined : 2009-08-21
OS OS : Visat
Points Points : 26838
Re: Strange CPU behavior
Post by Dr Jay on Mon Sep 20, 2010 9:34 am
Note: the following tool is to only be used under the guidance of a malware helper. In the event you already have the tool, please delete the old copy and download a new copy.
[You must be registered and logged in to see this link.] (Click the green button on the page to download it).
Rename ComboFix.exe to combo-fix.exe before you save it to your Desktop
  • Click Start then copy paste the following command into the search box & hit enter: "%userprofile%\desktop\combo-fix.exe" /killall
  • As part of it's process, ComboFix will check to see if the Microsoft Windows Recovery Console is installed. This will not install in Vista, so it will just continue scanning, and skip the console install.
Posts Posts : 13714
Points Points : 302072
Post by wmbarnes on Mon Sep 20, 2010 5:11 pm
When I log in I literally can't see anything. Just a black screen and a mouse cursor. Any other way to do this?
wmbarnes
Posts Posts : 18
OS OS : Visat
Post by wmbarnes on Tue Sep 21, 2010 5:48 am
so.... you got anything?
wmbarnes
Posts Posts : 18
OS OS : Visat
Post by Dr Jay on Tue Sep 21, 2010 9:14 am
Did that happen after you ran ComboFix?
Posts Posts : 13714
