trojan.generic and trojan.obfuscated.gx problem
Post by luv2tvl on Sat Sep 11, 2010 2:22 pm
Please be patient with me as I am only slightly computer literate.
Yesterday my MCAFEE stated it quarantined 2 trojan horses. Ever since then my Interenet Explorer keeps locking up, I got a few pop up messages: rundll32.exe is infected / ytbb.exe is infected / and mccpsexe is infected (I'm not 100% sure on the last one).
What do I do. This is a computer that I am using for work and I dont want to lose anything. How do I save everything without saving the infected stuff and how do I get rid of them?
luv2tvl
Posts Posts : 10
Joined Joined : 2010-09-11
OS OS : microsoft windows xp home version 2002
Protection Protection : McAffee Total Protection and PC Tools Spyware DR
Points Points : 22904
Re: trojan.generic and trojan.obfuscated.gx problem
Post by Sneakyone on Sat Sep 11, 2010 11:38 pm
Hi.
Please boot into Safe Mode with Networking by rebooting the computer, then rapidly tapping the F8 button until it asks you what mode you would like to boot into.
Once you are at this screen please choose Safe Mode with Networking and run this:
Please download [You must be registered and logged in to see this link.] to your Desktop. (If you already have it downloaded, then just follow the instructions below).
    %systemroot%\*. /mp /s
    %systemroot%\system32\*.sys
    %SYSTEMDRIVE%\*.*
    %PROGRAMFILES%\*.
    %appdata%\*.*
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    ahcix86.sys
    KR10N.sys
    disk.sys
    nvstor32.sys
    ahcix86s.sys
    nvrd32.sys
    symmpi.sys
    adp3132.sys
    mv61xx.sys
    usbstor.sys
    /md5stop
    CREATERESTOREPOINT
Sneakyone
Posts Posts : 2707
Joined Joined : 2010-01-10
Points Points : 56084
Post by luv2tvl on Mon Sep 13, 2010 9:56 pm
ok, I cant boot into any mode. Safe or otherwise. It stops at mcpvdrv.sys, then reboots back to the beginning. I ran spyware doctor, in safemode, to get rid of the trojans. And since then it wont boot in any mode. I know mcpvdrv is a McAfee component, beyond that, not sure what to do. I have important stuff on the drive I want to save if I can, but I cant get it off the disk manually(my XP copy will let me do a repair, but I cant put anything on disk, because I have no floppy on this computer.
Thanks in advance.
[You must be registered and logged in to see this link.] wrote:Hi.
    %SYSTEMDRIVE%\*.*
    %PROGRAMFILES%\*.
    %appdata%\*.*
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    ahcix86.sys
    KR10N.sys
    disk.sys
    nvstor32.sys
    ahcix86s.sys
    nvrd32.sys
    symmpi.sys
    adp3132.sys
    mv61xx.sys
    usbstor.sys
    /md5stop
    CREATERESTOREPOINT
luv2tvl
Posts Posts : 10
Post by Sneakyone on Tue Sep 14, 2010 2:24 am
Hi.
Step 1: you need to get the appropriate burning software for this task.
  • This will allow you to burn OTLPE ISO to a cd and make it bootable. Just install the program, from there on in it is fairly automatic.
  • See the [You must be registered and logged in to see this link.] page for more info.
Step 2: download the OTLPE REATOGO Windows Recovery Environment.
  • Download [You must be registered and logged in to see this link.] and burn to a CD using ISO Burner. NOTE: This file is 292Mb in size so it may take some time to download.
  • When downloaded double click and this will then open ISOBurner to burn the file to CD
    Note : If you do not know how to set your computer to boot from CD follow the steps [You must be registered and logged in to see this link.]
Sneakyone
Posts Posts : 2707
Post by luv2tvl on Tue Sep 14, 2010 2:12 pm
Whenever I try the link to OTLPE I receive a 404 error message. Do you have an alternative link?
luv2tvl
Posts Posts : 10
Post by luv2tvl on Tue Sep 14, 2010 8:26 pm
We got it, will post here when we get it.
I say we, because I am her husband, and know a bit more about computers than she does.
luv2tvl
Posts Posts : 10
Post by luv2tvl on Tue Sep 14, 2010 8:42 pm
OTL logfile created on: 9/14/2010 5:29:05 PM - Run
OTLPE by OldTimer - Version 3.1.41.0 Folder = X:\Programs\OTLPE
Microsoft Windows XP Service Pack 3 (Version = 5.1.2600) - Type = SYSTEM
Internet Explorer (Version = 7.0.5730.13)
3.00 Gb Total Physical Memory | 3.00 Gb Available Physical Memory | 91.00% Memory free
3.00 Gb Paging File | 3.00 Gb Available in Paging File | 98.00% Paging File free
Paging file location(s): C:\pagefile.sys 2046 4092 [binary data]
Drive C: | 298.08 Gb Total Space | 282.29 Gb Free Space | 94.70% Space Free | Partition Type: NTFS
Drive X: | 434.85 Mb Total Space | 0.00 Mb Free Space | 0.00% Space Free | Partition Type: CDFS
Computer Name: REATOGO
Current User Name: SYSTEM
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: All users
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
Using ControlSet: ControlSet001
SRV - File not found [On_Demand] -- C:\WINDOWS\System32\appmgmts.dll -- (AppMgmt)
SRV - File not found [Auto] -- C:\WINDOWS\System32\6to4v32.dll -- (6to4)
SRV - [2010/05/20 17:19:16 | 000,088,176 | ---- | M] (McAfee, Inc.) [Auto] -- C:\Program Files\McAfee\SiteAdvisor\McSACore.exe -- (McAfee SiteAdvisor Service)
SRV - [2010/04/27 17:16:24 | 000,188,136 | ---- | M] (McAfee, Inc.) [Auto] -- C:\Program Files\Common Files\McAfee\SystemCore\mfefire.exe -- (mfefire)
SRV - [2010/04/27 17:16:24 | 000,141,792 | ---- | M] (McAfee, Inc.) [Auto] -- C:\Program Files\Common Files\McAfee\SystemCore\mfevtps.exe -- (mfevtp)
SRV - [2010/04/15 09:45:10 | 000,364,216 | ---- | M] (McAfee, Inc.) [On_Demand] -- C:\Program Files\McAfee\VirusScan\mcods.exe -- (McODS)
SRV - [2010/04/14 12:29:58 | 000,170,144 | ---- | M] (McAfee, Inc.) [Auto] -- C:\Program Files\Common Files\McAfee\SystemCore\mcshield.exe -- (McShield)
SRV - [2010/03/18 10:57:48 | 000,020,480 | ---- | M] (AG Interactive) [Auto] -- C:\Program Files\AGI\core\4.2.0.10753\AGCoreService.exe -- (AGCoreService)
SRV - [2010/03/10 10:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto] -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe -- (MSK80Service)
SRV - [2010/03/10 10:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto] -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe -- (McProxy)
SRV - [2010/03/10 10:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto] -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe -- (McNASvc)
SRV - [2010/03/10 10:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto] -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe -- (McNaiAnn)
SRV - [2010/03/10 10:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto] -- C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe -- (mcmscsvc)
SRV - [2010/03/10 10:14:44 | 000,271,480 | ---- | M] (McAfee, Inc.) [Auto] -- C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe -- (McMPFSvc)
SRV - [2010/01/15 08:49:20 | 000,227,232 | ---- | M] (McAfee, Inc.) [On_Demand] -- C:\Program Files\McAfee Security Scan\2.0.181\McCHSvc.exe -- (McComponentHostService)
SRV - [2009/09/23 14:33:42 | 001,141,200 | ---- | M] (PC Tools) [Auto] -- C:\Program Files\Spyware Doctor\pctsSvc.exe -- (sdCoreService)
SRV - [2009/09/23 13:17:22 | 000,358,600 | ---- | M] (PC Tools) [Auto] -- C:\Program Files\Spyware Doctor\pctsAuxs.exe -- (sdAuxService)
SRV - [2009/08/18 11:29:22 | 001,529,728 | ---- | M] (Microsoft Corporation) [Auto] -- C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE -- (wlidsvc)
SRV - [2009/06/03 02:41:40 | 000,068,528 | ---- | M] (McAfee) [On_Demand] -- C:\Program Files\McAfee\MBK\MBackMonitor.exe -- (MBackMonitor)
SRV - [2009/02/19 00:30:20 | 000,121,360 | ---- | M] (Logitech, Inc.) [On_Demand] -- C:\Program Files\Common Files\Logitech\Bluetooth\LBTServ.exe -- (LBTServ)
SRV - [2008/11/09 16:48:14 | 000,602,392 | ---- | M] (Yahoo! Inc.) [Auto] -- C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe -- (YahooAUService)
DRV - File not found [Kernel | On_Demand] -- C:\WINDOWS\System32\Drivers\ZDPSp50.sys -- (ZDPSp50)
DRV - File not found [Kernel | On_Demand] -- -- (WDICA)
DRV - File not found [Kernel | On_Demand] -- -- (PDRFRAME)
DRV - File not found [Kernel | On_Demand] -- -- (PDRELI)
DRV - File not found [Kernel | On_Demand] -- -- (PDFRAME)
DRV - File not found [Kernel | On_Demand] -- -- (PDCOMP)
DRV - File not found [Kernel | System] -- -- (PCIDump)
DRV - File not found [Kernel | System] -- -- (lbrtfdc)
DRV - File not found [Kernel | System] -- -- (i2omgmt)
DRV - File not found [Kernel | On_Demand] -- C:\DOCUME~1\TINADA~1\LOCALS~1\Temp\cpuz132\cpuz132_x32.sys -- (cpuz132)
DRV - File not found [Kernel | System] -- -- (Changer)
DRV - [2010/09/10 10:49:55 | 000,050,704 | ---- | M] (CACE Technologies, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\npf.sys -- (NPF) WinPcap Packet Driver (NPF)
DRV - [2010/04/27 17:16:24 | 000,385,880 | ---- | M] (McAfee, Inc.) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\mfehidk.sys -- (mfehidk)
DRV - [2010/04/27 17:16:24 | 000,312,616 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\mfefirek.sys -- (mfefirek)
DRV - [2010/04/27 17:16:24 | 000,152,320 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\mfeavfk.sys -- (mfeavfk)
DRV - [2010/04/27 17:16:24 | 000,095,568 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\mfeapfk.sys -- (mfeapfk)
DRV - [2010/04/27 17:16:24 | 000,088,480 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\mfendisk.sys -- (mfendiskmp)
DRV - [2010/04/27 17:16:24 | 000,088,480 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\mfendisk.sys -- (mfendisk)
DRV - [2010/04/27 17:16:24 | 000,083,496 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\mferkdet.sys -- (mferkdet)
DRV - [2010/04/27 17:16:24 | 000,082,952 | ---- | M] (McAfee, Inc.) [Kernel | System] -- C:\WINDOWS\system32\drivers\mfetdi2k.sys -- (mfetdi2k)
DRV - [2010/04/27 17:16:24 | 000,055,456 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\cfwids.sys -- (cfwids)
DRV - [2010/04/27 17:16:24 | 000,051,688 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\mfebopk.sys -- (mfebopk)
DRV - [2010/04/03 22:55:32 | 010,232,128 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\nv4_mini.sys -- (nv)
DRV - [2009/11/17 12:15:28 | 000,063,080 | ---- | M] (McAfee) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\McPvDrv.sys -- (McPvDrv)
DRV - [2009/11/04 17:54:12 | 000,040,552 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\mfesmfk.sys -- (mfesmfk)
DRV - [2009/09/23 17:10:06 | 000,207,280 | ---- | M] (PC Tools) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\PCTCore.sys -- (PCTCore)
DRV - [2009/09/16 10:22:14 | 000,034,248 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\mferkdk.sys -- (mferkdk)
DRV - [2009/07/18 18:07:07 | 000,722,432 | ---- | M] (ZyDAS Technology Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\ZD1211BU.sys -- (ZD1211BU(Atheros)) Atheros ZD1211B IEEE 802.11 Wireless LAN Driver (USB)(Atheros)
DRV - [2009/02/11 12:40:40 | 005,028,352 | ---- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\RtkHDAud.sys -- (IntcAzAudAddService) Service for Realtek HD Audio (WDM)
DRV - [2008/12/18 23:43:54 | 000,079,248 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\LMouKE.Sys -- (LMouKE)
DRV - [2008/12/18 23:43:12 | 000,063,248 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\L8042mou.Sys -- (L8042mou)
DRV - [2008/12/18 23:43:06 | 000,020,240 | ---- | M] (Logitech, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\L8042Kbd.sys -- (L8042Kbd)
DRV - [2008/11/12 17:58:38 | 000,145,952 | ---- | M] (NVIDIA Corporation) [Kernel | Boot] -- C:\WINDOWS\system32\drivers\nvgts.sys -- (nvgts)
DRV - [2008/08/01 11:36:26 | 000,022,016 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\nvnetbus.sys -- (nvnetbus)
DRV - [2008/08/01 11:36:20 | 000,054,784 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\NVENETFD.sys -- (NVENETFD)
DRV - [2008/04/14 08:00:00 | 000,144,384 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\hdaudbus.sys -- (HDAudBus)
DRV - [2008/04/13 20:10:28 | 000,057,600 | ---- | M] () [Kernel | System] -- C:\WINDOWS\system32\drivers\redbook.sys -- (redbook)
DRV - [2005/12/15 23:41:56 | 000,408,064 | R--- | M] (SMC Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\SMCWGU.sys -- (SMCWGU(SMC)) SMCWUSB-G 802.11g Wireless USB 2.0 Adapter(SMC)
DRV - [2005/09/29 09:34:58 | 000,056,960 | ---- | M] (OrangeWare Corporation) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\ousb2hub.sys -- (ousb2hub)
DRV - [2005/09/29 09:34:50 | 000,045,824 | ---- | M] (OrangeWare Corporation) [Kernel | Auto] -- C:\WINDOWS\system32\drivers\ousbehci.sys -- (ousbehci)
DRV - [2005/07/27 18:25:28 | 000,077,056 | ---- | M] (Unibrain S.A.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\ubohci.sys -- (ubohci)
DRV - [2005/07/27 18:25:28 | 000,036,352 | ---- | M] (Unibrain S.A.) [Kernel | Auto] -- C:\WINDOWS\system32\drivers\UBUMAPI.sys -- (ubumapi)
DRV - [2005/07/27 18:25:28 | 000,014,080 | ---- | M] (Unibrain S.A.) [Kernel | Auto] -- C:\WINDOWS\system32\drivers\UBSBM.sys -- (ubsbm)
DRV - [2004/12/15 15:18:32 | 000,220,928 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\HSFHWBS2.sys -- (HSFHWBS2)
DRV - [2004/12/15 15:18:28 | 000,703,232 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\HSF_CNXT.sys -- (winachsf)
DRV - [2004/12/15 15:18:26 | 001,038,208 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand] -- C:\WINDOWS\system32\drivers\HSF_DP.sys -- (HSF_DP)
IE - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = [You must be registered and logged in to see this link.]
IE - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = %SystemRoot%\system32\blank.htm
IE - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = [You must be registered and logged in to see this link.]
IE - HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 1
IE - HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyOverride" =
IE - HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyServer" = http=127.0.0.1:6092
IE - HKU\Administrator_ON_C\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
IE - HKU\Tina_DaBella_ON_C\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = [You must be registered and logged in to see this link.]
IE - HKU\Tina_DaBella_ON_C\Software\Microsoft\Internet Explorer\Main,Local Page = \blank.htm
IE - HKU\Tina_DaBella_ON_C\Software\Microsoft\Internet Explorer\Main,SearchDefaultBranded = 1
IE - HKU\Tina_DaBella_ON_C\Software\Microsoft\Internet Explorer\Main,Start Page = [You must be registered and logged in to see this link.]
IE - HKU\Tina_DaBella_ON_C\..\URLSearchHook: {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\Program Files\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
IE - HKU\Tina_DaBella_ON_C\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 1
IE - HKU\Tina_DaBella_ON_C\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyOverride" =
IE - HKU\Tina_DaBella_ON_C\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyServer" = http=127.0.0.1:6092
========== FireFox ==========
FF - prefs.js..browser.search.defaultenginename: "egreetings.com Toolbar"
FF - prefs.js..browser.startup.homepage: "http://search.imgag.com/?appid=egtb&c=&sbs=7&sc=2&f=homepage&vernum=3.2&uid=&did={c9a42d54-d5ed-4ecd-ae65-a6c98731ffcd}&q="
FF - prefs.js..extensions.enabledItems: {B7082FAA-CB62-4872-9106-E42DD88EDE45}:3.1
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:3.0
FF - prefs.js..keyword.URL: "http://search.imgag.com/?appid=egtb&c=&sbs=1&sc=&f=web&vernum=3.2&uid=&did={c9a42d54-d5ed-4ecd-ae65-a6c98731ffcd}&component=UnifiedToolbarFF&q="
FF - HKLM\software\mozilla\Firefox\Extensions\\{1650a312-02bc-40ee-977e-83f158701739}: C:\Program Files\SiteAdvisor\FF1 [2009/02/03 10:32:41 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\unifiedtoolbar@aginteractive.com: C:\Program Files\UnifiedToolbar\3.2\Firefox [2010/02/08 12:36:24 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\{B7082FAA-CB62-4872-9106-E42DD88EDE45}: C:\Program Files\McAfee\SiteAdvisor [2010/08/19 09:23:56 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.6\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/06/30 09:22:17 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.6\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/09/11 09:42:09 | 000,000,000 | ---D | M]
[2010/05/24 13:13:29 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Extensions
[2010/05/24 13:15:18 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\d333evhj.default\extensions
[2010/05/24 13:15:18 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\d333evhj.default\extensions\{20a82645-c095-46ed-80e3-08825760534b}
[2010/05/24 13:13:37 | 000,002,050 | ---- | M] () -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\d333evhj.default\searchplugins\egreetingscom-toolbar.xml
[2009/11/23 13:21:54 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
[2010/04/27 17:16:24 | 000,024,376 | ---- | M] (McAfee, Inc.) -- C:\Program Files\Mozilla Firefox\components\Scriptff.dll
[2010/08/02 09:50:29 | 000,101,768 | ---- | M] (Cisco WebEx LLC) -- C:\Program Files\Mozilla Firefox\plugins\ieatgpc.dll
[2010/08/02 09:50:19 | 000,064,392 | ---- | M] (Cisco WebEx LLC) -- C:\Program Files\Mozilla Firefox\plugins\npatgpc.dll
[2009/11/19 18:16:28 | 000,091,552 | ---- | M] (Coupons, Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npCouponPrinter.dll
[2009/11/19 18:16:29 | 000,091,552 | ---- | M] (Coupons, Inc.) -- C:\Program Files\Mozilla Firefox\plugins\npMozCouponPrinter.dll
[2010/06/10 15:38:36 | 000,002,021 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\McSiteAdvisor.xml
O1 HOSTS File: ([2008/04/14 08:00:00 | 000,000,734 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
O2 - BHO: (&Yahoo! Toolbar Helper) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
O2 - BHO: (McAfee Phishing Filter) - {27B4851A-3207-45A2-B947-BE8AFE6163AB} - c:\Program Files\McAfee\MSK\mskapbho.dll ()
O2 - BHO: (scriptproxy) - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\Common Files\McAfee\SystemCore\ScriptSn.20100519091931.dll (McAfee, Inc.)
O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll (Google Inc.)
O2 - BHO: (McAfee SiteAdvisor BHO) - {B164E929-A1B6-4A06-B104-2CD0E90A88FF} - c:\Program Files\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
O2 - BHO: (SingleInstance Class) - {FDAD4DA1-61A2-4FD8-9C17-86F7AC245081} - C:\Program Files\Yahoo!\Companion\Installs\cpn\YTSingleInstance.dll (Yahoo! Inc)
O3 - HKLM\..\Toolbar: (McAfee SiteAdvisor Toolbar) - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\Program Files\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
O3 - HKLM\..\Toolbar: (Yahoo! Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
O3 - HKU\Tina_DaBella_ON_C\..\Toolbar\WebBrowser: (no name) - {D7E97865-918F-41E4-9CD0-25AB1C574CE8} - No CLSID value found.
O4 - HKLM..\Run: [] File not found
O4 - HKLM..\Run: [Alcmtr] C:\WINDOWS\ALCMTR.EXE (Realtek Semiconductor Corp.)
O4 - HKLM..\Run: [andfjnbd] C:\Documents and Settings\NetworkService\Local Settings\Application Data\yvamoxnlk\mfwoolnuqiw.exe (Security Suites Corporation)
O4 - HKLM..\Run: [ISTray] C:\Program Files\Spyware Doctor\pctsTray.exe (PC Tools)
O4 - HKLM..\Run: [Kernel and Hardware Abstraction Layer] C:\WINDOWS\KHALMNPR.Exe (Logitech, Inc.)
O4 - HKLM..\Run: [MBkLogonHook] File not found
O4 - HKLM..\Run: [McAfee Backup] C:\Program Files\McAfee\MBK\McAfeeDataBackup.exe (McAfee)
O4 - HKLM..\Run: [McPvTray] C:\Program Files\McAfee\Anti-Theft\McPvTray.exe (McAfee)
O4 - HKLM..\Run: [mcui_exe] C:\Program Files\McAfee.com\Agent\mcagent.exe (McAfee, Inc.)
O4 - HKLM..\Run: [mfhikxkt] C:\Documents and Settings\NetworkService\Local Settings\Application Data\rjllpyama\mentnuuuqiw.exe (Security Suites Corporation)
O4 - HKLM..\Run: [NvCplDaemon] C:\WINDOWS\System32\NvCpl.DLL (NVIDIA Corporation)
O4 - HKLM..\Run: [NvMediaCenter] C:\WINDOWS\System32\NvMcTray.DLL (NVIDIA Corporation)
O4 - HKLM..\Run: [nwiz] File not found
O4 - HKLM..\Run: [YMailAdvisor] C:\Program Files\Yahoo!\Common\YMailAdvisor.exe (Yahoo! Inc.)
O4 - HKU\.DEFAULT..\Run: [andfjnbd] C:\Documents and Settings\NetworkService\Local Settings\Application Data\yvamoxnlk\mfwoolnuqiw.exe (Security Suites Corporation)
O4 - HKU\.DEFAULT..\Run: [Ktohanamisu] C:\WINDOWS\mapin320.DLL (trbarry@trbarry.com)
O4 - HKU\.DEFAULT..\Run: [mfhikxkt] C:\Documents and Settings\NetworkService\Local Settings\Application Data\rjllpyama\mentnuuuqiw.exe (Security Suites Corporation)
O4 - HKU\Tina_DaBella_ON_C..\Run: [MoneyAgent] C:\Program Files\Microsoft Money\System\Money Express.exe (Microsoft Corporation)
O4 - HKU\Tina_DaBella_ON_C..\Run: [qkwayawg] C:\Documents and Settings\Tina DaBella\Local Settings\Application Data\dnnncxapi\xiosrwbtssd.exe File not found
O4 - HKU\Tina_DaBella_ON_C..\Run: [swg] C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe (Google Inc.)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\HP Photosmart Premier Fast Start.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe (Hewlett-Packard Development Company, L.P.)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Logitech SetPoint.lnk = C:\Program Files\Logitech\SetPoint\SetPoint.exe (Logitech, Inc.)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\McAfee Security Scan Plus.lnk = C:\Program Files\McAfee Security Scan\2.0.181\SSScheduler.exe (McAfee, Inc.)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE (Microsoft Corporation)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Microsoft Works Calendar Reminders.lnk = File not found
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Windows Search.lnk = C:\Program Files\Windows Desktop Search\WindowsSearch.exe (Microsoft Corporation)
O4 - Startup: C:\Documents and Settings\Tina DaBella\Start Menu\Programs\Startup\Dropbox.lnk = C:\Documents and Settings\Administrator\Application Data\Dropbox\bin\Dropbox.exe File not found
O4 - Startup: C:\Documents and Settings\Tina DaBella\Start Menu\Programs\Startup\OpenOffice.org 3.0.lnk = C:\Program Files\OpenOffice.org 3\program\quickstart.exe ()
O7 - HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
O7 - HKU\Administrator_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
O7 - HKU\LocalService_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
O7 - HKU\NetworkService_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
O7 - HKU\Tina_DaBella_ON_C\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDriveTypeAutoRun = 145
O16 - DPF: {02BCC737-B171-4746-94C9-0D8A0B2C0089} [You must be registered and logged in to see this link.] (Microsoft Office Template and Media Control)
O16 - DPF: {05CA9FB0-3E3E-4B36-BF41-0E3A5CAA8CD8} [You must be registered and logged in to see this link.] (Office Genuine Advantage Validation Tool)
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} C:\Program Files\Yahoo!\Common\Yinsthelper.dll (Installation Support)
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} [You must be registered and logged in to see this link.] (MUWebControl Class)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_13)
O16 - DPF: {CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_07)
O16 - DPF: {CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_13)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_13)
O16 - DPF: {E06E2E99-0AA1-11D4-ABA6-0060082AA75C} [You must be registered and logged in to see this link.] (GpcContainer Class)
O16 - DPF: CabBuilder [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 24.92.226.11 24.92.226.12
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: NameServer = 93.188.162.127,93.188.161.217
O18 - Protocol\Handler\dssrequest {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\Program Files\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
O18 - Protocol\Handler\sacore {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\Program Files\McAfee\SiteAdvisor\McIEPlg.dll (McAfee, Inc.)
O20 - Winlogon\Notify\LBTWlgn: DllName - c:\program files\common files\logitech\bluetooth\LBTWlgn.dll - c:\Program Files\Common Files\Logitech\Bluetooth\LBTWLgn.dll (Logitech, Inc.)
O28 - HKLM ShellExecuteHooks: {56F9679E-7826-4C84-81F3-532071A8BCC5} - C:\Program Files\Windows Desktop Search\MsnlNamespaceMgr.dll (Microsoft Corporation)
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2009/02/03 09:43:17 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O32 - AutoRun File - [2006/03/24 07:06:41 | 000,000,053 | R--- | M] () - X:\AUTORUN.INF -- [ CDFS ]
[2010/09/12 08:07:33 | 000,000,000 | ---D | C] -- C:\test
[2010/09/11 09:47:11 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Yahoo
[2010/09/11 09:47:06 | 000,000,000 | R--D | C] -- C:\Documents and Settings\NetworkService\Favorites
[2010/09/11 09:47:06 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Application Data\Yahoo!
[2010/09/11 09:44:19 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\rjllpyama
[2010/09/11 09:44:16 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\yvamoxnlk
[2010/09/11 09:43:58 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Adobe
[2010/09/11 09:43:50 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Application Data\Sun
[2010/09/10 11:20:45 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Application Data\Macromedia
[2010/09/10 11:20:40 | 000,000,000 | ---D | C] -- C:\Documents and Settings\NetworkService\Application Data\Adobe
[2010/09/10 10:49:55 | 000,281,104 | ---- | C] (CACE Technologies, Inc.) -- C:\WINDOWS\System32\wpcap.dll
[2010/09/10 10:49:55 | 000,100,880 | ---- | C] (CACE Technologies, Inc.) -- C:\WINDOWS\System32\Packet.dll
[2010/09/10 10:49:55 | 000,050,704 | ---- | C] (CACE Technologies, Inc.) -- C:\WINDOWS\System32\drivers\npf.sys
[2010/09/10 10:49:15 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Tina DaBella\Local Settings\Application Data\bcevrfiot
[2010/09/10 10:49:11 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Tina DaBella\Local Settings\Application Data\kcxwrmhvq
[2010/09/10 10:48:46 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Tina DaBella\Application Data\D79E7BE99A6B1AC96034878052C3100F
[2006/02/19 04:28:56 | 000,012,288 | ---- | C] (Hewlett-Packard Development Company, L.P.) -- C:\WINDOWS\Fonts\RandFont.dll
[4 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
[2 C:\Documents and Settings\Tina DaBella\My Documents\*.tmp files -> C:\Documents and Settings\Tina DaBella\My Documents\*.tmp -> ]
[1 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
[2010/09/14 17:30:55 | 000,786,432 | -H-- | M] () -- C:\Documents and Settings\Administrator\NTUSER.DAT
[2010/09/14 16:18:38 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
[2010/09/13 12:32:30 | 000,000,353 | RHS- | M] () -- C:\boot.ini
[2010/09/12 11:01:16 | 000,262,144 | -H-- | M] () -- C:\Documents and Settings\NetworkService\NTUSER.DAT
[2010/09/12 11:01:00 | 004,718,592 | -H-- | M] () -- C:\Documents and Settings\Tina DaBella\NTUSER.DAT
[2010/09/12 11:01:00 | 000,000,278 | -HS- | M] () -- C:\Documents and Settings\Tina DaBella\ntuser.ini
[2010/09/12 11:00:57 | 005,053,544 | -H-- | M] () -- C:\Documents and Settings\Tina DaBella\Local Settings\Application Data\IconCache.db
[2010/09/12 08:45:33 | 000,271,638 | ---- | M] () -- C:\WINDOWS\System32\NvApps.xml
[2010/09/12 08:45:28 | 000,000,868 | ---- | M] () -- C:\WINDOWS\tasks\Google Software Updater.job
[2010/09/12 08:45:01 | 000,000,436 | -H-- | M] () -- C:\WINDOWS\tasks\User_Feed_Synchronization-{C9E9931F-F833-425B-B8F8-CCD122295382}.job
[2010/09/12 08:44:13 | 000,000,882 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineCore.job
[2010/09/12 08:44:11 | 000,013,734 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
[2010/09/12 08:44:04 | 000,000,006 | -H-- | M] () -- C:\WINDOWS\tasks\SA.DAT
[2010/09/11 12:12:17 | 000,262,144 | -H-- | M] () -- C:\Documents and Settings\LocalService\NTUSER.DAT
[2010/09/11 12:01:00 | 000,001,006 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-1229272821-1078081533-682003330-1004UA.job
[2010/09/11 09:43:50 | 000,001,324 | ---- | M] () -- C:\WINDOWS\System32\d3d9caps.dat
[2010/09/10 18:00:08 | 000,000,886 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskMachineUA.job
[2010/09/10 17:58:37 | 000,020,480 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\TRANSfER CLIENT LTR - Lori Webers bkg Mertson.doc
[2010/09/10 17:50:52 | 000,020,480 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\TRANSfER CLIENT LTR - Lori Webers bkg Shepard.doc
[2010/09/10 17:00:03 | 000,000,404 | ---- | M] () -- C:\WINDOWS\tasks\RegCure Program Check.job
[2010/09/10 10:49:55 | 000,281,104 | ---- | M] (CACE Technologies, Inc.) -- C:\WINDOWS\System32\wpcap.dll
[2010/09/10 10:49:55 | 000,100,880 | ---- | M] (CACE Technologies, Inc.) -- C:\WINDOWS\System32\Packet.dll
[2010/09/10 10:49:55 | 000,050,704 | ---- | M] (CACE Technologies, Inc.) -- C:\WINDOWS\System32\drivers\npf.sys
[2010/09/10 10:49:54 | 000,956,416 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\Local Settings\Application Data\198821728.exe
[2010/09/10 10:49:42 | 000,942,080 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\Local Settings\Application Data\0866785025.exe
[2010/09/09 19:01:00 | 000,000,954 | ---- | M] () -- C:\WINDOWS\tasks\GoogleUpdateTaskUserS-1-5-21-1229272821-1078081533-682003330-1004Core.job
[2010/09/09 16:02:05 | 000,002,337 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\Desktop\Google Chrome.lnk
[2010/09/09 15:21:25 | 000,023,552 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\BIO for website.doc
[2010/09/09 11:54:52 | 000,032,768 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\CLIENT - DiGiacomo PCL Corporate.doc
[2010/09/09 10:50:21 | 000,026,624 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\TC - Letterhead.doc
[2010/09/08 16:37:42 | 000,184,173 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\Supplier Logins for CATE PATELUNAS.wks
[2010/09/08 14:50:35 | 000,184,319 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\Supplier Logins for MELINDA EATON.wks
[2010/09/08 14:45:01 | 000,182,362 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\Supplier Logins BLANK for IC.wks
[2010/09/08 14:44:30 | 000,183,656 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\Supplier Logins for LORI WEBER LEWIS.wks
[2010/09/08 14:38:54 | 000,185,256 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\Supplier Logins 1.wks
[2010/09/04 15:55:46 | 000,029,184 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\TC - CONTRACT for Group Leader.doc
[2010/09/04 12:33:18 | 000,025,600 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\TC - FEE Structure.doc
[2010/09/04 12:15:53 | 000,029,184 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\ADVISEMENTS - PROPER DOCUMENTAION.doc
[2010/09/04 12:03:07 | 000,023,552 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\ADVISEMENTS - AFFIDAVIT OF PARENTAL CONSENT.doc
[2010/09/04 11:48:31 | 000,046,080 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\CUSTOMER CONTRACT.doc
[2010/09/04 11:41:07 | 000,029,184 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\CUSTOMER CONTRACT FOR AIR - CAR.doc
[2010/09/03 15:26:53 | 000,032,256 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\GROUP FLYER - TC groupsdoc.doc
[2010/09/03 11:13:18 | 000,028,160 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\POLITICS - 2010 Candidates Profile.doc
[2010/09/03 10:20:14 | 000,032,256 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\GAIL arrest 2.doc
[2010/09/02 18:01:11 | 000,047,104 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\CLIENT - Rowell Air contract.doc
[2010/09/02 17:28:14 | 000,027,136 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\CUSTOMER CONTRACT FOR AIR ONLY.doc
[2010/09/02 17:24:30 | 000,023,040 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\ADVISEMENTS - Air Reconfirmation.doc
[2010/09/02 17:22:50 | 000,030,208 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\ADVISEMENTS - 311 CC Reconfirm for email.doc
[2010/09/02 13:38:52 | 000,028,672 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\TC - Office numbers.doc
[2010/09/02 12:42:23 | 000,052,736 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\CRUISE TIPS.doc
[2010/09/02 09:47:43 | 000,000,162 | -H-- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\~$LITICAL - AFRTC reading of constitution2.doc
[2010/09/01 17:10:32 | 000,031,232 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\TC - CONTRACT for Customer Referral.doc
[2010/09/01 15:28:13 | 000,025,600 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\Cruise sale verbage for postcards.doc
[2010/09/01 12:12:01 | 000,102,912 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\POLITICS - AFRTC reading of constitution2.doc
[2010/08/28 13:52:18 | 000,036,352 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\AIRLINE - CO carryon bags.doc
[2010/08/27 11:07:31 | 000,030,208 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\TC - New agency setup LTR.doc
[2010/08/25 12:00:44 | 000,028,672 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\CLIENT LTR - Richardson transfer of bkg.doc
[2010/08/25 09:31:21 | 000,019,968 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\POLITICS - AFRTC Board Member Phone #s.doc
[2010/08/25 09:15:52 | 000,102,400 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\POLITICS - AFRTC reading of constitution.doc
[2010/08/23 12:42:43 | 000,028,672 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\DRIVER LIST Aug 2010.doc
[2010/08/20 12:02:59 | 000,027,648 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\GROUP CRUISE - 2011 NCL BDA GRP SPECS 5Jun.doc
[2010/08/20 11:59:19 | 000,027,648 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\GROUP CRUISE - 2011 NCL NAS GRP SPECS 23Apr.doc
[2010/08/19 17:43:04 | 000,037,376 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\POLITICS - Bus Rally flyer for meeting.doc
[2010/08/19 15:33:27 | 000,071,680 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\GROUP CRUISE - 2011 NCL NAS Group CONTRACT 23Apr.doc
[2010/08/19 13:24:21 | 000,028,672 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\GROUP CRUISE - PIC NCL BDA 2011.doc
[2010/08/18 17:58:31 | 000,064,000 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\GROUP CRUISE - 2011 NCL BDA Group CONTRACT 5JUN.doc
[2010/08/16 17:08:50 | 000,035,840 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\TC - Office Procedures.doc
[2010/08/16 16:20:19 | 000,029,696 | ---- | M] () -- C:\Documents and Settings\Tina DaBella\My Documents\TC - LEAD SHEET.doc
[2010/09/13 12:32:30 | 000,000,353 | RHS- | C] () -- C:\boot.ini
[2010/09/10 17:58:37 | 000,020,480 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\TRANSfER CLIENT LTR - Lori Webers bkg Mertson.doc
[2010/09/10 17:50:51 | 000,020,480 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\TRANSfER CLIENT LTR - Lori Webers bkg Shepard.doc
[2010/09/10 10:49:54 | 000,956,416 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\Local Settings\Application Data\198821728.exe
[2010/09/10 10:49:42 | 000,942,080 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\Local Settings\Application Data\0866785025.exe
[2010/09/09 11:49:46 | 000,032,768 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\CLIENT - DiGiacomo PCL Corporate.doc
[2010/09/04 15:55:46 | 000,029,184 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\TC - CONTRACT for Group Leader.doc
[2010/09/03 18:37:55 | 000,029,184 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\ADVISEMENTS - PROPER DOCUMENTAION.doc
[2010/09/03 11:13:18 | 000,028,160 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\POLITICS - 2010 Candidates Profile.doc
[2010/09/02 18:32:25 | 000,032,256 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\GAIL arrest 2.doc
[2010/09/02 18:00:25 | 000,047,104 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\CLIENT - Rowell Air contract.doc
[2010/09/02 17:24:30 | 000,023,040 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\ADVISEMENTS - Air Reconfirmation.doc
[2010/09/02 17:22:49 | 000,030,208 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\ADVISEMENTS - 311 CC Reconfirm for email.doc
[2010/09/02 09:47:43 | 000,000,162 | -H-- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\~$LITICAL - AFRTC reading of constitution2.doc
[2010/09/01 15:28:13 | 000,025,600 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\Cruise sale verbage for postcards.doc
[2010/09/01 12:12:01 | 000,102,912 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\POLITICS - AFRTC reading of constitution2.doc
[2010/08/28 13:52:17 | 000,036,352 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\AIRLINE - CO carryon bags.doc
[2010/08/25 12:00:44 | 000,028,672 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\CLIENT LTR - Richardson transfer of bkg.doc
[2010/08/25 09:31:21 | 000,019,968 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\POLITICS - AFRTC Board Member Phone #s.doc
[2010/08/25 09:15:51 | 000,102,400 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\POLITICS - AFRTC reading of constitution.doc
[2010/08/20 11:59:19 | 000,027,648 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\GROUP CRUISE - 2011 NCL NAS GRP SPECS 23Apr.doc
[2010/08/19 17:43:03 | 000,037,376 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\POLITICS - Bus Rally flyer for meeting.doc
[2010/08/19 15:33:26 | 000,071,680 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\GROUP CRUISE - 2011 NCL NAS Group CONTRACT 23Apr.doc
[2010/08/19 14:39:07 | 000,032,256 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\GROUP FLYER - TC groupsdoc.doc
[2010/08/19 13:24:21 | 000,028,672 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\GROUP CRUISE - PIC NCL BDA 2011.doc
[2010/08/16 16:30:14 | 000,035,840 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\TC - Office Procedures.doc
[2010/08/16 16:19:22 | 000,029,696 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\TC - LEAD SHEET.doc
[2010/08/16 14:29:24 | 000,031,232 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\My Documents\TC - CONTRACT for Customer Referral.doc
[2010/05/24 13:11:23 | 000,000,136 | ---- | C] () -- C:\Documents and Settings\Administrator\Local Settings\Application Data\fusioncache.dat
[2010/05/24 13:10:11 | 000,000,278 | -HS- | C] () -- C:\Documents and Settings\Administrator\ntuser.ini
[2010/05/24 13:10:10 | 000,069,632 | -H-- | C] () -- C:\Documents and Settings\Administrator\ntuser.dat.LOG
[2010/05/24 13:10:09 | 000,786,432 | -H-- | C] () -- C:\Documents and Settings\Administrator\NTUSER.DAT
[2010/05/21 09:35:25 | 000,000,221 | ---- | C] () -- C:\WINDOWS\NCLogConfig.ini
[2009/10/12 10:28:23 | 000,000,012 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\.javafx_ping_sent
[2009/06/12 13:56:56 | 000,051,304 | ---- | C] () -- C:\WINDOWS\System32\drivers\atnt40k.sys
[2009/05/27 09:40:36 | 000,000,760 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\Application Data\setup_ldm.iss
[2009/04/27 14:47:37 | 000,000,000 | ---- | C] () -- C:\WINDOWS\hpqEmlSz.INI
[2009/04/01 09:26:25 | 000,072,080 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\g2mdlhlpx.exe
[2009/03/27 09:42:41 | 000,000,052 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\A_PSchedule.txt
[2009/03/26 17:44:24 | 000,000,030 | ---- | C] () -- C:\WINDOWS\System32\MSVolume.dll
[2009/03/16 10:33:59 | 000,755,272 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\ProductContext7300.log
[2009/03/16 10:21:40 | 000,000,157 | ---- | C] () -- C:\WINDOWS\System32\AddPort.ini
[2009/03/11 10:51:59 | 000,000,475 | ---- | C] () -- C:\WINDOWS\hpntwksetup.ini
[2009/02/11 14:44:40 | 000,011,264 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\Supplier logins.wdb
[2009/02/09 14:35:17 | 000,000,376 | ---- | C] () -- C:\WINDOWS\ODBC.INI
[2009/02/09 12:39:03 | 000,000,000 | ---- | C] () -- C:\WINDOWS\AutoRun.INI
[2009/02/07 17:54:55 | 000,000,135 | ---- | C] () -- C:\Documents and Settings\Tina DaBella\Local Settings\Application Data\fusioncache.dat
[2009/02/07 16:47:27 | 000,077,824 | R--- | C] () -- C:\WINDOWS\System32\hpzids01.dll
[2009/02/03 09:46:52 | 000,016,384 | -H-- | C] () -- C:\Documents and Settings\Tina DaBella\ntuser.dat.LOG
[2009/02/03 09:46:52 | 000,000,278 | -HS- | C] () -- C:\Documents and Settings\Tina DaBella\ntuser.ini
[2009/02/03 09:46:51 | 004,718,592 | -H-- | C] () -- C:\Documents and Settings\Tina DaBella\NTUSER.DAT
[2009/02/03 09:46:13 | 000,262,144 | -H-- | C] () -- C:\Documents and Settings\LocalService\NTUSER.DAT
[2009/02/03 09:46:13 | 000,008,192 | -H-- | C] () -- C:\Documents and Settings\LocalService\ntuser.dat.LOG
[2009/02/03 09:46:13 | 000,000,020 | -HS- | C] () -- C:\Documents and Settings\LocalService\ntuser.ini
[2009/02/03 09:45:26 | 000,262,144 | -H-- | C] () -- C:\Documents and Settings\NetworkService\NTUSER.DAT
[2009/02/03 09:45:26 | 000,008,192 | -H-- | C] () -- C:\Documents and Settings\NetworkService\ntuser.dat.LOG
[2009/02/03 09:45:26 | 000,000,020 | -HS- | C] () -- C:\Documents and Settings\NetworkService\ntuser.ini
[2009/02/02 22:29:32 | 000,057,600 | ---- | C] () -- C:\WINDOWS\System32\drivers\redbook.sys
[2008/08/01 15:48:00 | 000,286,720 | ---- | C] () -- C:\WINDOWS\System32\nvnt4cpl.dll
[2008/04/14 08:00:00 | 000,076,288 | ---- | C] () -- C:\WINDOWS\hpreclsp.dll
[2008/02/04 19:23:10 | 000,693,792 | ---- | C] () -- C:\WINDOWS\System32\OGACheckControl.DLL
[2007/09/27 11:51:02 | 000,020,698 | ---- | C] () -- C:\WINDOWS\System32\idxcntrs.ini
[2007/09/27 11:48:48 | 000,030,628 | ---- | C] () -- C:\WINDOWS\System32\gsrvctr.ini
[2007/09/27 11:48:28 | 000,031,698 | ---- | C] () -- C:\WINDOWS\System32\gthrctr.ini
[2005/07/12 15:44:42 | 000,015,872 | ---- | C] () -- C:\WINDOWS\System32\InsDrvZD64.DLL
[2004/03/23 17:38:00 | 000,028,672 | ---- | C] () -- C:\WINDOWS\System32\InsDrvZD.dll
[2001/07/07 04:00:00 | 000,003,399 | ---- | C] () -- C:\WINDOWS\System32\hptcpmon.ini
[2010/05/24 13:13:36 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\agi
[2010/05/24 13:18:51 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Windows Search
[2009/12/02 13:07:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\SACore
[2010/02/08 12:42:23 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\AGI
[2009/03/04 19:29:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
[2010/09/10 10:48:48 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\D79E7BE99A6B1AC96034878052C3100F
[2010/09/12 08:46:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\Dropbox
[2009/02/17 12:43:42 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\GetRightToGo
[2009/02/17 11:59:18 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\OfficeUpdate12
[2009/02/17 11:26:49 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\OpenOffice.org
[2009/06/23 13:59:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\Rucicy
[2009/07/29 17:51:11 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\SiteRanker
[2009/09/17 18:11:12 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\Uniblue
[2010/08/02 09:50:44 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\WebEx
[2010/01/07 11:56:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\Windows Desktop Search
[2010/02/05 11:08:10 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\Windows Search
[2009/03/28 07:30:26 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Tina DaBella\Application Data\Yrtouk
[2010/09/10 17:00:03 | 000,000,404 | ---- | M] () -- C:\WINDOWS\Tasks\RegCure Program Check.job
[2010/05/06 03:00:00 | 000,000,386 | ---- | M] () -- C:\WINDOWS\Tasks\RegCure.job
[2010/09/12 08:45:01 | 000,000,436 | -H-- | M] () -- C:\WINDOWS\Tasks\User_Feed_Synchronization-{C9E9931F-F833-425B-B8F8-CCD122295382}.job
luv2tvl
Posts Posts : 10
Post by Sneakyone on Thu Sep 16, 2010 4:35 am
Hi.
Please run OTL.exe.
    :OTL
    :commands
    [emptytemp]
    [resethosts]
    [reboot]
  • Close OTL.exe
  • Make sure a checkmark is placed next to Update Malwarebytes Anti-Malware and Launch Malwarebytes Anti-Malware, then click Finish.
  • When disinfection is completed, a log will open in Notepad and you may be prompted to Restart.(See Extra Note)
  • Copy&Paste the entire report in your next reply.
If MBAM encounters a file that is difficult to remove,you will be presented with 1 of 2 prompts,click OK to either and let MBAM proceed with the disinfection process. If asked to restart the computer, please do so immediatly.
Sneakyone
Posts Posts : 2707
Post by luv2tvl on Thu Sep 16, 2010 11:28 am
it seems to be hanging on
that command?? should there be a value there??
luv2tvl
Posts Posts : 10
Post by Sneakyone on Thu Sep 16, 2010 8:28 pm
Hi.
Try this one:
Please run OTL.exe.
    :OTL
    :commands
    [emptytemp]
    [resethosts]
    [reboot]
  • Close OTL.exe
Sneakyone
Posts Posts : 2707
Post by luv2tvl on Thu Sep 16, 2010 10:29 pm
========== OTL ==========
Service\Driver key 6to4 not found.
File C:\WINDOWS\System32\6to4v32.dll not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\ not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\andfjnbd not found.
File C:\Documents and Settings\NetworkService\Local Settings\Application Data\yvamoxnlk\mfwoolnuqiw.exe not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\MBkLogonHook not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\\mfhikxkt not found.
File C:\Documents and Settings\NetworkService\Local Settings\Application Data\rjllpyama\mentnuuuqiw.exe not found.
Registry value HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run\\andfjnbd not found.
Registry value HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run\\Ktohanamisu not found.
File C:\WINDOWS\mapin320.DLL not found.
Registry value HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run\\mfhikxkt not found.
Registry value HKEY_USERS\Tina_DaBella_ON_C\Software\Microsoft\Windows\CurrentVersion\Run\\qkwayawg not found.
Folder C:\Documents and Settings\NetworkService\Local Settings\Application Data\rjllpyama\ not found.
Folder C:\Documents and Settings\NetworkService\Local Settings\Application Data\yvamoxnlk\ not found.
Folder C:\Documents and Settings\Tina DaBella\Local Settings\Application Data\bcevrfiot\ not found.
Folder C:\Documents and Settings\Tina DaBella\Local Settings\Application Data\kcxwrmhvq\ not found.
Folder C:\Documents and Settings\Tina DaBella\Application Data\D79E7BE99A6B1AC96034878052C3100F\ not found.
File C:\Documents and Settings\Tina DaBella\Local Settings\Application Data\198821728.exe not found.
File C:\Documents and Settings\Tina DaBella\Local Settings\Application Data\0866785025.exe not found.
[EMPTYTEMP]
User: Administrator
->Temporary Internet Files folder emptied: 0 bytes
->FireFox cache emptied: 0 bytes
User: All Users
User: Default User
User: LocalService
User: NetworkService
->Java cache emptied: 0 bytes
User: Tina DaBella
->Google Chrome cache emptied: 0 bytes
%systemroot% .tmp files removed: 0 bytes
Windows Temp folder emptied: 0 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 0 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 0 bytes
Total Files Cleaned = 0.00 mb
C:\WINDOWS\System32\drivers\etc\Hosts moved successfully.
HOSTS file reset successfully
OTLPE by OldTimer - Version 3.1.41.0 log created on 09172010_012703
luv2tvl
Posts Posts : 10
Post by Sneakyone on Thu Sep 16, 2010 10:41 pm
Hi.
Can you boot into windows normally now?
Sneakyone
Posts Posts : 2707
Post by luv2tvl on Thu Sep 16, 2010 10:42 pm
no
but there is a file that was put on the desktop
h2rf1.tmp
luv2tvl
Posts Posts : 10
Post by luv2tvl on Sat Sep 18, 2010 3:21 pm
Database version: 4645
Internet Explorer 6.0.2900.5512
9/18/2010 11:21:23 AM
mbam-log-2010-09-18 (11-21-23).txt
Scan type: Quick scan
Objects scanned: 162794
Time elapsed: 6 minute(s), 47 second(s)
Files Infected: 2
C:\WINDOWS\hpreclsp.dll (Trojan.Hiloti) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\MSVolume.dll (Fake.Dropped.Malware) -> Quarantined and deleted successfully.
luv2tvl
Posts Posts : 10
Post by Sneakyone on Sat Sep 18, 2010 6:26 pm
Hi.
Sneakyone
Posts Posts : 2707
