problem emptying temp folder
Post by nicarp on 6th September 2010, 10:18 pm
I'm trying to get my computer so iTunes will recognize my iPod. One thing Apple support says to try is emptying my temp folder. But when I try that, I get an error saying it can't delete JET7F7B.tmp because it's being used by another program. Except no other programs are running. Ideas? Thanks--
nicarp
Joined Joined : 2009-07-24
Points Points : 26946
Re: problem emptying temp folder
Post by Nazzgull on 17th September 2010, 5:55 pm
Hi, i suggest you just to reinstall iTunes.
But, if you decide not to do that, try to use Unlocker and manually delete temp files from iTunes.
http://www.filehippo.com/download_unlocker/
Points Points : 40475
