no audio device/ code 10 error HELP!
Post by bottleneck on 31st August 2010, 5:47 pm
about a week ago the sound on my laptop stopped working. i got the red x along with the no audio device installed message. i tried downloading a new audio driver, tried updating the driver but whenever i do i get a message that says the driver loaded incorrectly code 10 error wont let it start. i've tried the realtek driver and i get that message, the only time it doesnt happen is when i install the conextant audio driver but that causes my computer to shutdown and more problems. as you can probably tell i know very little about computers. i have an hp pavilion dv2000 and am using vista. any help/advice would be greatly appreciated.
bottleneck
Joined Joined : 2010-08-31
OS OS : windows vista
Points Points : 22923
Re: no audio device/ code 10 error HELP!
Post by Sir $wat on 5th September 2010, 3:25 pm
Hey,
Try uninstalling the driver and restart. Allow it to pick up the device and install it.
Do you have the drivers CD? If so, install the driver from there.
Points Points : 34201
Post by Nazzgull on 17th September 2010, 6:42 pm
Hi, download last AC'97 from CNet or some other website and install it. It should helps.
Posts Posts : 2330
Points Points : 40485
