Newbie needs help with C:\PROGRA~1\Ofoto\OfotoNow\OFUSBS.DLL error
Newbie needs help with C:PROGRA~1OfotoOfotoNowOFUSBS.DLL error
Post by jerryscholder on Tue 31 Aug 2010, 2:48 am
I just finished doing all the needed things before posting and wow! what an incredible procedure. The genius behind you guys and girls is just amazing. Great directions. I am getting an error message and also "windows installer" is trying to load but can't. My computer has been running really slow as of late and I tried to get rid of some programs I thought I wasn't using according to the computer which stated I used "rarely" and even gave me the last date used. Turns out it wasn't accurate and I had to restart from the day I changed the programs. I don't know how many things could be wrong. I also installed a program called Registry Patrol and it didn't help. Hope the attached information will enable you to help me. Thanks and look forward to your reply. I sent the file seperately under submit query as it wouldn't fit in the comment section. Will you find it?
The windows installer error message: This patch package could not be opened. Verify it exists and that you can access it, or contact the application vendor to verify it is a valid Windows Installer patch package.
Last edited by jerryscholder on Tue 31 Aug 2010, 2:58 am; edited 2 times in total (Reason for editing : Window installer error message)
jerryscholder
Operating System : windows XP 2000
Re: Newbie needs help with C:\PROGRA~1\Ofoto\OfotoNow\OFUSBS.DLL error
Post by Belahzur on Wed 01 Sep 2010, 11:34 am
Download OTL by OldTimer to your Desktop.
Manager | Tech Officer
