unknown problems help please
Post by nfoster on Tue 31 Aug 2010, 2:20 am
dont know if it was a installer for adobe flash 11 or for activex 11 plugin but now i cant connect to any wireless network and it has disabled themes and the service will not turn back on and i am stuck looking at windows classic start menu and taskbar and all the windows. i dont know if there is a redirect yet cause i have no internet. i suspect a virus because i can not run malawarebytes at all i finally got symantic to run a scan and so far its discovered 6 problems. i am still doing the scanning now so i dont know if that has fixed or not. please help
nfoster
Unborn
Unborn
Operating System : windows xp sp3
Re: unknown problems help please
Post by nfoster on Tue 31 Aug 2010, 6:06 am
think i got it down to all the services are disabled and i cant restart them
nfoster
Unborn
Unborn
Post by Belahzur on Wed 01 Sep 2010, 11:39 am
Download OTL by OldTimer to your Desktop.
Manager | Tech Officer
Post by Sponsored content Today at 2:46 am
