Java problems
Solved Java problems
Post by drjones26 on Sun Aug 29, 2010 9:29 pm
I'm sorry, I don't know if this is being posted in the right section. But I am having problems running programs that use Java. I have tried to uninstall and reinstall Java and that didn't fix the problem and I can't find anything useful at their website. I hope you have some ideas. Thanks.
drjones26
Posts Posts : 15
Joined Joined : 2009-10-31
OS OS : Vista
Protection Protection : McAfee
Points Points : 25967
Solved Re: Java problems
Post by Sir $wat on Sun Sep 05, 2010 3:30 pm
Do you have the lastest version of JAVA installed?
Points Points : 34171
Post by drjones26 on Sun Sep 05, 2010 6:54 pm
I guess so, it is the only one they have available at java.com
drjones26
Posts Posts : 15
OS OS : Vista
Post by drjones26 on Tue Sep 07, 2010 2:34 am
Ok, I solved my own problem. I'll post what I did in case anyone has the same problem. I had to download Java version 6.20 first (the previous version) with version 6.21 uninstalled. The place to get the 6.20 version is here:
http://www.oracle.com/technetwork/java/archive-139210.html
Then go down to where it says:
Java Platform Standard Edition (Java SE)
JDK/JRE - 6
and from the menu choose version 20
After the download was complete, I downloaded version 21 from java.com and everything works for me now.
drjones26
Posts Posts : 15
OS OS : Vista
