wampserver help
Solved wampserver help
Post by ThunderBluff on 14th July 2008, 11:15 am
how do i activate wamp server from being offline, i wanna run a localhost on it online
ThunderBluff
Posts Posts : 373
Joined Joined : 2008-07-04
OS OS : Windows Vista Home Premium
Points Points : 30976
Solved Re: wampserver help
Post by Digitalocksmith on 14th July 2008, 2:44 pm
You should notice a small icon in the bottom right corner of your screen changing from red to white.
By left-clicking on the icon you'll get to the server options. The meaning of the icon status changes are shown as 'WAMP offline mode' and 'WAMP online mode.
Good Luck!
Digitalocksmith
Posts Posts : 625
Joined Joined : 2007-12-22
Points Points : 48931
Post by Zojin182 on 15th July 2008, 11:55 pm
what's a wamp server? Let me think
Zojin182
Posts Posts : 7
Joined Joined : 2008-07-08
Points Points : 30740
Post by Digitalocksmith on 16th July 2008, 10:22 am
WampServer is basically server software based on Windows and is primarily used for the web development environment on a physical or even virtual web server.
The main advantage of this software is that it allows you to utilize Apache, PHP and the MySQL database's all within the one package.
Cool hey!
Digitalocksmith
Posts Posts : 625
