problem trying to run security suite removal tool
Post by jmoney77 on Mon 23 Aug 2010, 1:09 pm
I downloaded the the OTL from this forum to remove security suite, but the virus won't let me open it, it tells me: Secuity warning, application cannot be executed. the otl.exe is infected. Do you want to activate your antivirus software now? Please help, thanks!
jmoney77
Unborn
Unborn
Operating System : windows xp
Re: problem trying to run security suite removal tool
Post by Sneakyone on Mon 23 Aug 2010, 1:32 pm
Hi, Welcome to GeekPolice.net!
Could you please go into Safe Mode with Networking and run this:
To get into Safe Mode with Networking please restart your computer and rapidly tap F8 until it asks what mode you want to boot into, please choose Safe Mode with Networking, then download and run the following:
Please download OTL to your Desktop. (If you already have it downloaded, then just follow the instructions below).
    %systemroot%\*. /mp /s
    %systemroot%\system32\*.sys
    %SYSTEMDRIVE%\*.*
    %PROGRAMFILES%\*.
    %appdata%\*.*
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    ahcix86.sys
    KR10N.sys
    disk.sys
    nvstor32.sys
    ahcix86s.sys
    nvrd32.sys
    symmpi.sys
    adp3132.sys
    mv61xx.sys
    usbstor.sys
    /md5stop
    CREATERESTOREPOINT
Sneakyone
Tech Officer
Tech Officer
